[QGIS Commit] r13783 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jun 22 19:23:48 EDT 2010
Author: macho
Date: 2010-06-22 23:23:48 +0000 (Tue, 22 Jun 2010)
New Revision: 13783
   trunk/qgis/i18n/qgis_el_GR.ts
translation update: el_GR by mike
Modified: trunk/qgis/i18n/qgis_el_GR.ts
--- trunk/qgis/i18n/qgis_el_GR.ts	2010-06-22 16:22:52 UTC (rev 13782)
+++ trunk/qgis/i18n/qgis_el_GR.ts	2010-06-22 23:23:48 UTC (rev 13783)
@@ -6,7 +6,7 @@
     <message>
         <location filename="../src/gui/symbology-ng/characterwidget.cpp" line="111"/>
         <source>&lt;p&gt;Character: &lt;span style=&quot;font-size: 24pt; font-family: %1%2&lt;/span&gt;&lt;p&gt;Value: 0x%3&quot;&gt;</source>
-        <translation type="unfinished"></translation>
+        <translation></translation>
     </message>
 </context>
 <context>
@@ -295,7 +295,7 @@
     <message>
         <location filename="../python/plugins/fTools/tools/frmGeoprocessing.ui" line="262"/>
         <source>Segments to approximate</source>
+        <translation>Τμήματα κατά προσέγγιση</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmIntersectLines.ui" line="16"/>
@@ -1625,7 +1625,7 @@
     </message>
     <message>
         <source>Sieve</source>
+        <translation>Κόσκινο</translation>
     </message>
     <message>
         <source>Removes small raster polygons</source>
@@ -1649,7 +1649,7 @@
     </message>
     <message>
         <source>Warp</source>
     </message>
     <message>
         <source>Warp an image into a new coordinate system</source>
@@ -1771,7 +1771,7 @@
     <message>
         <source>
 (using GDAL v. %1)</source>
     </message>
     <message>
         <source>GDAL Tools (AKA Raster Tools) is a plugin for QuantumGIS aiming at making life simpler for users of GDAL Utilities, providing a simplified graphical interface for most commonly used programs.
@@ -1892,7 +1892,7 @@
     </message>
     <message>
         <source>Warning: CRS information for all raster in subfolders will be rewritten. Are you sure?</source>
+        <translation>Προειδοποίηση: CRS πληροφορία για όλα τα raster στους υποφακέλους θα ξαναγραφεί. Είστε βέβαιος;</translation>
     </message>
     <message>
         <source>Select the file to analyse</source>
@@ -1900,7 +1900,7 @@
     </message>
     <message>
         <source>Select the input directory with files to Assign projection</source>
+        <translation>Επιλέξτε το φάκελο εισαγωγής με αρχεία για την ανάθεση προβολής</translation>
     </message>
     <message>
         <source>Assign projection</source>
@@ -1924,87 +1924,87 @@
     </message>
     <message>
         <source>Select the input file for Warp</source>
+        <translation>Επιλέξτε το αρχειο εισόδου για το Warp</translation>
     </message>
     <message>
         <source>Select the input directory with files to Warp</source>
+        <translation>Επιλέξτε το φάκελο εισόδου με τα αρχεία για το Warp</translation>
     </message>
     <message>
         <source>Select the output directory to save the results to</source>
+        <translation>Επιλέξτε το φάκελο εξόδου για να σώζετε τα αποτελέσματα</translation>
     </message>
     <message>
         <source>Select the input file for Sieve</source>
+        <translation>Επιλέξτε το αρχείο εισόδου για το Sieve</translation>
     </message>
     <message>
         <source>Select the files to Merge</source>
+        <translation>Eπιλέξτε τα αρχεία προς συγχώνευση</translation>
     </message>
     <message>
         <source>Select where to save the Merge output</source>
+        <translation>Επιλέξτε που θα αποθηκεύσετε το αποτέλεσμα της Συγχώνευσης</translation>
     </message>
     <message>
         <source>Select the input file for convert</source>
+        <translation>Επιλέξτε το αρχείο εισόδου για μετατροπή</translation>
     </message>
     <message>
         <source>Select the input file for Polygonize</source>
+        <translation>Επιλέξτε το αρχειο εισόδου για Πολυγωνισμό</translation>
     </message>
     <message>
         <source>Select where to save the Polygonize output</source>
+        <translation>Επιλέξτε που θα αποθηκεύσετε το αποτέλεσμα του Πολυγωνισμού</translation>
     </message>
     <message>
         <source>Select the input file for Contour</source>
+        <translation>Επιλέξτε το αρχείο εισόδου για Ανίχνευση περιγράμματος</translation>
     </message>
     <message>
         <source>Select where to save the Contour output</source>
+        <translation>Επιλέξτε που θα αποθηκεύσετε το αποτέλεσμα της Ανίχνευσης περιγράμματος</translation>
     </message>
     <message>
         <source>No active raster layers. You must add almost one raster layer to continue.</source>
+        <translation>Κανένα ενεργό επίπεδο raster. Πρέπει να προσθέσετε τουλάχιστον ένα επίπεδο raster για να συνεχίσετε.</translation>
     </message>
     <message>
         <source>Select the input file for Translate</source>
+        <translation>Επιλέξτε το αεχείο εισόδου για μετάφραση</translation>
     </message>
     <message>
         <source>Select the input directory with files to Translate</source>
+        <translation>Επιλέξτε το φάκελο εισόδου με αρχεία για μετάφραση</translation>
     </message>
     <message>
         <source>Convert paletted image to RGB</source>
+        <translation>Μετατροπή εικόνας παλέτας σε RGB</translation>
     </message>
     <message>
         <source>Band to convert:</source>
+        <translation>Ζώνη (Band) για μετατροπή:</translation>
     </message>
     <message>
         <source>Select the input file for Rasterize</source>
+        <translation>Επιλέξτε το αρχείο εισόδου για μετατροπή σε Raster</translation>
     </message>
     <message>
         <source>Copy</source>
+        <translation>Αντιγραφή</translation>
