[QGIS Commit] r13691 - in branches/threading-branch/src: app ui
svn_qgis at osgeo.org
Tue Jun 8 12:43:30 EDT 2010
Author: wonder
Date: 2010-06-08 12:43:28 -0400 (Tue, 08 Jun 2010)
New Revision: 13691
branches/threading-branch/src/app/qgisapp.cpp
branches/threading-branch/src/app/qgsoptions.cpp
branches/threading-branch/src/ui/qgsoptionsbase.ui
Make threading configurable in options dialog.
Modified: branches/threading-branch/src/app/qgisapp.cpp
--- branches/threading-branch/src/app/qgisapp.cpp 2010-06-08 14:11:48 UTC (rev 13690)
+++ branches/threading-branch/src/app/qgisapp.cpp 2010-06-08 16:43:28 UTC (rev 13691)
@@ -2100,9 +2100,10 @@
// moved here to set anti aliasing to both map canvas and overview
QSettings mySettings;
+ mMapCanvas->mapRenderer()->setCachingEnabled( mySettings.value( "/qgis/enable_render_caching", false ).toBool() );
+ mMapCanvas->mapRenderer()->setThreadingEnabled( mySettings.value( "/qgis/enable_threaded_rendering", false ).toBool() );
mMapCanvas->enableAntiAliasing( mySettings.value( "/qgis/enable_anti_aliasing", false ).toBool() );
- mMapCanvas->useImageToRender( mySettings.value( "/qgis/use_qimage_to_render", false ).toBool() );
- mMapCanvas->mapRenderer()->setCachingEnabled( mySettings.value( "/qgis/enable_render_caching", false ).toBool() );
+ mMapCanvas->useImageToRender( mySettings.value( "/qgis/use_qimage_to_render", false ).toBool() ); // also does a refresh
int action = mySettings.value( "/qgis/wheel_action", 0 ).toInt();
double zoomFactor = mySettings.value( "/qgis/zoom_factor", 2 ).toDouble();
@@ -5082,9 +5083,10 @@
setTheme( optionsDialog->theme() );
mMapCanvas->enableAntiAliasing( mySettings.value( "/qgis/enable_anti_aliasing" ).toBool() );
- mMapCanvas->useImageToRender( mySettings.value( "/qgis/use_qimage_to_render" ).toBool() );
+ mMapCanvas->useImageToRender( mySettings.value( "/qgis/use_qimage_to_render" ).toBool() ); // also does a refresh
Modified: branches/threading-branch/src/app/qgsoptions.cpp
--- branches/threading-branch/src/app/qgsoptions.cpp 2010-06-08 14:11:48 UTC (rev 13690)
+++ branches/threading-branch/src/app/qgsoptions.cpp 2010-06-08 16:43:28 UTC (rev 13691)
@@ -222,6 +222,7 @@
//set the state of the checkboxes
chkAntiAliasing->setChecked( settings.value( "/qgis/enable_anti_aliasing", false ).toBool() );
chkUseRenderCaching->setChecked( settings.value( "/qgis/enable_render_caching", false ).toBool() );
+ chkUseThreadedRendering->setChecked( settings.value( "/qgis/enable_threaded_rendering", false ).toBool() );
chkUseSymbologyNG->setChecked( settings.value( "/qgis/use_symbology_ng", false ).toBool() );
@@ -492,6 +493,7 @@
settings.setValue( "/qgis/new_layers_visible", chkAddedVisibility->isChecked() );
settings.setValue( "/qgis/enable_anti_aliasing", chkAntiAliasing->isChecked() );
settings.setValue( "/qgis/enable_render_caching", chkUseRenderCaching->isChecked() );
+ settings.setValue( "/qgis/enable_threaded_rendering", chkUseThreadedRendering->isChecked() );
settings.setValue( "/qgis/use_qimage_to_render", !( chkUseQPixmap->isChecked() ) );
settings.setValue( "/qgis/use_symbology_ng", chkUseSymbologyNG->isChecked() );
settings.setValue( "qgis/capitaliseLayerName", capitaliseCheckBox->isChecked() );
Modified: branches/threading-branch/src/ui/qgsoptionsbase.ui
--- branches/threading-branch/src/ui/qgsoptionsbase.ui 2010-06-08 14:11:48 UTC (rev 13690)
+++ branches/threading-branch/src/ui/qgsoptionsbase.ui 2010-06-08 16:43:28 UTC (rev 13691)
@@ -509,14 +509,21 @@
</property>
</widget>
</item>
- <item row="2" column="0" colspan="2">
+ <item row="4" column="0">
+ <widget class="QCheckBox" name="chkUseThreadedRendering">
+ <property name="text">
+ <string>Use threading to speed up rendering on computers with multiple CPUs</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0">
<widget class="QLabel" name="textLabel3">
<string><b>Note:</b> Use zero to prevent display updates until all features have been rendered</string>
</property>
</widget>
</item>
- <item row="3" column="0" colspan="2">
+ <item row="3" column="0">
<widget class="QCheckBox" name="chkUseRenderCaching">
<string>Use render caching where possible to speed up redraws</string>
@@ -1603,7 +1610,6 @@
<tabstop>cbxAddPostgisDC</tabstop>
<tabstop>chkAddedVisibility</tabstop>
<tabstop>spinBoxUpdateThreshold</tabstop>
- <tabstop>chkUseRenderCaching</tabstop>
<tabstop>chkAntiAliasing</tabstop>
<tabstop>chkUseQPixmap</tabstop>
<tabstop>mBtnAddSVGPath</tabstop>
