[QGIS Commit] r14561 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Fri Nov 12 11:59:36 EST 2010
Author: aghisla
Date: 2010-11-12 08:59:36 -0800 (Fri, 12 Nov 2010)
New Revision: 14561
docs/trunk/english_us/user_guide/features_at_a_glance.tex
Added documentation for --optionspath and --configpath.
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-11-12 16:42:52 UTC (rev 14560)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-11-12 16:59:36 UTC (rev 14561)
@@ -51,6 +51,9 @@
[--project projectfile] load the given QGIS project
[--extent xmin,ymin,xmax,ymax] set initial map extent
[--nologo] hide splash screen
+ [--noplugins] don't restore plugins on startup
+ [--optionspath path] use the given QSettings path
+ [--configpath path] use the given path for all user configuration
[--help] this text
FILES:
@@ -103,6 +106,15 @@
\minisec{Command line option \usertext{---nologo}}
This command line argument hides the splash screen when you start QGIS.
+\minisec{Command line option \usertext{---noplugins}}
+If you have trouble at startup with plugins, you can avoid loading them at startup. They will still be available in Plugins Manager afterwards.
+\minisec{Command line option \usertext{---optionspath}}
+You can have multiple configurations and decide which one to use when starting QGIS using this option. See \ref{subsec:gui_options} to check where does the operating system save the settings files. Presently there is no way to specify in which file where to write the settings, therefore you can create a copy of the original settings file and rename it.
+\minisec{Command line option \usertext{---configpath}}
+This option is similar to the one above, but furthermore overrides the default path (~/.qgis) for user configuration and forces QSettings to use this directory, too. This allows users to e.g. carry QGIS installation on a flash drive together with all plugins and settings
\section{QGIS GUI}\index{main window}
\label{label_qgismainwindow}
