[QGIS Commit] r14328 - in trunk/qgis/src: app gui ui
svn_qgis at osgeo.org
Mon Oct 4 10:57:40 EDT 2010
Author: timlinux
Date: 2010-10-04 14:57:40 +0000 (Mon, 04 Oct 2010)
New Revision: 14328
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/gui/qgisgui.cpp
trunk/qgis/src/gui/qgisgui.h
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
Added option to save histogram and also refactored dialog filetype list for saving images into qgisgui
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-10-04 10:00:28 UTC (rev 14327)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-10-04 14:57:40 UTC (rev 14328)
@@ -2593,24 +2593,10 @@
- Convenience function for readily creating file filters.
- Given a long name for a file filter and a regular expression, return
- a file filter string suitable for use in a QFileDialog::OpenFiles()
- call. The regular express, glob, will have both all lower and upper
- case versions added.
-static QString createFileFilter_( QString const &longName, QString const &glob )
- return longName + " (" + glob.toLower() + " " + glob.toUpper() + ")";
-} // createFileFilter_
This method prompts the user for a list of vector file names with a dialog.
@@ -3558,94 +3544,16 @@
void QgisApp::saveMapAsImage()
- //create a map to hold the QImageIO names and the filter names
- //the QImageIO name must be passed to the mapcanvas saveas image function
- typedef QMap<QString, QString> FilterMap;
- FilterMap myFilterMap;
- //find out the last used filter
- QSettings myQSettings; // where we keep last used filter in persistent state
- QString myLastUsedFilter = myQSettings.value( "/UI/lastSaveAsImageFilter" ).toString();
- QString myLastUsedDir = myQSettings.value( "/UI/lastSaveAsImageDir", "." ).toString();
- // get a list of supported output image types
- int myCounterInt = 0;
- QString myFilters;
- QList<QByteArray> formats = QImageWriter::supportedImageFormats();
- for ( ; myCounterInt < formats.count(); myCounterInt++ )
+ QPair< QString,QString> myFileNameAndFilter = QgisGui::getSaveAsImageName( this, tr( "Choose a file name to save the map image as" ) );
+ if ( myFileNameAndFilter.first != "" )
- QString myFormat = QString( formats.at( myCounterInt ) );
- //svg doesnt work so skip it
- if ( myFormat == "svg" )
- continue;
- QString myFilter = createFileFilter_( myFormat + " format", "*." + myFormat );
- if ( !myFilters.isEmpty() )
- myFilters += ";;";
- myFilters += myFilter;
- myFilterMap[myFilter] = myFormat;
-#ifdef QGISDEBUG
- QgsDebugMsg( "Available Filters Map: " );
- FilterMap::Iterator myIterator;
- for ( myIterator = myFilterMap.begin(); myIterator != myFilterMap.end(); ++myIterator )
- QgsDebugMsg( myIterator.key() + " : " + myIterator.value() );
-#endif
- //create a file dialog using the the filter list generated above
- std::auto_ptr < QFileDialog > myQFileDialog( new QFileDialog( this,
- tr( "Choose a file name to save the map image as" ),
- myLastUsedDir, myFilters ) );
- // allow for selection of more than one file
- myQFileDialog->setFileMode( QFileDialog::AnyFile );
- myQFileDialog->setAcceptMode( QFileDialog::AcceptSave );
- myQFileDialog->setConfirmOverwrite( true );
- if ( !myLastUsedFilter.isEmpty() ) // set the filter to the last one used
- myQFileDialog->selectFilter( myLastUsedFilter );
- //prompt the user for a fileName
- QString myOutputFileNameQString; // = myQFileDialog->getSaveFileName(); //delete this
- if ( myQFileDialog->exec() == QDialog::Accepted )
- myOutputFileNameQString = myQFileDialog->selectedFiles().first();
- QString myFilterString = myQFileDialog->selectedFilter();
- QgsDebugMsg( "Selected filter: " + myFilterString );
- QgsDebugMsg( "Image type to be passed to mapcanvas: " + myFilterMap[myFilterString] );
- // Add the file type suffix to the fileName if required
- if ( !myOutputFileNameQString.endsWith( myFilterMap[myFilterString] ) )
- myOutputFileNameQString += "." + myFilterMap[myFilterString];
- myQSettings.setValue( "/UI/lastSaveAsImageFilter", myFilterString );
- myQSettings.setValue( "/UI/lastSaveAsImageDir", myQFileDialog->directory().absolutePath() );
- if ( myOutputFileNameQString != "" )
//save the mapview to the selected file
- mMapCanvas->saveAsImage( myOutputFileNameQString, NULL, myFilterMap[myFilterString] );
- statusBar()->showMessage( tr( "Saved map image to %1" ).arg( myOutputFileNameQString ) );
+ mMapCanvas->saveAsImage( myFileNameAndFilter.first, NULL, myFileNameAndFilter.second );
+ statusBar()->showMessage( tr( "Saved map image to %1" ).arg( myFileNameAndFilter.first ) );
} // saveMapAsImage
//overloaded version of the above function
void QgisApp::saveMapAsImage( QString theImageFileNameQString, QPixmap * theQPixmap )
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-10-04 10:00:28 UTC (rev 14327)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-10-04 14:57:40 UTC (rev 14328)
@@ -66,7 +66,8 @@
: QDialog( parent, fl ),
// Constant that signals property not used.
