[QGIS Commit] r14562 - in trunk/qgis: python/core src/app/ogr
src/core src/ui
svn_qgis at osgeo.org
Fri Nov 12 12:00:49 EST 2010
Author: jef
Date: 2010-11-12 09:00:49 -0800 (Fri, 12 Nov 2010)
New Revision: 14562
trunk/qgis/python/core/qgsvectorfilewriter.sip
trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp
trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.h
trunk/qgis/src/core/qgsvectorfilewriter.cpp
trunk/qgis/src/core/qgsvectorfilewriter.h
trunk/qgis/src/ui/qgsvectorlayersaveasdialogbase.ui
[FEATURE] allow OGR save as without attributes (for eg. DGN/DXF)
Modified: trunk/qgis/python/core/qgsvectorfilewriter.sip
--- trunk/qgis/python/core/qgsvectorfilewriter.sip 2010-11-12 16:59:36 UTC (rev 14561)
+++ trunk/qgis/python/core/qgsvectorfilewriter.sip 2010-11-12 17:00:49 UTC (rev 14562)
@@ -44,7 +44,9 @@
bool onlySelected = FALSE,
QString *errorMessage = 0,
const QStringList &datasourceOptions = QStringList(),
- const QStringList &layerOptions = QStringList() );
+ const QStringList &layerOptions = QStringList(),
+ bool skipAttributeCreation = FALSE // added in 1.7
/** create shapefile and initialize it */
QgsVectorFileWriter(const QString& vectorFileName,
Modified: trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp
--- trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp 2010-11-12 16:59:36 UTC (rev 14561)
+++ trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.cpp 2010-11-12 17:00:49 UTC (rev 14562)
@@ -26,15 +26,15 @@
#include <QTextCodec>
QgsVectorLayerSaveAsDialog::QgsVectorLayerSaveAsDialog( QWidget* parent, Qt::WFlags fl )
- : QDialog( parent, fl )
- , mCRS( -1 )
+ : QDialog( parent, fl )
+ , mCRS( -1 )
setupUi( this );
QSettings settings;
QMap<QString, QString> map = QgsVectorFileWriter::ogrDriverList();
mFormatComboBox->blockSignals( true );
- for ( QMap< QString, QString>::const_iterator it = map.constBegin(); it != map.constEnd(); ++it )
+ for( QMap< QString, QString>::const_iterator it = map.constBegin(); it != map.constEnd(); ++it )
mFormatComboBox->addItem( it.key(), it.value() );
@@ -47,7 +47,7 @@
QString enc = settings.value( "/UI/encoding", QString( "System" ) ).toString();
int idx = mEncodingComboBox->findText( enc );
- if ( idx < 0 )
+ if( idx < 0 )
mEncodingComboBox->insertItem( 0, enc );
idx = 0;
@@ -77,7 +77,7 @@
browseFilename->setEnabled( true );
leFilename->setEnabled( true );
- if ( format() == "KML" )
+ if( format() == "KML" )
mEncodingComboBox->setCurrentIndex( mEncodingComboBox->findText( "UTF-8" ) );
mEncodingComboBox->setDisabled( true );
@@ -94,7 +94,7 @@
QString dirName = leFilename->text().isEmpty() ? settings.value( "/UI/lastVectorFileFilterDir", "." ).toString() : leFilename->text();
QString filterString = QgsVectorFileWriter::filterForDriver( format() );
QString outputFile = QFileDialog::getSaveFileName( 0, tr( "Save layer as..." ), dirName, filterString );
- if ( !outputFile.isNull() )
+ if( !outputFile.isNull() )
leFilename->setText( outputFile );
@@ -103,12 +103,12 @@
void QgsVectorLayerSaveAsDialog::on_browseCRS_clicked()
QgsGenericProjectionSelector * mySelector = new QgsGenericProjectionSelector();
- if ( mCRS >= 0 )
+ if( mCRS >= 0 )
mySelector->setSelectedCrsId( mCRS );
