[QGIS Commit] r14192 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org
Sun Sep 5 10:11:56 EDT 2010
Author: mhugent
Date: 2010-09-05 14:11:56 +0000 (Sun, 05 Sep 2010)
New Revision: 14192
trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialog.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h
trunk/qgis/src/plugins/georeferencer/qgsresidualplotitem.cpp
trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.cpp
trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.h
trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialogbase.ui
Apply patch #2948 from Stefan Ziegler (PDF map for georeferencer)
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialog.cpp 2010-09-04 13:08:17 UTC (rev 14191)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialog.cpp 2010-09-05 14:11:56 UTC (rev 14192)
@@ -15,6 +15,7 @@
/* $Id$ */
#include <QCloseEvent>
#include <QSettings>
+#include <QSizeF>
#include "qgsgeorefconfigdialog.h"
@@ -24,6 +25,35 @@
setupUi( this );
readSettings();
+ mPaperSizeComboBox->addItem( tr( "A5 (148x210 mm)" ), QSizeF( 148, 210 ) );
+ mPaperSizeComboBox->addItem( tr( "A4 (210x297 mm)" ), QSizeF( 210, 297 ) );
+ mPaperSizeComboBox->addItem( tr( "A3 (297x420 mm)" ), QSizeF( 297, 420 ) );
+ mPaperSizeComboBox->addItem( tr( "A2 (420x594 mm)" ), QSizeF( 420, 594 ) );
+ mPaperSizeComboBox->addItem( tr( "A1 (594x841 mm)" ), QSizeF( 594, 841 ) );
+ mPaperSizeComboBox->addItem( tr( "A0 (841x1189 mm)" ), QSizeF( 841, 1189 ) );
+ mPaperSizeComboBox->addItem( tr( "B5 (176 x 250 mm)" ), QSizeF( 176, 250 ) );
+ mPaperSizeComboBox->addItem( tr( "B4 (250 x 353 mm)" ), QSizeF( 250, 353 ) );
+ mPaperSizeComboBox->addItem( tr( "B3 (353 x 500 mm)" ), QSizeF( 353, 500 ) );
+ mPaperSizeComboBox->addItem( tr( "B2 (500 x 707 mm)" ), QSizeF( 500, 707 ) );
+ mPaperSizeComboBox->addItem( tr( "B1 (707 x 1000 mm)" ), QSizeF( 707, 1000 ) );
+ mPaperSizeComboBox->addItem( tr( "B0 (1000 x 1414 mm)" ), QSizeF( 1000, 1414 ) );
+ // North american formats
+ mPaperSizeComboBox->addItem( tr( "Legal (8.5x14 inches)" ), QSizeF( 215.9, 355.6 ) );
+ mPaperSizeComboBox->addItem( tr( "ANSI A (Letter; 8.5x11 inches)" ), QSizeF( 215.9, 279.4 ) );
+ mPaperSizeComboBox->addItem( tr( "ANSI B (Tabloid; 11x17 inches)" ), QSizeF( 279.4, 431.8 ) );
+ mPaperSizeComboBox->addItem( tr( "ANSI C (17x22 inches)" ), QSizeF( 431.8, 558.8 ) );
+ mPaperSizeComboBox->addItem( tr( "ANSI D (22x34 inches)" ), QSizeF( 558.8, 863.6 ) );
+ mPaperSizeComboBox->addItem( tr( "ANSI E (34x44 inches)" ), QSizeF( 863.6, 1117.6 ) );
+ mPaperSizeComboBox->addItem( tr( "Arch A (9x12 inches)" ), QSizeF( 228.6, 304.8 ) );
+ mPaperSizeComboBox->addItem( tr( "Arch B (12x18 inches)" ), QSizeF( 304.8, 457.2 ) );
+ mPaperSizeComboBox->addItem( tr( "Arch C (18x24 inches)" ), QSizeF( 457.2, 609.6 ) );
+ mPaperSizeComboBox->addItem( tr( "Arch D (24x36 inches)" ), QSizeF( 609.6, 914.4 ) );
+ mPaperSizeComboBox->addItem( tr( "Arch E (36x48 inches)" ), QSizeF( 914.4, 1219.2 ) );
+ mPaperSizeComboBox->addItem( tr( "Arch E1 (30x42 inches)" ) , QSizeF( 762, 1066.8 ) );
+ mPaperSizeComboBox->setCurrentIndex( 2 ); //A3
void QgsGeorefConfigDialog::changeEvent( QEvent *e )
@@ -109,4 +139,9 @@
s.setValue( "/Plugin-GeoReferencer/Config/LeftMarginPDF", mLeftMarginSpinBox->value() );
s.setValue( "/Plugin-GeoReferencer/Config/RightMarginPDF", mRightMarginSpinBox->value() );
