[QGIS Commit] r13804 - trunk/qgis/i18n
svn_qgis at osgeo.org
Fri Jun 25 20:13:32 EDT 2010
Author: borysiasty
Date: 2010-06-26 00:13:32 +0000 (Sat, 26 Jun 2010)
New Revision: 13804
trunk/qgis/i18n/qgis_pl_PL.ts
translation update: pl by Robert
Modified: trunk/qgis/i18n/qgis_pl_PL.ts
--- trunk/qgis/i18n/qgis_pl_PL.ts 2010-06-24 21:53:38 UTC (rev 13803)
+++ trunk/qgis/i18n/qgis_pl_PL.ts 2010-06-26 00:13:32 UTC (rev 13804)
@@ -6,7 +6,7 @@
<message>
<location filename="../src/gui/symbology-ng/characterwidget.cpp" line="111"/>
<source><p>Character: <span style="font-size: 24pt; font-family: %1%2</span><p>Value: 0x%3"></source>
- <translation type="unfinished"></translation>
+ <translation><p>Znak: <span style="font-size: 24pt; font-family: %1%2</span><p>Value: 0x%3"></translation>
</message>
</context>
<context>
@@ -295,7 +295,7 @@
<message>
<location filename="../python/plugins/fTools/tools/frmGeoprocessing.ui" line="262"/>
<source>Segments to approximate</source>
+ <translation>Segmentów aproksymacji</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmIntersectLines.ui" line="16"/>
@@ -886,7 +886,7 @@
<message>
<location filename="../python/plugins/fTools/tools/frmVectorSplit.ui" line="45"/>
<source>Output folder</source>
- <translation>Kartoteka wyjściowa</translation>
+ <translation>Katalog wyjściowy</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmVisual.ui" line="17"/>
@@ -1325,7 +1325,7 @@
<message>
<location filename="../python/plugins/fTools/tools/frmMergeShapes.ui" line="20"/>
<source>Input directory</source>
- <translation>Kartoteka źródłowa</translation>
+ <translation>Katalog źródłowa</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmMergeShapes.ui" line="62"/>
@@ -1366,17 +1366,17 @@
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="20"/>
<source>Symbol preview</source>
+ <translation>Podgląd symbolu</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="31"/>
<source>Symbol layer type</source>
+ <translation>Typ symbolu</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="100"/>
<source>Symbol layers</source>
+ <translation>Warstwy symbolu</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="125"/>
@@ -1463,188 +1463,190 @@
<name>GdalTools</name>
<message>
<source>&Input directory:</source>
+ <translation>Katalog źródłowy:</translation>
</message>
<message>
<source>&Output directory:</source>
+ <translation>Katalog docelowy:</translation>
</message>
<message>
<source>The process failed to start. Either the invoked program is missing, or you may have insufficient permissions to invoke the program.</source>
+ <translation>Nie powiodło się uruchomienie procesu. Brak wywoływanego programu lub brak uprawnień do jego uruchomienia.</translation>
</message>
<message>
<source>The process crashed some time after starting successfully.</source>
+ <translation>Proces został uruchomiony, lecz nie zakończył się powodzeniem.</translation>
</message>
<message>
<source>An unknown error occurred.</source>
+ <translation>Wystąpił nieznany błąd.</translation>
</message>
<message>
<source>The selected file is not a supported OGR format</source>
+ <translation>Wybrany plik nie jest wspieranym formatem OGR</translation>
</message>
<message>
<source>Quantum GIS version detected: </source>
- <translation type="unfinished">Wykryto wersję Quantum GIS:</translation>
+ <translation>Wykryto wersję Quantum GIS:</translation>
</message>
<message>
<source>This version of Gdal Tools requires at least QGIS version 1.0.0
Plugin will not be enabled.</source>
+ <translation>Ta wersja GDAL Tools wymaga przynajmniej QGIS w wersji 1.0.0
+Wtyczka nie zostanie włączona.</translation>
</message>
<message>
<source>&Raster</source>
+ <translation>&Raster</translation>
</message>
<message>
<source>Build Virtual Raster (catalog)</source>
+ <translation>Wirtualny raster (VRT)</translation>
</message>
<message>
<source>Builds a VRT from a list of datasets</source>
+ <translation>Zbuduj wirtualny raster (VRT) z listy plików</translation>
</message>
<message>
<source>Contour</source>
+ <translation>Warstwice</translation>
</message>
<message>
<source>Builds vector contour lines from a DEM</source>
+ <translation>Generuje warstwice wektorowe z DEM</translation>
</message>
<message>
<source>Rasterize</source>
+ <translation>Rasteryzuj</translation>
</message>
<message>
<source>Burns vector geometries into a raster</source>
+ <translation>Wpisuje obiekty wektorowe na raster</translation>
</message>
<message>
<source>Polygonize</source>
+ <translation>Poligonizuj</translation>
</message>
<message>
<source>Produces a polygon feature layer from a raster</source>
+ <translation>Generuje obiekty poligonowe z rastra</translation>
</message>
<message>
<source>Merge</source>
- <translation type="unfinished">Połącz</translation>
+ <translation>Złącz</translation>
</message>
<message>
<source>Build a quick mosaic from a set of images</source>
+ <translation>Generuje szybką mozaikę z podanych obrazów</translation>
</message>
<message>
<source>Sieve</source>
+ <translation>Sieve</translation>
</message>
<message>
<source>Removes small raster polygons</source>
