[QGIS Commit] r13123 - trunk/qgis/i18n
svn_qgis at osgeo.org
Sat Mar 20 19:23:33 EDT 2010
Author: pcav
Date: 2010-03-20 19:23:33 -0400 (Sat, 20 Mar 2010)
New Revision: 13123
trunk/qgis/i18n/qgis_it.ts
More IT translation
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts 2010-03-20 23:22:09 UTC (rev 13122)
+++ trunk/qgis/i18n/qgis_it.ts 2010-03-20 23:23:33 UTC (rev 13123)
@@ -23,7 +23,7 @@
<message>
<location filename="../src/plugins/coordinate_capture/coordinatecapture.cpp" line="116"/>
<source>Click to select the CRS to use for coordinate display</source>
- <translation>Clicca per selezionare il CRS da usare durante la visualizzazione delle coordinate</translation>
+ <translation>Clicca per scegliere il CRS da usare durante la visualizzazione delle coordinate</translation>
</message>
<message>
<location filename="../src/plugins/coordinate_capture/coordinatecapture.cpp" line="124"/>
@@ -456,11 +456,11 @@
</message>
<message>
<source>Select features in:</source>
- <translation>Seleziona le geometrie nel:</translation>
+ <translation>Scegli le geometrie nel:</translation>
</message>
<message>
<source>that intersect features in:</source>
- <translation type="unfinished">geometrie che si intersecano nel:</translation>
+ <translation>che intersecano geometrie in:</translation>
</message>
<message>
<source>Modify current selection by:</source>
@@ -1365,15 +1365,15 @@
<name>GeometryDialog</name>
<message>
<source>Cancel</source>
- <translation type="unfinished">Annulla</translation>
+ <translation>Annulla</translation>
</message>
<message>
<source>Merge all</source>
- <translation type="unfinished">Unisci tutto</translation>
+ <translation>Unisci tutto</translation>
</message>
<message>
<source>Geometry</source>
- <translation type="unfinished">Geometria</translation>
+ <translation>Geometria</translation>
</message>
<message>
<source>Please specify input vector layer</source>
@@ -1405,59 +1405,59 @@
</message>
<message>
<source>Extract nodes</source>
- <translation type="unfinished">Estrai nodi</translation>
+ <translation>Estrai nodi</translation>
</message>
<message>
<source>Polygons to lines</source>
- <translation type="unfinished">Da poligoni a linee</translation>
+ <translation>Da poligoni a linee</translation>
</message>
<message>
<source>Input polygon vector layer</source>
- <translation type="unfinished">Vettoriale poligoni in input</translation>
+ <translation>Vettoriale poligoni in input</translation>
</message>
<message>
<source>Export/Add geometry columns</source>
- <translation type="unfinished">Esporta/Aggiungi colonne geometriche</translation>
+ <translation>Esporta/Aggiungi colonne geometriche</translation>
</message>
<message>
<source>Input vector layer</source>
- <translation type="unfinished">Layer vettoriale in input</translation>
+ <translation>Layer vettoriale in input</translation>
</message>
<message>
<source>Simplify geometries</source>
- <translation type="unfinished">Semplifica geometrie</translation>
+ <translation>Semplifica geometrie</translation>
</message>
<message>
<source>Polygon centroids</source>
- <translation type="unfinished">Centroidi del poligono</translation>
+ <translation>Centroidi del poligono</translation>
</message>
<message>
<source>Output point shapefile</source>
- <translation type="unfinished">Shapefile punti in output</translation>
+ <translation>Shapefile punti in output</translation>
</message>
<message>
<source>Delaunay triangulation</source>
- <translation type="unfinished">Triangolazione di Delaunay</translation>
+ <translation>Triangolazione di Delaunay</translation>
</message>
<message>
<source>Input point vector layer</source>
- <translation type="unfinished">Vettoriale punti in input</translation>
+ <translation>Vettoriale punti in input</translation>
</message>
<message>
<source>Polygon from layer extent</source>
- <translation type="unfinished">Poligono dall'estensione del layer</translation>
+ <translation>Poligono dall'estensione del layer</translation>
</message>
<message>
<source>Input layer</source>
- <translation type="unfinished">Layer in input</translation>
+ <translation>Layer in input</translation>
</message>
<message>
<source>Output polygon shapefile</source>
- <translation type="unfinished">Shapefile poligoni in output</translation>
+ <translation>Shapefile poligoni in output</translation>
</message>
<message>
<source>Geoprocessing</source>
- <translation type="unfinished">Geoprocessa</translation>
+ <translation>Geoprocessa</translation>
</message>
<message>
<source>Unable to delete existing shapefile.</source>
@@ -1469,19 +1469,20 @@
</message>
<message>
<source>Error writing output shapefile.</source>
- <translation type="unfinished">Errore di scrittura per lo shapefile in output.</translation>
+ <translation>Errore di scrittura per lo shapefile in output.</translation>
</message>
<message>
<source>Error processing specified tolerance!
Please choose larger tolerance...</source>
- <translation type="unfinished"></translation>
+ <translation>Errore nell'elaborare la tolleranza specificata!