     </message>
     <message>
         <source>Copy all</source>
+        <translation>Αντιγραφή Όλων</translation>
     </message>
     <message>
         <source>Select the input file</source>
+        <translation>Επιλέξτε το αρχειο εισόδου</translation>
     </message>
     <message>
         <source>Select the input directory with files</source>
+        <translation>Επιλέξτε το φάκελο εισόδου με τα αρχεία</translation>
     </message>
 </context>
 <context>
@@ -2012,22 +2012,22 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/optionsTable.ui" line="45"/>
         <source>Name</source>
-        <translation type="unfinished">Όνομα</translation>
+        <translation>Όνομα</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/optionsTable.ui" line="50"/>
         <source>Value</source>
-        <translation type="unfinished">Τιμή</translation>
+        <translation>Τιμή</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/optionsTable.ui" line="60"/>
         <source>Add</source>
-        <translation type="unfinished">Προσθήκη</translation>
+        <translation>Προσθήκη</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/optionsTable.ui" line="67"/>
         <source>Remove</source>
+        <translation>Αφαίρεση</translation>
     </message>
 </context>
 <context>
@@ -2035,12 +2035,12 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="14"/>
         <source>Gdal Tools settings</source>
+        <translation>Ρυθμίσεις εργαλείων Gdal</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="20"/>
         <source>Path to the GDAL binaries</source>
+        <translation>Μονοπάτι για τον εκτελέσιμο κώδικα του Gdal</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="32"/>
@@ -2048,26 +2048,26 @@
         <location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="94"/>
         <location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="125"/>
         <source>Browse</source>
-        <translation type="unfinished">Αναζήτηση</translation>
+        <translation>Αναζήτηση</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="44"/>
         <source>GDAL data path</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="75"/>
         <source>GDAL driver path</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="106"/>
         <source>GDAL pymod path</source>
     </message>
     <message>
         <source>Select directory with GDAL executables</source>
+        <translation>Επιλογη φακέλου με εκτελέσιμα προγράμματα GDAL</translation>
     </message>
 </context>
 <context>
@@ -2075,13 +2075,13 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="20"/>
         <source>Build Virtual Raster</source>
+        <translation>Κατασκευή εικονικού raster</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="31"/>
         <location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="28"/>
         <source>&amp;Input files:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="53"/>
@@ -2117,7 +2117,7 @@
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="122"/>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="150"/>
         <source>Select...</source>
+        <translation>Επιλογή...</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="62"/>
@@ -2131,127 +2131,127 @@
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="72"/>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="72"/>
         <source>&amp;Output file:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="110"/>
         <source>Highest</source>
+        <translation>Υψηλότερο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="115"/>
         <source>Average</source>
+        <translation>Μέσο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="120"/>
         <source>Lowest</source>
+        <translation>Χαμηλότερο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="93"/>
         <source>&amp;Resolution:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="128"/>
         <source>&amp;Source No Data:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="20"/>
         <source>Clipper</source>
-        <translation type="unfinished">Συνδετήρας</translation>
+        <translation>Συνδετήρας</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="59"/>
         <location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="90"/>
         <source>&amp;No data value:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="75"/>
         <source>Re-Enable Clipping</source>
+        <translation>Επανενεργοποίηση Clipping</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="84"/>
         <source>Select the extent by drag &amp; drop on canvas</source>
+        <translation>Επιλέξτε την έκταση με σύρσιμο και απόθεση (drag and drop) στον καμβά</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="91"/>
         <source>or change the extent coordinates:</source>
+        <translation>ή αλλάξτε την έκταση των συντεταγμένων:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="102"/>
         <source>1:</source>
-        <translation type="unfinished">1:</translation>
+        <translation>1:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="113"/>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="178"/>
         <source>x</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="130"/>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="195"/>
         <source>y</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="167"/>
         <source>2:</source>
-        <translation type="unfinished">2:</translation>
+        <translation>2:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="218"/>
         <location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="123"/>
         <source>Grab pseudocolor table from the first image</source>