+ <translation>Usuwa małe poligony rastrowe</translation>
</message>
<message>
<source>Proximity</source>
+ <translation>Sąsiedztwo</translation>
</message>
<message>
<source>Produces a raster proximity map</source>
+ <translation>Generuje rastrową mapę sąsiedztwa</translation>
</message>
<message>
<source>Near black</source>
+ <translation>Prawie czarne/białe</translation>
</message>
<message>
<source>Convert nearly black/white borders to exact value</source>
+ <translation>Konwertuje prawie czarne/białe na skrajne wartości</translation>
</message>
<message>
<source>Warp</source>
+ <translation type="unfinished">Reprojekcja</translation>
</message>
<message>
<source>Warp an image into a new coordinate system</source>
+ <translation type="unfinished">Dokonaje reprojekcji obrazu do nowego układu współrzędnych</translation>
</message>
<message>
<source>Grid</source>
- <translation type="unfinished">Siatka</translation>
+ <translation>Siatka</translation>
</message>
<message>
<source>Create raster from the scattered data</source>
+ <translation>Tworzy raster z rozproszonych punktów</translation>
</message>
<message>
<source>Translate</source>
+ <translation type="unfinished">Konwertuj układ</translation>
</message>
<message>
<source>Converts raster data between different formats</source>
+ <translation type="unfinished">Konwertuje układ współrzędnych map rastrowych</translation>
</message>
<message>
<source>Information</source>
+ <translation>Informacja</translation>
</message>
<message>
<source>Lists information about raster dataset</source>
+ <translation>Wyświetla informacje o zbiorze rastrowym</translation>
</message>
<message>
<source>Assign projection</source>
+ <translation>Przypisz odwzorowanie</translation>
</message>
<message>
<source>Add projection info to the raster</source>
+ <translation>Dodaje do rastra informacje o odwzorowaniu</translation>
</message>
<message>
<source>Build overviews</source>
+ <translation>Generuj podgląd</translation>
</message>
<message>
<source>Builds or rebuilds overview images</source>
+ <translation>Generuje lub re-generuje podgląd obrazu</translation>
</message>
<message>
<source>Clipper</source>
+ <translatorcomment>termin z GIMPa</translatorcomment>
+ <translation>Kadrowanie</translation>
</message>
<message>
<source>RGB to PCT</source>
+ <translation>RGB na PCT</translation>
</message>
<message>
<source>Convert a 24bit RGB image to 8bit paletted</source>
+ <translation>Konwertuj 24-bitowe obraz RGB do palety 8-bitowej</translation>
</message>
<message>
<source>PCT to RGB</source>
+ <translation>PCT na RGB</translation>
</message>
<message>
<source>Convert an 8bit paletted image to 24bit RGB</source>
+ <translation>Konwertuj 8-bitową paletę obrazu na 24-bitowe RGB</translation>
</message>
<message>
<source>GdalTools settings</source>
+ <translation>Ustawienia GdalTools</translation>
</message>
<message>
<source>Various settings for Gdal Tools</source>
+ <translation>Ustawienia GDAL Tools</translation>
</message>
<message>
<source>About GdalTools</source>
+ <translation>O GDAL Tools</translation>
</message>
<message>
<source>Displays information about Gdal Tools</source>
+ <translation>Wyświetl informację o GDAL Tools</translation>
</message>
</context>
<context>
@@ -1652,17 +1654,17 @@
<message>
<location filename="../python/plugins/GdalTools/tools/dialogAbout.ui" line="14"/>
<source>About Gdal Tools</source>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogAbout.ui" line="27"/>
<source>GDAL Tools</source>
+ <translation>GDAL Tools</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogAbout.ui" line="40"/>
<source>Version x.x-xxxxxx</source>
- <translation type="unfinished">Wersja x.x-xxxxxx</translation>
+ <translation>Wersja x.x-xxxxxx</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogAbout.ui" line="99"/>
@@ -1671,22 +1673,27 @@
p, li { white-space: pre-wrap; }
</style></head><body style=" font-family:'Sans'; font-size:10pt; font-weight:400; font-style:normal;">
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></body></html></source>
+ <translation><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><meta name="qrichtext" content="1" /><style type="text/css">
+p, li { white-space: pre-wrap; }
+</style></head><body style=" font-family:'Sans'; font-size:10pt; font-weight:400; font-style:normal;">
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></body></html></translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogAbout.ui" line="115"/>
<source>Web</source>
- <translation type="unfinished">Sieć</translation>
+ <translation>W internecie</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogAbout.ui" line="122"/>
<source>Close</source>
- <translation type="unfinished">Zamknij</translation>
+ <translation>Zamknij</translation>
</message>
<message>
<source>
(using GDAL v. %1)</source>
+ <translation>
+(oparta na GDAL v. %1)</translation>
</message>
<message>
<source>GDAL Tools (AKA Raster Tools) is a plugin for QuantumGIS aiming at making life simpler for users of GDAL Utilities, providing a simplified graphical interface for most commonly used programs.