+ s.setValue( "/Plugin-GeoReferencer/Config/WidthPDFMap", mPaperSizeComboBox->itemData( mPaperSizeComboBox->currentIndex() ).toSizeF().width() );
+ s.setValue( "/Plugin-GeoReferencer/Config/HeightPDFMap", mPaperSizeComboBox->itemData( mPaperSizeComboBox->currentIndex() ).toSizeF().height() );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui 2010-09-04 13:08:17 UTC (rev 14191)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui 2010-09-05 14:11:56 UTC (rev 14192)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>249</width>
- <height>344</height>
+ <width>309</width>
+ <height>468</height>
</rect>
</property>
<property name="windowTitle">
@@ -108,14 +108,14 @@
</layout>
</widget>
</item>
- <item row="3" column="0">
+ <item row="4" column="0">
<widget class="QCheckBox" name="mShowDockedCheckBox">
<property name="text">
<string>Show Georeferencer window docked</string>
</property>
</widget>
</item>
- <item row="4" column="0">
+ <item row="5" column="0">
<widget class="QDialogButtonBox" name="buttonBox">
<property name="orientation">
<enum>Qt::Horizontal</enum>
@@ -125,6 +125,29 @@
</property>
</widget>
</item>
+ <item row="3" column="0">
+ <widget class="QGroupBox" name="groupBox">
+ <property name="title">
+ <string>PDF map</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_5">
+ <item row="0" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_3">
+ <item>
+ <widget class="QLabel" name="label_3">
+ <property name="text">
+ <string>Paper size</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="mPaperSizeComboBox"/>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
+ </item>
</layout>
</widget>
<resources/>
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-09-04 13:08:17 UTC (rev 14191)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-09-05 14:11:56 UTC (rev 14192)
@@ -28,6 +28,9 @@
#include <QPushButton>
#include <QTextStream>
+#include <QPen>
+#include <QStringList>
+#include <QList>
#include "qgisinterface.h"
#include "qgslegendinterface.h"
@@ -62,7 +65,6 @@
#include "qgsgeorefplugingui.h"
QgsGeorefDockWidget::QgsGeorefDockWidget( const QString & title, QWidget * parent, Qt::WindowFlags flags )
: QDockWidget( title, parent, flags )
@@ -310,7 +312,7 @@
d.getTransformSettings( mTransformParam, mResamplingMethod, mCompressionMethod,
- mModifiedRasterFileName, mProjection, mPdfOutputFile, mUseZeroForTrans, mLoadInQgis, mUserResX, mUserResY );
+ mModifiedRasterFileName, mProjection, mPdfOutputMapFile, mPdfOutputFile, mUseZeroForTrans, mLoadInQgis, mUserResX, mUserResY );
mTransformParamLabel->setText( tr( "Transform: " ) + convertTransformEnumToString( mTransformParam ) );
mGeorefTransform.selectTransformParametrisation( mTransformParam );
mGCPListWidget->setGeorefTransform( &mGeorefTransform );
@@ -1219,6 +1221,12 @@
writePDFReportFile( mPdfOutputFile, mGeorefTransform );
+ if ( success && !mPdfOutputMapFile.isEmpty() )
+ writePDFMapFile( mPdfOutputMapFile, mGeorefTransform );
else // Helmert, Polinom 1, Polinom 2, Polinom 3
@@ -1243,6 +1251,10 @@
+ if ( !mPdfOutputMapFile.isEmpty() )
return true;
@@ -1328,6 +1340,112 @@
return true;
+bool QgsGeorefPluginGui::writePDFMapFile( const QString& fileName, const QgsGeorefTransform& transform )
+ if ( !mCanvas )
+ return false;
+ QgsMapRenderer* canvasRenderer = mCanvas->mapRenderer();