+Scegli una tolleranza più alta...</translation>
</message>
<message>
<source>Created output shapefile:
%1
Would you like to add the new layer to the TOC?</source>
- <translation type="unfinished">Creato uno shapefile di output:
+ <translation>Creato uno shapefile di output:
%1
Vuoi aggiungerlo alla legenda?</translation>
@@ -1489,7 +1490,7 @@
<message>
<source>Error loading output shapefile:
%1</source>
- <translation type="unfinished">Errore durante il caricamento dello shapefile di output:
+ <translation>Errore durante il caricamento dello shapefile di output:
%1</translation>
</message>
</context>
@@ -3494,7 +3495,7 @@
<message>
<location filename="../src/python/qgspythonutilsimpl.cpp" line="165"/>
<source>QGIS version:</source>
- <translation type="unfinished">Versione di QGIS:</translation>
+ <translation>Versione di QGIS:</translation>
</message>
<message>
<location filename="../src/python/qgspythonutilsimpl.cpp" line="166"/>
@@ -3666,7 +3667,7 @@
<message>
<location filename="../src/providers/grass/qgsgrass.cpp" line="1180"/>
<source>Cannot query raster </source>
+ <translation>Impossibile interrogare il raster </translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="65"/>
@@ -3676,12 +3677,12 @@
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="66"/>
<source>Georeferencing rasters using GDAL</source>
+ <translation>Georeferenziare raster tramite GDAL</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="67"/>
<source>Version 3.1.9</source>
+ <translation>Versione 3.1.9</translation>
</message>
<message>
<location filename="../src/app/qgsspatialitesourceselect.cpp" line="303"/>
@@ -3815,66 +3816,66 @@
<location filename="../src/app/qgsmaptoolnodetool.cpp" line="973"/>
<source>%n geometry error(s) found.</source>
<comment>number of geometry errors</comment>
- <numerusform></numerusform>
+ <translation>
+ <numerusform>%n errore geometrico trovato.</numerusform>
+ <numerusform>%n errori geometrici trovati.</numerusform>
</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6188"/>
<source>invalid line</source>
+ <translation>linea non valida</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6266"/>
<source>segment %1 of ring %2 of polygon %3 intersects segment %4 of ring %5 of polygon %6 at %7</source>
+ <translation>il segmento %1 dell'anello %2 del poligono %3 interseca il segmento %4 dell'anello %5 del poligono %6 in %7</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6274"/>
<location filename="../src/core/qgsgeometry.cpp" line="6362"/>
<source>stopping validation after more than 100 errors</source>
+ <translation>validazione interrotta dopo più di 100 errori</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6292"/>
<source>ring %1 with less than three points</source>
+ <translation>anello %1 con meno di tre punti</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6300"/>
<source>ring %1 not closed</source>
+ <translation>l'anello %1 non è chiuso</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6308"/>
<source>line %1 with less than two points</source>
+ <translation>linea %1 con meno di due punti</translation>
</message>
<message numerus="yes">
<location filename="../src/core/qgsgeometry.cpp" line="6326"/>
<source>line %1 contains %n duplicate node(s) at %2</source>
<comment>number of duplicate nodes</comment>
+ <translation>
+ <numerusform>la linea %1 contiene %n nodo duplicato in %2</numerusform>
+ <numerusform>la linea %1 contiene %n nodi duplicati in %2</numerusform>
</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6357"/>
<source>segments %1 and %2 of line %3 intersect at %4</source>
+ <translation>i segmenti %1 e %2 della linea %3 si intersecano in %4</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6378"/>
<source>ring %1 of polygon %2 not in exterior ring</source>
+ <translation>l'anello %1 del poligono %2 non è nell'anello esterno</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6448"/>
<location filename="../src/core/qgsgeometry.cpp" line="6452"/>
<source>polygon %1 inside polygon %2</source>
+ <translation>il poligono %1 all'interno del poligono %2</translation>
</message>
<message>
<location filename="../src/core/qgsgeometry.cpp" line="6464"/>
@@ -4841,7 +4842,8 @@
<location filename="../src/app/qgisapp.cpp" line="2193"/>
<source>
This copy of QGIS has been built with PostgreSQL support.</source>
+ <translation>
+Questa copia di QGIS è stata compilata con il supporto a PostgreSQL.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2195"/>
@@ -5762,7 +5764,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="3830"/>
<source>No active layer found. Please select a layer in the layer list</source>
- <translation>Non è stato trovato alcun layer attivo. Selezionane uno dalla lista</translation>
+ <translation>Non è stato trovato alcun layer attivo. Scegline uno dalla lista</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="3836"/>
@@ -5772,7 +5774,7 @@
<message>
<source>The merge features tool only works on vector layers. Please select a vector layer from the layer list</source>
- <translation>Lo strumento di unione delle geometrie funziona solo con layer vettoriali. Seleziona un layer vettoriale dalla lista</translation>
+ <translation>Lo strumento di unione delle geometrie funziona solo con layer vettoriali. Scegli un layer vettoriale dalla lista</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="3841"/>
@@ -6085,7 +6087,7 @@
<message>
<location filename="../src/app/qgsabout.cpp" line="298"/>
<source>Qt Image Plugin Search Paths <br></source>
+ <translation>Percorsi di ricerca per il Qt Image Plugin <br></translation>
</message>
<message>
<location filename="../src/ui/qgsabout.ui" line="217"/>
@@ -6144,7 +6146,7 @@
<source>Select an action</source>
<comment>File dialog window title</comment>
<translatorcomment>Titolo finestra di dialogo file</translatorcomment>
- <translation>Seleziona un'azione</translation>
+ <translation>Scegli un'azione</translation>
</message>
<message>
<location filename="../src/app/qgsattributeactiondialog.cpp" line="187"/>
@@ -6378,7 +6380,7 @@
<message>
<location filename="../src/gui/qgsattributeeditor.cpp" line="51"/>
<source>Select a file</source>
- <translation>Seleziona un file</translation>
+ <translation>Scegli un file</translation>
</message>
<message>
<location filename="../src/gui/qgsattributeeditor.cpp" line="355"/>
@@ -6413,7 +6415,7 @@
<message>
<location filename="../src/ui/qgsattributeloadfrommap.ui" line="76"/>
<source>Select data from attributes in selected layer.</source>
- <translation>Seleziona i dati dagli attributi del layer selezionato.</translation>
