[QGIS Commit] r13754 - in trunk/qgis: python/core src/app
src/app/attributetable src/core
svn_qgis at osgeo.org
Sun Jun 20 11:52:54 EDT 2010
Author: wonder
Date: 2010-06-20 15:52:54 +0000 (Sun, 20 Jun 2010)
New Revision: 13754
trunk/qgis/python/core/qgssearchtreenode.sip
trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
trunk/qgis/src/app/qgssearchquerybuilder.cpp
trunk/qgis/src/core/qgssearchstringlexer.ll
trunk/qgis/src/core/qgssearchtreenode.cpp
trunk/qgis/src/core/qgssearchtreenode.h
Fixed #2346 - allow quoting of column references using double quotes.
Quoting is done in both search query builder and search from attribute table.
Modified: trunk/qgis/python/core/qgssearchtreenode.sip
--- trunk/qgis/python/core/qgssearchtreenode.sip 2010-06-20 15:21:04 UTC (rev 13753)
+++ trunk/qgis/python/core/qgssearchtreenode.sip 2010-06-20 15:52:54 UTC (rev 13754)
@@ -115,6 +115,10 @@
//! @note added in 1.5
bool needsGeometry();
+ //! return quoted column reference (in double quotes)
+ //! @note added in 1.5
+ static QString quotedColumnRef( QString name );
protected:
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2010-06-20 15:21:04 UTC (rev 13753)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2010-06-20 15:52:54 UTC (rev 13754)
@@ -615,21 +615,17 @@
void QgsAttributeTableDialog::search()
- QString str = mColumnBox->currentText();
+ QString fieldName = mColumnBox->currentText();
const QgsFieldMap& flds = mLayer->pendingFields();
- int fldIndex = mLayer->fieldNameIndex( str );
+ int fldIndex = mLayer->fieldNameIndex( fieldName );
QVariant::Type fldType = flds[fldIndex].type();
bool numeric = ( fldType == QVariant::Int || fldType == QVariant::Double );
- if ( numeric )
- str += " = '";
- else
- str += " ~ '";
+ QString str = QString( "%1 %2 '%3'" )
+ .arg( QgsSearchTreeNode::quotedColumnRef( fieldName ) )
+ .arg( numeric ? "=" : "~" )
+ .arg( mQuery->displayText().replace( "'", "''" ) ); // escape quotes
- str += mQuery->displayText().replace( "'", "''" ); // escape quotes
- str += "'";
doSearch( str );
Modified: trunk/qgis/src/app/qgssearchquerybuilder.cpp
--- trunk/qgis/src/app/qgssearchquerybuilder.cpp 2010-06-20 15:21:04 UTC (rev 13753)
+++ trunk/qgis/src/app/qgssearchquerybuilder.cpp 2010-06-20 15:52:54 UTC (rev 13754)
@@ -80,11 +80,14 @@
void QgsSearchQueryBuilder::populateFields()
QgsDebugMsg( "entering." );
+ QRegExp reQuote( "[A-Za-z_][A-Za-z0-9_]*" );
const QgsFieldMap& fields = mLayer->pendingFields();
for ( QgsFieldMap::const_iterator it = fields.begin(); it != fields.end(); ++it )
QString fieldName = it->name();
mFieldMap[fieldName] = it.key();
+ if ( !reQuote.exactMatch( fieldName ) ) // quote if necessary
+ fieldName = QgsSearchTreeNode::quotedColumnRef( fieldName );
QStandardItem *myItem = new QStandardItem( fieldName );
myItem->setEditable( false );
mModelFields->insertRow( mModelFields->rowCount(), myItem );
Modified: trunk/qgis/src/core/qgssearchstringlexer.ll
--- trunk/qgis/src/core/qgssearchstringlexer.ll 2010-06-20 15:21:04 UTC (rev 13753)
+++ trunk/qgis/src/core/qgssearchstringlexer.ll 2010-06-20 15:52:54 UTC (rev 13754)
@@ -49,6 +49,9 @@
col_next [A-Za-z0-9_]|{non_ascii}
column_ref {col_first}{col_next}*
+col_str_char "\"\""|[^\"]
+column_ref_quoted "\""{col_str_char}*"\""
dig [0-9]
num1 {dig}+\.?([eE][-+]?{dig}+)?
num2 {dig}*\.{dig}+([eE][-+]?{dig}+)?
@@ -101,6 +104,7 @@
"$length" { return LENGTH; }
{column_ref} { return COLUMN_REF; }
+{column_ref_quoted} { return COLUMN_REF; }
{white} /* skip blanks and tabs */
Modified: trunk/qgis/src/core/qgssearchtreenode.cpp
--- trunk/qgis/src/core/qgssearchtreenode.cpp 2010-06-20 15:21:04 UTC (rev 13753)
+++ trunk/qgis/src/core/qgssearchtreenode.cpp 2010-06-20 15:52:54 UTC (rev 13754)
@@ -70,6 +70,11 @@
mType = tColumnRef;
mText = text;
+ if ( text.at( 0 ) == '\"' )
+ // column reference is quoted
+ stripColRef();
else
@@ -162,6 +167,21 @@
+void QgsSearchTreeNode::stripColRef()
+ // strip double quotes on start,end
+ mText = mText.mid( 1, mText.length() - 2 );
+ // make single "double quotes" from double "double quotes"
+ mText.replace( QRegExp( "\"\"" ), "\"" );
+QString QgsSearchTreeNode::quotedColumnRef( QString name )
+ return QString( "\"%1\"" ).arg( name.replace( "\"", "\"\"" ) );
QString QgsSearchTreeNode::makeSearchString()
QString str;
Modified: trunk/qgis/src/core/qgssearchtreenode.h
--- trunk/qgis/src/core/qgssearchtreenode.h 2010-06-20 15:21:04 UTC (rev 13753)
+++ trunk/qgis/src/core/qgssearchtreenode.h 2010-06-20 15:52:54 UTC (rev 13754)
@@ -153,6 +153,10 @@
protected:
@@ -162,6 +166,9 @@
//! strips mText when node is of string type
void stripText();
+ //! strip mText when column reference is quoted
+ void stripColRef();
//! initialize node's internals
void init();
