[QGIS Commit] r13894 - trunk/qgis/python/plugins/mapserver_export
svn_qgis at osgeo.org
Tue Jul 6 15:03:44 EDT 2010
Author: rduivenvoorde
Date: 2010-07-06 19:03:44 +0000 (Tue, 06 Jul 2010)
New Revision: 13894
trunk/qgis/python/plugins/mapserver_export/ms_export.py
fix for #2848: exported style better in line with qgis style
Modified: trunk/qgis/python/plugins/mapserver_export/ms_export.py
--- trunk/qgis/python/plugins/mapserver_export/ms_export.py 2010-07-06 18:17:05 UTC (rev 13893)
+++ trunk/qgis/python/plugins/mapserver_export/ms_export.py 2010-07-06 19:03:44 UTC (rev 13894)
@@ -719,6 +719,61 @@
# using a mapfile pre-processor, the proper id field can be substituted in the following:
return str("%" + tableName + "_id%")
+ # Get RGB code from a XML color node, returning string like '45 124 255'
+ def getRgbFromNode(self, symbolNode, elementName):
+ if symbolNode == None or symbolNode.getElementsByTagName(elementName).length == 0:
+ return ''
+ colorNode = symbolNode.getElementsByTagName(elementName)[0]
+ return colorNode.getAttribute('red').encode('utf-8') + ' ' + colorNode.getAttribute('green').encode('utf-8') + ' ' + colorNode.getAttribute('blue').encode('utf-8')
+ # Get a size (multiplied by symbolSizeMultiplier) from given sizeNode's child with elementName
+ def getSizeStringFromNode(self, symbolNode, elementName):
+ return ''
+ size = float(symbolNode.getElementsByTagName(elementName)[0].childNodes[0].nodeValue.encode('utf-8'))
+ symbolSize = size * symbolSizeMultiplier
+ return str(symbolSize)
+ def getSymbolProperty(self, symbolNode, elementName):
+ return ''
+ return str(symbolNode.getElementsByTagName(elementName)[0].childNodes[0].nodeValue.encode('utf-8'))
+ def writeClassStyleContent(self, symbolNode, geometry):
+ outlinecolor = self.getRgbFromNode(symbolNode, 'outlinecolor')
+ fillcolor = self.getRgbFromNode(symbolNode, 'fillcolor')
+ pointsize = self.getSizeStringFromNode(symbolNode, 'pointsize')
+ outlinewidth = self.getSizeStringFromNode(symbolNode, 'outlinewidth')
+ fillpattern = self.getSymbolProperty(symbolNode, 'fillpattern');
+ class_def = " STYLE\n"
+ # for POINT by SYMBOL and SIZE
+ if geometry == 'POINT':
+ # use the point symbol map to lookup the mapserver symbol type
+ symbol = self.msSymbol( geometry, symbolNode )
+ class_def += " SYMBOL " + symbol + " \n"
+ class_def += " SIZE " + pointsize + " \n"
+ # for LINE and POLYGON size define by WIDTH
+ else:
+ class_def += " WIDTH " + outlinewidth + " \n"
+ # for LINE defined by COLOR from outlinecolor
+ if geometry == 'LINE':
+ class_def += " COLOR " + outlinecolor + "\n"
+ # for POLYGON and POINT defined by COLOR from fillcolor and OUTLINECOLOR from outlinecolor
+ else:
+ class_def += " OUTLINECOLOR " + outlinecolor + "\n"
+ if 'NoBrush' != fillpattern:
+ class_def += " COLOR " + fillcolor + "\n"
+ class_def += " END\n"
+ return class_def
# Simple renderer ouput
# We need the layer node and symbol node
def simpleRenderer(self, layerNode, symbolNode):
@@ -729,21 +784,8 @@
class_def += " NAME '" + layerNode.getElementsByTagName("layername")[0].childNodes[0].nodeValue.encode('utf-8').replace("\"", "") + "' \n"
- class_def += " STYLE\n"
- # use the point symbol map to lookup the mapserver symbol type