mySelector->setMessage( tr( "Select the coordinate reference system for the vector file. "
"The data points will be transformed from the layer coordinate reference system." ) );
- if ( mySelector->exec() )
+ if( mySelector->exec() )
QgsCoordinateReferenceSystem srs( mySelector->selectedCrsId(), QgsCoordinateReferenceSystem::InternalCrsId );
mCRS = srs.srsid();
@@ -147,3 +147,8 @@
return mOgrLayerOptions->toPlainText().split( "\n" );
+bool QgsVectorLayerSaveAsDialog::skipAttributeCreation() const
+ return mSkipAttributeCreation->isChecked();
Modified: trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.h
--- trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.h 2010-11-12 16:59:36 UTC (rev 14561)
+++ trunk/qgis/src/app/ogr/qgsvectorlayersaveasdialog.h 2010-11-12 17:00:49 UTC (rev 14562)
@@ -40,6 +40,7 @@
QStringList datasourceOptions() const;
QStringList layerOptions() const;
long crs() const;
+ bool skipAttributeCreation() const;
private slots:
void on_mFormatComboBox_currentIndexChanged( int idx );
Modified: trunk/qgis/src/core/qgsvectorfilewriter.cpp
--- trunk/qgis/src/core/qgsvectorfilewriter.cpp 2010-11-12 16:59:36 UTC (rev 14561)
+++ trunk/qgis/src/core/qgsvectorfilewriter.cpp 2010-11-12 17:00:49 UTC (rev 14562)
@@ -53,10 +53,10 @@
const QStringList &datasourceOptions,
- : mDS( NULL )
- , mLayer( NULL )
- , mGeom( NULL )
- , mError( NoError )
+ : mDS( NULL )
+ , mLayer( NULL )
+ , mGeom( NULL )
+ , mError( NoError )
QString vectorFileName = theVectorFileName;
QString fileEncoding = theFileEncoding;
@@ -66,7 +66,7 @@
QgsApplication::registerOgrDrivers();
poDriver = OGRGetDriverByName( driverName.toLocal8Bit().data() );
- if ( poDriver == NULL )
+ if( poDriver == NULL )
mErrorMessage = QObject::tr( "OGR driver for '%1' not found (OGR error: %2)" )
.arg( driverName )
@@ -75,9 +75,9 @@
return;
- if ( driverName == "ESRI Shapefile" )
+ if( driverName == "ESRI Shapefile" )
- if ( !vectorFileName.endsWith( ".shp", Qt::CaseInsensitive ) )
+ if( !vectorFileName.endsWith( ".shp", Qt::CaseInsensitive ) )
vectorFileName += ".shp";
@@ -85,10 +85,10 @@
// check for unique fieldnames
QSet<QString> fieldNames;
QgsFieldMap::const_iterator fldIt;
- for ( fldIt = fields.begin(); fldIt != fields.end(); ++fldIt )
+ for( fldIt = fields.begin(); fldIt != fields.end(); ++fldIt )
QString name = fldIt.value().name().left( 10 );
- if ( fieldNames.contains( name ) )
+ if( fieldNames.contains( name ) )
mErrorMessage = QObject::tr( "trimming attribute name '%1' to ten significant characters produces duplicate column name." )
.arg( fldIt.value().name() );
@@ -100,14 +100,14 @@
deleteShapeFile( vectorFileName );
- else if ( driverName == "KML" )
+ else if( driverName == "KML" )
- if ( !vectorFileName.endsWith( ".kml", Qt::CaseInsensitive ) )
+ if( !vectorFileName.endsWith( ".kml", Qt::CaseInsensitive ) )
vectorFileName += ".kml";
- if ( fileEncoding.compare( "UTF-8", Qt::CaseInsensitive ) != 0 )
+ if( fileEncoding.compare( "UTF-8", Qt::CaseInsensitive ) != 0 )
QgsDebugMsg( "forced UTF-8 encoding for KML" );
fileEncoding = "UTF-8";
@@ -121,10 +121,10 @@
char **options = NULL;
- if ( !datasourceOptions.isEmpty() )
+ if( !datasourceOptions.isEmpty() )
options = new char *[ datasourceOptions.size()+1 ];