+ if ( !canvasRenderer )
+ return false;
+ QgsRasterLayer *rlayer = ( QgsRasterLayer* ) mCanvas->layer( 0 );
+ if ( !rlayer )
+ return false;
+ double mapRatio = rlayer->extent().width() / rlayer->extent().height();
+ QPrinter printer;
+ printer.setOutputFormat( QPrinter::PdfFormat );
+ printer.setOutputFileName( fileName );
+ QSettings s;
+ double paperWidth = s.value( "/Plugin-GeoReferencer/Config/WidthPDFMap" ).toDouble();
+ double paperHeight = s.value( "/Plugin-GeoReferencer/Config/HeightPDFMap" ).toDouble();
+ //create composition
+ QgsComposition* composition = new QgsComposition( mCanvas->mapRenderer() );
+ if ( mapRatio >= 1 )
+ composition->setPaperSize( paperHeight, paperWidth );
+ else
+ composition->setPaperSize( paperWidth, paperHeight );
+ composition->setPrintResolution( 300 );
+ printer.setPaperSize( QSizeF( composition->paperWidth(), composition->paperHeight() ), QPrinter::Millimeter );
+ double leftMargin = 8;
+ double topMargin = 8;
+ double contentWidth = composition->paperWidth() - 2 * leftMargin;
+ double contentHeight = composition->paperHeight() - 2 * topMargin;
+ double contentRatio = contentWidth / contentHeight;
+ //composer map
+ QgsComposerMap* composerMap = new QgsComposerMap( composition, leftMargin, topMargin, contentWidth, contentHeight );
+ composerMap->setKeepLayerSet( true );
+ QStringList list;
+ list.append( canvasRenderer->layerSet()[0] );
+ composerMap->setLayerSet( list );
+ double xcenter = rlayer->extent().center().x();
+ double ycenter = rlayer->extent().center().y();
+ QgsRectangle rect;
+ if ( mapRatio > contentRatio )
+ rect = QgsRectangle( 0, ycenter - ( rlayer->extent().width() / contentRatio ) / 2, rlayer->extent().width(), ycenter + ( rlayer->extent().width() / contentRatio ) / 2 );
+ if ( mapRatio <= contentRatio )
+ rect = QgsRectangle( xcenter - ( rlayer->extent().height() * contentRatio / 2 ), -1 * rlayer->extent().height(), xcenter + ( rlayer->extent().height() * contentRatio / 2 ), 0 );
+ composerMap->setNewExtent( rect );
+ composition->addItem( composerMap );
+ printer.setFullPage( true );
+ printer.setColorMode( QPrinter::Color );
+ QString residualUnits;
+ if ( s.value( "/Plugin-GeoReferencer/Config/ResidualUnits" ) == "mapUnits" && mGeorefTransform.providesAccurateInverseTransformation() )
+ residualUnits = tr( "map units" );
+ else
+ residualUnits = tr( "pixels" );
+ //residual plot
+ QgsResidualPlotItem* resPlotItem = new QgsResidualPlotItem( composition );
+ composition->addItem( resPlotItem );
+ resPlotItem->setSceneRect( QRectF( leftMargin, topMargin, contentWidth, contentHeight ) );
+ resPlotItem->setExtent( rect );
+ resPlotItem->setGCPList( mPoints );
+ resPlotItem->setConvertScaleToMapUnits( residualUnits == tr( "map units" ) );
+ printer.setResolution( composition->printResolution() );
+ QPainter p( &printer );
+ composition->setPlotStyle( QgsComposition::Print );
+ QRectF paperRectMM = printer.pageRect( QPrinter::Millimeter );
+ QRectF paperRectPixel = printer.pageRect( QPrinter::DevicePixel );
+ composition->render( &p, paperRectPixel, paperRectMM );
+ delete resPlotItem;
+ delete composerMap;
+ delete composition;
+ return true;
bool QgsGeorefPluginGui::writePDFReportFile( const QString& fileName, const QgsGeorefTransform& transform )
if ( !mCanvas )
@@ -1475,7 +1593,7 @@
gcpTable->setHeaderFont( tableHeaderFont );
