[QGIS Commit] r15327 - in trunk/qgis: python/core src/core
svn_qgis at osgeo.org
Thu Mar 3 17:45:22 EST 2011
Author: wonder
Date: 2011-03-03 14:45:21 -0800 (Thu, 03 Mar 2011)
New Revision: 15327
trunk/qgis/python/core/qgsvectorlayer.sip
trunk/qgis/src/core/qgsvectorlayer.h
Added missing python bindings for table joins
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip 2011-03-03 22:21:09 UTC (rev 15326)
+++ trunk/qgis/python/core/qgsvectorlayer.sip 2011-03-03 22:45:21 UTC (rev 15327)
@@ -4,6 +4,27 @@
typedef QSet<int> QgsAttributeIds;
+/** @note added in 1.7 */
+struct QgsVectorJoinInfo
+%TypeHeaderCode
+#include "qgsvectorlayer.h"
+%End
+ /**Join field in the target layer*/
+ int targetField;
+ /**Source layer*/
+ QString joinLayerId;
+ /**Join field in the source layer*/
+ int joinField;
+ /**True if the join is cached in virtual memory*/
+ bool memoryCache;
+ /**Cache for joined attributes to provide fast lookup (size is 0 if no memory caching)*/
+ // TODO: needs conversion
+ // QHash< QString, QgsAttributeMap> cachedAttributes;
class QgsVectorLayer : QgsMapLayer
%TypeHeaderCode
@@ -88,6 +109,19 @@
/** Setup the coordinate system tranformation for the layer */
void setCoordinateSystem();
+ /** Joins another vector layer to this layer
+ @param joinInfo join object containing join layer id, target and source field
+ @param cacheInMemory if true: caches the content of the join layer in virtual memory
+ @note added in 1.7 */
+ void addJoin( QgsVectorJoinInfo joinInfo );
+ /** Removes a vector layer join
+ void removeJoin( const QString& joinLayerId );
+ /** @note added in 1.7 */
+ const QList< QgsVectorJoinInfo >& vectorJoins() const;
QgsLabel *label();
QgsAttributeAction *actions();
@@ -549,12 +583,20 @@
@note public and static from version 1.4 */
static void drawVertexMarker( double x, double y, QPainter& p, QgsVectorLayer::VertexMarkerType type, int vertexSize );
+ /** Assembles mUpdatedFields considering provider fields, joined fields and added fields
+ void updateFieldMap();
+ /** Caches joined attributes if required (and not already done)
+ void createJoinCaches();
/**Returns unique values for column
@param index column index for attribute
@param uniqueValues out: result list
@limit maximum number of values to return (-1 if unlimited)
@note: this method was added in version 1.7*/
- void uniqueValues( int index, QList<QVariant>& uniqueValues, int limit );
+ void uniqueValues( int index, QList<QVariant>& uniqueValues /Out/, int limit );
public slots:
@@ -574,6 +616,10 @@
virtual void updateExtents();
+ /** Check if there is a join with a layer that will be removed
+ void checkJoinLayerRemove( QString theLayerId );
signals:
/** This signal is emited when selection was changed */
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2011-03-03 22:21:09 UTC (rev 15326)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2011-03-03 22:45:21 UTC (rev 15327)
@@ -55,6 +55,7 @@
typedef QSet<int> QgsFeatureIds;
struct CORE_EXPORT QgsVectorJoinInfo
@@ -69,8 +70,10 @@
-/**Join information prepared for fast attribute id mapping in QgsVectorLayerJoinBuffer::updateFeatureAttributes().
- Created in the select() method of QgsVectorLayerJoinBuffer for the joins that contain fetched attributes*/
+/** Join information prepared for fast attribute id mapping in QgsVectorLayerJoinBuffer::updateFeatureAttributes().
+ Created in the select() method of QgsVectorLayerJoinBuffer for the joins that contain fetched attributes
struct CORE_EXPORT QgsFetchJoinInfo
const QgsVectorJoinInfo* joinInfo;
@@ -150,14 +153,17 @@
- /**Joins another vector layer to this layer
- @param cacheInMemory if true: caches the content of the join layer in virtual memory*/
- /**Removes a vector layer join*/
/** Get the label object associated with this layer */
@@ -631,11 +637,12 @@
- /**Assembles mUpdatedFields considering provider fields, joined fields and added fields
- @note added in version 1.6*/
- /**Caches joined attributes if required (and not already done)*/
@@ -663,7 +670,8 @@
- /**Check if there is a join with a layer that will be removed*/
signals:
