[QGIS Commit] r13753 - in trunk/qgis: doc src/app
svn_qgis at osgeo.org
Sun Jun 20 11:21:04 EDT 2010
Author: timlinux
Date: 2010-06-20 15:21:04 +0000 (Sun, 20 Jun 2010)
New Revision: 13753
trunk/qgis/doc/index.html
trunk/qgis/src/app/qgisapp.cpp
Updated whats new texts
Modified: trunk/qgis/doc/index.html
--- trunk/qgis/doc/index.html 2010-06-20 13:26:08 UTC (rev 13752)
+++ trunk/qgis/doc/index.html 2010-06-20 15:21:04 UTC (rev 13753)
@@ -10,7 +10,7 @@
</td>
<td valign="center">
<span class="header">Quantum GIS Documentation</span><br>
- <span class="subheader">Version 1.4.0 <i>Enceladus</i></span><br>
+ <span class="subheader">Version 1.5.0 <i>Tethys</i></span><br>
<span class="warning">Please read this entire document for important information about this release.</span><br>
<span class="warning">You find a <a href="http://www.qgis.org/en/documentation/manuals.html">PDF manual of the current version</a> on the QGIS website.</span>
</td>
@@ -23,16 +23,93 @@
<!-- This documentation describes the Quantum GIS (QGIS) application. More
information on QGIS is available on the web page at http://qgis.org. -->
-<h2>Whats new in Version 1.4.0 'Enceladus'?</h2>
+<h2>Whats new in Version 1.5.0 'Tethys'?</h2>
<p>
-Please note that this is a release in our 'cutting edge' release series. As
-such it contains new features and extends the programmatic interface over
-QGIS 1.0.x and QGIS 1.2.0. If an unchanging user interface, programmatic API
-and long term support is more important to you then cool new and untested
-features, we recommend that you use a copy of QGIS from our Long Term Support
-(LTS)1.0.x release series.
+Please note that this is a release in our 'cutting edge' release series. As
+such it contains new features and extends the programmatic interface over QGIS
+1.0.x and QGIS 1.4.0. If an unchanging user interface, programmatic API and
+long term support is more important to you then cool new and untested features,
+we recommend that you use a copy of QGIS from our Long Term Support (LTS)1.0.x
+release series. In all other cases we recommend that you use this version.
</p>
<p>
+This release includes over 350 bug fixes, over 40 new features.
+Once again it is impossible to document everything here that has changed so we will
+just provide a bullet list of key new features here.
+</p>
+<h3>Main GUI</h3>
+<ul>
+ <li>There is a new angle measuring tool that allows you to interactively measure angles against the map backdrop.</li>
+ <li>Live GPS Tracking tool</li>
+ <li>User configurable WMS search server</li>
+ <li>Allow editing of invalid geometry in node tool</li>
+ <li>Choice between mm and map units for new symbology. Scaling to use new symbology in print composer as well</li>
+ <li>SVG fill symbol layer for polygon textures</li>
+ <li>Font marker symbol layer</li>
+ <li>Added --noplugins command line options to avoid restoring the plugins. Useful when a plugin misbehaves and causes QGIS to crash during startup</li>
+ <li>Allow hiding of deprecated CRSes</li>
+ <li>Add point displacement renderer plugin - allows points to be shifted to avoid colliding with other points</li>
+ <li>Allow saving vector layers as ogr vector files</li>
+ <li>Raster provider: reduce debugging noise</li>
+ <li>Allow adding parts to multi points and lines</li>
+ <li>Text and form annotation tools are now in gui and app</li>
+ <li>Added possibility to place a set of default composer templates in pkgDataPath/composer_templates</li>
+ <li>Gradient color ramps now support multiple stops - for adding intermediate colors</li>
+ <li>Center map if user clicks into the map</li>
+ <li>New plugin for carrying out spatial selections</li>
+ <li>Data-defined size and rotation for single symbol renderer in symbology-ng</li>
+ <li>IdentifyAsHtml to raster layer and use it in identify</li>
+ <li>Export legend groups and layers with legendinterface and use this information to display groups in the composer legend.</li>
+ <li>Show selected feature count in status bar </li>
+ <li>Query option added to layer menu to subset vector layers</li>
+ <li>Option to label only selected features (on the 'old' labelling tool)</li>
+ <li>Load/save queries created in the query builder.</li>
+ <li>Manual adding of categories in symbology-ng.</li>
+ <li>Georeferencer: possibility to configure if residuals should be showed in pixels or map units</li>
+ <li>Delimited text provider: allow empty values in numeric columns</li>
+ <li>Added rule-based renderer for symbology-ng</li>