gcpTable->setContentFont( tableContentFont );
QStringList gcpHeader;
- gcpHeader << "id" << "enabled" << "pixelX" << "pixelY" << "mapX" << "mapY" << "resX[" + residualUnits + "]" << "resY[" + residualUnits + "]" << "resTot[" + residualUnits + "]";
+ gcpHeader << "id" << "enabled" << "pixelX" << "pixelY" << "mapX" << "mapY" << "resX [" + residualUnits + "]" << "resY [" + residualUnits + "]" << "resTot [" + residualUnits + "]";
gcpTable->setHeaderLabels( gcpHeader );
QgsGCPList::const_iterator gcpIt = mPoints.constBegin();
@@ -1494,8 +1612,8 @@
currentGCPStrings << tr( "no" );
- currentGCPStrings << QString::number(( *gcpIt )->pixelCoords().x(), 'f', 2 ) << QString::number(( *gcpIt )->pixelCoords().y(), 'f', 2 ) << QString::number(( *gcpIt )->mapCoords().x(), 'f', 2 )\
- << QString::number(( *gcpIt )->mapCoords().y(), 'f', 2 ) << QString::number( residual.x() ) << QString::number( residual.y() ) << QString::number( residualTot );
+ currentGCPStrings << QString::number(( *gcpIt )->pixelCoords().x(), 'f', 0 ) << QString::number(( *gcpIt )->pixelCoords().y(), 'f', 0 ) << QString::number(( *gcpIt )->mapCoords().x(), 'f', 3 )\
+ << QString::number(( *gcpIt )->mapCoords().y(), 'f', 3 ) << QString::number( residual.x() ) << QString::number( residual.y() ) << QString::number( residualTot );
gcpTable->addRow( currentGCPStrings );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h 2010-09-04 13:08:17 UTC (rev 14191)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h 2010-09-05 14:11:56 UTC (rev 14192)
@@ -103,7 +103,7 @@
void updateMouseCoordinatePrecision();
// when one Layer is removed
- void layerWillBeRemoved ( QString theLayerId );
+ void layerWillBeRemoved( QString theLayerId );
void extentsChanged(); // Use for need add again Raster (case above)
bool updateGeorefTransform();
@@ -127,7 +127,7 @@
void setupConnections();
// Mapcanvas Plugin
- void addRaster(QString file);
+ void addRaster( QString file );
// settings
void readSettings();
@@ -142,6 +142,7 @@
bool georeference();
bool writeWorldFile( QgsPoint origin, double pixelXSize, double pixelYSize, double rotation );
bool writePDFReportFile( const QString& fileName, const QgsGeorefTransform& transform );
+ bool writePDFMapFile( const QString& fileName, const QgsGeorefTransform& transform );
void updateTransformParamLabel();
// gdal script
@@ -201,6 +202,7 @@
QString mGCPpointsFileName;
QString mProjection;
QString mPdfOutputFile;
+ QString mPdfOutputMapFile;
double mUserResX, mUserResY; // User specified target scale
QgsGeorefTransform::TransformParametrisation mTransformParam;
Modified: trunk/qgis/src/plugins/georeferencer/qgsresidualplotitem.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsresidualplotitem.cpp 2010-09-04 13:08:17 UTC (rev 14191)
+++ trunk/qgis/src/plugins/georeferencer/qgsresidualplotitem.cpp 2010-09-05 14:11:56 UTC (rev 14192)
@@ -44,12 +44,10 @@
double widthMM = rect().width();
double heightMM = rect().height();
- QPen enabledPen( QColor( 0, 0, 255, 255 ) );
- enabledPen.setWidthF( 0.4 );
- QPen disabledPen( QColor( 0, 0, 255, 127 ) );
- disabledPen.setWidthF( 0.3 );
- QBrush enabledBrush( QColor( 255, 0, 0, 255 ) );
- QBrush disabledBrush( QColor( 255, 0, 0, 127 ) );
+ QPen enabledPen( QColor( 255, 0, 0, 255 ), 0.3, Qt::SolidLine, Qt::FlatCap, Qt::MiterJoin );
