[QGIS Commit] r15328 - trunk/qgis/i18n
svn_qgis at osgeo.org
Fri Mar 4 00:26:19 EST 2011
Author: pcav
Date: 2011-03-03 21:26:19 -0800 (Thu, 03 Mar 2011)
New Revision: 15328
trunk/qgis/i18n/qgis_it.ts
Updates to IT GUI translation
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts 2011-03-03 22:45:21 UTC (rev 15327)
+++ trunk/qgis/i18n/qgis_it.ts 2011-03-04 05:26:19 UTC (rev 15328)
@@ -211,7 +211,7 @@
<message>
<location filename="../python/plugins/fTools/tools/frmGeometry.ui" line="16"/>
<source>Extract Nodes</source>
- <translation>Estrai nodi</translation>
+ <translation>Estrai vertici</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmGeometry.ui" line="27"/>
@@ -3271,7 +3271,7 @@
</message>
<message>
<source>Extract nodes</source>
</message>
<message>
<source>Polygons to lines</source>
@@ -25446,27 +25446,27 @@
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="476"/>
<source>Min. X</source>
- <translation type="unfinished"></translation>
+ <translation>X Min</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="493"/>
<source>Min. Y</source>
+ <translation>Y Min</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="510"/>
<source>Max. X</source>
+ <translation>X Max</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="527"/>
<source>Max. Y</source>
+ <translation>Y Max</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="544"/>
<source>Use Current Canvas Extent</source>
+ <translation>Imposta alla estensione della mappa</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="567"/>
@@ -25761,7 +25761,9 @@
<source>
The data provider said:
%1</source>
+ <translation>
+La sorgente dati riporta:
+%1</translation>
</message>
<message>
<source>An error occurred when executing the query</source>
@@ -32878,7 +32880,7 @@
<message>
<location filename="../src/plugins/roadgraph/settingsdlg.cpp" line="32"/>
<source>Road graph plugin settings</source>
+ <translation>Impostazioni del plugin grafo strade</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/settingsdlg.cpp" line="36"/>
@@ -32893,7 +32895,7 @@
<message>
<location filename="../src/plugins/roadgraph/settingsdlg.cpp" line="66"/>
<source>second</source>
+ <translation>secondi</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/settingsdlg.cpp" line="67"/>
@@ -32916,12 +32918,12 @@
<message>
<location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="54"/>
<source>Shortest path</source>
+ <translation>Via più breve</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="65"/>
<source>Start</source>
+ <translation>Partenza</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="77"/>
@@ -32943,7 +32945,7 @@
<location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="93"/>
<location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="107"/>
<source>Time</source>
+ <translation>Tempo</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="115"/>
@@ -32979,12 +32981,12 @@
<message>
<location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="249"/>
<source>Start point doesn't tie to the road!</source>
+ <translation>Il punto di partenza non è sulla strada!</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="254"/>
<source>Stop point doesn't tie to the road!</source>
+ <translation>Il punto di arrivo non è sulla strada!</translation>
</message>
</context>
<context>
@@ -32992,12 +32994,12 @@
<message>
<location filename="../src/plugins/roadgraph/roadgraphplugin.cpp" line="98"/>
<source>Road graph settings</source>
+ <translation>Impostazioni del grafo strade</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/roadgraphplugin.cpp" line="99"/>
<source>Show road's direction</source>
+ <translation>Mostra la direzione della strada</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/roadgraphplugin.cpp" line="100"/>
@@ -33026,7 +33028,7 @@
<location filename="../src/plugins/roadgraph/roadgraphplugin.cpp" line="134"/>
<location filename="../src/plugins/roadgraph/roadgraphplugin.cpp" line="135"/>
<source>Road graph</source>
+ <translation>Grafo strade</translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/roadgraphplugin.cpp" line="196"/>
@@ -33046,7 +33048,7 @@
<message>
<location filename="../src/plugins/roadgraph/roadgraphplugin.cpp" line="207"/>
<source><b>Homepage:</b></source>
+ <translation><b>Homepage:</b></translation>
</message>
<message>
<location filename="../src/plugins/roadgraph/roadgraphplugin.cpp" line="235"/>
@@ -33079,7 +33081,7 @@
<message>
<location filename="../src/plugins/sqlanywhere/sadbtablemodel.cpp" line="42"/>
<source>Line Interpretation</source>
+ <translation>Interpretazione della linea</translation>
</message>
<message>
<location filename="../src/plugins/sqlanywhere/sadbtablemodel.cpp" line="43"/>
@@ -33107,7 +33109,7 @@
<message>
<location filename="../src/plugins/sqlanywhere/sanewconnection.cpp" line="127"/>
<source>Failed to load interface</source>
+ <translation>Impossibile caricare l'interfaccia</translation>
</message>
<message>
<location filename="../src/plugins/sqlanywhere/sanewconnection.cpp" line="154"/>
@@ -33126,7 +33128,10 @@
SQL Anywhere error code: %1
Description: %2</source>
+ <translation>Connessione non riuscita. Controlla le impostazioni e riprova.
+Codice di errore SQL Anywhere: %1
+Descrizione: %2</translation>
</message>
</context>
<context>
@@ -33397,7 +33402,7 @@
<location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="77"/>
<location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="220"/>
</message>
<message>
<location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="78"/>
@@ -33434,7 +33439,7 @@
<message>
<location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="352"/>
</message>
<message>
<location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="409"/>
@@ -33462,7 +33467,7 @@
<message>
<location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="566"/>
<source>found</source>
+ <translation>trovato</translation>
</message>
<message>
@@ -35133,7 +35138,7 @@
</message>
<message>
</message>
<message>
<source>Simplify geometries</source>