+ <li>Ability to create spatial lite databases from within QGIS</li>
+ <li>Inclusion of GDAL Raster tools plugin into QGIS core</li>
+ <li>New python console (with history)</li>
+ <li>Add validation to capture tool</li>
+ <li>Allow postgres layers without saved username & password by asking for credentials</li>
+ <li>Support NULL values in search strings</li>
+ <li>Optionally add new layers to the selected group</li>
+ <li>Map composer can add attribute Tables in layouts. It is possibile to show only visible features in composer table or all features</li>
+ <li>Identify tool attribute form now non-modal in view mode (since r12796)</li>
+ <li>Identified features' highlight disappear when window is deactivate or closed and reappears when reactivated.</li>
+</ul>
+<h3>WMS and WMS-C Support</h3>
+<ul>
+ <li>WMS-C support, new spatial authorities, wms selection improvements</li>
+ <li>Resolved EPSG dependency in spatial reference systems and included french IGNF definitions in srs.db</li>
+ <li>WWM provider makes requests asynchronously through QNetworkAccessManager now</li>
+ <li>WMS selection allows inserting of all layers of a branch</li>
+ <li>WMS has support for more mime types</li>
+ <li>Added load/save to WMS dialog</li>
+ <li>WMS-C scale slider gui added and more selection improvements</li>
+</ul>
+<h3>API Updates</h3>
+<ul>
+ <li>QgsDataProvider & QgsMapLayer: add dataChanged() signal, so that a provider can signal that the datasource changed</li>
+ <li>Use QNetworkAccessManager instead of QgsHttpTransaction (including caching and dynamic authentification to website and proxies)</li>
+ <li>Allow opening layer properties from plugins</li>
+ <li>Support for custom plugin layers.</li>
+ <li>Allow refreshing of plugins programmatically</li>
+ <li>Support for custom plugin directories using QGIS_PLUGINPATH environment variables. More paths can be passed, separated by semicolon.</li>
+ <li>Legend interface added to retrieve layers in legend order</li>
+ <li>Support more GEOS operators</li>
+</ul>
+<h2>Whats new in Version 1.4.0 'Enceladus'?</h2>
+<p>
1.0.x and QGIS 1.3.0. If an unchanging user interface, programmatic API and
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-06-20 13:26:08 UTC (rev 13752)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-06-20 15:21:04 UTC (rev 13753)
@@ -2426,78 +2426,90 @@
abt->setVersion( versionString );
QString whatsNew = "<html><body>" ;
whatsNew += "<h2>" + tr( "Version" ) + " " + QString( QGis::QGIS_VERSION ) + "</h2>";
- whatsNew += "<h3>" + tr( "Whats new in Version 1.4.0?" ) + "</h3>"
- "<p>"
- + tr( "Please note that this is a release in our 'cutting edge' release series. As "
- "such it contains new features and extends the programmatic interface over "
- "QGIS 1.0.x and QGIS 1.3.0. If an unchanging user interface, programmatic API "
- "and long term support is more important to you than cool new and untested "
- "features, we recommend that you use a copy of QGIS from our Long Term Support "
- "(LTS)1.0.x release series. In all other cases we recommend that you use this "
- "version." )
- + "</p><p>" +
- tr( "This release includes around 200 bug fixes, nearly 30 new "
- "features and has had a lot of love and attention poured in "
- "to it to take our favourite desktop GIS application another "
- "step on the road to GIS nirvana! So much has happened in "
- "the 3 months since our last release that it is impossible "
- "to document everything here. Instead we will just highlight "
- "a couple of important new features for you." )
- + "</p><p>" +
- tr( "Probably the biggest new feature is the addition of the new "
- "vector symbology infrastructure. This is provided alongside the "
- "old implementation - you can switch using a button in the "
- "vector layer properties dialog. It does't replace the old "
- "symbology implementation completely yet because there are "
- "various issues that need to be resolved and a large amount "
- "of testing before it is considered ready." )
- + "</p><p>" +
- tr( "QGIS now has a field calculator, accessible via a button in "
- "the attribute section of the vector properties, and from "
- "the attribute table user interface. You can use feature "
- "length, feature area, string concatenation and type "
- "conversions in the field calculator, as well as field "
- "values." )
- + "</p><p>" +
- tr( "The map composer has had a lot of attention. A grid can now "
- "be added to composer maps. Composer maps can now be rotated "