+        <translation>Αδράξτε πίνακα ψευδοχρωμάτων από την πρώτη εικόνα</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="20"/>
         <source>Contour</source>
-        <translation type="unfinished">Περίγραμμα</translation>
+        <translation>Περίγραμμα</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="28"/>
         <location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="28"/>
         <source>&amp;Input file (raster):</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="65"/>
         <source>&amp;Output directory for contour lines (shapefile):</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="124"/>
         <source>&amp;Attribute name:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="142"/>
         <source>If not provided, no elevation attribute is attached.</source>
+        <translation>Εάν δεν δίνεται, δεν επικολλάται κανένα πεδίο με το υψόμετρο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="156"/>
         <source>ELEV</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="96"/>
         <source>I&amp;nterval between contour lines:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="20"/>
         <source>Convert RGB image to paletted</source>
+        <translation>Μετατροπή RGB εικόνας σε εικόνα παλέτας</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="26"/>
@@ -2260,7 +2260,7 @@
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="26"/>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="26"/>
         <source>Batch mode (for processing whole directory)</source>
+        <translation>Μαζικά (για επεξεργασία ολόκληρου φακέλου)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="35"/>
@@ -2273,57 +2273,57 @@
         <location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="28"/>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="35"/>
         <source>&amp;Input file:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="96"/>
         <source>Number of colors</source>
+        <translation>Πλήθος χρωμάτων</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="20"/>
         <source>Grid</source>
-        <translation type="unfinished">Πλέγμα</translation>
+        <translation>Πλέγμα</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="65"/>
         <source>&amp;Z Field:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="106"/>
         <source>&amp;Algorithm:</source>
+        <translation>&amp;Αλγόριθμος</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="114"/>
         <source>Inverse distance to a power</source>
+        <translation>Νιοστη Δύναμη του αντριστρόφου της απόστασης</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="119"/>
         <source>Moving average</source>
+        <translation>Κινούμενος μέσος</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="124"/>
         <source>Nearest neighbor</source>
+        <translation>Εγγύτερος γειίτονας</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="129"/>
         <source>Data metrics</source>
+        <translation>Στατιστικά Δεδομένων</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="157"/>
         <source>Power:</source>
+        <translation>Εκθέτης:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="171"/>
         <source>Smoothing:</source>
+        <translation>Εξομάλυνση:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="188"/>
@@ -2331,7 +2331,7 @@
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="387"/>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="498"/>
         <source>Radius1:</source>
+        <translation>Ακτίνα1:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="205"/>
@@ -2339,7 +2339,7 @@
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="404"/>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="515"/>
         <source>Radius2:</source>
+        <translation>Ακτίνα2:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="222"/>
@@ -2347,19 +2347,19 @@
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="421"/>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="532"/>
         <source>Angle:</source>
-        <translation type="unfinished">Γωνία:</translation>
+        <translation>Γωνία:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="239"/>
         <source>Max points:</source>
+        <translation>Μέγιστος αριθμός σημείων:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="253"/>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="339"/>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="549"/>
         <source>Min points:</source>
+        <translation>Ελάχιστος αριθμός σημείων:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="267"/>
@@ -2367,73 +2367,73 @@
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="438"/>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="563"/>
         <source>No data:</source>
+        <translation>Καθόλου δεδομένα:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="472"/>
         <source>Metrics:</source>
+        <translation>Στατιστικά:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="480"/>
         <source>Minimum</source>
-        <translation type="unfinished">Ελάχιστο</translation>
+        <translation>Ελάχιστο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="485"/>
         <source>Maximum</source>
+        <translation>Μέγιστο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="490"/>
         <source>Range</source>
-        <translation type="unfinished">Εύρος</translation>
+        <translation>Εύρος</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetInfo.ui" line="20"/>
         <source>Info</source>
-        <translation type="unfinished">Πληροφορίες</translation>
+        <translation>Πληροφορίες</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetInfo.ui" line="63"/>