@@ -1709,66 +1716,87 @@
HOMEPAGE:
http://trac.faunalia.it/GdalTools-plugin</source>
+ <translation>GDAL Tools (AKA Raster Tools) to wtyczka do Quantum GIS do łatwego wykorzystania narzędzi biblioteki GDAL, udostępniająca prosty interfejs graficzny dla najczęściej używanych programół.
+Wtyczka została stworzona przez Faunalia (http://faunalia.it) z pomocą GIS-lab (http://gis-lab.info).
+Ikony - Robert Szczepanek.
+Dziękujemy Silvio Grosso za wsparcie finansowe.
+Prosimy o pomoc przy testowaniu narzędzi, raportowaniu ewentualnych błędów, doskonaleniu kodu lub wsparcie finansowe.
+PROGRAMIŚCI:
+ Faunalia
+ Paolo Cavallini
+ Giuseppe Sucameli
+ Lorenzo Masini
+ GIS-lab
+ Maxim Dubinin
+ Alexander Bruy
+ikony - Robert Szczepanek
+STRONA PROJEKTU:
+http://trac.faunalia.it/GdalTools-plugin</translation>
</message>
</context>
<context>
<name>GdalToolsBaseBatchWidget</name>
<message>
<source>Finished</source>
+ <translation>Zakończono</translation>
</message>
<message>
<source>Operation completed.</source>
+ <translation>Zakończono operację.</translation>
</message>
<message>
<source>Warning</source>
- <translation type="unfinished">Ostrzeżenie</translation>
+ <translation>Ostrzeżenie</translation>
</message>
<message>
<source>The following files were not created:
%1</source>
+ <translation>Następujące pliki nie zostały utworzone:
+%1</translation>
</message>
</context>
<context>
<name>GdalToolsBaseDialog</name>
<message>
</message>
<message>
<source>The command is still running.
Do you want terminate it anyway?</source>
+ <translation>Polecenie jest nadal aktywne.
+Czy chcesz je zakończyć mimo wszystko?</translation>
</message>
<message>
<source>Invalid parameters.</source>
+ <translation>Niepoprawne parametry.</translation>
</message>
</context>
<context>
<name>GdalToolsBasePluginWidget</name>
<message>
</message>
<message>
<source>No output file created.</source>
+ <translation>Nie utworzono pliku wynikowego.</translation>
</message>
<message>
</message>
<message>
<source>Elaboration completed.</source>
</message>
<message>
<source>%1 not created.</source>
+ <translation>%1 nie utworzono.</translation>
</message>
</context>
<context>
@@ -1776,32 +1804,32 @@
<message>
<location filename="../python/plugins/GdalTools/tools/dialogBase.ui" line="14"/>
<source>Dialog</source>
- <translation type="unfinished">Ustawienia</translation>
+ <translation>Ustawienia</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogBase.ui" line="30"/>
<source>&Load into canvas when finished</source>
+ <translation>&Wyświetl po zakończeniu</translation>
</message>
<message>
<source>Select the input file for Proximity</source>
+ <translation>Wybierz plik wejściowy</translation>
</message>
<message>
<source>Select the raster file to save the results to</source>
+ <translation>Wybierz plik rastrowy do zapisania wyników</translation>
</message>
<message>
<source>Select the input file for Near Black</source>
</message>
<message>
<source>Select the input file for Grid</source>
</message>
<message>
</message>
<message>
<source>Warning: CRS information for all raster in subfolders will be rewritten. Are you sure?</source>
@@ -1809,115 +1837,115 @@
</message>
<message>
<source>Select the file to analyse</source>
+ <translation>Wybierz plik do analizy</translation>
</message>
<message>
<source>Select the input directory with files to Assign projection</source>
+ <translation>Wybierz katalog z plikami do przypisania odwzorowania</translation>
</message>
<message>
</message>
<message>
<source>This raster already found in map canvas</source>
+ <translation>Ten raster już jest dodany do mapy</translation>
</message>
<message>
<source>Select the files for VRT</source>
+ <translation>Wybierz pliki do VRT</translation>
</message>
<message>
<source>Select where to save the VRT</source>
+ <translation>Podaj gdzie zapisać VRT</translation>
</message>
<message>
<source>VRT (*.vrt)</source>
+ <translation>VRT (*.vrt)</translation>
</message>
<message>
<source>Select the input file for Warp</source>
</message>
<message>
<source>Select the input directory with files to Warp</source>
+ <translation>Wybierz katalog wejściowy z plikami</translation>
</message>
<message>
<source>Select the output directory to save the results to</source>
+ <translation>Wybierz katalog docelowy do zapisania wyników</translation>
</message>
<message>
<source>Select the input file for Sieve</source>
</message>
<message>
<source>Select the files to Merge</source>
+ <translation>Wybierz pliki</translation>
</message>
<message>
<source>Select where to save the Merge output</source>
</message>
<message>
<source>Select the input file for convert</source>
</message>
<message>
<source>Select the input file for Polygonize</source>
</message>
<message>
<source>Select where to save the Polygonize output</source>
</message>
<message>
<source>Select the input file for Contour</source>
</message>
<message>
<source>Select where to save the Contour output</source>
</message>
<message>
<source>No active raster layers. You must add almost one raster layer to continue.</source>
+ <translation>Brak aktywnych warstw rastrowych. Należy dodać przynajmniej jedną.</translation>
</message>
<message>
<source>Select the input file for Translate</source>
</message>
<message>
<source>Select the input directory with files to Translate</source>
</message>
<message>
<source>Convert paletted image to RGB</source>
+ <translation>Konwertuj paletę obrazu do RGB</translation>
</message>
<message>
<source>Band to convert:</source>
+ <translation>Kanał do konwersji:</translation>
</message>
<message>
<source>Select the input file for Rasterize</source>
</message>
<message>
<source>Copy</source>
+ <translation>Kopiuj</translation>
</message>
<message>
<source>Copy all</source>
+ <translation>Kopiuj wszystko</translation>
</message>
<message>
<source>Select the input file</source>