- for ( int i = 0; i < datasourceOptions.size(); i++ )
+ for( int i = 0; i < datasourceOptions.size(); i++ )
options[i] = CPLStrdup( datasourceOptions[i].toLocal8Bit().data() );
@@ -134,15 +134,15 @@
// create the data source
mDS = OGR_Dr_CreateDataSource( poDriver, vectorFileName.toLocal8Bit().data(), options );
- if ( options )
+ if( options )
CPLFree( options[i] );
delete [] options;
options = NULL;
- if ( mDS == NULL )
+ if( mDS == NULL )
mError = ErrCreateDataSource;
mErrorMessage = QObject::tr( "creation of data source failed (OGR error:%1)" )
@@ -154,13 +154,13 @@
// use appropriate codec
mCodec = QTextCodec::codecForName( fileEncoding.toLocal8Bit().data() );
- if ( !mCodec )
+ if( !mCodec )
QSettings settings;
QgsDebugMsg( "error finding QTextCodec for " + fileEncoding );
mCodec = QTextCodec::codecForName( enc.toLocal8Bit().data() );
- if ( !mCodec )
+ if( !mCodec )
QgsDebugMsg( "error finding QTextCodec for " + enc );
mCodec = QTextCodec::codecForLocale();
@@ -169,7 +169,7 @@
// consider spatial reference system of the layer
OGRSpatialReferenceH ogrRef = NULL;
- if ( srs )
+ if( srs )
QString srsWkt = srs->toWkt();
QgsDebugMsg( "WKT to save as is " + srsWkt );
@@ -180,10 +180,10 @@
QString layerName = QFileInfo( vectorFileName ).baseName();
OGRwkbGeometryType wkbType = static_cast<OGRwkbGeometryType>( geometryType );
- if ( !layerOptions.isEmpty() )
+ if( !layerOptions.isEmpty() )
options = new char *[ layerOptions.size()+1 ];
- for ( int i = 0; i < layerOptions.size(); i++ )
+ for( int i = 0; i < layerOptions.size(); i++ )
options[i] = CPLStrdup( layerOptions[i].toLocal8Bit().data() );
@@ -192,21 +192,21 @@
mLayer = OGR_DS_CreateLayer( mDS, QFile::encodeName( layerName ).data(), ogrRef, wkbType, options );
- if ( options )
+ if( options )
delete [] options;
options = NULL;
- if ( srs )
+ if( srs )
QString layerName = vectorFileName.left( vectorFileName.indexOf( ".shp", Qt::CaseInsensitive ) );
QFile prjFile( layerName + ".qpj" );
- if ( prjFile.open( QIODevice::WriteOnly ) )
+ if( prjFile.open( QIODevice::WriteOnly ) )
QTextStream prjStream( &prjFile );
prjStream << srs->toWkt().toLocal8Bit().data() << endl;
@@ -221,7 +221,7 @@
OSRDestroySpatialReference( ogrRef );
- if ( mLayer == NULL )
+ if( mLayer == NULL )
mErrorMessage = QObject::tr( "creation of layer failed (OGR error:%1)" )
.arg( QString::fromUtf8( CPLGetLastErrorMsg() ) );
@@ -240,14 +240,14 @@
mAttrIdxToOgrIdx.clear();
const QgsField& attrField = fldIt.value();
OGRFieldType ogrType = OFTString; //default to string
int ogrWidth = fldIt->length();
int ogrPrecision = fldIt->precision();
- switch ( attrField.type() )
+ switch( attrField.type() )
case QVariant::LongLong:
@@ -257,7 +257,7 @@
case QVariant::String:
- if ( ogrWidth < 0 || ogrWidth > 255 )
+ if( ogrWidth < 0 || ogrWidth > 255 )
ogrWidth = 255;
break;
@@ -281,12 +281,12 @@
// create field definition
OGRFieldDefnH fld = OGR_Fld_Create( mCodec->fromUnicode( attrField.name() ), ogrType );
- if ( ogrWidth > 0 )
+ if( ogrWidth > 0 )
OGR_Fld_SetWidth( fld, ogrWidth );
- if ( ogrPrecision >= 0 )
+ if( ogrPrecision >= 0 )
OGR_Fld_SetPrecision( fld, ogrPrecision );
@@ -296,7 +296,7 @@