TRSTRING_NOT_SET( tr( "Not Set" ) ),
- mRasterLayer( qobject_cast<QgsRasterLayer *>( lyr ) )
+ mRasterLayer( qobject_cast<QgsRasterLayer *>( lyr ) ),
+ mpPlot( 0 )
ignoreSpinBoxEvent = false; //Short circuit signal loop between min max field and stdDev spin box
mGrayMinimumMaximumEstimated = true;
@@ -204,6 +205,8 @@
pbtnExportColorMapToFile->setIcon( QgisApp::getThemeIcon( "/mActionFileSave.png" ) );
pbtnLoadColorMapFromFile->setIcon( QgisApp::getThemeIcon( "/mActionFileOpen.png" ) );
+ mSaveAsImageButton->setIcon( QgisApp::getThemeIcon( "/mActionFileSave.png" ) );
mMapCanvas = theCanvas;
mPixelSelectorTool = 0;
if ( mMapCanvas )
@@ -1849,29 +1852,31 @@
void QgsRasterLayerProperties::refreshHistogram()
+ if ( mpPlot != 0 )
+ delete mpPlot;
mHistogramProgress->show();
connect( mRasterLayer, SIGNAL( progressUpdate( int ) ), mHistogramProgress, SLOT( setValue( int ) ) );
QApplication::setOverrideCursor( Qt::WaitCursor );
QgsDebugMsg( "entered." );
- QwtPlot * mypPlot = new QwtPlot( mChartWidget );
- mypPlot->canvas()->setCursor( Qt::ArrowCursor );
+ mpPlot = new QwtPlot( mChartWidget );
//ensure all children get removed
- mypPlot->setAutoDelete( true );
+ mpPlot->setAutoDelete( true );
QVBoxLayout *mpHistogramLayout = new QVBoxLayout( mChartWidget );
mpHistogramLayout->setContentsMargins( 0, 0, 0, 0 );
- mpHistogramLayout->addWidget( mypPlot );
+ mpHistogramLayout->addWidget( mpPlot );
mChartWidget->setLayout( mpHistogramLayout );
- mypPlot->setTitle( QObject::tr( "Raster Histogram" ) );
- mypPlot->insertLegend( new QwtLegend(), QwtPlot::BottomLegend );
+ mpPlot->setTitle( QObject::tr( "Raster Histogram") );
+ mpPlot->insertLegend( new QwtLegend(), QwtPlot::BottomLegend );
// Set axis titles
- mypPlot->setAxisTitle( QwtPlot::xBottom, QObject::tr( "Pixel Value" ) );
- mypPlot->setAxisTitle( QwtPlot::yLeft, QObject::tr( "Frequency" ) );
- mypPlot->setAxisAutoScale( QwtPlot::xBottom );
- mypPlot->setAxisAutoScale( QwtPlot::yLeft );
+ mpPlot->setAxisTitle( QwtPlot::xBottom, QObject::tr("Pixel Value") );
+ mpPlot->setAxisTitle( QwtPlot::yLeft, QObject::tr("Frequency") );
+ mpPlot->setAxisAutoScale( QwtPlot::xBottom );
+ mpPlot->setAxisAutoScale( QwtPlot::yLeft );
// add a grid
QwtPlotGrid * myGrid = new QwtPlotGrid();
- myGrid->attach( mypPlot );
+ myGrid->attach(mpPlot);
// Explanation:
// We use the gdal histogram creation routine is called for each selected
// layer. Currently the hist is hardcoded
@@ -1917,15 +1922,39 @@
myX2Data.append( double( myBin ) );
myY2Data.append( double( myBinValue ) );
- mypCurve->setData( myX2Data, myY2Data );
- mypCurve->attach( mypPlot );
+ mypCurve->setData(myX2Data,myY2Data);
+ mypCurve->attach(mpPlot);
- mypPlot->replot();
+ mpPlot->replot();
disconnect( mRasterLayer, SIGNAL( progressUpdate( int ) ), mHistogramProgress, SLOT( setValue( int ) ) );
mHistogramProgress->hide();
+ mpPlot->canvas()->setCursor(Qt::ArrowCursor);
QApplication::restoreOverrideCursor();
+void QgsRasterLayerProperties::on_mSaveAsImageButton_clicked()
+ if ( mpPlot == 0 )
+ return;
+ QPixmap myPixmap(600, 600);
+ myPixmap.fill(Qt::white); // Qt::transparent ?
