[QGIS Commit] r13791 - in branches/threading-branch/src: app core
svn_qgis at osgeo.org
Wed Jun 23 12:01:32 EDT 2010
Author: wonder
Date: 2010-06-23 16:01:32 +0000 (Wed, 23 Jun 2010)
New Revision: 13791
branches/threading-branch/src/app/qgisapp.cpp
branches/threading-branch/src/core/qgsmaprenderer.cpp
branches/threading-branch/src/core/qgsmaprenderer.h
Revived rendering progress bar, stop rendering button moved to right side of the progress bar and made visible only while rendering.
Removed a bunch of blockers for actions that can be safely triggered also when rendering is active.
Modified: branches/threading-branch/src/app/qgisapp.cpp
--- branches/threading-branch/src/app/qgisapp.cpp 2010-06-23 14:15:07 UTC (rev 13790)
+++ branches/threading-branch/src/app/qgisapp.cpp 2010-06-23 16:01:32 UTC (rev 13791)
@@ -528,6 +528,7 @@
mLastComposerId = 0;
mLBL = new QgsPalLabeling();
mMapCanvas->mapRenderer()->setLabelingEngine( mLBL );
+ QgsDebugMsg("\nInit done\n");
} // QgisApp ctor
@@ -1703,6 +1704,17 @@
mProgressBar->setWhatsThis( tr( "Progress bar that displays the status "
"of rendering layers and other time-intensive operations" ) );
statusBar()->addPermanentWidget( mProgressBar, 1 );
+ //stop rendering status bar widget
+ mStopRenderButton = new QToolButton( statusBar() );
+ mStopRenderButton->setMaximumWidth( 20 );
+ mStopRenderButton->setMaximumHeight( 20 );
+ mStopRenderButton->setIcon( getThemeIcon( "mIconDelete.png" ) );
+ mStopRenderButton->setToolTip( tr( "Stop map rendering" ) );
+ mStopRenderButton->hide();
+ statusBar()->addPermanentWidget( mStopRenderButton, 0 );
// Bumped the font up one point size since 8 was too
// small on some platforms. A point size of 9 still provides
// plenty of display space on 1024x768 resolutions
@@ -1777,13 +1789,7 @@
statusBar()->addPermanentWidget( mScaleEdit, 0 );
connect( mScaleEdit, SIGNAL( editingFinished() ), this, SLOT( userScale() ) );
- //stop rendering status bar widget
- mStopRenderButton = new QToolButton( statusBar() );
- mStopRenderButton->setMaximumWidth( 20 );
- mStopRenderButton->setMaximumHeight( 20 );
- mStopRenderButton->setIcon( getThemeIcon( "mIconDelete.png" ) );
- mStopRenderButton->setToolTip( tr( "Stop map rendering" ) );
- statusBar()->addPermanentWidget( mStopRenderButton, 0 );
+ /* Not necessary anymore! rendering doesn't block GUI.
// render suppression status bar widget
mRenderSuppressionCBox = new QCheckBox( tr( "Render" ), statusBar() );
mRenderSuppressionCBox->setChecked( true );
@@ -1794,6 +1800,8 @@
"to add a large number of layers and symbolize them before rendering." ) );
mRenderSuppressionCBox->setToolTip( tr( "Toggle map rendering" ) );
statusBar()->addPermanentWidget( mRenderSuppressionCBox, 0 );
// On the fly projection status bar icon
// Changed this to a tool button since a QPushButton is
// sculpted on OS X and the icon is never displayed [gsherman]
@@ -1962,8 +1970,8 @@
mActionZoomLast, SLOT( setEnabled( bool ) ) );
connect( mMapCanvas, SIGNAL( zoomNextStatusChanged( bool ) ),
mActionZoomNext, SLOT( setEnabled( bool ) ) );
- connect( mRenderSuppressionCBox, SIGNAL( toggled( bool ) ),
- mMapCanvas, SLOT( setRenderFlag( bool ) ) );
+ //connect( mRenderSuppressionCBox, SIGNAL( toggled( bool ) ),
+ // mMapCanvas, SLOT( setRenderFlag( bool ) ) );
// connect renderer
connect( mMapCanvas->mapRenderer(), SIGNAL( drawingProgress( int, int ) ),
@@ -2526,10 +2534,6 @@
void QgisApp::addVectorLayer()
- if ( mMapCanvas && mMapCanvas->isDrawing() )
- return;
mMapCanvas->freeze();
QgsOpenVectorLayerDialog *ovl = new QgsOpenVectorLayerDialog( this );
@@ -2546,8 +2550,7 @@
mMapCanvas->freeze( false );
delete ovl;
- // update UI
- qApp->processEvents();
@@ -2633,9 +2636,6 @@
- // update UI
// draw the map
mMapCanvas->refresh();
@@ -2718,10 +2718,6 @@
#else
void QgisApp::addDatabaseLayer()
- return;
// only supports postgis layers at present
// show the postgis dialog
@@ -2776,9 +2772,6 @@
delete dbs;
- // update UI
// draw the map
@@ -2795,11 +2788,6 @@
#else
void QgisApp::addSpatiaLiteLayer()
- return;
// show the SpatiaLite dialog
QgsSpatiaLiteSourceSelect *dbs = new QgsSpatiaLiteSourceSelect( this );
@@ -2854,9 +2842,6 @@
delete dbs;
- // update UI
// draw the map
@@ -2869,10 +2854,6 @@