" type " + QString( QVariant::typeToName( attrField.type() ) ) +
" width " + QString::number( ogrWidth ) +
" precision " + QString::number( ogrPrecision ) );
- if ( OGR_L_CreateField( mLayer, fld, true ) != OGRERR_NONE )
+ if( OGR_L_CreateField( mLayer, fld, true ) != OGRERR_NONE )
QgsDebugMsg( "error creating field " + attrField.name() );
mErrorMessage = QObject::tr( "creation of field %1 failed (OGR error: %2)" )
@@ -307,24 +307,24 @@
int ogrIdx = OGR_FD_GetFieldIndex( defn, mCodec->fromUnicode( attrField.name() ) );
- if ( ogrIdx < 0 )
+ if( ogrIdx < 0 )
// if we didn't find our new column, assume it's name was truncated and
// it was the last one added (like for shape files)
int fieldCount = OGR_FD_GetFieldCount( defn );
OGRFieldDefnH fdefn = OGR_FD_GetFieldDefn( defn, fieldCount - 1 );
- if ( fdefn )
+ if( fdefn )
const char *fieldName = OGR_Fld_GetNameRef( fdefn );
- if ( attrField.name().left( strlen( fieldName ) ) == fieldName )
+ if( attrField.name().left( strlen( fieldName ) ) == fieldName )
ogrIdx = fieldCount - 1;
- if ( ogrIdx < 0 )
+ if( ogrIdx < 0 )
mErrorMessage = QObject::tr( "created field %1 not found (OGR error: %2)" )
@@ -370,15 +370,15 @@
// attribute handling
- for ( fldIt = mFields.begin(); fldIt != mFields.end(); ++fldIt )
+ for( fldIt = mFields.begin(); fldIt != mFields.end(); ++fldIt )
- if ( !feature.attributeMap().contains( fldIt.key() ) )
+ if( !feature.attributeMap().contains( fldIt.key() ) )
QgsDebugMsg( QString( "no attribute for field %1" ).arg( fldIt.key() ) );
continue;
- if ( !mAttrIdxToOgrIdx.contains( fldIt.key() ) )
+ if( !mAttrIdxToOgrIdx.contains( fldIt.key() ) )
QgsDebugMsg( QString( "no ogr field for field %1" ).arg( fldIt.key() ) );
continue;
@@ -387,7 +387,7 @@
const QVariant& attrValue = feature.attributeMap()[ fldIt.key()];
int ogrField = mAttrIdxToOgrIdx[ fldIt.key()];
- switch ( attrValue.type() )
+ switch( attrValue.type() )
case QVariant::Int:
OGR_F_SetFieldInteger( poFeature, ogrField, attrValue.toInt() );
@@ -413,7 +413,7 @@
// build geometry from WKB
QgsGeometry *geom = feature.geometry();
- if ( !geom )
+ if( !geom )
QgsDebugMsg( "invalid geometry" );
mErrorMessage = QObject::tr( "Invalid feature geometry" );
@@ -422,7 +422,7 @@
return false;
- if ( geom->wkbType() != mWkbType )
+ if( geom->wkbType() != mWkbType )
// there's a problem when layer type is set as wkbtype Polygon
// although there are also features of type MultiPolygon
@@ -435,7 +435,7 @@
OGRGeometryH mGeom2 = createEmptyGeometry( geom->wkbType() );
- if ( !mGeom2 )
+ if( !mGeom2 )
QgsDebugMsg( QString( "Failed to create empty geometry for type %1 (OGR error: %2)" ).arg( geom->wkbType() ).arg( CPLGetLastErrorMsg() ) );
mErrorMessage = QObject::tr( "Feature geometry not imported (OGR error: %1)" )
@@ -446,7 +446,7 @@
OGRErr err = OGR_G_ImportFromWkb( mGeom2, geom->asWkb(), geom->wkbSize() );
- if ( err != OGRERR_NONE )
+ if( err != OGRERR_NONE )
QgsDebugMsg( QString( "Failed to import geometry from WKB: %1 (OGR error: %2)" ).arg( err ).arg( CPLGetLastErrorMsg() ) );
@@ -462,7 +462,7 @@
else
OGRErr err = OGR_G_ImportFromWkb( mGeom, geom->asWkb(), geom->wkbSize() );
@@ -477,7 +477,7 @@
// put the created feature to layer
- if ( OGR_L_CreateFeature( mLayer, poFeature ) != OGRERR_NONE )
