[QGIS Commit] r14303 - trunk/qgis/src/mapserver
svn_qgis at osgeo.org
Tue Sep 28 16:00:58 EDT 2010
Author: mhugent
Date: 2010-09-28 20:00:58 +0000 (Tue, 28 Sep 2010)
New Revision: 14303
trunk/qgis/src/mapserver/qgis_map_serv.cpp
Possibility to set prefix path for mapserver by environment variable
Modified: trunk/qgis/src/mapserver/qgis_map_serv.cpp
--- trunk/qgis/src/mapserver/qgis_map_serv.cpp 2010-09-27 21:10:33 UTC (rev 14302)
+++ trunk/qgis/src/mapserver/qgis_map_serv.cpp 2010-09-28 20:00:58 UTC (rev 14303)
@@ -125,9 +125,20 @@
QgsApplication qgsapp( argc, argv, false );
- // init QGIS's paths - true means that all path will be inited from prefix
- QgsApplication::setPrefixPath( CMAKE_INSTALL_PREFIX, TRUE );
+ //Default prefix path may be altered by environment variable
+ char* prefixPath = getenv( "QGIS_PREFIX_PATH" );
+ if ( prefixPath )
+ QgsApplication::setPrefixPath( prefixPath, TRUE );
+ else
+ // init QGIS's paths - true means that all path will be inited from prefix
+ QgsApplication::setPrefixPath( CMAKE_INSTALL_PREFIX, TRUE );
// Instantiate the plugin directory so that providers are loaded
QgsProviderRegistry::instance( QgsApplication::pluginPath() );
#ifdef QGSMSDEBUG