void QgisApp::addWmsLayer()
- return;
// Fudge for now
QgsDebugMsg( "about to addRasterLayer" );
@@ -2906,10 +2887,8 @@
//as file new but accepts flags to indicate whether we should prompt to save
void QgisApp::fileNew( bool thePromptToSaveFlag )
- return;
+ // make sure no rendering is going on
+ mMapCanvas->cancelRendering();
if ( thePromptToSaveFlag )
@@ -2924,7 +2903,6 @@
mMapCanvas->freeze( true );
removeAllLayers();
- mMapCanvas->clear();
QgsProject* prj = QgsProject::instance();
prj->title( QString::null );
@@ -2978,11 +2956,6 @@
void QgisApp::newVectorLayer()
- return;
QgsNewVectorLayerDialog geomDialog( this );
if ( geomDialog.exec() == QDialog::Rejected )
@@ -3078,10 +3051,6 @@
#ifdef HAVE_SPATIALITE
void QgisApp::newSpatialiteLayer()
- return;
QgsNewSpatialiteLayerDialog spatialiteDialog( this );
spatialiteDialog.exec();
@@ -3089,10 +3058,8 @@
void QgisApp::fileOpen()
- return;
// possibly save any pending work before opening a new project
if ( saveDirty() )
@@ -3206,11 +3173,6 @@
bool QgisApp::fileSave()
- return false;
// if we don't have a file name, then obviously we need to get one; note
// that the project file name is reset to null in fileNew()
QFileInfo fullPath;
@@ -3284,11 +3246,6 @@
void QgisApp::fileSaveAs()
- return;
// Retrieve last used project dir from persistent settings
QSettings settings;
QString lastUsedDir = settings.value( "/UI/lastProjectDir", "." ).toString();
@@ -3400,11 +3357,6 @@
void QgisApp::newPrintComposer()
- return;
createNewComposer();
@@ -4321,15 +4273,6 @@
void QgisApp::deselectAll()
- if ( !mMapCanvas || mMapCanvas->isDrawing() )
- return;
- // Turn off rendering to improve speed.
- bool renderFlagState = mMapCanvas->renderFlag();
- mMapCanvas->setRenderFlag( false );
QMap<QString, QgsMapLayer*> layers = QgsMapLayerRegistry::instance()->mapLayers();
for ( QMap<QString, QgsMapLayer*>::iterator it = layers.begin(); it != layers.end(); it++ )
@@ -4340,8 +4283,7 @@
vl->removeSelection();
- // Turn on rendering (if it was on previously)
- mMapCanvas->setRenderFlag( renderFlagState );
+ mMapCanvas->refresh();
void QgisApp::addVertex()
@@ -4543,9 +4485,6 @@
void QgisApp::layerSubsetString()
- return;
QgsVectorLayer *vlayer = qobject_cast<QgsVectorLayer *>( activeLayer() );
if ( !vlayer )
return;
@@ -4768,11 +4707,6 @@
void QgisApp::removeLayer()
- return;
QgsMapLayer *layer = activeLayer();
if ( !layer )
@@ -5148,11 +5082,6 @@
QgsVectorLayer* QgisApp::addVectorLayer( QString vectorLayerPath, QString baseName, QString providerKey )
- return NULL;
// Let render() do its own cursor management
@@ -5186,9 +5115,6 @@
return NULL;
- // update UI
// draw the map
@@ -5224,9 +5150,6 @@
tr( "The layer is not a valid layer and can not be added to the map" ) );
- // update UI
// draw the map
@@ -5444,6 +5367,7 @@
mProgressBar->reset();
mProgressBar->hide();
else
@@ -5451,6 +5375,8 @@
if ( !mProgressBar->isVisible() )
mProgressBar->show();
+ if (mMapCanvas->mapRenderer()->isDrawing())
+ mStopRenderButton->show();
mProgressBar->setMaximum( theTotalSteps );
mProgressBar->setValue( theProgress );
@@ -6035,11 +5961,6 @@
// this is a slot for action from GUI to add raster layer
void QgisApp::addRasterLayer()
- return;
QString fileFilters;
QStringList selectedFiles;
@@ -6066,11 +5987,6 @@
bool QgisApp::addRasterLayer( QgsRasterLayer *theRasterLayer )
- return false;
Q_CHECK_PTR( theRasterLayer );
if ( ! theRasterLayer )
@@ -6105,11 +6021,6 @@
QgsRasterLayer* QgisApp::addRasterLayer( QString const & rasterFile, QString const & baseName, bool guiWarning )
- return NULL;
// let the user know we're going to possibly be taking a while
QApplication::setOverrideCursor( Qt::WaitCursor );
@@ -6175,11 +6086,6 @@
QgsDebugMsg( "about to get library for " + providerKey );
- return 0;
@@ -6217,8 +6123,6 @@
- // update UI
// draw the map
@@ -6234,11 +6138,6 @@
//create a raster layer object and delegate to addRasterLayer(QgsRasterLayer *)
bool QgisApp::addRasterLayers( QStringList const &theFileNameQStringList, bool guiWarning )
- return false;
if ( theFileNameQStringList.empty() )
// no files selected so bail out, but
@@ -6363,11 +6262,6 @@
void QgisApp::customProjection()
- return;
// Create an instance of the Custom Projection Designer modeless dialog.