+ <translation>Scegli i dati dagli attributi del layer selezionato.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeloadfrommap.ui" line="93"/>
@@ -6471,24 +6473,24 @@
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="85"/>
<source>Attribute table - %1 (%n Feature(s))</source>
<comment>feature count</comment>
+ <translation>
+ <numerusform>Tabella degli attributi - %1 (%n elemento)</numerusform>
+ <numerusform>Tabella degli attributi - %1 (%n elementi)</numerusform>
</translation>
</message>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="584"/>
<source>Attribute table - %1 (%n matching features)</source>
<comment>matching features</comment>
+ <translation>
+ <numerusform>Tabella degli attributi - %1 (%n elemento coincidente)</numerusform>
+ <numerusform>Tabella degli attributi - %1 (%n elementi coincidenti)</numerusform>
</translation>
</message>
<message>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="588"/>
<source>Attribute table - %1 (No matching features)</source>
+ <translation>Tabella degli attributi - %1 (nessun elemento coincidente)</translation>
</message>
<message>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="679"/>
@@ -6655,7 +6657,7 @@
<message>
<location filename="../src/app/attributetable/qgsattributetableview.cpp" line="98"/>
<source>Run action</source>
- <translation type="unfinished">Esegui azione</translation>
+ <translation>Esegui azione</translation>
</message>
</context>
<context>
@@ -6663,7 +6665,7 @@
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="124"/>
</message>
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="133"/>
@@ -7186,7 +7188,7 @@
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="45"/>
<source>Line width </source>
- <translation type="unfinished">Larghezza linea</translation>
+ <translation>Larghezza linea </translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="52"/>
@@ -7270,7 +7272,7 @@
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="262"/>
<source>Select/Move item</source>
- <translation>Seleziona/Sposta oggetto</translation>
+ <translation>Scegli/Sposta oggetto</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="301"/>
@@ -7516,12 +7518,12 @@
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="471"/>
<source>Add table</source>
+ <translation>Aggiungi tabella</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="474"/>
<source>Adds attribute table</source>
+ <translation>Aggiungi tabella attributi</translation>
</message>
</context>
<context>
@@ -8056,12 +8058,12 @@
<message>
<location filename="../src/app/composer/qgscomposerpicturewidget.cpp" line="69"/>
<source>Select svg or image file</source>
- <translation>Seleziona un svg o altra immagine</translation>
+ <translation>Scegli SVG o altra immagine</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposerpicturewidget.cpp" line="172"/>
<source>Select new preview directory</source>
- <translation>Seleziona una directory di anteprima</translation>
+ <translation>Scegli una directory di anteprima</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposerpicturewidget.cpp" line="292"/>
@@ -8311,7 +8313,7 @@
<message>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="130"/>
<source>Select outline color</source>
- <translation>Selezione il colore del contorno</translation>
+ <translation>Scegli il colore del contorno</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="179"/>
@@ -8364,24 +8366,24 @@
<message>
<location filename="../src/app/composer/qgscomposertablewidget.cpp" line="33"/>
<source>General options</source>
- <translation type="unfinished">Opzioni generali</translation>
+ <translation>Opzioni generali</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposertablewidget.cpp" line="59"/>
<location filename="../src/app/composer/qgscomposertablewidget.cpp" line="266"/>
<source>Map %1</source>
- <translation type="unfinished">Mappa %1</translation>
+ <translation>Mappa %1</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposertablewidget.cpp" line="172"/>
<location filename="../src/app/composer/qgscomposertablewidget.cpp" line="187"/>
<source>Select Font</source>
+ <translation>Scegli il carattere</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposertablewidget.cpp" line="212"/>
<source>Select grid color</source>
+ <translation>Scegli il colore della griglia</translation>
</message>
</context>
<context>
@@ -8976,12 +8978,12 @@
<message>
<location filename="../src/core/qgscoordinatetransform.cpp" line="456"/>
<source>inverse transform</source>
+ <translation>trasformazione inversa</translation>
</message>
<message>
<location filename="../src/core/qgscoordinatetransform.cpp" line="463"/>
<source>forward transform</source>
+ <translation>trasformazione diretta</translation>
</message>
<message>
<location filename="../src/core/qgscoordinatetransform.cpp" line="483"/>
@@ -8989,7 +8991,9 @@
%2
failed with error: %3
</source>
+ <translation>%1 di
+%2
+fallito con errore: %3</translation>
</message>
<message>
<location filename="../src/core/qgscoordinatetransform.cpp" line="425"/>
@@ -9469,7 +9473,7 @@
<message>
<location filename="../src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp" line="223"/>
<source>Choose a delimited text file to open</source>
- <translation>Seleziona un file di testo delimitato da aprire</translation>
+ <translation>Scegli un file di testo delimitato da aprire</translation>
</message>
<message>
<location filename="../src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp" line="35"/>
@@ -9715,12 +9719,12 @@
<message>
<location filename="../src/app/qgsdisplayangle.cpp" line="41"/>
<source>%1 degrees</source>
+ <translation>%1 gradi</translation>
</message>
<message>
<location filename="../src/app/qgsdisplayangle.cpp" line="45"/>
<source>%1 radians</source>
+ <translation>%1 radianti</translation>
</message>
<message>
<location filename="../src/app/qgsdisplayangle.cpp" line="49"/>
@@ -9733,7 +9737,7 @@
<message>
<location filename="../src/ui/qgsdisplayanglebase.ui" line="14"/>
<source>Angle</source>
- <translation type="unfinished">Angolo</translation>
+ <translation>Angolo</translation>
</message>
</context>
<context>
@@ -10013,12 +10017,12 @@
<message>
<location filename="../src/plugins/georeferencer/qgsgcplistwidget.cpp" line="176"/>
<source>Recenter</source>
+ <translation>Ricentra</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgcplistwidget.cpp" line="180"/>
<source>Remove</source>
- <translation type="unfinished">Rimuovi</translation>
+ <translation>Rimuovi</translation>
</message>
</context>
<context>
@@ -10605,7 +10609,7 @@
<source>Unable to read the selected file.
