[QGIS Commit] r13757 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sun Jun 20 14:21:05 EDT 2010
Author: jef
Date: 2010-06-20 18:21:05 +0000 (Sun, 20 Jun 2010)
New Revision: 13757
trunk/qgis/src/app/qgisapp.cpp
fix translation string
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-06-20 17:09:21 UTC (rev 13756)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-06-20 18:21:05 UTC (rev 13757)
@@ -2430,17 +2430,17 @@
whatsNew += "<h2>" + tr( "Whats new in Version 1.5.0 'Tethys'?" ) + "</h2>";
whatsNew += "<p>";
- whatsNew += tr( "Please note that this is a release in our 'cutting edge' release series. As " );
- whatsNew += tr( "such it contains new features and extends the programmatic interface over QGIS " );
- whatsNew += tr( "1.0.x and QGIS 1.4.0. If an unchanging user interface, programmatic API and " );
- whatsNew += tr( "long term support is more important to you then cool new and untested features, " );
- whatsNew += tr( "we recommend that you use a copy of QGIS from our Long Term Support (LTS)1.0.x " );
- whatsNew += tr( "release series. In all other cases we recommend that you use this version." );
+ whatsNew += tr( "Please note that this is a release in our 'cutting edge' release series. As "
+ "such it contains new features and extends the programmatic interface over QGIS "
+ "1.0.x and QGIS 1.4.0. If an unchanging user interface, programmatic API and "
+ "long term support is more important to you then cool new and untested features, "
+ "we recommend that you use a copy of QGIS from our Long Term Support (LTS)1.0.x "
+ "release series. In all other cases we recommend that you use this version." );
whatsNew += "</p>";
whatsNew += "<p>";
- whatsNew += tr( "This release includes over 350 bug fixes, over 40 new features. " );
- whatsNew += tr( "Once again it is impossible to document everything here that has changed so we will " );
- whatsNew += tr( "just provide a bullet list of key new features here." );
+ whatsNew += tr( "This release includes over 350 bug fixes, over 40 new features. "
+ "Once again it is impossible to document everything here that has changed so we will "
+ "just provide a bullet list of key new features here." );
whatsNew += "</p>";
whatsNew += "<h3>" + tr( "Main GUI" ) + "</h3>";
@@ -2453,7 +2453,7 @@
whatsNew += " <li>" + tr( "Choice between mm and map units for new symbology. Scaling to use new symbology in print composer as well" ) + "</li>";
whatsNew += " <li>" + tr( "SVG fill symbol layer for polygon textures" ) + "</li>";
whatsNew += " <li>" + tr( "Font marker symbol layer" ) + "</li>";
- whatsNew += " <li>" + tr( "Added --noplugins command line options to avoid restoring the plugins. Useful when a plugin misbehaves and causes QGIS to crash during startup" ) + "</li>";
+ whatsNew += " <li>" + tr( "Added --noplugins command line options to avoid restoring the plugins. Useful when a plugin misbehaves and causes QGIS to crash during startup" ) + "</li>";
whatsNew += " <li>" + tr( "Allow hiding of deprecated CRSes" ) + "</li>";
whatsNew += " <li>" + tr( "Add point displacement renderer plugin - allows points to be shifted to avoid colliding with other points" ) + "</li>";
whatsNew += " <li>" + tr( "Allow saving vector layers as ogr vector files" ) + "</li>";