+ QPen disabledPen( QColor( 255, 0, 0, 85 ), 0.2, Qt::SolidLine, Qt::FlatCap, Qt::MiterJoin );
+ QBrush enabledBrush( QColor( 255, 255, 255, 255 ) );
+ QBrush disabledBrush( QColor( 255, 255, 255, 127 ) );
//draw all points and collect minimal mm/pixel ratio
double minMMPixelRatio = DBL_MAX;
@@ -74,7 +72,7 @@
painter->setPen( disabledPen );
painter->setBrush( disabledBrush );
- painter->drawRect( QRectF( gcpItemMMX - 1, gcpItemMMY - 1, 2, 2 ) );
+ painter->drawRect( QRectF( gcpItemMMX - 0.5, gcpItemMMY - 0.5, 1, 1 ) );
drawText( painter, gcpItemMMX + 2, gcpItemMMY + 2, QString::number(( *gcpIt )->id() ), QFont() );
mmPixelRatio = maxMMToPixelRatioForGCP( *gcpIt, gcpItemMMX, gcpItemMMY );
Modified: trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.cpp 2010-09-04 13:08:17 UTC (rev 14191)
+++ trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.cpp 2010-09-05 14:11:56 UTC (rev 14192)
@@ -48,16 +48,16 @@
leTargetSRS->setValidator( mRegExpValidator );
// Populate CompressionComboBox
- mListCompression.append("NONE");
- mListCompression.append("LZW");
- mListCompression.append("PACKBITS");
- mListCompression.append("DEFLATE");
+ mListCompression.append( "NONE" );
+ mListCompression.append( "LZW" );
+ mListCompression.append( "PACKBITS" );
+ mListCompression.append( "DEFLATE" );
QStringList listCompressionTr;
- foreach ( QString item, mListCompression)
+ foreach( QString item, mListCompression )
- listCompressionTr.append(tr(item.toAscii().data()));
+ listCompressionTr.append( tr( item.toAscii().data() ) );
- cmbCompressionComboBox->addItems(listCompressionTr);
+ cmbCompressionComboBox->addItems( listCompressionTr );
QSettings s;
@@ -86,12 +86,13 @@
tbnOutputRaster->setIcon( getThemeIcon( "/mPushButtonFileOpen.png" ) );
tbnTargetSRS->setIcon( getThemeIcon( "/mPushButtonTargetSRSDisabled.png" ) );
tbnReportFile->setIcon( getThemeIcon( "/mActionSaveAsPDF.png" ) );
+ tbnMapFile->setIcon( getThemeIcon( "/mActionSaveAsPDF.png" ) );
void QgsTransformSettingsDialog::getTransformSettings( QgsGeorefTransform::TransformParametrisation &tp,
QgsImageWarper::ResamplingMethod &rm,
QString &comprMethod, QString &raster,
- QString &proj, QString& pdfReportFile, bool &zt, bool &loadInQgis,
+ QString &proj, QString& pdfMapFile, QString& pdfReportFile, bool &zt, bool &loadInQgis,
double& resX, double& resY )
if ( cmbTransformType->currentIndex() == -1 )
@@ -110,6 +111,7 @@
raster = leOutputRaster->text();
proj = leTargetSRS->text();
+ pdfMapFile = mMapFileLineEdit->text();
pdfReportFile = mReportFileLineEdit->text();
zt = cbxZeroAsTrans->isChecked();
loadInQgis = cbxLoadInQgisWhenDone->isChecked();
@@ -244,6 +246,21 @@
+void QgsTransformSettingsDialog::on_tbnMapFile_clicked()
+ QSettings s;
+ QString myLastUsedDir = s.value( "/Plugin-GeoReferencer/lastPDFReportDir", "" ).toString();
+ QString outputFileName = QFileDialog::getSaveFileName( 0, tr( "Select save PDF file" ), myLastUsedDir, tr( "PDF Format" ) + " (*.pdf *PDF)" );
+ if ( !outputFileName.isNull() )
+ if ( !outputFileName.endsWith( ".pdf", Qt::CaseInsensitive ) )
+ outputFileName.append( ".pdf" );
+ mMapFileLineEdit->setText( outputFileName );
void QgsTransformSettingsDialog::on_tbnReportFile_clicked()
QSettings s;
Modified: trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.h
--- trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.h 2010-09-04 13:08:17 UTC (rev 14191)