         <source>Raster info</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetInfo.ui" line="83"/>
         <source>Suppress GCP printing</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetInfo.ui" line="90"/>
         <source>Suppress metadata printing</source>
+        <translation>Αποτροπή εκτύπωσης μεταδεδομένων </translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="20"/>
         <source>Merge</source>
-        <translation type="unfinished">Συγχώνευση</translation>
+        <translation>Συγχώνευση</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="106"/>
         <source>Layer stack</source>
+        <translation>Στοίβα από επίπεδα</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="116"/>
         <source>Use intersected extent</source>
+        <translation>Χρήση της έκτασης της τομής</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="130"/>
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="150"/>
         <source>&amp;Creation Options:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetNearBlack.ui" line="20"/>
         <source>Near Black</source>
+        <translation>Εγγύς Μαύρο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetNearBlack.ui" line="96"/>
@@ -2448,57 +2448,57 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="20"/>
         <source>Add overview</source>
+        <translation>Προσθήκη overview</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="72"/>
         <source>Resampling method</source>
+        <translation>Τρόπος Επαναδειγματοληψίας</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="80"/>
         <source>nearest</source>
+        <translation>εγγύτερο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="85"/>
         <source>average</source>
+        <translation>μέσο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="90"/>
         <source>gauss</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="95"/>
         <source>average_mp</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="100"/>
         <source>average_magphase</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="105"/>
         <source>mode</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="113"/>
         <source>Levels (space delimited)</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="125"/>
         <source>Open in read-only mode</source>
+        <translation>Άνοιγμα σε κατάσταση ανάγνωσης μόνο</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="20"/>
         <source>Polygonize</source>
-        <translation type="unfinished">Πολυγωνοποίηση</translation>
+        <translation>Πολυγωνοποίηση</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="65"/>
@@ -2508,150 +2508,152 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="103"/>
         <source>DN</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="96"/>
         <source>&amp;Field name:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="20"/>
-        <translation type="unfinished">Ανάθεση προβολής</translation>
+        <translation>Ανάθεση προβολής</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="33"/>
         <source>WARNING: current projection definition will be cleared</source>
+        <translation>Προειδοποίηση: τρέχων ορισμός προβολης θα χαθεί</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="80"/>
         <source>Desired SRS:</source>
+        <translation>Επιθυμητό SRS:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="101"/>
         <source>Output will be:
 - new GeoTiff if input file is not GeoTiff
 - overwritten if input is GeoTiff</source>
+        <translation>Το αποτέλεσμα θα είναι:
+- νέο GeoTiff εφόσον το αρχείο εισόδου δεν ήταν GeoTiff
+- αντικατάσταση του αρχείου εάν το αρχειο ήταν GeoTiff</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="73"/>
         <source>Recurse subdirectories</source>
+        <translation>Αναδρομικά στους υποφακέλους</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="20"/>
         <source>Proximity</source>
-        <translation type="unfinished">Εγγύτητα</translation>
+        <translation>Εγγύτητα</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="89"/>
         <source>&amp;Values:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="121"/>
         <source>&amp;Dist units:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="132"/>
         <source>GEO</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="137"/>
         <source>PIXEL</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="145"/>
         <source>&amp;Max dist:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="159"/>
         <source>&amp;No data:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="173"/>
         <source>&amp;Fixed buf val:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="20"/>
         <source>Rasterize</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="28"/>
         <source>&amp;Input file (shapefile):</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="85"/>
         <source>&amp;Output file for rasterized vectors (raster, must exists):</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="65"/>
         <source>&amp;Attribute field:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="118"/>
         <source>4</source>
-        <translation type="unfinished">4</translation>
+        <translation>4</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="123"/>
         <source>8</source>
-        <translation type="unfinished">8</translation>
+        <translation>8</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="96"/>
         <source>&amp;Threshold:</source>
+        <translation>Κα&amp;τώφλι:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="110"/>
