[QGIS Commit] r13014 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Mar 7 12:34:21 EST 2010
Author: jef
Date: 2010-03-07 12:34:20 -0500 (Sun, 07 Mar 2010)
New Revision: 13014
   trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
   trunk/qgis/src/providers/postgres/qgspostgresprovider.h
fix #2511
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2010-03-07 16:19:34 UTC (rev 13013)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2010-03-07 17:34:20 UTC (rev 13014)
@@ -115,12 +115,26 @@
     return;
-  sql = QString( "SELECT "
-                 "has_table_privilege(%1,'DELETE'),"
-                 "has_table_privilege(%1,'UPDATE'),"
-                 "has_table_privilege(%1,'INSERT'),"
-                 "current_schema()" )
-        .arg( quotedValue( mSchemaTableName ) );
+  if ( connectionRO->pgVersion() >= 80400 )
+    sql = QString( "SELECT "
+                   "has_table_privilege(%1,'DELETE'),"
+                   "has_any_column_privilege(%1,'UPDATE'),"
+                   "has_column_privilege(%1,%2,'UPDATE'),"
+                   "has_table_privilege(%1,'INSERT'),"
+                   "current_schema()" )
+          .arg( quotedValue( mSchemaTableName ) ).arg( quotedValue( geometryColumn ) );
+  else
+                   "has_table_privilege(%1,'UPDATE'),"
+          .arg( quotedValue( mSchemaTableName ) );
   testAccess = connectionRO->PQexec( sql );
   if ( PQresultStatus( testAccess ) != PGRES_TUPLES_OK )
@@ -148,16 +162,22 @@
   if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 1 ) ) == "t" )
     // UPDATE
-    enabledCapabilities |= QgsVectorDataProvider::ChangeGeometries | QgsVectorDataProvider::ChangeAttributeValues;
+    enabledCapabilities |= QgsVectorDataProvider::ChangeAttributeValues;
   if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 2 ) ) == "t" )
+    // UPDATE
+    enabledCapabilities |= QgsVectorDataProvider::ChangeGeometries;
+  if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 3 ) ) == "t" )
     // INSERT
     enabledCapabilities |= QgsVectorDataProvider::AddFeatures;
-  mCurrentSchema = QString::fromUtf8( PQgetvalue( testAccess, 0, 3 ) );
+  mCurrentSchema = QString::fromUtf8( PQgetvalue( testAccess, 0, 4 ) );
   if ( mCurrentSchema == mSchemaName )
     mUri.clearSchema();
@@ -2055,6 +2075,8 @@
 /* Functions for determining available features in postGIS */
 QString QgsPostgresProvider::Conn::postgisVersion()
+  postgresqlVersion = PQserverVersion( conn );
   Result result = PQexec( "select postgis_version()" );
   if ( PQntuples( result ) != 1 )
@@ -2694,15 +2716,6 @@
   sql += QString( "not IsEmpty(%1) limit 5" ).arg( quotedIdentifier( geometryColumn ) );
-#if WASTE_TIME
-  sql = QString( "select "
-                 "xmax(extent(%1)) as xmax,"
-                 "xmin(extent(%1)) as xmin,"
-                 "ymax(extent(%1)) as ymax,"
-                 "ymin(extent(%1)) as ymin"
-                 " from %2" ).arg( quotedIdentifier( geometryColumn ) ).arg( mSchemaTableName );
-#endif
   QgsDebugMsg( "Getting approximate extent using: '" + sql + "'" );
   Result result = connectionRO->PQexec( sql );
@@ -2733,13 +2746,18 @@
   QString ext;
   // get the extents
-  if ( sqlWhereClause.isEmpty() )
+  if ( sqlWhereClause.isEmpty() && !connectionRO->hasNoExtentEstimate() )
     result = connectionRO->PQexec( QString( "select estimated_extent(%1,%2,%3)" )
                                    .arg( quotedValue( mSchemaName ) )
                                    .arg( quotedValue( mTableName ) )
                                    .arg( quotedValue( geometryColumn ) ) );
-    if ( PQntuples( result ) == 1 )
+    if ( PQresultStatus( result ) != PGRES_TUPLES_OK )
+      connectionRO->PQexecNR( "ROLLBACK" );
+      connectionRO->setNoExtentEstimate();
+    else if ( PQntuples( result ) == 1 )
       ext = PQgetvalue( result, 0, 0 );
@@ -2753,19 +2771,12 @@
       sql += QString( "where %1" ).arg( sqlWhereClause );
-#if WASTE_TIME
-#endif
   QgsDebugMsg( "Getting extents using schema.table: " + sql );
   QRegExp rx( "\\((.+) (.+),(.+) (.+)\\)" );
@@ -2784,19 +2795,6 @@
 #endif
-#if 0
-#ifdef QGISDEBUG
-  QString xMsg;
-  QTextOStream( &xMsg ).precision( 18 );
-  QTextOStream( &xMsg ).width( 18 );
-  QTextOStream( &xMsg ) << "QgsPostgresProvider: Set extents to: "
-  << layerExtent.xMinimum() << ", "
-  << layerExtent.yMinimum() << " "
-  << layerExtent.xMaximum() << ", "
-  << layerExtent.yMaximum();
-  QgsDebugMsg( xMsg );
-#endif
-#endif
   QgsDebugMsg( "Set extents to: " + layerExtent.toString() );
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h	2010-03-07 16:19:34 UTC (rev 13013)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h	2010-03-07 17:34:20 UTC (rev 13014)
@@ -581,7 +581,8 @@
             ref( 1 ),
             openCursors( 0 ),
             conn( connection ),
-            gotPostgisVersion( false )
+            gotPostgisVersion( false ),
+            mHasNoExtentEstimate( false )
@@ -603,10 +604,19 @@
         //! major PostgreSQL version
         int majorVersion() { return postgisVersionMajor; }
-        // run a query and free result buffer
+        //! PostgreSQL version
+        int pgVersion() { return postgresqlVersion; }
+        //! has PostGIS no extent estimate?
+        bool hasNoExtentEstimate() { return mHasNoExtentEstimate; }
+        //! PostGIS does not have a extent estimate
+        void setNoExtentEstimate( bool flag = true ) { mHasNoExtentEstimate = flag; }
+        //! run a query and free result buffer
         bool PQexecNR( QString query );
-        // cursor handling
+        //! cursor handling
         bool openCursor( QString cursorName, QString declare );
         bool closeCursor( QString cursorName );
@@ -643,6 +653,9 @@
         //! Are postgisVersionMajor, postgisVersionMinor, geosAvailable, gistAvailable, projAvailable valid?
         bool gotPostgisVersion;
+        int postgresqlVersion;
         //! PostGIS major version
         int postgisVersionMajor;
@@ -658,6 +671,9 @@
         //! encode wkb in hex
         bool mUseWkbHex;
+        //! PostGIS doesn't have extent estimates
+        bool mHasNoExtentEstimate;
         static QMap<QString, Conn *> connectionsRW;
         static QMap<QString, Conn *> connectionsRO;
         static QMap<QString, QString> passwordCache;
More information about the QGIS-commit mailing list