+ if( OGR_L_CreateFeature( mLayer, poFeature ) != OGRERR_NONE )
mErrorMessage = QObject::tr( "Feature creation error (OGR error: %1)" ).arg( QString::fromUtf8( CPLGetLastErrorMsg() ) );
mError = ErrFeatureWriteFailed;
@@ -494,12 +494,12 @@
QgsVectorFileWriter::~QgsVectorFileWriter()
- if ( mGeom )
+ if( mGeom )
OGR_G_DestroyGeometry( mGeom );
- if ( mDS )
+ if( mDS )
OGR_DS_Destroy( mDS );
@@ -530,13 +530,14 @@
bool onlySelected,
QString *errorMessage,
- const QStringList &layerOptions )
+ const QStringList &layerOptions,
+ bool skipAttributeCreation )
const QgsCoordinateReferenceSystem* outputCRS;
QgsCoordinateTransform* ct = 0;
int shallTransform = false;
- if ( destCRS && destCRS->isValid() )
+ if( destCRS && destCRS->isValid() )
// This means we should transform
outputCRS = destCRS;
@@ -548,24 +549,24 @@
outputCRS = &layer->srs();
QgsVectorFileWriter* writer =
- new QgsVectorFileWriter( fileName, fileEncoding, layer->pendingFields(), layer->wkbType(), outputCRS, driverName, datasourceOptions, layerOptions );
+ new QgsVectorFileWriter( fileName, fileEncoding, skipAttributeCreation ? QgsFieldMap() : layer->pendingFields(), layer->wkbType(), outputCRS, driverName, datasourceOptions, layerOptions );
// check whether file creation was successful
WriterError err = writer->hasError();
- if ( err != NoError )
+ if( err != NoError )
- if ( errorMessage )
+ if( errorMessage )
*errorMessage = writer->errorMessage();
delete writer;
return err;
errorMessage->clear();
- QgsAttributeList allAttr = layer->pendingAllAttributesList();
+ QgsAttributeList allAttr = skipAttributeCreation ? QgsAttributeList() : layer->pendingAllAttributesList();
QgsFeature fet;
layer->select( allAttr, QgsRectangle(), true );
@@ -573,13 +574,13 @@
const QgsFeatureIds& ids = layer->selectedFeaturesIds();
// Create our transform
- if ( destCRS )
+ if( destCRS )
ct = new QgsCoordinateTransform( layer->srs(), *destCRS );
// Check for failure
- if ( ct == NULL )
+ if( ct == NULL )
@@ -587,21 +588,21 @@
int n = 0, errors = 0;
// write all features
- while ( layer->nextFeature( fet ) )
+ while( layer->nextFeature( fet ) )
- if ( onlySelected && !ids.contains( fet.id() ) )
+ if( onlySelected && !ids.contains( fet.id() ) )
continue;
- if ( shallTransform )
+ if( shallTransform )
try
- if ( fet.geometry() )
+ if( fet.geometry() )
fet.geometry()->transform( *ct );
- catch ( QgsCsException &e )
+ catch( QgsCsException &e )
delete ct;
delete writer;
@@ -609,18 +610,22 @@
QString msg = QObject::tr( "Failed to transform a point while drawing a feature of type '%1'. Writing stopped. (Exception: %2)" )
.arg( fet.typeName() ).arg( e.what() );
QgsLogger::warning( msg );
*errorMessage = msg;
return ErrProjection;
- if ( !writer->addFeature( fet ) )
+ if( skipAttributeCreation )
+ fet.clearAttributeMap();
+ if( !writer->addFeature( fet ) )
- if ( err != NoError && errorMessage )
+ if( err != NoError && errorMessage )
- if ( errorMessage->isEmpty() )
+ if( errorMessage->isEmpty() )
*errorMessage = QObject::tr( "Feature write errors:" );
@@ -628,9 +633,9 @@
errors++;
- if ( errors > 1000 )
+ if( errors > 1000 )
*errorMessage += QObject::tr( "Stopping after %1 errors" ).arg( errors );
