[QGIS Commit] r14728 - in trunk/qgis: . src/app src/ui
svn_qgis at osgeo.org
Sun Nov 21 15:04:36 EST 2010
Author: jef
Date: 2010-11-21 12:04:36 -0800 (Sun, 21 Nov 2010)
New Revision: 14728
trunk/qgis/.gitignore
trunk/qgis/src/app/qgssnappingdialog.cpp
trunk/qgis/src/ui/qgsannotationwidgetbase.ui
trunk/qgis/src/ui/qgscredentialdialog.ui
trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui
trunk/qgis/src/ui/qgstextannotationdialogbase.ui
- update .gitignore
- typo fix
- fix ui permissions
Modified: trunk/qgis/.gitignore
--- trunk/qgis/.gitignore 2010-11-21 12:21:10 UTC (rev 14727)
+++ trunk/qgis/.gitignore 2010-11-21 20:04:36 UTC (rev 14728)
@@ -4,6 +4,13 @@
desktop.ini
+*.diff
+*.log*
+*.prepare
+debian/*.debhelper
+debian/*.substvars
+Makefile
+*-stamp
api_doc
build
ms-windows/Installer-Files/postinstall.bat
@@ -13,3 +20,5 @@
ms-windows/*Setup.exe
ms-windows/osgeo4w/nsis/
ms-windows/osgeo4w/untgz/
+scripts/astyle
+qtcreator-build/
Modified: trunk/qgis/src/app/qgssnappingdialog.cpp
--- trunk/qgis/src/app/qgssnappingdialog.cpp 2010-11-21 12:21:10 UTC (rev 14727)
+++ trunk/qgis/src/app/qgssnappingdialog.cpp 2010-11-21 20:04:36 UTC (rev 14728)
@@ -106,8 +106,8 @@
QSettings myQsettings;
bool myDockFlag = myQsettings.value( "/qgis/dockSnapping", false ).toBool();
- double defaultSnapppingTolerance = myQsettings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
- int defaultSnapppingUnit = myQsettings.value( "/qgis/digitizing/default_snapping_tolerance_unit", 0 ).toInt();
+ double defaultSnappingTolerance = myQsettings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
+ int defaultSnappingUnit = myQsettings.value( "/qgis/digitizing/default_snapping_tolerance_unit", 0 ).toInt();
QString defaultSnappingString = myQsettings.value( "/qgis/digitizing/default_snap_mode", "to vertex" ).toString();
int defaultSnappingStringIdx = 0;
@@ -160,7 +160,7 @@
QLineEdit *leTolerance = new QLineEdit( mLayerTreeWidget );
QDoubleValidator *validator = new QDoubleValidator( leTolerance );
leTolerance->setValidator( validator );
- leTolerance->setText( QString::number( defaultSnapppingTolerance, 'f' ) );
+ leTolerance->setText( QString::number( defaultSnappingTolerance, 'f' ) );
mLayerTreeWidget->setItemWidget( item, 3, leTolerance );
@@ -168,7 +168,7 @@
QComboBox *cbxUnits = new QComboBox( mLayerTreeWidget );
cbxUnits->insertItem( 0, tr( "map units" ) );
cbxUnits->insertItem( 1, tr( "pixels" ) );
- cbxUnits->setCurrentIndex( defaultSnapppingUnit );
+ cbxUnits->setCurrentIndex( defaultSnappingUnit );
mLayerTreeWidget->setItemWidget( item, 4, cbxUnits );
int idx = layerIdList.indexOf( currentVectorLayer->getLayerID() );
Property changes on: trunk/qgis/src/ui/qgsannotationwidgetbase.ui
___________________________________________________________________
Deleted: svn:executable
Property changes on: trunk/qgis/src/ui/qgscredentialdialog.ui
Property changes on: trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui
Property changes on: trunk/qgis/src/ui/qgstextannotationdialogbase.ui