         <source>&amp;Pixel connections:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="20"/>
         <source>Translate</source>
-        <translation type="unfinished">Μετάφραση</translation>
+        <translation>Μετάφραση</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="35"/>
         <source>&amp;Input Layer:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="120"/>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="131"/>
         <source>&amp;Target SRS:</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="103"/>
         <source>Output format</source>
+        <translation>Φορμάτ προορισμού</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="103"/>
@@ -2661,67 +2663,67 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="159"/>
         <source>&amp;Resampling method:</source>
+        <translation>Μέθοδος Επαναδειγματοληψίας (&amp;Resampling):</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="167"/>
         <source>Near</source>
+        <translation>Πλησίον</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="172"/>
         <source>Bilinear</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="177"/>
         <source>Cubic</source>
-        <translation type="unfinished">Κυβικός</translation>
+        <translation>Κυβικός</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="182"/>
         <source>Cubic spline</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="187"/>
         <source>Lanczos</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="205"/>
         <source>&amp;Memory used for caching:</source>
+        <translation>%Μνήμη χρησιμοποιούμενη για &quot;κασάρισμα&quot;:</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="212"/>
         <source>MB</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="195"/>
         <source>Set no data value</source>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="227"/>
         <source>Resize</source>
+        <translation>Αλλαγή μεγέθους</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="242"/>
         <source>Image width</source>
+        <translation>Πλάτος εικόνας</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="256"/>
         <source>Image height</source>
+        <translation>Ύψος εικόνας</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="276"/>
         <source>Use m&amp;ultithreaded warping implementation</source>
+        <translation>Χρήση πολ&amp;υνηματικής εφαρμογής με warp</translation>
     </message>
 </context>
 <context>
@@ -2998,7 +3000,7 @@
     <message>
         <source>
 Input CRS error: One or more input layers missing coordinate reference information, results may not be as expected.</source>
+        <translation>Σφάλμα Συστήματος αναφοράς συντεταγμένων εισόδου: Ένα ή περισσότερα επίπεδα εισόδου δεν συνοδεύονται από πληροφορία συστήματος αναφοράς, με συνέπεια τα αποτελέσματα ίσως να μην είναι τα αναμενόμενα.</translation>
     </message>
     <message>
         <source>
@@ -4165,12 +4167,12 @@
     <message>
         <location filename="../src/core/qgssearchtreenode.cpp" line="312"/>
         <source>Expected operator, got scalar value!</source>
+        <translation>Αναμένετο τελεστής, και βρέθηκε βαθμωτό μέγεθος!</translation>
     </message>
     <message>
         <location filename="../src/core/qgssearchtreenode.cpp" line="375"/>
         <source>Unexpected state when evaluating operator!</source>
+        <translation>Απροσδιόριστη κατάσταση κατά την αποτίμηση τελεστή!</translation>
     </message>
     <message>
         <location filename="../src/core/qgssearchtreenode.cpp" line="393"/>
@@ -4181,7 +4183,7 @@
         <location filename="../src/core/qgssearchtreenode.cpp" line="415"/>
         <location filename="../src/core/qgssearchtreenode.cpp" line="436"/>
         <source>Unknown operator: %1</source>
+        <translation>Άγνωστος τελεστης: %1!</translation>
     </message>
     <message>
         <location filename="../src/core/qgssearchtreenode.cpp" line="431"/>
@@ -4191,12 +4193,12 @@
     <message>
         <location filename="../src/core/qgssearchtreenode.cpp" line="439"/>
         <source>Unknown token: %1</source>
+        <translation>Άγνωστο στοιχείο: %1</translation>
     </message>
     <message>
         <location filename="../src/core/qgssearchtreenode.cpp" line="442"/>
         <source>Unknown error!</source>
+        <translation>Άγνωστο σφάλμα!</translation>
     </message>
     <message>
         <location filename="../src/plugins/coordinate_capture/coordinatecapture.cpp" line="53"/>
@@ -5049,7 +5051,7 @@
     <message>
         <location filename="../src/core/symbology-ng/qgsrendererv2registry.cpp" line="25"/>
         <source>Rule-based</source>
+        <translation>Στηριζόμενο σε κανόνες</translation>
     </message>
     <message>
         <source>Labeling</source>
@@ -5180,7 +5182,7 @@
     <message>
         <location filename="../src/plugins/point_displacement_renderer/qgsdisplacementplugin.cpp" line="45"/>
         <source>Point Displacement</source>
+        <translation>Μετατόπιση σημείου</translation>
     </message>
     <message>
         <source>point Displacement</source>
@@ -5214,7 +5216,7 @@
     <message>
         <location filename="../src/gui/qgstextannotationitem.cpp" line="96"/>
         <source>&lt;html&gt;QGIS rocks!&lt;/html&gt;</source>
     </message>
     <message>
         <location filename="../src/plugins/spatialquery/qgsspatialquery.cpp" line="58"/>
@@ -5284,54 +5286,56 @@
     <message>
         <location filename="../src/app/qgsspatialitesourceselect.cpp" line="303"/>
         <source>SQLite DB (*.sqlite *.db);;All files (*)</source>
     </message>
     <message>
         <location filename="../src/app/main.cpp" line="472"/>
         <source>QGIS starting in non-interactive mode not supported.
