[QGIS Commit] r14727 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Sun Nov 21 07:21:10 EST 2010
Author: dassau
Date: 2010-11-21 04:21:10 -0800 (Sun, 21 Nov 2010)
New Revision: 14727
docs/trunk/english_us/user_guide/working_with_ogc.tex
added note about wfs-t
Modified: docs/trunk/english_us/user_guide/working_with_ogc.tex
--- docs/trunk/english_us/user_guide/working_with_ogc.tex 2010-11-21 10:36:15 UTC (rev 14726)
+++ docs/trunk/english_us/user_guide/working_with_ogc.tex 2010-11-21 12:21:10 UTC (rev 14727)
@@ -5,7 +5,7 @@
% comment out the following line:
%\updatedisclaimer
-QGIS supports WMS and WFS as data sources. WMS-support is native; WFS is
+QGIS supports WMS and WFS as data sources. WMS-support is native; WFS and WFS-T is
implemented as a plugin.
\section{What is OGC Data}\index{OGC!introduction}
@@ -63,11 +63,12 @@
\subsection{Selecting WMS Servers}\label{sec:ogc-wms-servers}\index{WMS!remote server!selection}
The first time you use the WMS feature, there are no servers defined. You
-can begin by clicking the \toolbtntwo{mActionAddWmsLayer}{Add WMS layer} button inside the toolbar,
-or through the \mainmenuopt{Layer} \arrow \dropmenuopttwo{mActionAddWmsLayer}{Add
-WMS Layer...} menu.
+can begin by clicking the \toolbtntwo{mActionAddWmsLayer}{Add WMS layer}
+button inside the toolbar, or through the \mainmenuopt{Layer}
+\arrow \dropmenuopttwo{mActionAddWmsLayer}{Add WMS Layer...} menu.
-The dialog \dialog{Add Layer(s) from a Server} for adding layers from the WMS server pops up. Fortunately you can
+The dialog \dialog{Add Layer(s) from a Server} for adding layers from the
+WMS server pops up. Fortunately you can
add some servers to play with by clicking the \button{Add default servers}
button. This will add at least three WMS servers for you to use, including the NASA (JPL)
WMS server. To define a new WMS server in the \tab{Layers},
@@ -110,28 +111,6 @@
in your URL.\index{WMS!remote server!URL}
\end{Tip}
-% in QGIS 1.1.x not needed anymore since there is a search-interface
-%%% Table \ref{tab:wms_example_urls} shows some example WMS URLs to get you started.
-%%% These links were last checked in April 2009, but could change at any time:
-%%% %FIXME: WMS URLs should be checked again and maybe extended in QGIS
-%%% \begin{table}[ht]\index{WMS!remote server!URL!examples}
-%%% \centering
-%%% \caption{Example Public WMS URLs}\label{tab:wms_example_urls}\medskip
-%%% \begin{tabular}{|l|l|}
-%%% \hline \textbf{Name} & \textbf{URL} \\
-%%% \hline Atlas of Canada & http://atlas.gc.ca/cgi-bin/atlaswms\_en? \\
-%%% \hline DEMIS & http://www2.demis.nl/wms/wms.asp?wms=WorldMap\& \\
-%%% \hline Geoscience Australia & http://www.ga.gov.au/wms/getmap?dataset=national\& \\
-%%% \hline NASA JPL OnEarth & http://wms.jpl.nasa.gov/wms.cgi? \\
-%%% % \hline QGIS Users & http://qgis.org/cgi-bin/mapserv?map=/var/www/maps/main.map\& \\
-%%% \hline QGIS Users & http://linfiniti.com:8080/geoserver/wms? \\
-%%% \hline
-%%% \end{tabular}
-%%% \end{table}
-%%% An exhaustive list of WMS servers can be found at \url{http://wms-sites.com}.
\subsection{Loading WMS Layers}\label{sec:ogc-wms-layers}\index{WMS!client!layers}
Once you have successfully filled in your parameters you can select the
@@ -456,15 +435,16 @@
% WFS-client
-\section{WFS Client}\label{sec:ogc-wfs}
+\section{WFS and WFS-T Client}\label{sec:ogc-wfs}
+\index{WFS!WFS-T}
+\index{WFS!Transactional}
In QGIS, a WFS layer behaves pretty much like any other vector layer. You
-can identify and select features and view the attribute table. An exception
-is that editing is not supported at this time (at the time of this writing
-there will be support for WFS-T in the near future as well).
-To start the WFS plugin you
-need to open \mainmenuopt{Plugins} \arrow \dropmenuopttwo{mActionShowPluginManager}{Plugin Manager...},
-activate the \checkbox{WFS plugin} checkbox and click \button{OK}.
+can identify and select features and view the attribute table. Since QGIS 1.6
+editing (WFS-T) is also supported, if the server provides this feature. To start
+the WFS plugin you need to open \mainmenuopt{Plugins} \arrow
+\dropmenuopttwo{mActionShowPluginManager}{Plugin Manager...}, activate the
+\checkbox{WFS plugin} checkbox and click \button{OK}.
A new \toolbtntwo{mIconAddWfsLayer}{Add WFS Layer} icon appears next
to the WMS icon. Click on it to open the dialog. In general adding a WFS
@@ -513,9 +493,9 @@
usefull when you only want to request \textbf{some} features from a huge
WFS-dataset.
-You'll notice the download progress is visualized in the left bottom of the QGIS main window.
-Once the layer is loaded, you can identify and select a province or two and view the
-attribute table.
+You'll notice the download progress is visualized in the left bottom of the
+QGIS main window. Once the layer is loaded, you can identify and select a
+province or two and view the attribute table.
Remember this plugin works best with MapServer WFS servers. It still
could be, that you might experience random behavior