- symbol = self.msSymbol( geometry, symbolNode )
- class_def += " SYMBOL " + symbol + " \n"
- class_def += self.getSymbolSizeString(symbolNode)
+ class_def += self.writeClassStyleContent(symbolNode, geometry)
- # outline color
- outlineNode = symbolNode.getElementsByTagName('outlinecolor')[0]
- class_def += " OUTLINECOLOR " + outlineNode.getAttribute('red').encode('utf-8') + ' ' + outlineNode.getAttribute('green').encode('utf-8') + ' ' + outlineNode.getAttribute('blue').encode('utf-8') + "\n"
- # color
- colorNode = symbolNode.getElementsByTagName('fillcolor')[0]
- class_def += " COLOR " + colorNode.getAttribute('red').encode('utf-8') + ' ' + colorNode.getAttribute('green').encode('utf-8') + ' ' + colorNode.getAttribute('blue').encode('utf-8') + "\n"
- class_def += " END\n"
class_def += self.msLabel( layerNode )
# end of CLASS
@@ -752,12 +794,6 @@
return class_def
- def getSymbolSizeString(self, symbolNode):
- size = float(symbolNode.getElementsByTagName('pointsize')[0].childNodes[0].nodeValue.encode('utf-8'))
- symbolSize = size * symbolSizeMultiplier
- return " SIZE " + str(symbolSize) + " \n"
# Graduated symbol renderer output
def graduatedRenderer(self, layerNode, symbolNode):
# get the layers geometry type
@@ -785,23 +821,8 @@
class_def += " EXPRESSION ( ([" + classField + "] >= " + lower + ") AND ([" + classField + "] <= " + upper + ") )\n"
- class_def += " SYMBOL " + symbol + "\n"
+ class_def += self.writeClassStyleContent(cls, geometry)
- # Symbol size
- if geometry == 'POINT' or geometry == 'LINE':
- class_def += self.getSymbolSizeString(cls)
- # outline color
- outlineNode = cls.getElementsByTagName('outlinecolor')[0]
- # color
- colorNode = cls.getElementsByTagName('fillcolor')[0]
# label
@@ -810,6 +831,7 @@
return class_def
# Continuous symbol renderer output
def continuousRenderer(self, layerNode, symbolNode):
@@ -827,8 +849,8 @@
# color
lower = symbolNode.getElementsByTagName('lowestsymbol')[0].getElementsByTagName('symbol')[0]
upper = symbolNode.getElementsByTagName('highestsymbol')[0].getElementsByTagName('symbol')[0]
- lowerColor = lower.getElementsByTagName('fillcolor')[0]
- upperColor = upper.getElementsByTagName('fillcolor')[0]
+ lowerColor = lower.getElementsByTagName('outlinecolor')[0]
+ upperColor = upper.getElementsByTagName('outlinecolor')[0]
# outline color
outlineNode = lower.getElementsByTagName('outlinecolor')[0]
@@ -842,11 +864,43 @@
class_def += " DATARANGE " + lower.getElementsByTagName('lowervalue')[0].childNodes[0].nodeValue.encode('utf-8') + ' ' + upper.getElementsByTagName('lowervalue')[0].childNodes[0].nodeValue.encode('utf-8') + '\n'
class_def += " RANGEITEM '" + classField + "'\n"
- class_def += " OUTLINECOLOR " + outlineNode.getAttribute('red').encode('utf-8') + " " + outlineNode.getAttribute('green').encode('utf-8') + " " + outlineNode.getAttribute('blue').encode('utf-8') + "\n"
+ # upper and lower have same size
+ outlinecolor = self.getRgbFromNode(upper, 'outlinecolor')
+ fillcolor = self.getRgbFromNode(upper, 'fillcolor')
+ outlinewidth = self.getSizeStringFromNode(upper, 'outlinewidth')
+ size = float(lower.getElementsByTagName('pointsize')[0].childNodes[0].nodeValue.encode('utf-8'))
