[QGIS Commit] r13790 - in trunk/qgis/mac/xcode: . Qgis.xcodeproj
svn_qgis at osgeo.org
Wed Jun 23 10:15:07 EDT 2010
Author: kyngchaos
Date: 2010-06-23 14:15:07 +0000 (Wed, 23 Jun 2010)
New Revision: 13790
trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
trunk/qgis/mac/xcode/ReadMe.rtf
trunk/qgis/mac/xcode/qgis_settings.xcconfig
trunk/qgis/mac/xcode/qgis_user-template.xcconfig
bundle Qt codecs plugins, in case #2419 affects OSX;
allow configuration for custom Qt installation, should help #2760 which needs a PPC cocoa Qt
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-06-23 12:14:45 UTC (rev 13789)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-06-23 14:15:07 UTC (rev 13790)
@@ -7581,6 +7581,7 @@
72EA46F10FCD7772009D4CFB /* mActionArrowUp.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = mActionArrowUp.png; path = ../../images/themes/default/mActionArrowUp.png; sourceTree = SOURCE_ROOT; };
72EA46F20FCD7772009D4CFB /* mActionArrowDown.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = mActionArrowDown.png; path = ../../images/themes/default/mActionArrowDown.png; sourceTree = SOURCE_ROOT; };
72EA46F50FCD77CB009D4CFB /* qgis_xh.ts */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text.xml; name = qgis_xh.ts; path = ../../i18n/qgis_xh.ts; sourceTree = SOURCE_ROOT; };
+ 72EAB8C811D0F49C00C6B9C4 /* qgsplugininstalleroldreposbase.ui */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text.xml; name = qgsplugininstalleroldreposbase.ui; path = ../../python/plugins/plugin_installer/qgsplugininstalleroldreposbase.ui; sourceTree = SOURCE_ROOT; };
72EB12930F7E9AED002C38FA /* LICENSE */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text; name = LICENSE; path = ../../python/plugins/fTools/LICENSE; sourceTree = SOURCE_ROOT; };
72EB12950F7E9B51002C38FA /* plugin_installer.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = plugin_installer.png; path = ../../images/themes/default/plugins/plugin_installer.png; sourceTree = SOURCE_ROOT; };
72EB30FE10B99969002A971B /* qgsludialog.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; name = qgsludialog.cpp; path = ../../src/gui/qgsludialog.cpp; sourceTree = SOURCE_ROOT; };
@@ -10500,6 +10501,7 @@
7209EDE80F39E5D9003DC336 /* qgsplugininstallerbase.ui */,
7209EDEA0F39E5D9003DC336 /* qgsplugininstallerfetchingbase.ui */,
7209EDEC0F39E5D9003DC336 /* qgsplugininstallerinstallingbase.ui */,
+ 72EAB8C811D0F49C00C6B9C4 /* qgsplugininstalleroldreposbase.ui */,
7209EDEE0F39E5D9003DC336 /* qgsplugininstallerpluginerrorbase.ui */,
7209EDF00F39E5D9003DC336 /* qgsplugininstallerrepositorybase.ui */,
7209EDF10F39E5D9003DC336 /* repoConnected.png */,
@@ -15058,7 +15060,7 @@
runOnlyForDeploymentPostprocessing = 0;
shellPath = /bin/sh;
- shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths. ***FIXME***\n\nmkdir -p \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\nQGISPYDIR=\"$QGIS_BUILD_PATH/MacOS/$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\tditto -X $QARCHS \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libp
q.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDAL_PREFIX/lib/libgdal.dylib\" ] ; then\n\tditto -X $QARCHS \"$GDAL_PREFIX/lib/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tditto -X $QARCHS \"$PYSITE/osgeo\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tfor p in gdal gdalconst gdalnumeric ogr osr\n\tdo\n\t\tditto -X $QARCHS \"$PYSITE/$p.py\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tdone\n\tfor p in $GDAL_PROGS\n\tdo\n\t\tif [ -e \"$GDAL_PREFIX/bin/$p\" ] ; then\n\t\t\tditto -X $QARCHS \"$GDAL_PREFIX/bin/$p\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\t\tfi\n\tdone\n\tglib=`otool -L \"$GDAL_PREFIX/lib/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# ***