 You are seeing this message most likely because you have no DISPLAY environment variable set.
 </source>
+        <translation>Έναρξη του QGIS σε μη αλληλεπιδραστική λειτουργία δεν υποστηρίζεται.
+Βλέπετε αυτό το μήνυμα πιθανότατα επειδή δεν έχετε ορισμένη τη μεταβλητή περιβάλλοντος DISPLAY.
+</translation>
     </message>
     <message>
         <location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="13"/>
         <source>Simple line</source>
+        <translation>Απλή γραμμή</translation>
     </message>
     <message>
         <location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="15"/>
         <source>Marker line</source>
+        <translation>Γραμμή marker</translation>
     </message>
     <message>
         <location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="17"/>
         <source>Line decoration</source>
+        <translation>Διακόσμηση γραμμής</translation>
     </message>
     <message>
         <location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="20"/>
         <source>Simple marker</source>
+        <translation>Απλός δείκτης (marker)</translation>
     </message>
     <message>
         <location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="22"/>
         <source>SVG marker</source>
     </message>
     <message>
         <location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="24"/>
         <source>Font marker</source>
+        <translation>Δείκτης γραμματοσειράς</translation>
     </message>
     <message>
         <location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="27"/>
         <source>Simple fill</source>
+        <translation>Απλό γέμισμα</translation>
     </message>
     <message>
         <location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="29"/>
         <source>SVG fill</source>
     </message>
 </context>
 <context>
@@ -6119,12 +6123,12 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1067"/>
         <source>Query...</source>
+        <translation>Επερώτηση...</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1069"/>
         <source>Set subset query of the current layer</source>
+        <translation>Ορισμός επερώτησης υποσυνόλου για το τρέχον επίπεδο</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1073"/>
@@ -6567,7 +6571,7 @@
         <location filename="../src/app/qgisapp.cpp" line="2397"/>
         <source>
 This copy of QGIS has been built with GDAL/OGR %1.</source>
+        <translation>Αυτό το αντίγραρο του QGIS έχει κατασκευστεί με GDAL/OGR %1.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2400"/>
@@ -6701,23 +6705,24 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="3872"/>
         <source>Saving done</source>
+        <translation>Η αποθήκευση τελείωσε</translation>
     </message>
     <message>
         <source>Export to vector file has been completed</source>
+        <translation>Η εξαγωγή σε διανυσματικο αρχείο ολοκληρώθηκε</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="3876"/>
         <source>Save error</source>
-        <translation type="unfinished">Σφάλμα αποθήκευσης</translation>
+        <translation>Σφάλμα αποθήκευσης</translation>
     </message>
     <message>
         <source>Export to vector file failed.
 Error: %1</source>
+        <translation>Η εξαγωγή σε διανυσματικο αρχείο απέτυχε.
+Σφάλμα: %1</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="3902"/>
@@ -6883,15 +6888,15 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="5209"/>
         <source>The layer %1 is not a valid layer and can not be added to the map</source>
+        <translation>Το επίπεδο %1 δεν είναι ένα έγκυρο επίπεδο και δεν μπορεί να προστεθεί στο χάρτη</translation>
     </message>
     <message numerus="yes">
         <location filename="../src/app/qgisapp.cpp" line="5706"/>
         <source>%n feature(s) selected on layer %1.</source>
         <comment>number of selected features</comment>
-            <numerusform></numerusform>
+        <translation>
+            <numerusform>%n χαρακτηριστικό προστέθηκε στο επίπεδο %1.</numerusform>
+            <numerusform>%n χαρακτηριστικά προστέθηκαν στο επίπεδο %1.</numerusform>
         </translation>
     </message>
     <message>
@@ -6946,7 +6951,7 @@
         <location filename="../src/app/qgisapp.cpp" line="763"/>
         <location filename="../src/app/qgisapp.cpp" line="765"/>
         <source>Move Feature(s)</source>
+        <translation>Μετακίνηση χαρακτηριστικού(ών)</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="956"/>
@@ -6967,7 +6972,7 @@
         <location filename="../src/app/qgisapp.cpp" line="968"/>
         <location filename="../src/app/qgisapp.cpp" line="3774"/>