+ pointsize = 2 * size * symbolSizeMultiplier
+ class_def += " SIZE " + str(pointsize) + " \n"
+ else:
+ else:
+ # only outlines for polygons
+ outline = symbolNode.getElementsByTagName('polygonoutline')
+ if geometry == 'POLYGON' and outline is not None and '1' == outline[0].childNodes[0].nodeValue.encode('utf-8'):
+ class_def += " STYLE\n"
+ class_def += " WIDTH 1 " + "\n"
+ class_def += " OUTLINECOLOR 0 0 0" + "\n"
# label
@@ -855,8 +909,8 @@
return class_def
# Unique value renderer output
def uniqueRenderer(self, layerNode, symbolNode):
# get the renderer field for building up the classes
@@ -882,47 +936,23 @@
# If there's a label use it, otherwise autogenerate one
try:
label = cls.getElementsByTagName('label')[0].childNodes[0].nodeValue.encode('utf-8')
- class_def += " NAME '" + label + "'\n"
+ class_def += ' NAME "' + label + '"\n'
except:
- class_def += " NAME '" + classField + " = " + lower + "' \n"
+ class_def += ' NAME "' + classField + ' = ' + lower + '" \n'
- class_def += " EXPRESSION '" + lower + "' \n"
+ class_def += ' EXPRESSION "' + lower + '" \n'
- # Get the symbol name
- # Symbol size
- # outline color
- class_def += " OUTLINECOLOR " \
- + outlineNode.getAttribute('red').encode('utf-8') + ' ' \
- + outlineNode.getAttribute('green').encode('utf-8') + ' ' \
- + outlineNode.getAttribute('blue').encode('utf-8') \
- + "\n"
- # color
- class_def += " COLOR " \
- + colorNode.getAttribute('red').encode('utf-8') + ' ' \
- + colorNode.getAttribute('green').encode('utf-8') + ' ' \
- + colorNode.getAttribute('blue').encode('utf-8') \
- + "\n"
# label
# end of CLASS
return class_def
# Utility method to format a proj4 text string into mapserver format
def formatProj4(self, proj4text):
parms = proj4text.split(" ")
@@ -932,6 +962,7 @@
ret = ret + " '" + p + "'\n"
return ret
def getProj4(self, proj4text):
"""Returns the proj4 string as a dictionary with key value pairs."""
@@ -950,6 +981,7 @@
ret[key] = value
return ret
# Determines the symbol name and adds it to the symbol queue
def msSymbol(self, geometry, symbolNode):
# contains the same markup for a layer regardless of type
@@ -958,9 +990,11 @@
symbol = '0'
if geometry == 'POLYGON':
- symbol = '0'
+ #symbol = '0'
+ pass
elif geometry == 'LINE':
- symbol = '0'
+ #symbol = '0'
+ pass
elif geometry == 'POINT':
try:
symbolName = qgis2map_symbol[symbolNode.getElementsByTagName('pointsymbol')[0].childNodes[0].nodeValue.encode('utf-8')]
@@ -1083,7 +1117,12 @@
# qgis uses a fill color around the label
# Note that buffer only works for truetype fonts
buffer = labelNode.getElementsByTagName('buffersize')[0].getAttribute('value').encode('utf-8')
- labelBlock += " BUFFER " + buffer + "\n"
+ bufferon = labelNode.getElementsByTagName('bufferenabled')[0].getAttribute('on').encode('utf-8')
+ buffercolor= self.getRgbFromNode(labelNode, 'buffercolor')
+ if bufferon is not None and '1' == bufferon:
+ # not sure if we should use this BUFFER
+ #labelBlock += " BUFFER " + buffer + "\n"
+ labelBlock += " BACKGROUNDCOLOR " + buffercolor + "\n"
# alignment in QGis corresponds to position in MapServer
alignment = labelNode.getElementsByTagName('alignment')[0].getAttribute('value').encode('utf-8')