Please reselect a valid file.</source>
<translation>Impossibile leggere il file selezionato
-Seleziona un file valido.</translation>
+Scegli un file valido.</translation>
</message>
<message>
<location filename="../src/plugins/gps_importer/qgsgpsplugin.cpp" line="416"/>
@@ -10633,12 +10637,12 @@
<location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="246"/>
<location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="377"/>
<source>Select GPX file</source>
- <translation>Seleziona file GPX</translation>
+ <translation>Scegli un file GPX</translation>
</message>
<message>
<location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="261"/>
<source>Select file and format to import</source>
- <translation>Seleziona file e formato da importare</translation>
+ <translation>Scegli file e formato da importare</translation>
</message>
<message>
<location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="98"/>
@@ -10663,7 +10667,7 @@
<location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="295"/>
<location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="389"/>
<source>Choose a file name to save under</source>
- <translation>Seleziona un nome con cui salvare il file</translation>
+ <translation>Scegli un nome con cui salvare il file</translation>
</message>
</context>
<context>
@@ -10866,7 +10870,7 @@
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="14"/>
<source>Configure Georeferencer</source>
+ <translation>Configura il georeferenziatore</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="20"/>
@@ -10876,12 +10880,12 @@
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="26"/>
<source>Show IDs</source>
+ <translation>Mostra ID</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="36"/>
<source>Show coords</source>
+ <translation>Mostra le coordinate</translation>
</message>
</context>
<context>
@@ -10898,7 +10902,12 @@
p, li { white-space: pre-wrap; }
</style></head><body style=" font-family:'Sans Serif'; font-size:10pt; font-weight:400; font-style:normal;">
<p style="-qt-paragraph-type:empty; margin-top:12px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p></body></html></source>
+ <translatorcomment>identico</translatorcomment>
+ <translation><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><meta name="qrichtext" content="1" /><style type="text/css">
+p, li { white-space: pre-wrap; }
+</style></head><body style=" font-family:'Sans Serif'; font-size:10pt; font-weight:400; font-style:normal;">
+<p style="-qt-paragraph-type:empty; margin-top:12px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p></body></html></translation>
</message>
</context>
<context>
@@ -10906,7 +10915,7 @@
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="103"/>
<source>&About</source>
+ <translation>&Informazioni</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsgeorefplugin.cpp" line="98"/>
@@ -11899,7 +11908,7 @@
<location filename="../src/plugins/grass/qgsgrassedittools.cpp" line="460"/>
<location filename="../src/plugins/grass/qgsgrassedittools.cpp" line="471"/>
<source>Select line segment</source>
- <translation>Seleziona segmento di linea</translation>
+ <translation>Scegli segmento di linea</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassedittools.cpp" line="456"/>
@@ -11917,7 +11926,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassedittools.cpp" line="870"/>
<source>Select element</source>
- <translation>Seleziona elemento</translation>
+ <translation>Scegli elemento</translation>
</message>
</context>
<context>
@@ -12798,12 +12807,12 @@
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2967"/>
<source>Warning</source>
- <translation type="unfinished">Attenzione</translation>
+ <translation>Attenzione</translation>
</message>
<message>
<source>'layer' attribute in field tag with key= %1 is missing.</source>
+ <translation>manca l'attributo 'layer' nel campo con key= %1.</translation>
</message>
</context>
<context>
@@ -12829,7 +12838,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2690"/>
<source>OGR/PostGIS/GDAL Input</source>
+ <translation>Input OGR/PostGIS/GDAL</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2710"/>
@@ -12856,7 +12865,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2771"/>
<source>Select a layer</source>
- <translation>Seleziona un layer</translation>
+ <translation>Scegli un layer</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2934"/>
@@ -12936,17 +12945,17 @@
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="585"/>
<source>Item with key %1 not found</source>
+ <translation>Oggetto con chiave %1 non trovato</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="546"/>
<source><< Hide advanced options</source>
+ <translation><< Nascondi le opzioni avanzate</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="551"/>
<source>Show advanced options >></source>
+ <translation>Mostra le opzioni avanzate >></translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="317"/>
@@ -13250,7 +13259,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassnewmapsetbase.ui" line="607"/>
<source>Select existing directory or create a new one:</source>
- <translation>Seleziona una cartella esistente o creane una nuova:</translation>
+ <translation>Scegli una cartella esistente o creane una nuova:</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassnewmapsetbase.ui" line="639"/>
@@ -13260,7 +13269,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassnewmapsetbase.ui" line="654"/>
<source>Select location</source>
- <translation>Seleziona location</translation>
+ <translation>Scegli una location</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassnewmapsetbase.ui" line="671"/>
@@ -13597,12 +13606,12 @@
<message>
<location filename="../src/plugins/grass/qgsgrassplugin.cpp" line="314"/>
<source>Cannot open vector %1 in mapset %2 on level 2 (topology not available, try to rebuild topology using v.build module).</source>
+ <translation>Impossibile aprire il vettore %1 nel mapset %2 a livello 2 (topologia non disponibile, prova a ricostruirla con il modulo v.build).</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassplugin.cpp" line="321"/>
<source>Cannot open vector %1 in mapset %2</source>
+ <translation>Impossibile aprire il vettore %1 nel mapset %2</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassplugin.cpp" line="426"/>
@@ -13780,22 +13789,22 @@
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="64"/>
<source>Select GRASS Vector Layer</source>
- <translation>Seleziona layer vettoriale GRASS</translation>
+ <translation>Scegli layer vettoriale GRASS</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="71"/>
<source>Select GRASS Raster Layer</source>
- <translation>Seleziona layer raster GRASS</translation>
+ <translation>Scegli layer raster GRASS</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="78"/>
<source>Select GRASS mapcalc schema</source>
- <translation>Seleziona schema mapcalc GRASS</translation>
+ <translation>Scegli schema mapcalc GRASS</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="86"/>