</message>
<message>
<source>Select the input directory with files</source>
</message>
</context>
<context>
@@ -1925,22 +1953,22 @@
<message>
<location filename="../python/plugins/GdalTools/tools/optionsTable.ui" line="45"/>
<source>Name</source>
+ <translation>Nazwa</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/optionsTable.ui" line="50"/>
<source>Value</source>
- <translation type="unfinished">Wartość</translation>
+ <translation>Wartość</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/optionsTable.ui" line="60"/>
<source>Add</source>
- <translation type="unfinished">Dodaj</translation>
+ <translation>Dodaj</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/optionsTable.ui" line="67"/>
<source>Remove</source>
+ <translation>Usuń</translation>
</message>
</context>
<context>
@@ -1948,12 +1976,12 @@
<message>
<location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="14"/>
<source>Gdal Tools settings</source>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="20"/>
<source>Path to the GDAL binaries</source>
+ <translation>Ścieżka do plików binarnych GDAL</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="32"/>
@@ -1961,26 +1989,26 @@
<location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="94"/>
<location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="125"/>
<source>Browse</source>
+ <translation>Przeglądaj</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="44"/>
<source>GDAL data path</source>
+ <translation>GDAL - ścieżka do danych</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="75"/>
<source>GDAL driver path</source>
+ <translation>GDAL - ścieżka do sterownika</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/dialogSettings.ui" line="106"/>
<source>GDAL pymod path</source>
+ <translation>GDAL - ścieżka do pymod</translation>
</message>
<message>
<source>Select directory with GDAL executables</source>
+ <translation>Wskaż ścieżkę z plikami wykonywalnymi GDAL</translation>
</message>
</context>
<context>
@@ -1988,13 +2016,13 @@
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="20"/>
<source>Build Virtual Raster</source>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="31"/>
<location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="28"/>
<source>&Input files:</source>
+ <translation>Pliki ź&ródłowe:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="53"/>
@@ -2030,7 +2058,7 @@
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="122"/>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="150"/>
<source>Select...</source>
+ <translation>Wybierz...</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="62"/>
@@ -2044,127 +2072,127 @@
<location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="72"/>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="72"/>
<source>&Output file:</source>
+ <translation>Plik &wynikowy:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="110"/>
<source>Highest</source>
+ <translation>Najwyższa</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="115"/>
<source>Average</source>
- <translation type="unfinished">Średnia</translation>
+ <translation>Średnia</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="120"/>
<source>Lowest</source>
+ <translation>Najniższa</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="93"/>
<source>&Resolution:</source>
+ <translation>&Rozdzielczość:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="128"/>
<source>&Source No Data:</source>
+ <translation>&Oznaczenie braku danych:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="59"/>
<location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="90"/>
<source>&No data value:</source>
+ <translation>Oznaczenie &braku danych:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="75"/>
<source>Re-Enable Clipping</source>
+ <translation>Ponowne kadrowanie</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="84"/>
<source>Select the extent by drag & drop on canvas</source>
+ <translation>Wskaż zakres na mapie (drag&drop)</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="91"/>
<source>or change the extent coordinates:</source>
+ <translation>lub wpisz współrzędne:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="102"/>
<source>1:</source>
- <translation type="unfinished">1:</translation>
+ <translation>1:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="113"/>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="178"/>
<source>x</source>
- <translation type="unfinished">x</translation>
+ <translation>x</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="130"/>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="195"/>
<source>y</source>
- <translation type="unfinished">y</translation>
+ <translation>y</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="167"/>
<source>2:</source>
- <translation type="unfinished">2:</translation>
+ <translation>2:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="218"/>
<location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="123"/>
<source>Grab pseudocolor table from the first image</source>
+ <translation>Paleta kolorów z pierwszego obrazu</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="28"/>
<location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="28"/>
<source>&Input file (raster):</source>
+ <translation>Plik źró&dłowy (raster):</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="65"/>
<source>&Output directory for contour lines (shapefile):</source>
+ <translation>&Katalog docelowy dla warstwic:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="124"/>
<source>&Attribute name:</source>
+ <translation>Nazwa &atrybutu:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="142"/>
<source>If not provided, no elevation attribute is attached.</source>
+ <translation>Jeśli nie podano - atrybut wysokości nie zostanie dołączony.</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="156"/>
