[QGIS Commit] r14178 - trunk/qgis/src/core/pal
svn_qgis at osgeo.org
Thu Sep 2 04:11:45 EDT 2010
Author: mhugent
Date: 2010-09-02 08:11:45 +0000 (Thu, 02 Sep 2010)
New Revision: 14178
trunk/qgis/src/core/pal/feature.cpp
Fix another memory leak
Modified: trunk/qgis/src/core/pal/feature.cpp
--- trunk/qgis/src/core/pal/feature.cpp 2010-09-01 21:46:44 UTC (rev 14177)
+++ trunk/qgis/src/core/pal/feature.cpp 2010-09-02 08:11:45 UTC (rev 14178)
@@ -654,7 +654,6 @@
if ( index <= 1 && distance < 0 ) // We've gone off the start, fail out
- std::cerr << "err1" << std::endl;
return NULL;
@@ -666,7 +665,6 @@
if ( index >= path_positions->nbPoints )
- std::cerr << "err2" << std::endl;
return NULL;
@@ -688,7 +686,6 @@
if ( segment_length == 0 )
// Not allowed to place across on 0 length segments or discontinuities
- std::cerr << "err3" << std::endl;
return NULL;
@@ -714,7 +711,7 @@
- std::cerr << "err4" << std::endl;
+ delete slp;
return NULL;
@@ -743,7 +740,7 @@
index++;
if ( index >= path_positions->nbPoints ) // Bail out if we run off the end of the shape
- //std::cerr << "err5" << std::endl;
+ delete slp;
return NULL;
new_x = path_positions->x[index];
@@ -777,7 +774,7 @@
while ( angle_delta < -M_PI ) angle_delta += 2 * M_PI;
if ( f->labelInfo->max_char_angle_delta > 0 && fabs( angle_delta ) > f->labelInfo->max_char_angle_delta*( M_PI / 180 ) )
- std::cerr << "err6" << std::endl;
+ delete slp;
return NULL;
@@ -826,12 +823,14 @@
if ( !orientation_forced )
orientation = -orientation;
+ delete slp;
+ slp = NULL;
slp = curvedPlacementAtOffset( path_positions, path_distances, orientation, initial_index, initial_distance );
else
// Otherwise we have failed to find a placement
- //std::cerr << "err7" << std::endl;
+ delete slp;
return NULL;