<source>Select GRASS Mapset</source>
- <translation>Seleziona Mapset GRASS</translation>
+ <translation>Scegli mapset GRASS</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="421"/>
@@ -13806,17 +13815,17 @@
<message>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="428"/>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="485"/>
<source>Choose existing GISDBASE</source>
- <translation>Seleziona un GISDBASE esistente</translation>
+ <translation>Scegli un GISDBASE esistente</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="502"/>
@@ -13831,7 +13840,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="521"/>
<source>Select a map.</source>
- <translation>Seleziona una mappa.</translation>
+ <translation>Scegli una mappa.</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselect.cpp" line="522"/>
@@ -13889,7 +13898,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassselectbase.ui" line="119"/>
<source>Select or type map name (wildcards '*' and '?' accepted for rasters)</source>
- <translation>Seleziona o scrivi il nome della mappa (i caratteri jolly '*' e '?' sono validi per i raster)</translation>
+ <translation>Scegli o scrivi il nome della mappa (i caratteri jolly '*' e '?' sono validi per i raster)</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassselectbase.ui" line="19"/>
@@ -14004,7 +14013,7 @@
<message>
<location filename="../src/helpviewer/qgshelpviewer.cpp" line="139"/>
<source>This help file is not available in your language %1. If you would like to translate it, please contact the QGIS development team.</source>
+ <translation>Questa guida non esiste nella lingua attualmente in uso %1. Se sei interessato a crearla, contatta il team di sviluppo di QGIS.</translation>
</message>
<message>
<location filename="../src/helpviewer/qgshelpviewer.cpp" line="196"/>
@@ -14025,7 +14034,7 @@
<message>
<location filename="../src/helpviewer/qgshelpviewer.cpp" line="144"/>
<source>This help file does not exist for your language:<p><b>%1</b><p>If you would like to create it, contact the QGIS development team</source>
- <translation>Questa guida non esiste nella lingua attualmente in uso.<p><b>%1</b><p>Se interessati a crearlo, contattare il team di sviluppo QGIS</translation>
+ <translation>Questa guida non esiste nella lingua attualmente in uso.<p><b>%1</b><p>Se sei interessato a crearla, contatta il team di sviluppo di QGIS</translation>
</message>
<message>
<location filename="../src/helpviewer/qgshelpviewer.cpp" line="191"/>
@@ -14302,7 +14311,7 @@
<message>
<location filename="../src/plugins/georeferencer/qgsimagewarper.cpp" line="220"/>
<source>Progress indication</source>
+ <translation>Indicazione di avanzamento</translation>
</message>
</context>
<context>
@@ -14925,12 +14934,12 @@
<message>
<location filename="../src/app/legend/qgslegendlayer.cpp" line="427"/>
<source>Save as...</source>
+ <translation>Salva con nome...</translation>
</message>
<message>
<location filename="../src/app/legend/qgslegendlayer.cpp" line="430"/>
<source>Save selection as...</source>
+ <translation>Salva la selezione con nome...</translation>
</message>
<message>
<location filename="../src/app/legend/qgslegendlayer.cpp" line="441"/>
@@ -14947,7 +14956,7 @@
<location filename="../src/app/legend/qgslegendlayer.cpp" line="546"/>
<location filename="../src/app/legend/qgslegendlayer.cpp" line="634"/>
<source>Select the coordinate reference system for the saved shapefile. The data points will be transformed from the layer coordinate reference system.</source>
- <translation>Seleziona il sistema di riferimento di coordinate per lo shapefile salvato. Le informazioni dei punti saranno trasformate secondo il sistema di coordinate di riferimento del layer.</translation>
+ <translation>Scegli il sistema di riferimento di coordinate per lo shapefile salvato. Le informazioni dei punti saranno trasformate secondo il sistema di coordinate di riferimento del layer.</translation>
</message>
<message>
<location filename="../src/app/legend/qgslegendlayer.cpp" line="668"/>
@@ -14962,7 +14971,7 @@
<message>
<location filename="../src/app/legend/qgslegendlayer.cpp" line="672"/>
<source>Save error</source>
- <translation type="unfinished">Errore di scrittura</translation>
+ <translation>Errore di scrittura</translation>
</message>
</context>
<context>
@@ -15112,17 +15121,17 @@
<message>
<location filename="../src/ui/qgsmanageconnectionsdialogbase.ui" line="14"/>
<source>Manage connections</source>
+ <translation>Gestisci le connessioni</translation>
</message>
<message>
<location filename="../src/ui/qgsmanageconnectionsdialogbase.ui" line="22"/>
<source>Save to file</source>
+ <translation>Salva su file</translation>
</message>
<message>
<location filename="../src/ui/qgsmanageconnectionsdialogbase.ui" line="32"/>
<source>Browse</source>
- <translation type="unfinished">Sfoglia</translation>
+ <translation>Sfoglia</translation>
</message>
</context>
<context>
@@ -15148,7 +15157,7 @@
<message>
<location filename="../src/plugins/georeferencer/qgsmapcoordsdialog.cpp" line="31"/>
<source>From map canvas</source>
+ <translation>Dalla mappa</translation>
</message>
</context>
<context>
@@ -15156,7 +15165,7 @@
<message>
<location filename="../src/plugins/georeferencer/qgsmapcoordsdialogbase.ui" line="14"/>
<source>Enter map coordinates</source>
- <translation type="unfinished">Inserire le coordinate mappa</translation>
+ <translation>Inserisci le coordinate mappa</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsmapcoordsdialogbase.ui" line="23"/>
@@ -15166,12 +15175,12 @@
<message>
<location filename="../src/plugins/georeferencer/qgsmapcoordsdialogbase.ui" line="35"/>
<source>X:</source>
- <translation type="unfinished">X:</translation>
+ <translation>X:</translation>
</message>
<message>
<location filename="../src/plugins/georeferencer/qgsmapcoordsdialogbase.ui" line="49"/>
<source>Y:</source>
- <translation type="unfinished">Y:</translation>
+ <translation>Y:</translation>
</message>
</context>
<context>
@@ -15381,13 +15390,13 @@
<location filename="../src/app/qgsmaptooladdisland.cpp" line="63"/>
<location filename="../src/app/qgsmaptooladdisland.cpp" line="122"/>
<source>No feature selected. Please select a feature with the selection tool or in the attribute table</source>
- <translation>Nessuna geometria selezionata. Seleziona una geometria con lo strumento di selezione o mediante la tabella attributi</translation>
+ <translation>Nessuna geometria selezionata. Scegli una geometria con lo strumento di selezione o mediante la tabella attributi</translation>
</message>
<message>
<location filename="../src/app/qgsmaptooladdisland.cpp" line="67"/>
<location filename="../src/app/qgsmaptooladdisland.cpp" line="126"/>
<source>Several features are selected. Please select only one feature to which an island should be added.</source>
- <translation type="unfinished">Ci sono più geometrie selezionate. Seleziona una sola geometria alla quale aggiungere un'isola.</translation>
+ <translation>Ci sono più geometrie selezionate. Scegli una sola geometria alla quale aggiungere un'isola.</translation>