Note: may need support files also ***\n\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJ_PREFIX/lib/libproj.dylib\" ] ; then\n\tditto -X $QARCHS \"$PROJ_PREFIX/lib/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJ_PREFIX/lib/libproj.dylib\" | grep -E -m 1 \"libproj.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\tditto -X $QARCHS \"$GEOSROOT/libgeos.dylib\" \"$GEOSROOT/libgeos_c.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/\"\n\tglib=`otool -L \"$GEOSROOT/libgeos.dylib\" | grep -E -m 1 \"libgeos.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GEOSROOT/libgeos_c.dylib\"
| grep -E -m 1 \"libgeos_c.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgeos_c.dylib\"\nfi\n\n# SQLite & SpatiaLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\tditto -X $QARCHS \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tif [ -f \"$SQLITEROOT/libspatialite.dylib\" ] ; then\n\t\tditto -X $QARCHS \"$SQLITEROOT/libspatialite.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\t\tslib=`otool -L
\"$SQLITEROOT/libspatialite.dylib\" | grep -E -m 1 \"libspatialite.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tSPATIALITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\tfi\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\tditto -X $QARCHS \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tditto -X $QARCHS \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E -m 1 \"libgslcblas.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -
change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR\"\n# clean out pyc\nfind python -name *.pyc -print0 | xargs -0 rm -f\n# python binary modules\npymodlist=`find -x python -name *.so`\nfor p in $pymodlist\ndo\n\tinstall_name_tool $GDAL_CHG $PROJ_CHG $
GEOS_CHG $SQLITE_CHG $p\ndone\n\n# change bundled progs from above bundling\n# will get error on qgis_help.app\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\nbinlist=`ls`\nfor p in $binlist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\"\ndone\n\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n\n# user bundling from bundle.sh\n\nif [ -f bundle.sh ] ; then\n\t./bundle.sh\nfi\n";
+ shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths. ***FIXME***\n\nmkdir -p \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\nQGISPYDIR=\"$QGIS_BUILD_PATH/MacOS/$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\techo \"Copying libpq...\"\n\tditto -X $QARCHS \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executab
le_path/$QGIS_LIB_SUBDIR/libpq.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDAL_PREFIX/lib/libgdal.dylib\" ] ; then\n\techo \"Copying GDAL...\"\n\tditto -X $QARCHS \"$GDAL_PREFIX/lib/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tditto -X $QARCHS \"$PYSITE/osgeo\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tfor p in gdal gdalconst gdalnumeric ogr osr\n\tdo\n\t\tditto -X $QARCHS \"$PYSITE/$p.py\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tdone\n\tfor p in $GDAL_PROGS\n\tdo\n\t\tif [ -e \"$GDAL_PREFIX/bin/$p\" ] ; then\n\t\t\tditto -X $QARCHS \"$GDAL_PREFIX/bin/$p\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\t\tfi\n\tdone\n\tglib=`otool -L \"$GDAL_PREFIX/lib/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CHG=\"-change $glib @executable_pa
th/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJ_PREFIX/lib/libproj.dylib\" ] ; then\n\techo \"Copying PROJ...\"\n\tditto -X $QARCHS \"$PROJ_PREFIX/lib/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJ_PREFIX/lib/libproj.dylib\" | grep -E -m 1 \"libproj.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\techo \"Copying GEOS...\"\n\tditto -X $QARCHS \"$GEOSROOT/libgeos.dylib\" \"$GEOSROOT/libgeos_c.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/\"\n\tglib=`otool -L \"$GEOSROOT/libgeos.dylib\" | grep -E -m 1 \"libgeos.+ \" | cut -
d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GEOSROOT/libgeos_c.dylib\" | grep -E -m 1 \"libgeos_c.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgeos_c.dylib\"\nfi\n\n# SQLite & SpatiaLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\techo \"Copying Sqlite3...\"\n\tditto -X $QARCHS \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tif [ -f \"$SQLITEROOT/libspatialite.dylib\" ] ; the
