[QGIS Commit] r13692 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jun 8 15:27:06 EDT 2010
Author: micha
Date: 2010-06-08 15:27:04 -0400 (Tue, 08 Jun 2010)
New Revision: 13692
   docs/trunk/english_us/user_guide/features_at_a_glance.tex
   docs/trunk/english_us/user_guide/grass_integration.tex
   docs/trunk/english_us/user_guide/plugins_dxf2shape_converter.tex
Fixed some typos
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex	2010-06-08 16:43:28 UTC (rev 13691)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex	2010-06-08 19:27:04 UTC (rev 13692)
@@ -39,7 +39,7 @@
 \small
 \begin{verbatim}
 qgis --help
-Quantum GIS - 1.4.0-Enceladus 'Enceladus' (exported)
+Quantum GIS - 1.5.0-Tethys 'Tethys' (exported)
 Quantum GIS (QGIS) is a viewer for spatial data sets, including
 raster and vector data.
 Usage: qgis [options] [FILES]
@@ -945,7 +945,7 @@
 \minisec{Rendering \& SVG Tab}
 \begin{itemize}
-\item \checkbox{By deafult new layers added to the map should be displayed}
+\item \checkbox{By default new layers added to the map should be displayed}
 \item Define number of features to draw before updating the display.
 \item \checkbox{Use render caching where possible to speed up redraws}
 \item \checkbox{Make lines appear less jagged at the expense of some drawing
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex	2010-06-08 16:43:28 UTC (rev 13691)
+++ docs/trunk/english_us/user_guide/grass_integration.tex	2010-06-08 19:27:04 UTC (rev 13692)
@@ -316,7 +316,7 @@
 To create a new GRASS vector layer with the GRASS plugin click the
 \toolbtntwo{grass_new_vector_layer}{Create new GRASS vector} toolbar icon.
 Enter a name in the text box and you can start digitizing point, line or
-polygone geometries, following the procedure described in Section
+polygon geometries, following the procedure described in Section
 \ref{grass_digitising}.
 In GRASS it is possible to organize all sort of geometry types (point, line
@@ -338,8 +338,8 @@
 shows the GRASS edit dialog that is displayed when you click on the edit tool.
 The tools and settings are discussed in the following sections.
-\begin{Tip}\caption{\textsc{Digitizing polygones in GRASS}}
-If you want to create a polygone in GRASS, you first digitize the boundary of
+\begin{Tip}\caption{\textsc{Digitizing polygons in GRASS}}
+If you want to create a polygon in GRASS, you first digitize the boundary of
 the polygon, setting the mode to \usertext{No category}. Then you add a
 centroid (label point) into the closed boundary, setting the mode to
 \usertext{Next not used}. The reason is, that a topological vector model links
Modified: docs/trunk/english_us/user_guide/plugins_dxf2shape_converter.tex
--- docs/trunk/english_us/user_guide/plugins_dxf2shape_converter.tex	2010-06-08 16:43:28 UTC (rev 13691)
+++ docs/trunk/english_us/user_guide/plugins_dxf2shape_converter.tex	2010-06-08 19:27:04 UTC (rev 13692)
@@ -13,7 +13,7 @@
 \item \textbf{Input DXF file}: Enter path to the DXF file to be converted
 \item \textbf{Output Shp file}: Enter desired name of the Shapefile to be created
 \item \textbf{Output file type}: Specify the geometry type of the output Shapefile.
-Currently supported types are polyline, polygone, and point.
+Currently supported types are polyline, polygon, and point.
 \item \textbf{Export text labels}: When this checkbox is enabled, an additional Shapefile point layer will be created, and the associated dbf table will contain information about the "TEXT" fields found in the dxf file, and the text strings themselves.
 \end{itemize}
More information about the QGIS-commit mailing list