</message>
<message>
<location filename="../src/app/qgsmaptooladdisland.cpp" line="72"/>
@@ -16730,22 +16739,22 @@
<message>
<location filename="../src/app/ogr/qgsogrsublayersdialog.cpp" line="26"/>
<source>Layer ID</source>
+ <translation>ID del layer</translation>
</message>
<message>
<source>Layer name</source>
+ <translation>Nome del layer</translation>
</message>
<message>
<source>Nb of features</source>
+ <translation>N di geometrie</translation>
</message>
<message>
<source>Geometry type</source>
+ <translation>Tipo di geometria</translation>
</message>
</context>
<context>
@@ -16753,7 +16762,7 @@
<message>
<location filename="../src/ui/qgsogrsublayersdialogbase.ui" line="13"/>
<source>Select OGR layers to load</source>
- <translation>Seleziona i layer OGR da caricare</translation>
+ <translation>Scegli i layer OGR da caricare</translation>
</message>
<message>
<location filename="../src/ui/qgsogrsublayersdialogbase.ui" line="57"/>
@@ -17293,7 +17302,7 @@
<location filename="../src/app/qgsoptions.cpp" line="815"/>
<location filename="../src/app/qgsoptions.cpp" line="857"/>
<source>Choose a directory</source>
- <translation>Seleziona una cartella</translation>
+ <translation>Scegli una cartella</translation>
</message>
<message>
<location filename="../src/app/qgsoptions.cpp" line="288"/>
@@ -17881,7 +17890,7 @@
<message>
<location filename="../src/plugins/oracle_raster/qgsoracle_plugin.cpp" line="56"/>
<source>Select GeoRaster</source>
- <translation>Seleziona GeoRaster</translation>
+ <translation>Scegli GeoRaster</translation>
</message>
<message>
<location filename="../src/plugins/oracle_raster/qgsoracle_plugin.cpp" line="58"/>
@@ -18266,22 +18275,22 @@
<message>
<location filename="../src/app/postgres/qgspgsourceselect.cpp" line="57"/>
<source>&Save</source>
+ <translation>&Salva</translation>
</message>
<message>
<location filename="../src/app/postgres/qgspgsourceselect.cpp" line="58"/>
<source>Save connections</source>
+ <translation>Salva connessioni</translation>
</message>
<message>
<location filename="../src/app/postgres/qgspgsourceselect.cpp" line="62"/>
<source>&Load</source>
+ <translation>&Carica</translation>
</message>
<message>
<location filename="../src/app/postgres/qgspgsourceselect.cpp" line="63"/>
<source>Load connections</source>
+ <translation>Carica connessioni</translation>
</message>
<message>
<location filename="../src/app/postgres/qgspgsourceselect.cpp" line="70"/>
@@ -18350,7 +18359,7 @@
<message>
<location filename="../src/app/postgres/qgspgsourceselect.cpp" line="394"/>
<source>Select Table</source>
- <translation>Seleziona tabella</translation>
+ <translation>Scegli tabella</translation>
</message>
<message>
@@ -18446,7 +18455,7 @@
<message>
<location filename="../src/ui/qgspgsourceselectbase.ui" line="94"/>
<source>Search options</source>
+ <translation>Opzioni di ricerca</translation>
</message>
<message>
<location filename="../src/ui/qgspgsourceselectbase.ui" line="118"/>
@@ -19186,7 +19195,7 @@
<name>QgsPluginInstallerPluginErrorDialog</name>
<message>
<source>no error message received</source>
- <translation type="unfinished">non è stato ricevuto nessun messaggio di errore</translation>
+ <translation>non è stato ricevuto nessun messaggio di errore</translation>
</message>
</context>
<context>
@@ -19370,7 +19379,7 @@
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3052"/>
<source>Unable to get feature type and srid</source>
- <translation type="unfinished">Impossibile recuperare il tipo di geometria e lo SRID</translation>
+ <translation>Impossibile recuperare il tipo di geometria e lo SRID</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2346"/>
@@ -19458,7 +19467,7 @@
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3048"/>
<source>Qgis was unable to determine the type and srid of column %1 in %2. The database communication log was:
%3</source>
- <translation type="unfinished">Impossibile individuare il tipo e lo SRID della colonna %1 in %2. Questo il messaggio di log del database:
+ <translation>Impossibile individuare il tipo e lo SRID della colonna %1 in %2. Questo il messaggio di log del database:
%3</translation>
</message>
<message>
@@ -19871,7 +19880,7 @@
<message>
<location filename="../src/ui/qgsprojectionselectorbase.ui" line="52"/>
<source>Authority ID</source>
+ <translation>ID dell'autorità</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectionselectorbase.ui" line="105"/>
@@ -19881,7 +19890,7 @@
<message>
<location filename="../src/ui/qgsprojectionselectorbase.ui" line="111"/>
<source>AuthorityID</source>
+ <translation>AuthorityID</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectionselectorbase.ui" line="149"/>
@@ -19896,7 +19905,7 @@
<message>
<location filename="../src/ui/qgsprojectionselectorbase.ui" line="20"/>
<source>Coordinate Reference System Selector</source>
- <translation>Seleziona Coordinate di Riferimento Spaziale</translation>
+ <translation>Selettore Coordinate di Riferimento Spaziale (CRS)</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectionselectorbase.ui" line="47"/>
@@ -20968,7 +20977,7 @@
</style></head><body style=" font-family:'Sans Serif'; font-size:9pt; font-weight:400; font-style:normal;">
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p></body></html></source>
- <translation type="unfinished"><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
@@ -21621,12 +21630,12 @@
<message>
<location filename="../src/plugins/diagram_overlay/qgssvgdiagramfactorywidget.cpp" line="93"/>
<source>Select svg file</source>
- <translation>Seleziona file svg</translation>
+ <translation>Scegli file SVG</translation>
</message>
<message>
<location filename="../src/plugins/diagram_overlay/qgssvgdiagramfactorywidget.cpp" line="133"/>
</message>
<message>
<location filename="../src/plugins/diagram_overlay/qgssvgdiagramfactorywidget.cpp" line="182"/>
@@ -21672,7 +21681,7 @@
<message>
<location filename="../src/gui/symbology-ng/qgssymbollayerv2widget.cpp" line="598"/>
<source>Select svg texture file</source>
+ <translation>Scegli un file di texture SVG</translation>
</message>
</context>
<context>
@@ -21845,13 +21854,13 @@
<message>
<location filename="../src/plugins/scale_bar/pluginguibase.ui" line="126"/>
<source>Color of bar</source>
+ <translation>Colore della barra</translation>
</message>
<message>
<location filename="../src/plugins/scale_bar/pluginguibase.ui" line="142"/>
<location filename="../src/plugins/scale_bar/pluginguibase.ui" line="145"/>
<source>Click to select the color</source>
+ <translation>Clicca per scegliere il colore</translation>
</message>
<message>
<location filename="../src/plugins/scale_bar/pluginguibase.ui" line="161"/>
@@ -21881,7 +21890,7 @@
<message>
<location filename="../src/plugins/scale_bar/pluginguibase.ui" line="93"/>
<source>Select the style of the scale bar</source>
- <translation>Seleziona lo stile della barra di scala</translation>
+ <translation>Scegli lo stile della barra di scala</translation>
</message>
<message>
<location filename="../src/plugins/scale_bar/pluginguibase.ui" line="187"/>