<source>ELEV</source>
+ <translation>ELEV</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetContour.ui" line="96"/>
<source>I&nterval between contour lines:</source>
+ <translation>&Cięcie warstwicowe:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="20"/>
<source>Convert RGB image to paletted</source>
+ <translation>Konwertuj obrazu RGB do indeksowanego</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="26"/>
@@ -2173,7 +2201,7 @@
<location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="26"/>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="26"/>
<source>Batch mode (for processing whole directory)</source>
+ <translation>Tryb wsadowy (dla całego katalogu)</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="35"/>
@@ -2186,57 +2214,57 @@
<location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="28"/>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="35"/>
<source>&Input file:</source>
+ <translation>Plik ź&ródłowy:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="96"/>
<source>Number of colors</source>
+ <translation>Liczba kolorów</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="65"/>
<source>&Z Field:</source>
+ <translation>&Z:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="106"/>
<source>&Algorithm:</source>
+ <translation>&Algorytm:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="114"/>
<source>Inverse distance to a power</source>
+ <translation>odwrotne odległości do potęgi</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="119"/>
<source>Moving average</source>
+ <translation type="unfinished">średnia krocząca</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="124"/>
<source>Nearest neighbor</source>
+ <translation>najbliższe sąsiedztwo</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="129"/>
<source>Data metrics</source>
+ <translation>statystyki</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="157"/>
<source>Power:</source>
+ <translation>Potęga:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="171"/>
<source>Smoothing:</source>
+ <translation>Wygładzanie:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="188"/>
@@ -2244,7 +2272,7 @@
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="387"/>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="498"/>
<source>Radius1:</source>
+ <translation>Promień 1:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="205"/>
@@ -2252,7 +2280,7 @@
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="404"/>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="515"/>
<source>Radius2:</source>
+ <translation>Promień 2:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="222"/>
@@ -2260,19 +2288,19 @@
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="421"/>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="532"/>
<source>Angle:</source>
- <translation type="unfinished">Kąt:</translation>
+ <translation>Kąt:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="239"/>
<source>Max points:</source>
+ <translation>Max. punktów:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="253"/>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="339"/>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="549"/>
<source>Min points:</source>
+ <translation>Min. punktów:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="267"/>
@@ -2280,52 +2308,52 @@
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="438"/>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="563"/>
<source>No data:</source>
+ <translation>Brak danych:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="472"/>
<source>Metrics:</source>
+ <translation>Statystyki:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="480"/>
<source>Minimum</source>
- <translation type="unfinished">Minimum</translation>
+ <translation>Minimum</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="485"/>
<source>Maximum</source>
- <translation type="unfinished">Maksimum</translation>
+ <translation>Maksimum</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="490"/>
<source>Range</source>
- <translation type="unfinished">Zakres</translation>
+ <translation>Zakres</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetInfo.ui" line="20"/>
<source>Info</source>
- <translation type="unfinished">Informacje</translation>
+ <translation>Informacje</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetInfo.ui" line="63"/>
<source>Raster info</source>
+ <translation>Informacje o rastrze</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetInfo.ui" line="83"/>
<source>Suppress GCP printing</source>
+ <translation>Nie wyświetlaj GCP</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetInfo.ui" line="90"/>
<source>Suppress metadata printing</source>
+ <translation>Nie wyświetlaj metadanych</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="106"/>
@@ -2341,300 +2369,302 @@
<location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="130"/>
<location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="150"/>
<source>&Creation Options:</source>
+ <translation>&Opcje generowania:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetNearBlack.ui" line="20"/>
<source>Near Black</source>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetNearBlack.ui" line="96"/>
<source>How &far from black (or white):</source>
+ <translation>&Margines czarnego (lub białego):</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetNearBlack.ui" line="112"/>
<source>Search for nearly &white (255) pixels instead of black ones</source>
+ <translation>Szukaj prawie &białego (255) zamiast czarnego</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="20"/>
<source>Add overview</source>
+ <translation>Dodaj podgląd</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="72"/>
<source>Resampling method</source>
- <translation type="unfinished">Metoda interpolacji</translation>