n\n\t\tditto -X $QARCHS \"$SQLITEROOT/libspatialite.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\t\tslib=`otool -L \"$SQLITEROOT/libspatialite.dylib\" | grep -E -m 1 \"libspatialite.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tSPATIALITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\tfi\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\techo \"Copying GSL...\"\n\tditto -X $QARCHS \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tditto -X $QARCHS \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E
-m 1 \"libgslcblas.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"Updating bundled library paths...\"\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\techo \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\techo \"install_name
_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR\"\n# clean out pyc\nfind python -name *.pyc -print0 | xargs -0 rm -f\n# python binary modules\npymodlist=`find -x python -name *.so`\nfor p in $pymodlist\ndo\n\techo \"install_name_tool $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG \\\"$p\\\"\"\n\tinstall_name_tool $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG \"$p\"\ndone\n\n# change bundled progs from above bundling\n# will get error on qgis_help.app\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\nbinlist=`ls`\nfor p in $binlist\ndo\n\techo \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\\\"\"\n\tinst
showEnvVarsInLog = 0;
7268C04D118294F2001BC9C4 /* Script - ui */ = {
@@ -15493,7 +15495,7 @@
- shellScript = "# Note: assumes default Qt binary framework install\n\nAPPDIRC=\"$QGIS_BUILD_PATH\" # app contents\nAPPDIR=\"$APPDIRC/MacOS\"\nFWDIR=\"$APPDIR/$QGIS_FW_SUBDIR\"\nLIBDIR=\"$APPDIR/$QGIS_LIB_SUBDIR\"\nQGISPYDIR=\"$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# qt arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\n# copy Qt frameworks\nmkdir -p \"$FWDIR\"\nfor q in $QTLISTQG\ndo\n\tif [ ! -d \"$FWDIR/$q.framework\" ] ; then\n\t\t# reconstruct framework to avoid excessive copying, then deleting\n\t\t# especially when debug variants are present\n\t\tmkdir -p \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\tln -sfh $QT_FWVER \"$FWDIR/$q.framework/Versions/Current\"\n\t\tditto -X $QARCHS \"/Library/Frameworks/$q.framework/$q\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$q\"\n\t\tln -sf Versions/Current/$q \"$FWDIR/$q.framework/$q\"\n\t\tif [ -d \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/Resources\" ] ; then\n\t\t\tcp -Rfp \"/Library
/Frameworks/$q.framework/Versions/$QT_FWVER/Resources\" \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\t\tln -sfh Versions/Current/Resources \"$FWDIR/$q.framework/Resources\"\n\t\tfi\n\t\t# debug variants\n\t\tqd=$q\"_debug\"\n\t\tif [ \"$CONFIGURATION\" = \"Debug\" ] && [ -f \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/$qd\" ] ; then\n\t\t\tditto -X $QARCHS \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/$qd\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$qd\"\n\t\t\tln -sf Versions/Current/$qd \"$FWDIR/$q.framework/$qd\"\n\t\t\tif [ -d \"/Library/Frameworks/$q.framework/$qd.dSYM\" ] ; then\n\t\t\t\tditto -X $QARCHS \"/Library/Frameworks/$q.framework/$qd.dSYM\" \"$FWDIR/$q.framework\"\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n\n# copy Qt plugins\nmkdir -p \"$APPDIRC/PlugIns/imageformats\"\nif [ ! -f \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\" ] ; then\n\tditto -X $QARCHS \"$QT_PLUGINS_DIR/imageformats/libqjpeg.dylib\" \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\nf
