[QGIS Commit] r14236 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Thu Sep 16 03:25:38 EDT 2010
Author: pcav
Date: 2010-09-16 07:25:38 +0000 (Thu, 16 Sep 2010)
New Revision: 14236
docs/trunk/english_us/user_guide/print_composer.tex
Correction of a few typos
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex 2010-09-16 07:20:03 UTC (rev 14235)
+++ docs/trunk/english_us/user_guide/print_composer.tex 2010-09-16 07:25:38 UTC (rev 14236)
@@ -88,7 +88,7 @@
Before you start to work with the print composer, you need to load some
raster and vector layers in the QGIS map canvas and adapt their properties
-to suite your own convinience. After everything is rendered and symbolized to
+to suite your own convenience. After everything is rendered and symbolized to
your liking you click the \toolbtntwo{mActionNewComposer}{New Print Composer}
icon in the toolbar or choose \mainmenuopt{File} \arrow
\dropmenuopttwo{mActionNewComposer}{New Print Composer}.
@@ -203,8 +203,8 @@
(see Figure \ref{fig:mapdialog}b)):
\begin{itemize}[label=--]
-\item The \textbf{Map extent} area allow to specify the map extend using Y
-and X min/max values or clicking the \button{Set to map canvas extend} button.
+\item The \textbf{Map extent} area allow to specify the map extent using Y
+and X min/max values or clicking the \button{Set to map canvas extent} button.
\end{itemize}
If you change the view on the QGIS map canvas by zooming or panning or
@@ -235,7 +235,7 @@
width used for cross or line grid type.
\item The \checkbox{Draw annotation} checkbox allows to add coordinates to
the map frame. The annotation can be drawn inside or outside the map frame.
-As annotatiion direction can be defined horizontal, vertical, horizontal and
+As annotation direction can be defined horizontal, vertical, horizontal and
vertical or boundary direction. And finally you can define the grid color,
the annotation font, the annotation distance from the map frame and the
precision of the drawn coordinates.
@@ -381,7 +381,7 @@
\item The legend items window lists all legend items and allows to change
item order, edit layer names, remove and restore items of the list. After
changing the symbology in the QGIS main window you can click on \button{Update} to
-adapt the changes in the legend element of the print composer. The item oder
+adapt the changes in the legend element of the print composer. The item order
can be changed using the \button{Up} and \button{Down} buttons or with Drag and Drop
functionality.
\end{itemize}