+ QwtPlotPrintFilter myFilter;
+ int myOptions = QwtPlotPrintFilter::PrintAll;
+ myOptions &= ~QwtPlotPrintFilter::PrintBackground;
+ myOptions |= QwtPlotPrintFilter::PrintFrameWithScales;
+ myFilter.setOptions(myOptions);
+ mpPlot->print(myPixmap, myFilter);
+ myPixmap.save( myFileNameAndFilter.first );
void QgsRasterLayerProperties::on_pbnImportTransparentPixelValues_clicked()
int myLineCounter = 0;
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2010-10-04 10:00:28 UTC (rev 14327)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2010-10-04 14:57:40 UTC (rev 14328)
@@ -31,8 +31,8 @@
class QgsMapCanvas;
class QgsRasterLayer;
class QgsPixelSelectorTool;
+class QwtPlot;
/**Property sheet for a raster map layer
*@author Tim Sutton
@@ -144,6 +144,8 @@
void on_pbnSaveStyleAs_clicked();
/** Help button */
void on_buttonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
+ /** This slot lets you save the histogram as an image to disk */
+ void on_mSaveAsImageButton_clicked();
signals:
@@ -219,6 +221,7 @@
QgsMapCanvas* mMapCanvas;
QgsPixelSelectorTool* mPixelSelectorTool;
+ QwtPlot * mpPlot;
Modified: trunk/qgis/src/gui/qgisgui.cpp
--- trunk/qgis/src/gui/qgisgui.cpp 2010-10-04 10:00:28 UTC (rev 14327)
+++ trunk/qgis/src/gui/qgisgui.cpp 2010-10-04 14:57:40 UTC (rev 14328)
@@ -15,9 +15,13 @@
#include "qgisgui.h"
#include <QSettings>
+#include <QObject> //for tr
+#include <QImageWriter>
#include "qgsencodingfiledialog.h"
#include "qgslogger.h"
+#include <memory> //for auto_ptr
namespace QgisGui
@@ -34,7 +38,7 @@
haveLastUsedFilter = settings.contains( "/UI/" + filterName );
QString lastUsedFilter = settings.value( "/UI/" + filterName,
- QVariant( QString::null ) ).toString();
+ QVariant( QString::null ) ).toString();
QString lastUsedDir = settings.value( "/UI/" + filterName + "Dir", "." ).toString();
@@ -84,5 +88,91 @@
return false;
+ QPair<QString, QString> GUI_EXPORT getSaveAsImageName( QWidget * theParent, QString theMessage )
+ //create a map to hold the QImageIO names and the filter names
+ //the QImageIO name must be passed to the mapcanvas saveas image function
+ typedef QMap<QString, QString> FilterMap;
+ FilterMap myFilterMap;
+ //find out the last used filter
+ QSettings myQSettings; // where we keep last used filter in persistent state
+ QString myLastUsedFilter = myQSettings.value( "/UI/lastSaveAsImageFilter" ).toString();
+ QString myLastUsedDir = myQSettings.value( "/UI/lastSaveAsImageDir", "." ).toString();
+ // get a list of supported output image types
+ int myCounterInt = 0;
+ QString myFilters;
+ QList<QByteArray> formats = QImageWriter::supportedImageFormats();
+ for ( ; myCounterInt < formats.count(); myCounterInt++ )
+ QString myFormat = QString( formats.at( myCounterInt ) );
+ //svg doesnt work so skip it
+ if ( myFormat == "svg" )
+ continue;
+ QString myFilter = createFileFilter_( myFormat + " format", "*." + myFormat );
+ if ( !myFilters.isEmpty() )
+ myFilters += ";;";
+ myFilters += myFilter;
+ myFilterMap[myFilter] = myFormat;
+#ifdef QGISDEBUG
+ QgsDebugMsg( "Available Filters Map: " );
+ FilterMap::Iterator myIterator;
+ for ( myIterator = myFilterMap.begin(); myIterator != myFilterMap.end(); ++myIterator )
+ QgsDebugMsg( myIterator.key() + " : " + myIterator.value() );
+#endif
+ //create a file dialog using the the filter list generated above
+ std::auto_ptr < QFileDialog > myQFileDialog( new QFileDialog( theParent,
+ QObject::tr( "Choose a file name to save the map image as" ),
+ myLastUsedDir, myFilters ) );
+ // allow for selection of more than one file