i\n\n# Qwt\n\nQWTROOT=\"$QWT_PREFIX/lib\"\nif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\tditto -X $QARCHS \"$QWTROOT/libqwt.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\tqlib=`otool -L \"$QWTROOT/libqwt.dylib\" | grep -E -m 1 \"libqwt.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tQWT_CHG=\"-change $qlib @executable_path/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\t# extra changes for Qt deps\n\tfor q in QtCore QtGui QtSvg\n\tdo\n\t\tqq=\"$q.framework/Versions/$QT_FWVER/$q\"\n\t\techo \"install_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\\\"\"\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\tdone\n\tinstall_name_tool $QWT_CHG \"$APPDIR/Qgis\"\nfi\n\n# PyQt path based on PYTHON_FORM\n\nif [ \"$PYSITE\" ] ; then\n\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tif [ ! -f \"$QGISPYDIR/si
p.so\" ] ; then\n\t\tditto -X $QARCHS \"$PYSITE/sip.so\" \"$QGISPYDIR/\"\n\t\tcp -fp \"$PYSITE/sipconfig.py\" \"$QGISPYDIR/\"\n\tfi\n\tfor q in $PYQTLIST\n\tdo\n\t\tif [ ! -f \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\" ] ; then\n\t\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/$q.so\" \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\"\n\t\tfi\n\tdone\n\tcp -fp \"$PYSITE/PyQt$QT_FWVER/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/\"\n\t# PyQwt\n\tif [ -d \"$PYSITE/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/_iqt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/Qwt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -fp \"$PYSITE/PyQt$QT_FWVER/Qwt5/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -Rfp \"$PYSITE/PyQt$QT_FWVER/uic\" \"$QGISPYDIR/PyQt$QT_FWVER\"\n\t\techo \"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/Py
Qt$QT_FWVER/Qwt5/_iqt.so\"\n\t\techo \"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\"\n\tfi\nfi\n\n# just in case no plugins were compiled\nmkdir -p \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\n# list plugins & libs\ncd \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls`\ncd \"$APPDIR/$QGIS_LIB_SUBDIR\"\nqgliblist=`ls *.dylib`\nif [ \"$PYSITE\" ] ; then\n\tcd \"$QGISPYDIR/qgis\"\n\tqgpylist=`ls *.so`\nfi\n\n# main Qt framework loop\n\ncd \"$APPDIR\"\n\nfor q in $QTLISTQG\ndo\n\tqq=\"$q.framework/Versions/$QT_FWVER/$q\"\n\t# app\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/Qgis\"\n\t# qgis_help qt linking done with symlinks\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\"\n\t# libs\n\tfor ql in $qgliblist\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_S
UBDIR/$qq \"$APPDIR/$QGIS_LIB_SUBDIR/$ql\"\n\tdone\n\t# plugins\n\tfor qp in $pluglist\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\"\n\tdone\n\t# qt fw\n\tfor qf in $QTLISTQG\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\"\n\tdone\n\t# qt plugs\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\n\t# PyQt\n\tif [ \"$PYSITE\" ] ; then\n\t\tfor pq in $PYQTLIST\n\t\tdo\n\t\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\"\n\t\tdone\n\t\tfor pg in $qgpylist\n\t\tdo\n\t\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/qgis/$pg\"\n\t\tdone\n\t\tif [ -d \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\t\tfor pw in _iqt Qwt\n\t\t\tdo\n\t\t\t\tinstall_name_tool -change $q
q @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\"\n\t\t\tdone\n\t\tfi\n\tfi\ndone\n";
+ shellScript = "# Note: assumes default Qt binary framework install\n\nAPPDIRC=\"$QGIS_BUILD_PATH\" # app contents\nAPPDIR=\"$APPDIRC/MacOS\"\nFWDIR=\"$APPDIR/$QGIS_FW_SUBDIR\"\nLIBDIR=\"$APPDIR/$QGIS_LIB_SUBDIR\"\nQGISPYDIR=\"$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# qt arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\n# copy Qt frameworks\necho \"Copying Qt frameworks...\"\nmkdir -p \"$FWDIR\"\nfor q in $QTLISTQG\ndo\n\tif [ ! -d \"$FWDIR/$q.framework\" ] && [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; then\n\t\t# reconstruct framework to avoid excessive copying, then deleting\n\t\t# especially when debug variants are present\n\t\tmkdir -p \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\tln -sfh $QT_FWVER \"$FWDIR/$q.framework/Versions/Current\"\n\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/$q\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$q\"\n\t\tln -sf Versions/Current/$q \"$FWDIR/$q.framework/$q\"\n\t\tif [ -d \"$QT_PREFIX_FW/$q.framework/V