+        <translation>Εισαγωγή ταμπελών</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="973"/>
@@ -7006,7 +7011,7 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1023"/>
         <source>Save edits</source>
+        <translation>Αποθήκευση των αλλαγών</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1029"/>
@@ -7306,7 +7311,7 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1025"/>
         <source>Save edits to current layer, but continue editing</source>
+        <translation>Αποθήκευση αλλαγών στο τρέχον επίπεδο, αλλά συνέχιση της επεξεργασίας</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1074"/>
@@ -7333,7 +7338,8 @@
         <location filename="../src/app/qgisapp.cpp" line="1109"/>
         <source>Ctrl+F</source>
         <comment>Toggle fullscreen mode</comment>
+        <translatorcomment>Αλλαγη σε πλήρη οθόνη</translatorcomment>
+        <translation>Ctrl+F</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1114"/>
@@ -7400,47 +7406,47 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2429"/>
         <source>Whats new in Version 1.5.0 &apos;Tethys&apos;?</source>
+        <translation>Τι καινούριο διαθέτει η έκδοση 1.5.0 &apos;Tethys&apos;;</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2432"/>
         <source>Please note that this is a release in our &apos;cutting edge&apos; release series. As such it contains new features and extends the programmatic interface over QGIS 1.0.x and QGIS 1.4.0. If an unchanging user interface, programmatic API and long term support is more important to you then cool new and untested features, we recommend that you use a copy of QGIS from our Long Term Support (LTS)1.0.x release series. In all other cases we recommend that you use this version.</source>
-        <translation type="unfinished">Παρακαλώ σημειώστε ότι αυτή είναι έκδοση στη σειρά εκδόσεων κατηγορία &quot;πρωτοπορίας&quot;. Ως εκ τούτου, περιέχει νέα στοιχεία και επεκτείνει την προγραμματική διεπαφή πέραν των QGIS 1.0.x και QGIS 1.3.0. Εάν είναι πιο σημαντικό για εσάς μια αμετάβλητη διεπαφή χρήστη, ή ένα προγραμματιστικό API και μακροχρόνια στήριξη συγκριτικά με μια όμορφη νέα διεπαφή με μη δοκιμασμένα χαρακτηριστικά, συνιστούμε να χρησιμοποιήσετε ένα αντίγραφο του QGIS από τη σειρά εκδόσεων κατηγορία &quot;μακροχρόνιας υποστήριξης&quot; (LTS) 1.0.x. Σε όλες τις άλλ
 ες περιπτώσεις, σας συνιστούμε να χρησιμοποιήσετε αυτήν την έκδοση. {1.0.?} {1.4.0.?} {1.0.?}</translation>
+        <translation>Παρακαλώ σημειώστε ότι αυτή είναι έκδοση στη σειρά εκδόσεων κατηγορία &quot;πρωτοπορίας&quot;. Ως εκ τούτου, περιέχει νέα στοιχεία και επεκτείνει την προγραμματική διεπαφή πέραν των QGIS 1.0.x και QGIS 1.3.0. Εάν είναι πιο σημαντικό για εσάς μια αμετάβλητη διεπαφή χρήστη, ή ένα προγραμματιστικό API και μακροχρόνια στήριξη συγκριτικά με μια όμορφη νέα διεπαφή με μη δοκιμασμένα χαρακτηριστικά, συνιστούμε να χρησιμοποιήσετε ένα αντίγραφο του QGIS από τη σειρά εκδόσεων κατηγορία &quot;μακροχρόνιας υποστήριξης&quot; (LTS) 1.0.x. Σε όλες τις άλλες περιπτÏ
 ŽÏƒÎµÎ¹Ï‚, σας συνιστούμε να χρησιμοποιήσετε αυτήν την έκδοση.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2440"/>
         <source>This release includes over 350 bug fixes, over 40 new features. Once again it is impossible to document everything here that has changed so we will just provide a bullet list of key new features here.</source>
+        <translation>Αυτή η έκδοση περιλαμβάνει πάνω από 350 διορθώσεις σφαλμάτων, πάνω από 40 νέα χαρακτηριστικά. Για άλλη μια φορά είναι αδύνατον να τεκμηριωθεί πάντα εδώ ότι έχει αλλάξει και έτσι θα παρέχει μόνο μια λίστα με σφαίρα των βασικών νέων χαρακτηριστικών εδώ.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2445"/>
         <source>Main GUI</source>
+        <translation>Κυρίως GUI</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2448"/>
         <source>There is a new angle measuring tool that allows you to interactively measure angles against the map backdrop.</source>
+        <translation>Υπάρχει ένα νέο εργαλείο μέτρησης γωνίας, που σας επιτρέπει να μετρήσετε αλληλεπιδραστικά γωνίες με φόντο το χάρτη.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2449"/>
         <source>Live GPS Tracking tool</source>
+        <translation>Λειτουργικο Εργαλείο ιχνηλάτισης GPS</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2450"/>
         <source>User configurable WMS search server</source>
+        <translation>Χρήση παραμετροποιήσιμου εξυπηρετητή αναζήτησης WMS</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2451"/>
         <source>Allow editing of invalid geometry in node tool</source>