- "in the layout. The limitation of a single map layout "
- "per project has been removed. A new composer manager dialog "
- "has been added to manage the existing composer instances. "
- "The composer widget property sheets have been completely "
- "overhauled to use less screen space " )
- + "</p><p>" +
- tr( "Various parts of the user interface have been overhauled "
- "with the goal of improving consistency and to improve "
- "support for netbooks and other smaller screen devices. "
- "Loading and saving of shortcuts. Position can now be "
- "displayed as Degrees, Minutes, Seconds in the status bar. "
- "The add, move and delete vertex buttons are now removed and "
- "the node tool is moved from the advanced editing toolbar to "
- "the standard editing toolbar. The identification tool has also "
- "undergone numerous improvements." )
- + "</p><p>" +
- tr( "A render caching capability has been added to QGIS. This "
- "speeds up common operations such as layer re-ordering, "
- "changing symbology, WMS / WFS client, hiding / showing "
- "layers and opens the door for future enhancements such as "
- "threaded rendering and pre-compositing layer cache "
- "manipulation. Note that it is disabled by default, and "
- "can be enabled in the options dialog." )
- + "</p><p>" +
- tr( "User defined SVG search paths are now added to the options "
- "dialog." )
- + "</p><p>" +
- tr( "When creating a new shapefile, you can now specify its CRS. "
- "Also the avoid intersections option for polygons is now "
- "also possible with background layers." )
- + "</p><p>" +
- tr( "For power users, you can now create customizable attribute "
- "forms using Qt Designer dialog UIs." )
- + "</p>" +
- + "</body></html>";
+ whatsNew += "<h3>" + tr( "Whats new in Version 1.4.0?" ) + "</h3>";
+ whatsNew += "<h2>" + tr( "Whats new in Version 1.5.0 'Tethys'?" ) + "</h2>";
+ whatsNew += "<p>";
+ whatsNew += tr( "Please note that this is a release in our 'cutting edge' release series. As " );
+ whatsNew += tr( "such it contains new features and extends the programmatic interface over QGIS " );
+ whatsNew += tr( "1.0.x and QGIS 1.4.0. If an unchanging user interface, programmatic API and " );
+ whatsNew += tr( "long term support is more important to you then cool new and untested features, " );
+ whatsNew += tr( "we recommend that you use a copy of QGIS from our Long Term Support (LTS)1.0.x " );
+ whatsNew += tr( "release series. In all other cases we recommend that you use this version." );
+ whatsNew += "</p>";
+ whatsNew += tr( "This release includes over 350 bug fixes, over 40 new features. " );
+ whatsNew += tr( "Once again it is impossible to document everything here that has changed so we will " );
+ whatsNew += tr( "just provide a bullet list of key new features here." );
+ whatsNew += "<h3>" + tr( "Main GUI" ) + "</h3>";
+ whatsNew += "<ul>";
+ whatsNew += " <li>" + tr( "There is a new angle measuring tool that allows you to interactively measure angles against the map backdrop." ) + "</li>";
+ whatsNew += " <li>" + tr( "Live GPS Tracking tool" ) + "</li>";
+ whatsNew += " <li>" + tr( "User configurable WMS search server" ) + "</li>";
+ whatsNew += " <li>" + tr( "Allow editing of invalid geometry in node tool" ) + "</li>";
+ whatsNew += " <li>" + tr( "Choice between mm and map units for new symbology. Scaling to use new symbology in print composer as well" ) + "</li>";
+ whatsNew += " <li>" + tr( "SVG fill symbol layer for polygon textures" ) + "</li>";
+ whatsNew += " <li>" + tr( "Font marker symbol layer" ) + "</li>";
+ whatsNew += " <li>" + tr( "Added --noplugins command line options to avoid restoring the plugins. Useful when a plugin misbehaves and causes QGIS to crash during startup" ) + "</li>";
+ whatsNew += " <li>" + tr( "Allow hiding of deprecated CRSes" ) + "</li>";
+ whatsNew += " <li>" + tr( "Add point displacement renderer plugin - allows points to be shifted to avoid colliding with other points" ) + "</li>";
+ whatsNew += " <li>" + tr( "Allow saving vector layers as ogr vector files" ) + "</li>";
+ whatsNew += " <li>" + tr( "Raster provider: reduce debugging noise" ) + "</li>";
+ whatsNew += " <li>" + tr( "Allow adding parts to multi points and lines" ) + "</li>";
+ whatsNew += " <li>" + tr( "Text and form annotation tools are now in gui and app" ) + "</li>";
+ whatsNew += " <li>" + tr( "Added possibility to place a set of default composer templates in pkgDataPath/composer_templates" ) + "</li>";