ersions/$QT_FWVER/Resources\" ] ; then\n\t\t\tcp -Rfp \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/Resources\" \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\t\tln -sfh Versions/Current/Resources \"$FWDIR/$q.framework/Resources\"\n\t\tfi\n\t\t# debug variants\n\t\tqd=$q\"_debug\"\n\t\tif [ \"$CONFIGURATION\" = \"Debug\" ] && [ -f \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/$qd\" ] ; then\n\t\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/$qd\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$qd\"\n\t\t\tln -sf Versions/Current/$qd \"$FWDIR/$q.framework/$qd\"\n\t\t\tif [ -d \"$QT_PREFIX_FW/$q.framework/$qd.dSYM\" ] ; then\n\t\t\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/$qd.dSYM\" \"$FWDIR/$q.framework\"\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n\n# copy Qt plugins\nmkdir -p \"$APPDIRC/PlugIns/imageformats\"\nif [ ! -f \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\" ] ; then\n\tditto -X $QARCHS \"$QT_PLUGINS_DIR/imageformats/libqjpeg.dylib\" \"$APPDIRC/PlugIn
s/imageformats/libqjpeg.dylib\"\nfi\nmkdir -p \"$APPDIRC/PlugIns/codecs\"\nfor c in cn jp kr tw\ndo\n\tif [ ! -f \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\" ] ; then\n\t\tditto -X $QARCHS \"$QT_PLUGINS_DIR/codecs/libq$c\"\"codecs.dylib\" \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\tfi\ndone\n\n# Qwt\n\necho \"Copying Qwt and updating library paths...\"\nQWTROOT=\"$QWT_PREFIX/lib\"\nif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\tditto -X $QARCHS \"$QWTROOT/libqwt.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\tqlib=`otool -L \"$QWTROOT/libqwt.dylib\" | grep -E -m 1 \"libqwt.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tQWT_CHG=\"-change $qlib @executable_path/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\techo \"install_name_tool $QWT_CHG \\\"$APPDIR/Qgis\\\"\"\n\tinstall_name_tool $QWT_CHG \"$APPDIR/Qgis\"\nfi\n\n# PyQt path based on PYTHON_FORM\n\nif [ \"$PYSITE\" ] ; then\n\techo \"Copying PyQt library paths...\"\n\t
mkdir -p \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tif [ ! -f \"$QGISPYDIR/sip.so\" ] ; then\n\t\tditto -X $QARCHS \"$PYSITE/sip.so\" \"$QGISPYDIR/\"\n\t\tcp -fp \"$PYSITE/sipconfig.py\" \"$QGISPYDIR/\"\n\tfi\n\tfor q in $PYQTLIST\n\tdo\n\t\tif [ ! -f \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\" ] ; then\n\t\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/$q.so\" \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\"\n\t\tfi\n\tdone\n\tcp -fp \"$PYSITE/PyQt$QT_FWVER/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/\"\n\t# PyQwt\n\tif [ -d \"$PYSITE/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\techo \"Copying PyQwt and updating library paths...\"\n\t\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/_iqt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/Qwt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -fp \"$PYSITE/PyQt$QT_FWVER/Qwt5/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -Rfp \"$PYSITE/PyQt$QT_FWVER/uic\" \"$QGISPYDIR/PyQt$QT_FWVER\"\n\t\techo \
"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqt.so\"\n\t\techo \"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\"\n\tfi\nfi\n\n# just in case no plugins were compiled\nmkdir -p \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\n# list plugins & libs\ncd \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls`\ncd \"$APPDIR/$QGIS_LIB_SUBDIR\"\nqgliblist=`ls libqgis*.dylib`\nif [ \"$PYSITE\" ] ; then\n\tcd \"$QGISPYDIR/qgis\"\n\tqgpylist=`ls *.so`\nfi\n\n# main Qt framework loop\n\necho \"Updating Qt library paths...\"\n\ncd \"$APPDIR\"\n\nfor q in $QTLISTQG\ndo\n\tif [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; then\n\t\tqq=`otool -L \"$QT_PREFIX_FW/$q.framework/$q\" | grep -E -m 1 \"$q.framework.*\\(\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tq_chg=\"-change $qq @executable_path/