// Autodelete the dialog when closing since a pointer is not retained.
QgsCustomProjectionDialog * myDialog = new QgsCustomProjectionDialog( this );
Modified: branches/threading-branch/src/core/qgsmaprenderer.cpp
--- branches/threading-branch/src/core/qgsmaprenderer.cpp 2010-06-23 14:15:07 UTC (rev 13790)
+++ branches/threading-branch/src/core/qgsmaprenderer.cpp 2010-06-23 16:01:32 UTC (rev 13791)
@@ -68,6 +68,8 @@
mLabelingEngine = NULL;
+ connect(QgsMapLayerRegistry::instance(), SIGNAL(layerWillBeRemoved(QString)), this, SLOT(handleLayerRemoval(QString)));
//connect(&mFW, SIGNAL(finished()), SLOT(futureFinished()));
@@ -415,24 +417,27 @@
// Now do the call to the layer that actually does
// the rendering work!
- connect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
+ // onDrawingProgress() does nothing
+ //connect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
if ( !mThreadingEnabled )
renderLayerNoThreading( ml );
else
renderLayerThreading( ml );
- disconnect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
+ //disconnect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
if ( mThreadingEnabled )
QgsDebugMsg("STARTING THREADED RENDERING!");
- //QtConcurrent::blockingMap(layers, _renderLayerThreading);
+ connect(&mFW, SIGNAL(progressValueChanged(int)), this, SLOT(futureProgress(int)));
+ emit drawingProgress(0, mThreadedJobs.count());
mFuture = QtConcurrent::map(mThreadedJobs, _renderLayerThreading);
mFW.setFuture(mFuture);
@@ -455,6 +460,12 @@
return i;
+void QgsMapRenderer::futureProgress(int value)
+ QgsDebugMsg(QString("future progress: %1/%2").arg(value).arg(mFW.progressMaximum()));
+ emit drawingProgress(value, mThreadedJobs.count());
void QgsMapRenderer::futureFinished()
QgsDebugMsg("THREADED RENDERING FINISHED!");
@@ -473,7 +484,10 @@
QgsDebugMsg("THREADED RENDERING DONE!");
disconnect(&mFW, SIGNAL(finished()), this, SLOT(futureFinished()));
+ disconnect(&mFW, SIGNAL(progressValueChanged(int)), this, SLOT(futureProgress(int)));
+ emit drawingProgress(1,1);
QPainter painter;
painter.begin(&i);
mRenderContext.setPainter(&painter);
@@ -785,7 +799,7 @@
// TODO: emit signal with progress
// QgsDebugMsg(QString("onDrawingProgress: %1 / %2").arg(current).arg(total));
- emit updateMap();
+ //emit updateMap();
@@ -1396,6 +1410,18 @@
+void QgsMapRenderer::handleLayerRemoval(QString layerId)
+ if (mLayerSet.contains(layerId))
+ // make sure that the layer won't be used in further rendering
+ if (isDrawing())
+ cancelThreadedRendering();
+ mLayerSet.removeAll(layerId);
QgsMapRendererCache::QgsMapRendererCache()
Modified: branches/threading-branch/src/core/qgsmaprenderer.h
--- branches/threading-branch/src/core/qgsmaprenderer.h 2010-06-23 14:15:07 UTC (rev 13790)
+++ branches/threading-branch/src/core/qgsmaprenderer.h 2010-06-23 16:01:32 UTC (rev 13791)
@@ -288,6 +288,7 @@
void destinationSrsChanged();
+ //! @note not used anymore
void updateMap();
void mapUnitsChanged();
@@ -298,12 +299,18 @@
public slots:
//! called by signal from layer current being drawn
+ //! @note currently does nothing
void onDrawingProgress( int current, int total );
void futureFinished();
+ void futureProgress(int value);
void clearLayerCache();
+ //! called to map layer registry
+ void handleLayerRemoval(QString layerId);
protected:
//! adjust extent to fit the pixmap size