+ whatsNew += " <li>" + tr( "Gradient color ramps now support multiple stops - for adding intermediate colors" ) + "</li>";
+ whatsNew += " <li>" + tr( "Center map if user clicks into the map" ) + "</li>";
+ whatsNew += " <li>" + tr( "New plugin for carrying out spatial selections" ) + "</li>";
+ whatsNew += " <li>" + tr( "Data-defined size and rotation for single symbol renderer in symbology-ng" ) + "</li>";
+ whatsNew += " <li>" + tr( "IdentifyAsHtml to raster layer and use it in identify" ) + "</li>";
+ whatsNew += " <li>" + tr( "Export legend groups and layers with legendinterface and use this information to display groups in the composer legend." ) + "</li>";
+ whatsNew += " <li>" + tr( "Show selected feature count in status bar " ) + "</li>";
+ whatsNew += " <li>" + tr( "Query option added to layer menu to subset vector layers" ) + "</li>";
+ whatsNew += " <li>" + tr( "Option to label only selected features (on the 'old' labelling tool)" ) + "</li>";
+ whatsNew += " <li>" + tr( "Load/save queries created in the query builder." ) + "</li>";
+ whatsNew += " <li>" + tr( "Manual adding of categories in symbology-ng." ) + "</li>";
+ whatsNew += " <li>" + tr( "Georeferencer: possibility to configure if residuals should be showed in pixels or map units" ) + "</li>";
+ whatsNew += " <li>" + tr( "Delimited text provider: allow empty values in numeric columns" ) + "</li>";
+ whatsNew += " <li>" + tr( "Added rule-based renderer for symbology-ng" ) + "</li>";
+ whatsNew += " <li>" + tr( "Ability to create spatial lite databases from within QGIS" ) + "</li>";
+ whatsNew += " <li>" + tr( "Inclusion of GDAL Raster tools plugin into QGIS core" ) + "</li>";
+ whatsNew += " <li>" + tr( "New python console (with history)" ) + "</li>";
+ whatsNew += " <li>" + tr( "Add validation to capture tool" ) + "</li>";
+ whatsNew += " <li>" + tr( "Allow postgres layers without saved username & password by asking for credentials" ) + "</li>";
+ whatsNew += " <li>" + tr( "Support NULL values in search strings" ) + "</li>";
+ whatsNew += " <li>" + tr( "Optionally add new layers to the selected group" ) + "</li>";
+ whatsNew += " <li>" + tr( "Map composer can add attribute Tables in layouts. It is possibile to show only visible features in composer table or all features" ) + "</li>";
+ whatsNew += " <li>" + tr( "Identify tool attribute form now non-modal in view mode (since r12796)" ) + "</li>";
+ whatsNew += " <li>" + tr( "Identified features' highlight disappear when window is deactivate or closed and reappears when reactivated." ) + "</li>";
+ whatsNew += "</ul>";
+ whatsNew += "<h3>" + tr( "WMS and WMS-C Support" ) + "</h3>";
+ whatsNew += " <li>" + tr( "WMS-C support, new spatial authorities, wms selection improvements" ) + "</li>";
+ whatsNew += " <li>" + tr( "Resolved EPSG dependency in spatial reference systems and included french IGNF definitions in srs.db" ) + "</li>";
+ whatsNew += " <li>" + tr( "WWM provider makes requests asynchronously through QNetworkAccessManager now" ) + "</li>";
+ whatsNew += " <li>" + tr( "WMS selection allows inserting of all layers of a branch" ) + "</li>";
+ whatsNew += " <li>" + tr( "WMS has support for more mime types" ) + "</li>";
+ whatsNew += " <li>" + tr( "Added load/save to WMS dialog" ) + "</li>";
+ whatsNew += " <li>" + tr( "WMS-C scale slider gui added and more selection improvements" ) + "</li>";
+ whatsNew += "<h3>" + tr( "API Updates" ) + "</h3>";
+ whatsNew += " <li>" + tr( "QgsDataProvider & QgsMapLayer: add dataChanged() signal, so that a provider can signal that the datasource changed" ) + "</li>";
+ whatsNew += " <li>" + tr( "Use QNetworkAccessManager instead of QgsHttpTransaction (including caching and dynamic authentification to website and proxies)" ) + "</li>";
+ whatsNew += " <li>" + tr( "Allow opening layer properties from plugins" ) + "</li>";
+ whatsNew += " <li>" + tr( "Support for custom plugin layers." ) + "</li>";
+ whatsNew += " <li>" + tr( "Allow refreshing of plugins programmatically" ) + "</li>";
+ whatsNew += " <li>" + tr( "Support for custom plugin directories using QGIS_PLUGINPATH environment variables. More paths can be passed, separated by semicolon." ) + "</li>";
+ whatsNew += " <li>" + tr( "Legend interface added to retrieve layers in legend order" ) + "</li>";
+ whatsNew += " <li>" + tr( "Support more GEOS operators" ) + "</li>";
+ whatsNew += "</body></html>";
abt->setWhatsNew( whatsNew );
QApplication::restoreOverrideCursor();