$QGIS_FW_SUBDIR/$q.framework/$q\"\n\t\t# app\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/Qgis\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/Qgis\"\n\t\t# qgis_help qt linking done with symlinks\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\"\n\t\t# libs\n\t\tfor ql in $qgliblist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_LIB_SUBDIR/$ql\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_LIB_SUBDIR/$ql\"\n\t\tdone\n\t\t# plugins\n\t\tfor qp in $pluglist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\"\n\t\tdone\n\t\t# qt fw\n\t\tfor qf in $QTLISTQG\n\t\tdo\n\t\t\tif [ -d \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework\" ] ; then\n\t\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_FW_S
UBDIR/$qf.framework/Versions/$QT_FWVER/$qf\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\"\n\t\t\tfi\n\t\tdone\n\t\t# qt plugs\n\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\n\t\tfor c in cn jp kr tw\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/codecs/libq$c\\\"\\\"codecs.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\t\tdone\n\t\t# Qwt\n\t\tif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\t\t\techo \"install_name_tool $q_chg \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\t\tfi\n\t\t# PyQt\n\t\tif [ \"$PYSITE\" ] ; then\n\t\t\tfor pq in $PYQTLIST\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER
/$pq.so\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\"\n\t\t\tdone\n\t\t\tfor pg in $qgpylist\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/qgis/$pg\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/qgis/$pg\"\n\t\t\tdone\n\t\t\tif [ -d \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\t\t\tfor pw in _iqt Qwt\n\t\t\t\tdo\n\t\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\\\"\"\n\t\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\"\n\t\t\t\tdone\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n";
72FB0B4B0FFD680F0052360B /* Script - ui */ = {
@@ -20509,7 +20511,7 @@
COPY_PHASE_STRIP = NO;
GCC_GENERATE_DEBUGGING_SYMBOLS = YES;
GCC_OPTIMIZATION_LEVEL = 0;
- QGIS_VERSION_BUILD = 13766;
+ QGIS_VERSION_BUILD = 13789;
STRIP_INSTALLED_PRODUCT = NO;
name = Debug;
@@ -20520,7 +20522,7 @@
buildSettings = {
COPY_PHASE_STRIP = YES;
GCC_GENERATE_DEBUGGING_SYMBOLS = NO;
STRIP_INSTALLED_PRODUCT = YES;
name = Release;
Modified: trunk/qgis/mac/xcode/ReadMe.rtf
--- trunk/qgis/mac/xcode/ReadMe.rtf 2010-06-23 12:14:45 UTC (rev 13789)
+++ trunk/qgis/mac/xcode/ReadMe.rtf 2010-06-23 14:15:07 UTC (rev 13790)
@@ -1,4 +1,4 @@
-{\rtf1\ansi\ansicpg1252\cocoartf1038\cocoasubrtf250
+{\rtf1\ansi\ansicpg1252\cocoartf1038\cocoasubrtf320
{\fonttbl\f0\fswiss\fcharset0 Helvetica;\f1\fnil\fcharset0 Monaco;}
{\colortbl;\red255\green255\blue255;}
\vieww10500\viewh12500\viewkind0
@@ -153,8 +153,28 @@
\f1\fs20 QT_VER_MAJOR
\f0\fs24 and
\f1\fs20 QT_VER_MINOR
-\f0\fs24 are the major.minor version of Qt (currently only major version is used). The default is for a binary installation of Qt 4.5. If built from source, you may need to change these.\
+\f0\fs24 are the major.minor version of Qt (currently only major version is used).
+\f1\fs20 QT_DIR
+\f0\fs24 is the prefix where the internally-used QtUiTools and QtCLucene headers are found.
+\f1\fs20 QT_DIR_SDK
+\f0\fs24 is a workaround for the default location of the QtUiTools and QtCLucene libraries (see the comment for details).
+\f1\fs20 QT_PREFIX_FW
+\f0\fs24 is the path where the frameworks are found.\
+The default is for a binary installation of Qt. If built from source, you may need to change these (
+\f1\fs20 QT_DIR
+\f0\fs24 ,
+\f0\fs24 will be the same, and
+\f0\fs24 ,
+\f1\fs20 QT_PLUGINS_DIR
+\f0\fs24 and
+\f1\fs20 QTBIN
+\f0\fs24 will be dirs off
+\f1\fs20 QT_DIR
+\f0\fs24 ).\