+ myQFileDialog->setFileMode( QFileDialog::AnyFile );
+ myQFileDialog->setAcceptMode( QFileDialog::AcceptSave );
+ myQFileDialog->setConfirmOverwrite( true );
+ if ( !myLastUsedFilter.isEmpty() ) // set the filter to the last one used
+ myQFileDialog->selectFilter( myLastUsedFilter );
+ //prompt the user for a fileName
+ QString myOutputFileName; // = myQFileDialog->getSaveFileName(); //delete this
+ if ( myQFileDialog->exec() == QDialog::Accepted )
+ myOutputFileName = myQFileDialog->selectedFiles().first();
+ QString myFilterString = myQFileDialog->selectedFilter();
+ QgsDebugMsg( "Selected filter: " + myFilterString );
+ QgsDebugMsg( "Image type: " + myFilterMap[myFilterString] );
+ // Add the file type suffix to the fileName if required
+ if ( !myOutputFileName.endsWith( myFilterMap[myFilterString] ) )
+ myOutputFileName += "." + myFilterMap[myFilterString];
+ myQSettings.setValue( "/UI/lastSaveAsImageFilter", myFilterString );
+ myQSettings.setValue( "/UI/lastSaveAsImageDir", myQFileDialog->directory().absolutePath() );
+ QPair <QString, QString> myPair;
+ myPair.first = myOutputFileName;
+ myPair.second = myFilterMap[myFilterString];
+ return myPair;
+ static QString createFileFilter_( QString const &longName, QString const &glob )
+ return longName + " (" + glob.toLower() + " " + glob.toUpper() + ")";
+ } // createFileFilter_
} // end of QgisGui namespace
Modified: trunk/qgis/src/gui/qgisgui.h
--- trunk/qgis/src/gui/qgisgui.h 2010-10-04 10:00:28 UTC (rev 14327)
+++ trunk/qgis/src/gui/qgisgui.h 2010-10-04 14:57:40 UTC (rev 14328)
@@ -17,6 +17,7 @@
#define QGISGUI_H
#include <Qt>
+#include <QPair>
class QStringList;
@@ -75,6 +76,29 @@
QString const &filters, QStringList & selectedFiles, QString& enc, QString &title,
bool cancelAll = false );
+ /** A helper function to get an image name from the user. It will nicely
+ * provide filters with all available writable image formats.
+ * @param QWidget - widget that should act as the parent for the file dialog
+ * @param QString the message to display to the user
+ * @return QPair<QString, QString> where first is the file name and second is
+ * the file type
+ * @note added in 1.6
+ QPair<QString, QString> GUI_EXPORT getSaveAsImageName( QWidget * theParent, QString theMessage );
+ Convenience function for readily creating file filters.
+ Given a long name for a file filter and a regular expression, return
+ a file filter string suitable for use in a QFileDialog::OpenFiles()
+ call. The regular express, glob, will have both all lower and upper
+ case versions added.
+ static QString createFileFilter_( QString const &longName, QString const &glob );
#endif
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-10-04 10:00:28 UTC (rev 14327)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-10-04 14:57:40 UTC (rev 14328)
@@ -1762,6 +1762,9 @@
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p>
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p>
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></td></tr></table></body></html></string>
</property>
</widget>
@@ -1854,6 +1857,17 @@
</property>
</widget>
</item>
+ <item row="1" column="2">
+ <widget class="QToolButton" name="mSaveAsImageButton">
+ <property name="text">
+ <string>Save as image...</string>
+ </property>
+ <property name="icon">
+ <iconset>
+ <normaloff>../../images/themes/default/mActionFileSave.png</normaloff>../../images/themes/default/mActionFileSave.png</iconset>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</widget>