+        <translation>Να επιτρέπεται η επεξεργασία μη έγκυρης γεωμετρίας από το εργαλείο κόμβων</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2452"/>
         <source>Choice between mm and map units for new symbology. Scaling to use new symbology in print composer as well</source>
+        <translation>Δυνατότητα επιλογής μεταξύ mm και χαρτογραφικών μονάδων για τα νέα σύμβολα. Κλιμάκωση στη χρήση νέων συμβόλων και στο συνθέτη εκτύπωσης.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2453"/>
@@ -7729,18 +7735,18 @@
     <message>
         <source>Please select a vector layer first.</source>
+        <translation>Παρακαλώ πρώτα επιλέξτε ένα διανυσματικό επίπεδο.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="4204"/>
         <location filename="../src/app/qgisapp.cpp" line="4243"/>
         <source>Not enough features selected</source>
+        <translation>Δεν επιλέχθηκαν αρκετά χαρακτηριστικά</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="4226"/>
         <source>Union operation canceled</source>
+        <translation>Η λειτουργία της συνένωσης ακυρώθηκε</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="4565"/>
@@ -8097,7 +8103,7 @@
     <message>
         <location filename="../src/core/qgsapplication.cpp" line="94"/>
         <source>unknown exception</source>
+        <translation>άγνωστο σφάλμα</translation>
     </message>
 </context>
 <context>
@@ -24230,42 +24236,42 @@
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1927"/>
+        <translation>Μέθοδος Επαναδειγματοληψίας</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1935"/>
+        <translation>Μέσος</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1940"/>
         <source>Nearest Neighbour</source>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1955"/>
         <source>Build pyramids</source>
+        <translation>Δημιουργία πυραμίδων</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="176"/>
         <source>Histogram</source>
+        <translation>Ιστόγραμμα</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1605"/>
         <source>Columns</source>
-        <translation type="unfinished">Στήλες</translation>
+        <translation>Στήλες</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1618"/>
         <source>Rows</source>
-        <translation type="unfinished">Σειρές</translation>
+        <translation>Σειρές</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1631"/>
         <source>No Data</source>
+        <translation>Χωρίς δεδομένα</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1887"/>
@@ -24277,37 +24283,37 @@
 &lt;tr&gt;
 &lt;td style=&quot;border: none;&quot;&gt;
 &lt;p style=&quot;-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:&apos;Sans Serif&apos;; font-size:9pt;&quot;&gt;&lt;/p&gt;&lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;/body&gt;&lt;/html&gt;</source>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="2006"/>
         <source>Chart Type</source>
+        <translation>Τύπος διαγράμματος</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="2015"/>
         <source>Line graph</source>
+        <translation>Γράφημα γραμμών</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="2025"/>
         <source>Bar chart</source>
+        <translation>Γράφημα με μπάρες</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="2035"/>
         <source>Options</source>
-        <translation type="unfinished">Επιλογές</translation>
+        <translation>Επιλογές</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="2041"/>
         <source>Column count</source>
+        <translation>Πλήθος στηλών</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="2064"/>
         <source>Out of range OK?</source>
+        <translation>Εκτός εύρους ΕΝΤΑΞΕΙ;</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="2071"/>
@@ -24393,7 +24399,7 @@
     <message>
         <location filename="../src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisdialogbase.ui" line="85"/>
+        <translation type="unfinished">Φορμάτ προορισμού</translation>
     </message>
     <message>
         <location filename="../src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisdialogbase.ui" line="78"/>
@@ -26713,7 +26719,7 @@
     <message>
         <location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="39"/>
         <source>Resampling method:</source>
-        <translation>Τρόπος Επανασχεδιασμού:</translation>
+        <translation>Μέθοδος Επαναδειγματοληψίας:</translation>
     </message>
     <message>
         <location filename="../src/plugins/georeferencer/qgstransformsettingsdialogbase.ui" line="53"/>
More information about the QGIS-commit mailing list