\f1\fs20 BISON
\f0\fs24 is the base path to Bison. If building on Tiger (not
@@ -224,16 +244,13 @@
\f1\fs20 PYQT_SIP_FLAGS
\f0\fs24 are set for a system SIP/PyQt install as described in INSTALL. They should be adjusted for other configurations. These can be found by starting Python (the desired Python for the Qgis build) in a Terminal, then:\
-\pard\tx720\tx1440\tx2160\tx2880\tx3600\tx4320\tx5040\tx5760\tx6480\tx7200\tx7920\tx8640\ql\qnatural\pardirnatural
-\f1\fs20 \cf0 import sipconfig\
+\f1\fs20 import sipconfig\
sipconfig.Configuration().sip_inc_dir\
-\cf0 import PyQt4.pyqtconfig\
+ import PyQt4.pyqtconfig\
PyQt4.pyqtconfig.Configuration().pyqt_sip_dir\
+ PyQt4.pyqtconfig.Configuration().pyqt_sip_flags\
-\cf0 PyQt4.pyqtconfig.Configuration().pyqt_sip_flags\
\f0\fs24 \cf0 \
SIP/PyQt utility programs are found with the
Modified: trunk/qgis/mac/xcode/qgis_settings.xcconfig
--- trunk/qgis/mac/xcode/qgis_settings.xcconfig 2010-06-23 12:14:45 UTC (rev 13789)
+++ trunk/qgis/mac/xcode/qgis_settings.xcconfig 2010-06-23 14:15:07 UTC (rev 13790)
@@ -36,6 +36,7 @@
// this is to enable Qt libs in /usr/lib (QtUiTools, QtCLucene) to work in SDKs
// -> create symlinks to these libs in /usr/local/lib
QT_DIR_SDK = /usr/local
+QT_PREFIX_FW = /Library/Frameworks
QT_PLUGINS_DIR = /Developer/Applications/Qt/plugins
QTBIN = /Developer/Tools/Qt
@@ -185,6 +186,7 @@
HEADER_SEARCH_PATHS = $(QGIS_HEADER_SEARCH_BASE)
ALWAYS_SEARCH_USER_PATHS = NO
USE_HEADERMAP = NO // else headers with same name cause confusion
+FRAMEWORK_SEARCH_PATHS = $(QT_PREFIX_FW)
DYLIB_CURRENT_VERSION = $(QGIS_VERSION_MAJOR).$(QGIS_VERSION_MINOR)
DYLIB_COMPATIBILITY_VERSION = $(QGIS_VERSION_MAJOR).0
@@ -222,7 +224,7 @@
// use full flags instead of Xcode includes and defs,
// since these are needed in scripts also
-QT_CXXFLAGS = -DQT_DLL -DQT_SVG_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_NO_CAST_TO_ASCII $(QTDEFS_$(CONFIGURATION)) -I/Library/Frameworks/QtCore.framework/Headers -I/Library/Frameworks/QtGui.framework/Headers -I/Library/Frameworks/QtNetwork.framework/Headers -I/Library/Frameworks/QtSql.framework/Headers -I/Library/Frameworks/QtSvg.framework/Headers -I/Library/Frameworks/QtXml.framework/Headers -I/Library/Frameworks/QtWebKit.framework/Headers
+QT_CXXFLAGS = -DQT_DLL -DQT_SVG_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_NO_CAST_TO_ASCII $(QTDEFS_$(CONFIGURATION)) -F$(QT_PREFIX_FW) -I$(QT_PREFIX_FW)/QtCore.framework/Headers -I$(QT_PREFIX_FW)/QtGui.framework/Headers -I$(QT_PREFIX_FW)/QtNetwork.framework/Headers -I$(QT_PREFIX_FW)/QtSql.framework/Headers -I$(QT_PREFIX_FW)/QtSvg.framework/Headers -I$(QT_PREFIX_FW)/QtXml.framework/Headers -I$(QT_PREFIX_FW)/QtWebKit.framework/Headers
QT_INC_UITOOLS = $(QT_DIR)/include/QtUiTools
QTDEFS_Debug = -DQT_DEBUG
QTDEFS_Release = -DQT_NO_DEBUG
Modified: trunk/qgis/mac/xcode/qgis_user-template.xcconfig
--- trunk/qgis/mac/xcode/qgis_user-template.xcconfig 2010-06-23 12:14:45 UTC (rev 13789)
+++ trunk/qgis/mac/xcode/qgis_user-template.xcconfig 2010-06-23 14:15:07 UTC (rev 13790)
@@ -29,6 +29,7 @@
//QT_DIR_SDK = /usr/local
+//QT_PREFIX_FW = /Library/Frameworks
//QT_PLUGINS_DIR = /Developer/Applications/Qt/plugins
//QTBIN = /Developer/Tools/Qt // bin dir
@@ -140,6 +141,8 @@
//QWT_PREFIX_shared = /usr/local/qwt-$(QWT_VERSION)
//QWT_PREFIX_static = $(QWT_PREFIX_shared)
+//PYTHON_USRBIN = $(PYTHON_USRBIN_$(PYTHON_FORM)) // User-installed executables
// do not change these unless you have a very odd layout for them
// or they just aren't coming out right in Xcode
@@ -177,7 +180,6 @@
//PYTHON_PREFIX = $(PYTHON_PREFIX_$(PYTHON_FORM))/Versions/$(PYTHON_VERSION)
//PYTHON_BIN = $(PYTHON_BIN_$(PYTHON_FORM)) // Python executables
-//PYTHON_USRBIN = $(PYTHON_USRBIN_$(PYTHON_FORM)) // User-installed executables
//PYTHON_INC = $(PYTHON_PREFIX)/Headers
//PYTHON_LIB = -framework Python // must always be framework, full path will work
//PYSITE = $(PYSITE_$(PYTHON_FORM)) // site-packages