+ <translation>Metoda resamplingu</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="80"/>
<source>nearest</source>
+ <translation>najbliższy</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="85"/>
<source>average</source>
+ <translation>średnia</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="90"/>
<source>gauss</source>
+ <translation>Gaussa</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="95"/>
<source>average_mp</source>
+ <translation>średnia_mp</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="100"/>
<source>average_magphase</source>
+ <translation>średnia_magphase</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="105"/>
<source>mode</source>
+ <translation>moda</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="113"/>
<source>Levels (space delimited)</source>
+ <translation>Poziom (rozdzielone spacjami)</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="125"/>
<source>Open in read-only mode</source>
+ <translation>Otwórz w trybie tylko do odczytu</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="65"/>
<source>&Output file for polygons (shapefile):</source>
+ <translation>&Plik docelowy dla poligonów:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="103"/>
<source>DN</source>
+ <translation>DN</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="96"/>
<source>&Field name:</source>
+ <translation>&Nazwa pola:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="33"/>
<source>WARNING: current projection definition will be cleared</source>
+ <translation>UWAGA: aktualna definicja odwzorowania zostanie usunięta</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="80"/>
<source>Desired SRS:</source>
+ <translation>Docelowy układ współrzędnych:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="101"/>
<source>Output will be:
- new GeoTiff if input file is not GeoTiff
- overwritten if input is GeoTiff</source>
+ <translation>Wynikiem będzie:
+- nowy GeoTiff jeśli plik źródłowy nie jest typu GeoTiff
+- nadpisanie jeśli jest to GeoTiff</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProjection.ui" line="73"/>
<source>Recurse subdirectories</source>
+ <translation>Z podkatalogami</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="89"/>
<source>&Values:</source>
+ <translation>&Wartości:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="121"/>
<source>&Dist units:</source>
+ <translation>&Jednostki odległości:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="132"/>
<source>GEO</source>
+ <translation>GEO</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="137"/>
<source>PIXEL</source>
+ <translation>PIXEL</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="145"/>
<source>&Max dist:</source>
+ <translation>&Max. odległość:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="159"/>
<source>&No data:</source>
+ <translation>&Brak danych:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="173"/>
<source>&Fixed buf val:</source>
+ <translation>&Stała wartość:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="28"/>
<source>&Input file (shapefile):</source>
+ <translation>Plik źró&dłowy (shapefile):</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="85"/>
<source>&Output file for rasterized vectors (raster, must exists):</source>
+ <translation>&Docelowy plik rastrowy (istniejący):</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="65"/>
<source>&Attribute field:</source>
+ <translation>Pole &atrybutu:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="20"/>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="118"/>
<source>4</source>
- <translation type="unfinished">4</translation>
+ <translation>4</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="123"/>
<source>8</source>
- <translation type="unfinished">8</translation>
+ <translation>8</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="96"/>
<source>&Threshold:</source>
+ <translation>&Próg:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetSieve.ui" line="110"/>
<source>&Pixel connections:</source>
+ <translation>Połączonych &komórek:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="20"/>
+ <translation>Konwertuj układ</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="35"/>
<source>&Input Layer:</source>
+ <translation>Warstwa &wejściowa:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="120"/>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="131"/>
<source>&Target SRS:</source>
+ <translation>&Układ współrzędnych:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="103"/>
<source>Output format</source>
- <translation type="unfinished">Format wyjściowy</translation>
+ <translation>Format docelowy</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="20"/>
+ <translation>Reprojekcja</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="103"/>
<source>&Source SRS:</source>
+ <translation>Ź&ródłowy układ współrzędnych:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="159"/>
<source>&Resampling method:</source>
+ <translation>Metoda &resamplingu:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="167"/>
<source>Near</source>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="172"/>
<source>Bilinear</source>
+ <translation>bilinearna</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="177"/>
<source>Cubic</source>
- <translation type="unfinished">sześcienna</translation>
+ <translation>sześcienna</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="182"/>
<source>Cubic spline</source>
+ <translation>splajn sześcienny</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="187"/>
<source>Lanczos</source>
- <translation type="unfinished">Lanczos</translation>
+ <translation>Lanczos</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="205"/>
<source>&Memory used for caching:</source>