@@ -21936,8 +21945,8 @@
<source>Found %n matching feature(s).</source>
<comment>test result</comment>
<translation>
- <numerusform>Trovata %n geometria corrispondente</numerusform>
- <numerusform>Trovate %n geometria corrispondenti</numerusform>
+ <numerusform>Trovata %n geometria corrispondente.</numerusform>
+ <numerusform>Trovate %n geometria corrispondenti.</numerusform>
</translation>
</message>
</context>
@@ -22271,7 +22280,7 @@
<message>
<location filename="../src/app/qgsspatialitesourceselect.cpp" line="302"/>
<source>Choose a SpatiaLite/SQLite DB to open</source>
- <translation>Seleziona un DB SpatiaLite/SQLite da aprire</translation>
+ <translation>Scegli un DB SpatiaLite/SQLite da aprire</translation>
</message>
<message>
<location filename="../src/app/qgsspatialitesourceselect.cpp" line="342"/>
@@ -22281,12 +22290,12 @@
<message>
<location filename="../src/app/qgsspatialitesourceselect.cpp" line="411"/>
</message>
<message>
<source>You must select a table in order to add a Layer.</source>
- <translation>Prima di aggiungere un layer occorre selezionare una tabella.</translation>
+ <translation>Prima di aggiungere un layer occorre scegliere una tabella.</translation>
</message>
<message>
<location filename="../src/app/qgsspatialitesourceselect.cpp" line="588"/>
@@ -22475,7 +22484,7 @@
<message>
<location filename="../src/plugins/spit/qgsspit.cpp" line="368"/>
<source>[Add ...] - open a File dialog and browse to the desired file(s) to import</source>
- <translation>[Aggiungi ... ] - apre una finestra di dialogo da cui puoi sfogliare il file system e selezionare uno o più file da importare</translation>
+ <translation>[Aggiungi ... ] - apre una finestra di dialogo da cui puoi sfogliare il file system e scegliere uno o più file da importare</translation>
</message>
<message>
<location filename="../src/plugins/spit/qgsspit.cpp" line="369"/>
@@ -22919,7 +22928,7 @@
<message>
<location filename="../src/gui/symbology-ng/qgssymbolv2selectordialog.cpp" line="263"/>
<source>Transparency: %1%</source>
- <translation type="unfinished">Trasparenza: %1%</translation>
+ <translation>Trasparenza: %1%</translation>
</message>
</context>
<context>
@@ -22932,22 +22941,22 @@
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="52"/>
<source>Unit</source>
+ <translation>Unità</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="60"/>
<source>Millimeter</source>
- <translation type="unfinished">Millimetri</translation>
+ <translation>Millimetri</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="65"/>
<source>Map unit</source>
+ <translation>Unità mappa</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="73"/>
<source>Opacity</source>
- <translation type="unfinished">Opacità</translation>
+ <translation>Opacità</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="96"/>
@@ -23812,7 +23821,7 @@
<message>
<location filename="../src/app/qgsvectorlayerproperties.cpp" line="1067"/>
<source>Select edit form</source>
- <translation>Seleziona form di modifica</translation>
+ <translation>Scegli form di modifica</translation>
</message>
<message>
@@ -24341,7 +24350,6 @@
<comment>selected layer count</comment>
</translation>
</message>
<message>
@@ -24882,7 +24890,6 @@
<comment>tile request count</comment>
</translation>
</message>
@@ -24892,7 +24899,6 @@
<comment>tile cache hits</comment>
</translation>
</message>
@@ -24902,7 +24908,6 @@
<comment>tile cache missed</comment>
</translation>
</message>
@@ -24912,7 +24917,6 @@
<comment>errors</comment>
</translation>
</message>
<message>
@@ -25088,7 +25092,7 @@
<message>
<location filename="../src/plugins/oracle_raster/qgsselectgeorasterbase.ui" line="14"/>
<source>Select Oracle Spatial GeoRaster</source>
- <translation>Seleziona Oracle Spatial GeoRaster</translation>
+ <translation>Scegli Oracle Spatial GeoRaster</translation>
</message>
<message>
<location filename="../src/plugins/oracle_raster/qgsselectgeorasterbase.ui" line="36"/>
@@ -25223,23 +25227,23 @@
<name>VisualDialog</name>
<message>
<source>Error!</source>
- <translation type="unfinished">Errore!</translation>
+ <translation>Errore!</translation>
</message>
<message>
</message>
<message>
<source>Parameter</source>
+ <translation>Parametro</translation>
</message>
<message>
<source>Value</source>
- <translation type="unfinished">Valore</translation>
+ <translation>Valore</translation>
</message>
<message>
- <translation>Seleziona vettoriale in input</translation>
+ <translation>Scegli vettoriale in input</translation>
</message>
<message>
<source>Please specify input field</source>
@@ -25251,7 +25255,7 @@
</message>
<message>
<source>Geometry errors</source>
- <translation type="unfinished">Errori geometria</translation>
+ <translation>Errori geometria</translation>
</message>
<message>
<source>Total encountered errors</source>
@@ -25380,27 +25384,27 @@
<message>
<location filename="../src/ui/symbollayer/widget_svgfill.ui" line="14"/>
<source>Form</source>
+ <translation>Modulo</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_svgfill.ui" line="22"/>
<source>Texture width:</source>
+ <translation>Larghezza della texture:</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_svgfill.ui" line="40"/>
<source>Outline:</source>
+ <translation>Contorno esterno:</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_svgfill.ui" line="47"/>
<source>Change</source>
- <translation type="unfinished">Cambia</translation>
+ <translation>Cambia</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_svgfill.ui" line="71"/>
<source>...</source>
- <translation type="unfinished">...</translation>
+ <translation>...</translation>
</message>
</context>
<context>
@@ -25673,7 +25677,7 @@
<message>
<location filename="../src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp" line="153"/>
<source>Choose a DXF file to open</source>
- <translation>Seleziona un file DXF da aprire</translation>
+ <translation>Scegli un file DXF da aprire</translation>
</message>
</context>
<context>
@@ -25828,7 +25832,7 @@
<message>
<location filename="../src/plugins/evis/ui/evisdatabaseconnectionguibase.ui" line="108"/>
<source>Select the predefined query you want to use from the drop-down list containing queries identified from the file loaded using the Open File icon above. To run the query you need to click on the SQL Query tab. The query will be automatically entered in the query window.</source>
- <translation>Seleziona la query predefinita che vuoi utilizzare dalla lista di drop down contenente le query del file caricato dall´icona Open File. Per eseguire la query si deve fare clic sul tab Query SQL. La query viene automaticamente inserita nella finestra di query.</translation>
+ <translation>Scegli la query predefinita che vuoi utilizzare dalla lista di drop down contenente le query del file caricato dall´icona Open File. Per eseguire la query si deve fare clic sul tab Query SQL. La query viene automaticamente inserita nella finestra di query.</translation>
</message>
<message>
<location filename="../src/plugins/evis/ui/evisdatabaseconnectionguibase.ui" line="165"/>