@@ -644,12 +649,12 @@
delete writer;
delete ct;
- if ( errors > 0 && errorMessage && n > 0 )
+ if( errors > 0 && errorMessage && n > 0 )
*errorMessage += QObject::tr( "\nOnly %1 of %2 features written." ).arg( n - errors ).arg( n );
@@ -665,7 +670,7 @@
QStringList filter;
const char *suffixes[] = { ".shp", ".shx", ".dbf", ".prj", ".qix", ".qpj" };
- for ( std::size_t i = 0; i < sizeof( suffixes ) / sizeof( *suffixes ); i++ )
+ for( std::size_t i = 0; i < sizeof( suffixes ) / sizeof( *suffixes ); i++ )
filter << fi.completeBaseName() + suffixes[i];
@@ -673,7 +678,7 @@
bool ok = true;
foreach( QString file, dir.entryList( filter ) )
- if ( !QFile::remove( dir.canonicalPath() + "/" + file ) )
+ if( !QFile::remove( dir.canonicalPath() + "/" + file ) )
QgsDebugMsg( "Removing file failed : " + file );
ok = false;
@@ -690,16 +695,16 @@
int const drvCount = OGRGetDriverCount();
- for ( int i = 0; i < drvCount; ++i )
+ for( int i = 0; i < drvCount; ++i )
OGRSFDriverH drv = OGRGetDriver( i );
- if ( drv )
+ if( drv )
QString drvName = OGR_Dr_GetName( drv );
- if ( OGR_Dr_TestCapability( drv, "CreateDataSource" ) != 0 )
+ if( OGR_Dr_TestCapability( drv, "CreateDataSource" ) != 0 )
QString filterString = filterForDriver( drvName );
- if ( filterString.isEmpty() )
+ if( filterString.isEmpty() )
continue;
resultMap.insert( filterString, drvName );
@@ -717,16 +722,16 @@
- if ( drv )
+ if( drv )
QPair<QString, QString> p = nameAndGlob( drvName );
- if ( p.first.isEmpty() )
+ if( p.first.isEmpty() )
continue;
resultMap.insert( p.first, drvName );
@@ -742,9 +747,9 @@
QString filterString;
QMap< QString, QString> driverFormatMap = supportedFiltersAndFormats();
QMap< QString, QString>::const_iterator it = driverFormatMap.constBegin();
- for ( ; it != driverFormatMap.constEnd(); ++it )
+ for( ; it != driverFormatMap.constEnd(); ++it )
filterString += ";;";
filterString += it.key();
@@ -756,7 +761,7 @@
QPair<QString, QString> p = nameAndGlob( driverName );
- if ( p.first.isEmpty() || p.second.isEmpty() )
+ if( p.first.isEmpty() || p.second.isEmpty() )
return "";
return "[OGR] " + p.first + " (" + p.second.toLower() + " " + p.second.toUpper() + ")";
@@ -767,102 +772,102 @@
QString longName;
QString glob;
- if ( driverName.startsWith( "AVCE00" ) )
+ if( driverName.startsWith( "AVCE00" ) )
longName = "Arc/Info ASCII Coverage";
glob = "*.e00";
- else if ( driverName.startsWith( "BNA" ) )
+ else if( driverName.startsWith( "BNA" ) )
longName = "Atlas BNA";
glob = "*.bna";
- else if ( driverName.startsWith( "CSV" ) )
+ else if( driverName.startsWith( "CSV" ) )
longName = "Comma Separated Value";
glob = "*.csv";
- else if ( driverName.startsWith( "ESRI" ) )
+ else if( driverName.startsWith( "ESRI" ) )
longName = "ESRI Shapefile";
glob = "*.shp";
- else if ( driverName.startsWith( "FMEObjects Gateway" ) )
+ else if( driverName.startsWith( "FMEObjects Gateway" ) )
longName = "FMEObjects Gateway";
glob = "*.fdd";
- else if ( driverName.startsWith( "GeoJSON" ) )
+ else if( driverName.startsWith( "GeoJSON" ) )
longName = "GeoJSON";
glob = "*.geojson";
- else if ( driverName.startsWith( "GeoRSS" ) )
+ else if( driverName.startsWith( "GeoRSS" ) )
longName = "GeoRSS";
glob = "*.xml";
