[QGIS Commit] r14356 - in trunk/qgis: python/core src/app/composer src/core/composer src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Oct 8 04:32:06 EDT 2010
Author: mhugent
Date: 2010-10-08 08:32:06 +0000 (Fri, 08 Oct 2010)
New Revision: 14356
   trunk/qgis/python/core/qgscomposeritem.sip
   trunk/qgis/src/app/composer/qgsitempositiondialog.cpp
   trunk/qgis/src/app/composer/qgsitempositiondialog.h
   trunk/qgis/src/core/composer/qgscomposeritem.cpp
   trunk/qgis/src/core/composer/qgscomposeritem.h
   trunk/qgis/src/ui/qgsitempositiondialogbase.ui
[FEATURE]: add capability to show and manipulate composer item with/ height in item position dialog
Modified: trunk/qgis/python/core/qgscomposeritem.sip
--- trunk/qgis/python/core/qgscomposeritem.sip	2010-10-07 21:17:30 UTC (rev 14355)
+++ trunk/qgis/python/core/qgscomposeritem.sip	2010-10-08 08:32:06 UTC (rev 14356)
@@ -76,6 +76,10 @@
     /**Moves the item to a new position (in canvas coordinates)*/
     void setItemPosition( double x, double y, ItemPositionMode itemPoint = UpperLeft );
+    /**Sets item position and width / height in one go
+      @note: this method was added in version 1.6*/
+    void setItemPosition( double x, double y, double width, double height, ItemPositionMode itemPoint = UpperLeft );
     /**Sets this items bound in scene coordinates such that 1 item size units
      corresponds to 1 scene size unit*/
     virtual void setSceneRect( const QRectF& rectangle );
Modified: trunk/qgis/src/app/composer/qgsitempositiondialog.cpp
--- trunk/qgis/src/app/composer/qgsitempositiondialog.cpp	2010-10-07 21:17:30 UTC (rev 14355)
+++ trunk/qgis/src/app/composer/qgsitempositiondialog.cpp	2010-10-08 08:32:06 UTC (rev 14356)
@@ -39,9 +39,18 @@
   mXLineEdit->setValidator( new QDoubleValidator( 0 ) );
   mYLineEdit->setValidator( new QDoubleValidator( 0 ) );
+  mWidthLineEdit->setValidator( new QDoubleValidator( 0 ) );
+  mHeightLineEdit->setValidator( new QDoubleValidator( 0 ) );
   //set lower left position of item
   mUpperLeftCheckBox->setCheckState( Qt::Checked );
+  //set initial width and height
+  if ( mItem )
+    mWidthLineEdit->setText( QString::number( mItem->rect().width() ) );
+    mHeightLineEdit->setText( QString::number( mItem->rect().height() ) );
 QgsItemPositionDialog::QgsItemPositionDialog(): mItem( 0 )
@@ -69,6 +78,22 @@
   return 0;
+int QgsItemPositionDialog::size( QSizeF& s ) const
+  bool convSuccessWidth, convSuccessHeight;
+  double width = mWidthLineEdit->text().toDouble( &convSuccessWidth );
+  double height = mHeightLineEdit->text().toDouble( &convSuccessHeight );
+  if ( !convSuccessWidth || !convSuccessHeight )
+    return 1;
+  s.setWidth( width );
+  s.setHeight( height );
+  return 0;
 QgsComposerItem::ItemPositionMode QgsItemPositionDialog::positionMode() const
   if ( mUpperLeftCheckBox->checkState() == Qt::Checked )
@@ -123,10 +148,18 @@
   QgsPoint itemPosition;
+  QSizeF itemSize;
   if ( position( itemPosition ) == 0 )
-    //query position and mode from dialog
-    mItem->setItemPosition( itemPosition.x(), itemPosition.y(), positionMode() );
+    if ( size( itemSize ) == 0 )
+      mItem->setItemPosition( itemPosition.x(), itemPosition.y(), itemSize.width(), itemSize.height(), positionMode() );
+    else
+      mItem->setItemPosition( itemPosition.x(), itemPosition.y(), positionMode() );
     mItem->update();
Modified: trunk/qgis/src/app/composer/qgsitempositiondialog.h
--- trunk/qgis/src/app/composer/qgsitempositiondialog.h	2010-10-07 21:17:30 UTC (rev 14355)
+++ trunk/qgis/src/app/composer/qgsitempositiondialog.h	2010-10-08 08:32:06 UTC (rev 14356)