+ <translation>Użyj &pamięci jako cache:</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="212"/>
<source>MB</source>
+ <translation>MB</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="195"/>
<source>Set no data value</source>
+ <translation>Brak danych</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="227"/>
<source>Resize</source>
+ <translation>Zmień rozmiar</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="242"/>
<source>Image width</source>
+ <translation>Szerokość obrazu</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="256"/>
<source>Image height</source>
+ <translation>Wysokość obrazu</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="276"/>
<source>Use m&ultithreaded warping implementation</source>
+ <translation>Reprojekcja &wielowątkowa</translation>
</message>
</context>
<context>
@@ -5211,42 +5241,43 @@
<message>
<location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="13"/>
<source>Simple line</source>
+ <translation>Zwykła linia</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="15"/>
<source>Marker line</source>
+ <translation>Linia ze znacznikami</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="17"/>
<source>Line decoration</source>
+ <translation>Dekoracja</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="20"/>
<source>Simple marker</source>
+ <translation>Prosty znacznik</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="22"/>
<source>SVG marker</source>
+ <translation>Znacznik SVG</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="24"/>
<source>Font marker</source>
+ <translatorcomment>Font to nie jest czcionka, ale na razie tak jest wszedzie tłumaczone! Zmienimy to ewentualnie przy wersji 2.0.</translatorcomment>
+ <translation type="unfinished">Znacznik z czcionki</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="27"/>
<source>Simple fill</source>
+ <translation>Proste wypełnienie</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgssymbollayerv2registry.cpp" line="29"/>
<source>SVG fill</source>
+ <translation>Wypełnienie SVG</translation>
</message>
</context>
<context>
@@ -5260,7 +5291,7 @@
<location filename="../src/core/gps/qextserialport/qextserialport.cpp" line="225"/>
<source>Invalid file descriptor (port was not opened correctly)</source>
<translatorcomment>a ten błąd mam często na windzie :p</translatorcomment>
+ <translation type="unfinished">Błędny deskryptor pliku (port nie został poprawnie owarty)</translation>
</message>
<message>
<location filename="../src/core/gps/qextserialport/qextserialport.cpp" line="226"/>
@@ -5378,57 +5409,57 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="2429"/>
<source>Whats new in Version 1.5.0 'Tethys'?</source>
+ <translation>Co nowego w wersji 1.5.0 'Tethys'?</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2432"/>
<source>Please note that this is a release in our 'cutting edge' release series. As such it contains new features and extends the programmatic interface over QGIS 1.0.x and QGIS 1.4.0. If an unchanging user interface, programmatic API and long term support is more important to you then cool new and untested features, we recommend that you use a copy of QGIS from our Long Term Support (LTS)1.0.x release series. In all other cases we recommend that you use this version.</source>
+ <translation>To wydanie należy do linii rozwojowej. Jako takie zawiera nowe funkcje w stosunku do QGIS 1.0.x i QGIS 1.4.0. Jeśli nad nowe funkcje przedkładasz długoterminowe wsparcie, polecamy wersję QGIS z linii 1.0.x (LTS).</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2440"/>
<source>This release includes over 350 bug fixes, over 40 new features. Once again it is impossible to document everything here that has changed so we will just provide a bullet list of key new features here.</source>
+ <translation>W tym wydaniu usunięto ponad 350 błędów i dodano 40 nowych funkcji. Nie jest możliwe udokumentowanie tutaj wszystkiego co uległo zmianie. Przedstawiamy tylko listę wybranych nowych funkcji.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2445"/>
<source>Main GUI</source>
+ <translation>Główny interfejs użytkownika</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2448"/>
<source>There is a new angle measuring tool that allows you to interactively measure angles against the map backdrop.</source>
+ <translation>Nowe narzędzie do interaktywnego pomiaru kątów na mapie.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2449"/>
<source>Live GPS Tracking tool</source>
+ <translation>Narzędzie śledzenia ścieżek GPS w czasie rzeczywistym</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2450"/>
<source>User configurable WMS search server</source>
+ <translation>Konfigurowalne poszukiwanie serwerów WMS</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2451"/>
<source>Allow editing of invalid geometry in node tool</source>
+ <translation>Dozwolona edycja błędnej geometrii dla węzłów</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2452"/>
<source>Choice between mm and map units for new symbology. Scaling to use new symbology in print composer as well</source>
+ <translation>Wybór pomiędzy milimetrami a jednostkami mapy przy nowych stylach. Skalowanie dla nowych stylów w wydrukach</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2453"/>
<source>SVG fill symbol layer for polygon textures</source>
+ <translation>Wypełnienie poligonów teksturą SVG</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2454"/>
<source>Font marker symbol layer</source>
+ <translation>Uzycie czcionek jako znaczników</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2455"/>
@@ -5438,57 +5469,57 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="2456"/>
<source>Allow hiding of deprecated CRSes</source>
+ <translation>Ukrywanie nieaktualnych układów współrzędnych (CRS)</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2457"/>