- else if ( driverName.startsWith( "GML" ) )
+ else if( driverName.startsWith( "GML" ) )
longName = "Geography Markup Language (GML)";
glob = "*.gml";
- else if ( driverName.startsWith( "GMT" ) )
+ else if( driverName.startsWith( "GMT" ) )
longName = "Generic Mapping Tools (GMT)";
glob = "*.gmt";
- else if ( driverName.startsWith( "GPX" ) )
+ else if( driverName.startsWith( "GPX" ) )
longName = "GPS eXchange Format";
glob = "*.gpx";
- else if ( driverName.startsWith( "Interlis 1" ) )
+ else if( driverName.startsWith( "Interlis 1" ) )
longName = "INTERLIS 1";
glob = "*.itf *.xml *.ili";
- else if ( driverName.startsWith( "Interlis 2" ) )
+ else if( driverName.startsWith( "Interlis 2" ) )
longName = "INTERLIS 2";
- else if ( driverName.startsWith( "KML" ) )
+ else if( driverName.startsWith( "KML" ) )
longName = "Keyhole Markup Language (KML)";
glob = "*.kml" ;
- else if ( driverName.startsWith( "MapInfo File" ) )
+ else if( driverName.startsWith( "MapInfo File" ) )
longName = "Mapinfo File";
glob = "*.mif *.tab";
- else if ( driverName.startsWith( "DGN" ) )
+ else if( driverName.startsWith( "DGN" ) )
longName = "Microstation DGN";
glob = "*.dgn";
- else if ( driverName.startsWith( "S57" ) )
+ else if( driverName.startsWith( "S57" ) )
longName = "S-57 Base file";
glob = "*.000";
- else if ( driverName.startsWith( "SDTS" ) )
+ else if( driverName.startsWith( "SDTS" ) )
longName = "Spatial Data Transfer Standard (SDTS)";
glob = "*catd.ddf";
- else if ( driverName.startsWith( "SQLite" ) )
+ else if( driverName.startsWith( "SQLite" ) )
longName = "SQLite";
glob = "*.sqlite";
- else if ( driverName.startsWith( "DXF" ) )
+ else if( driverName.startsWith( "DXF" ) )
longName = "AutoCAD DXF";
glob = "*.dxf";
- else if ( driverName.startsWith( "Geoconcept" ) )
+ else if( driverName.startsWith( "Geoconcept" ) )
longName = "Geoconcept";
glob = "*.gxt *.txt";
Modified: trunk/qgis/src/core/qgsvectorfilewriter.h
--- trunk/qgis/src/core/qgsvectorfilewriter.h 2010-11-12 16:59:36 UTC (rev 14561)
+++ trunk/qgis/src/core/qgsvectorfilewriter.h 2010-11-12 17:00:49 UTC (rev 14562)
@@ -78,7 +78,8 @@
bool onlySelected = false,
const QStringList &datasourceOptions = QStringList(), // added in 1.6
- const QStringList &layerOptions = QStringList() // added in 1.6
+ const QStringList &layerOptions = QStringList(), // added in 1.6
+ bool skipAttributeCreation = false // added in 1.6
Modified: trunk/qgis/src/ui/qgsvectorlayersaveasdialogbase.ui
--- trunk/qgis/src/ui/qgsvectorlayersaveasdialogbase.ui 2010-11-12 16:59:36 UTC (rev 14561)
+++ trunk/qgis/src/ui/qgsvectorlayersaveasdialogbase.ui 2010-11-12 17:00:49 UTC (rev 14562)
@@ -7,7 +7,7 @@
<x>0</x>
<y>0</y>
<width>383</width>
- <height>348</height>
+ <height>427</height>
</rect>
</property>
<property name="windowTitle">
@@ -133,6 +133,16 @@
</property>
</widget>
</item>
+ <item row="2" column="0" colspan="2">
+ <widget class="QCheckBox" name="mSkipAttributeCreation">
+ <property name="toolTip">
+ <string>This allows to surpress attribute creation as some OGR drivers (eg. DGN, DXF) don't support it.</string>
+ </property>
+ <property name="text">
+ <string>Skip attribute creation</string>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