@@ -32,6 +32,8 @@
     /**Get selected x- and y-coordinate as point. Returns 0 in case of success*/
     int position( QgsPoint& point ) const;
+    /**Get selected size. Returns 0 in case of success*/
+    int size( QSizeF& s ) const;
     /**A combination of upper/middle/lower and left/middle/right*/
     QgsComposerItem::ItemPositionMode positionMode() const;
Modified: trunk/qgis/src/core/composer/qgscomposeritem.cpp
--- trunk/qgis/src/core/composer/qgscomposeritem.cpp	2010-10-07 21:17:30 UTC (rev 14355)
+++ trunk/qgis/src/core/composer/qgscomposeritem.cpp	2010-10-08 08:32:06 UTC (rev 14356)
@@ -630,7 +630,11 @@
   double width = rect().width();
   double height = rect().height();
+  setItemPosition( x, y, width, height, itemPoint );
+void QgsComposerItem::setItemPosition( double x, double y, double width, double height, ItemPositionMode itemPoint )
   double upperLeftX = x;
   double upperLeftY = y;
Modified: trunk/qgis/src/core/composer/qgscomposeritem.h
--- trunk/qgis/src/core/composer/qgscomposeritem.h	2010-10-07 21:17:30 UTC (rev 14355)
+++ trunk/qgis/src/core/composer/qgscomposeritem.h	2010-10-08 08:32:06 UTC (rev 14356)
@@ -109,6 +109,10 @@
Modified: trunk/qgis/src/ui/qgsitempositiondialogbase.ui
--- trunk/qgis/src/ui/qgsitempositiondialogbase.ui	2010-10-07 21:17:30 UTC (rev 14355)
+++ trunk/qgis/src/ui/qgsitempositiondialogbase.ui	2010-10-08 08:32:06 UTC (rev 14356)
@@ -6,14 +6,14 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>434</width>
-    <height>274</height>
+    <width>334</width>
+    <height>192</height>
    </rect>
   </property>
   <property name="windowTitle">
    <string>Set item position</string>
   </property>
-  <layout class="QGridLayout">
+  <layout class="QGridLayout" name="gridLayout_2">
    <item row="0" column="0">
     <widget class="QGroupBox" name="mPositionGroupBox">
      <property name="title">
@@ -91,35 +91,47 @@
       <string>Coordinates</string>
      </property>
+     <layout class="QGridLayout" name="gridLayout">
-       <layout class="QHBoxLayout">
-        <item>
-         <widget class="QLabel" name="mXLabel">
-          <property name="text">
-           <string>x</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="mXLineEdit"/>
-        </item>
-       </layout>
+       <widget class="QLabel" name="mXLabel">
+        <property name="text">
+         <string>x</string>
+        </property>
+       </widget>
       </item>
+      <item row="0" column="1" colspan="2">
+       <widget class="QLineEdit" name="mXLineEdit"/>
+      </item>
       <item row="1" column="0">
-        <item>
-         <widget class="QLabel" name="mYLabel">
-           <string>y</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="mYLineEdit"/>
-        </item>
-       </layout>
+       <widget class="QLabel" name="mYLabel">
+         <string>y</string>
+        </property>
+       </widget>
       </item>
+      <item row="1" column="1" colspan="2">
+       <widget class="QLineEdit" name="mYLineEdit"/>
+      </item>
+      <item row="2" column="0" colspan="2">
+       <widget class="QLabel" name="mWidthLabel">
+         <string>Width</string>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="2">
+       <widget class="QLineEdit" name="mWidthLineEdit"/>
+      </item>
+      <item row="3" column="0" colspan="2">
+       <widget class="QLabel" name="mHeightLabel">
+         <string>Height</string>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="2">
+       <widget class="QLineEdit" name="mHeightLineEdit"/>
+      </item>
      </layout>
     </widget>
    </item>
More information about the QGIS-commit mailing list