<source>Add point displacement renderer plugin - allows points to be shifted to avoid colliding with other points</source>
+ <translation>Dodano wtyczkę przesunięcia punktów - pozwala na przesunięcie w celu uniknięcia kolizji z innymi punktami</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2458"/>
<source>Allow saving vector layers as ogr vector files</source>
+ <translation type="unfinished">Zapisywanie warstw wektorowych jako plików wektorowych OGR</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2459"/>
<source>Raster provider: reduce debugging noise</source>
+ <translation type="unfinished">Rastrowe źródło danych: redukcja informacji debugera</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2460"/>
<source>Allow adding parts to multi points and lines</source>
+ <translation>Dodawanie części do multipunktów i multilinii</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2461"/>
<source>Text and form annotation tools are now in gui and app</source>
+ <translation>Narzędzia do opisów tekstowych i formularzy dostępne w GUI i programie</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2462"/>
<source>Added possibility to place a set of default composer templates in pkgDataPath/composer_templates</source>
+ <translation>Możliwość umieszczenia domyślnych szablonów wydruku w pkgDataPath/composer_templates</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2463"/>
<source>Gradient color ramps now support multiple stops - for adding intermediate colors</source>
+ <translation>Gradientowe palety kolorów umożliwiają definiowanie punktów pośrednich</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2464"/>
<source>Center map if user clicks into the map</source>
+ <translation>Centrowanie mapy w punkcie kliknięcia</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2465"/>
<source>New plugin for carrying out spatial selections</source>
+ <translation>Nowa wtyczka wyboru przestrzennego</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2466"/>
<source>Data-defined size and rotation for single symbol renderer in symbology-ng</source>
+ <translation>W nowych stylach możliwość definiowania rozmiaru i kąta obrotu opartych na danych</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2467"/>
@@ -5498,47 +5529,47 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="2468"/>
<source>Export legend groups and layers with legendinterface and use this information to display groups in the composer legend.</source>
+ <translation>Eksport grup i warstw z legendy w celu użycia w legendzie wydruku.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2469"/>
<source>Show selected feature count in status bar </source>
+ <translation>Wyświetlanie liczby wybranych obiektów na pasku stanu</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2470"/>
<source>Query option added to layer menu to subset vector layers</source>
+ <translation>Do menu podręcznego warstwy dodano opcję zapytania</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2471"/>
<source>Option to label only selected features (on the 'old' labelling tool)</source>
+ <translation>Opcja etykietowania tylko wybranych obiektów (w 'starym' narzędziu etykietowania)</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2472"/>
<source>Load/save queries created in the query builder.</source>
+ <translation>Odczyt/zapis zapytań tworzonych w kreatorze zapytań.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2473"/>
<source>Manual adding of categories in symbology-ng.</source>
+ <translation>Szczegółowe definiowanie kategorii w nowych stylach.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2474"/>
<source>Georeferencer: possibility to configure if residuals should be showed in pixels or map units</source>
+ <translation>Georeferencer: możliwość konfiguracji jednostek błędu - komórki rastra lub jednostki mapy</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2475"/>
<source>Delimited text provider: allow empty values in numeric columns</source>
+ <translation>Źródło danych tekstowych: dopuszczenie pustych wartości w kolumnach numerycznych</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2476"/>
<source>Added rule-based renderer for symbology-ng</source>
+ <translation>Dodano renderowanie oparte na regułach dla nowych stylów</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2477"/>
@@ -10049,7 +10080,7 @@
<message>
<location filename="../src/ui/qgscomposerpicturewidgetbase.ui" line="53"/>
<source>Search directories</source>
- <translation>Szukaj w kartotekach</translation>
+ <translation>Szukaj w katalogach</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerpicturewidgetbase.ui" line="82"/>
@@ -15318,7 +15349,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="191"/>
<source>The directory doesn't exist!</source>
- <translation>Kartoteka nie istnieje!</translation>
+ <translation>Katalog nie istnieje!</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="336"/>
@@ -24654,7 +24685,7 @@
<message>
<location filename="../src/plugins/diagram_overlay/qgssvgdiagramfactorywidgetbase.ui" line="29"/>
</message>
<message>
<location filename="../src/plugins/diagram_overlay/qgssvgdiagramfactorywidgetbase.ui" line="48"/>
@@ -29230,7 +29261,7 @@
<message>
<location filename="../src/ui/symbollayer/widget_linedecoration.ui" line="22"/>
<source>Color</source>
- <translation type="unfinished">Kolor</translation>
+ <translation>Kolor</translation>
</message>
<message>
<source>Color:</source>
@@ -29252,17 +29283,17 @@
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="22"/>
<source>Marker</source>
+ <translation>Znacznik</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="52"/>
<source>Marker interval</source>
+ <translation>Odstęp znaczników</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="66"/>
<source>Line offset</source>
+ <translation>Przesunięcie linii</translation>
</message>
<message>
<source>Marker:</source>