+++ trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialog.h 2010-09-05 14:11:56 UTC (rev 14192)
@@ -12,7 +12,7 @@
* (at your option) any later version. *
-/* $Id: qgstransformsettingsdialog.h 13764 2010-06-21 12:11:11Z mhugent $ */
+/* $Id$ */
#ifndef QGSTRANSFORMSETTINGSDIALOG_H
#define QGSTRANSFORMSETTINGSDIALOG_H
@@ -32,7 +32,7 @@
int countGCPpoints, QWidget *parent = 0 );
void getTransformSettings( QgsGeorefTransform::TransformParametrisation &tp,
QgsImageWarper::ResamplingMethod &rm, QString &comprMethod,
- QString &raster, QString &proj, QString& pdfReportFile, bool &zt, bool &loadInQgis,
+ QString &raster, QString &proj, QString& pdfMapFile, QString& pdfReportFile, bool &zt, bool &loadInQgis,
double& resX, double& resY );
static void resetSettings();
@@ -43,6 +43,7 @@
private slots:
void on_tbnOutputRaster_clicked();
void on_tbnTargetSRS_clicked();
+ void on_tbnMapFile_clicked();
void on_tbnReportFile_clicked();
void on_leTargetSRS_textChanged( const QString &text );
void on_cmbTransformType_currentIndexChanged( const QString& text );
Modified: trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialogbase.ui
--- trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialogbase.ui 2010-09-04 13:08:17 UTC (rev 14191)
+++ trunk/qgis/src/plugins/georeferencer/qgstransformsettingsdialogbase.ui 2010-09-05 14:11:56 UTC (rev 14192)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>356</width>
- <height>429</height>
+ <width>438</width>
+ <height>478</height>
</rect>
</property>
@@ -137,14 +137,14 @@
</item>
</layout>
</item>
- <item row="6" column="0">
+ <item row="7" column="0">
<widget class="QLabel" name="label_6">
<string>Generate pdf report:</string>
</property>
</widget>
</item>
- <item row="6" column="1">
+ <item row="7" column="1">
<item>
<widget class="QLineEdit" name="mReportFileLineEdit"/>
@@ -158,21 +158,21 @@
</item>
</layout>
</item>
- <item row="7" column="0" colspan="2">
+ <item row="8" column="0" colspan="2">
<widget class="QCheckBox" name="cbxUserResolution">
<string>Set Target Resolution</string>
</property>
</widget>
</item>
- <item row="8" column="0">
+ <item row="9" column="0">
<widget class="QLabel" name="label_4">
<string>Horizontal</string>
</property>
</widget>
</item>
- <item row="8" column="1">
+ <item row="9" column="1">
<widget class="QgsValidatedDoubleSpinBox" name="dsbHorizRes">
<property name="decimals">
<number>5</number>
@@ -185,14 +185,14 @@
</property>
</widget>
</item>
- <item row="9" column="0">
+ <item row="10" column="0">
<widget class="QLabel" name="label_5">
<string>Vertical</string>
</property>
</widget>
</item>
- <item row="9" column="1">
+ <item row="10" column="1">
<widget class="QgsValidatedDoubleSpinBox" name="dsbVerticalRes">
<property name="sizePolicy">
<sizepolicy hsizetype="Minimum" vsizetype="Fixed">
@@ -221,6 +221,27 @@
</property>
</widget>
</item>
+ <item row="6" column="0">
+ <widget class="QLabel" name="label_7">
+ <string>Generate pdf map:</string>
+ </property>
+ </widget>
+ </item>
+ <item row="6" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout_4">
+ <item>
+ <widget class="QLineEdit" name="mMapFileLineEdit"/>
+ </item>
+ <item>
+ <widget class="QToolButton" name="tbnMapFile">
+ <string>...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
</layout>
</item>
<item row="1" column="0">