@@ -25894,7 +25898,7 @@
<message>
<location filename="../src/plugins/evis/ui/evisdatabaseconnectionguibase.ui" line="269"/>
<source>Select the type of database from the list of supported databases in the drop-down menu.</source>
- <translation>Seleziona il tipo di database dalla lista dei database supportati nel menu di drop down.</translation>
+ <translation>Scegli il tipo di database dalla lista dei database supportati nel menu di drop down.</translation>
</message>
<message>
<location filename="../src/plugins/evis/ui/evisdatabaseconnectionguibase.ui" line="289"/>
@@ -25952,7 +25956,7 @@
<message>
<location filename="../src/plugins/evis/ui/evisdatabaselayerfieldselectionguibase.ui" line="16"/>
<source>Database File Selection</source>
- <translation>Selezione File Database</translation>
+ <translation>Scegli file Database</translation>
</message>
<message>
<location filename="../src/plugins/evis/ui/evisdatabaselayerfieldselectionguibase.ui" line="45"/>
@@ -26120,7 +26124,7 @@
<message>
<location filename="../src/plugins/evis/ui/evisgenericeventbrowserguibase.ui" line="199"/>
<source>Use the drop-down list to select the field containing a directory path to the image. This can be an absolute or relative path.</source>
- <translation type="unfinished">Utilizza la lista drop down per selezionare il campo contenente il percorso della directory dell´immagine.Può essere un percorso assoluto o relativo.</translation>
+ <translation>Utilizza la lista drop down per selezionare il campo contenente il percorso della directory dell´immagine.Può essere un percorso assoluto o relativo.</translation>
</message>
<message utf8="true">
<location filename="../src/plugins/evis/ui/evisgenericeventbrowserguibase.ui" line="222"/>
@@ -26465,11 +26469,11 @@
</message>
<message>
<source>Random selection</source>
- <translation type="unfinished">Selezione casuale</translation>
+ <translation>Selezione casuale</translation>
</message>
<message>
<source>Random selection within subsets</source>
- <translation type="unfinished">Selezione causale con un sottoinsieme</translation>
+ <translation>Selezione causale con un sottoinsieme</translation>
</message>
<message>
<source>Random points</source>
@@ -26485,138 +26489,138 @@
</message>
<message>
<source>Select by location</source>
- <translation type="unfinished">Seleziona per localizzazione</translation>
+ <translation>Seleziona per localizzazione</translation>
</message>
<message>
</message>
<message>
<source>&Geoprocessing Tools</source>
- <translation type="unfinished">Strumenti di &Geoprocessing</translation>
+ <translation>Strumenti di &Geoprocessing</translation>
</message>
<message>
<source>Convex hull(s)</source>
- <translation type="unfinished">Inviluppo/i convesso/i</translation>
+ <translation>Inviluppo/i convesso/i</translation>
</message>
<message>
<source>Buffer(s)</source>
- <translation type="unfinished">Buffer</translation>
+ <translation>Buffer</translation>
</message>
<message>
<source>Intersect</source>
- <translation type="unfinished">Intersezione</translation>
+ <translation>Intersezione</translation>
</message>
<message>
<source>Union</source>
- <translation type="unfinished">Unione</translation>
+ <translation>Unione</translation>
</message>
<message>
<source>Symetrical difference</source>
- <translation type="unfinished">Differenza simmetrica</translation>
+ <translation>Differenza simmetrica</translation>
</message>
<message>
<source>Clip</source>
- <translation type="unfinished">Clip</translation>
+ <translation>Clip</translation>
</message>
<message>
<source>Dissolve</source>
- <translation type="unfinished">Dissolvenza</translation>
+ <translation>Dissolvenza</translation>
</message>
<message>
<source>Difference</source>
- <translation type="unfinished">Differenza</translation>
+ <translation>Differenza</translation>
</message>
<message>
<source>G&eometry Tools</source>
- <translation type="unfinished">Strumenti di G&eometria</translation>
+ <translation>Strumenti di G&eometria</translation>
</message>
<message>
- <translation type="unfinished">Estrai/Aggiungi colonne geometriche</translation>
+ <translation>Estrai/Aggiungi colonne geometriche</translation>
</message>
<message>
<source>Check geometry validity</source>
- <translation type="unfinished">Controlla validità geometria</translation>
+ <translation>Controlla validità geometria</translation>
</message>
<message>
- <translation type="unfinished">Centroidi di poligoni</translation>
+ <translation>Centroidi di poligoni</translation>
</message>
<message>
- <translation type="unfinished">Triangolazione Delaunay</translation>
+ <translation>Triangolazione Delaunay</translation>
</message>
<message>
</message>
<message>
</message>
<message>
<source>Multipart to singleparts</source>
- <translation type="unfinished">Da parti multiple a parti singole</translation>
+ <translation>Da parti multiple a parti singole</translation>
</message>
<message>
<source>Singleparts to multipart</source>
- <translation type="unfinished">Da parti singole a parti multiple</translation>
+ <translation>Da parti singole a parti multiple</translation>
</message>
<message>
</message>
<message>
<source>&Data Management Tools</source>
- <translation type="unfinished">Strumenti di gestione &Dati</translation>
+ <translation>Strumenti di gestione &Dati</translation>
</message>
<message>
<source>Export to new projection</source>
- <translation type="unfinished">Esporta a nuova proiezione</translation>
+ <translation>Esporta a nuova proiezione</translation>
</message>
<message>
<source>Define current projection</source>
- <translation type="unfinished">Definisci la proiezione in uso</translation>
+ <translation>Definisci la proiezione in uso</translation>
</message>
<message>
<source>Join attributes</source>
- <translation type="unfinished">Unisci attributi</translation>
+ <translation>Unisci attributi</translation>
</message>
<message>
<source>Join attributes by location</source>
- <translation type="unfinished">Unisci attributi per localizzazione</translation>
+ <translation>Unisci attributi per localizzazione</translation>
</message>
<message>
<source>Split vector layer</source>
- <translation type="unfinished">Dividi vettoriale</translation>
+ <translation>Dividi vettoriale</translation>
</message>
<message>
<source>fTools Information</source>
- <translation type="unfinished">Informazioni fTools</translation>
+ <translation>Informazioni fTools</translation>
</message>
</context>
<context>
<name>geometryThread</name>
<message>
<source>Polygon area</source>
+ <translation>Area del poligono</translation>
</message>
<message>
<source>Polygon perimeter</source>
+ <translation>Perimetro del poligono</translation>
</message>
<message>
<source>Line length</source>
+ <translation>Lunghezza della linea</translation>
</message>
<message>
<source>Point x coordinate</source>
+ <translation>Coordinata X del punto</translation>
</message>
<message>
<source>Point y coordinate</source>
+ <translation>Coordinata Y del punto</translation>
</message>
</context>
<context>
