[QGIS Commit] r15330 - trunk/qgis/src/plugins/roadgraph
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Mar 4 08:09:51 EST 2011
Author: stopa85
Date: 2011-03-04 05:09:51 -0800 (Fri, 04 Mar 2011)
New Revision: 15330
   trunk/qgis/src/plugins/roadgraph/CMakeLists.txt
   trunk/qgis/src/plugins/roadgraph/graphbuilder.h
   trunk/qgis/src/plugins/roadgraph/graphdirector.h
   trunk/qgis/src/plugins/roadgraph/linevectorlayerdirector.cpp
   trunk/qgis/src/plugins/roadgraph/shortestpathwidget.cpp
   trunk/qgis/src/plugins/roadgraph/simplegraphbuilder.cpp
   trunk/qgis/src/plugins/roadgraph/simplegraphbuilder.h
Add progress bar.
Modified: trunk/qgis/src/plugins/roadgraph/CMakeLists.txt
--- trunk/qgis/src/plugins/roadgraph/CMakeLists.txt	2011-03-04 07:14:17 UTC (rev 15329)
+++ trunk/qgis/src/plugins/roadgraph/CMakeLists.txt	2011-03-04 13:09:51 UTC (rev 15330)
@@ -19,6 +19,7 @@
 #SET ([pluginlcasename]_UIS [pluginlcasename]guibase.ui)
 SET (VRP_MOC_HDRS
+  graphdirector.h
   roadgraphplugin.h
   settingsdlg.h
   shortestpathwidget.h
Modified: trunk/qgis/src/plugins/roadgraph/graphbuilder.h
--- trunk/qgis/src/plugins/roadgraph/graphbuilder.h	2011-03-04 07:14:17 UTC (rev 15329)
+++ trunk/qgis/src/plugins/roadgraph/graphbuilder.h	2011-03-04 13:09:51 UTC (rev 15330)
@@ -56,7 +56,7 @@
      * add arc
-    virtual void addArc( const QgsPoint& pt1, const QgsPoint& pt2, double cost, double speed ) = 0;
+    virtual void addArc( const QgsPoint& pt1, const QgsPoint& pt2, double cost, double speed, int featureId ) = 0;
   private:
     QgsCoordinateReferenceSystem mCrs;
Modified: trunk/qgis/src/plugins/roadgraph/graphdirector.h
--- trunk/qgis/src/plugins/roadgraph/graphdirector.h	2011-03-04 07:14:17 UTC (rev 15329)
+++ trunk/qgis/src/plugins/roadgraph/graphdirector.h	2011-03-04 13:09:51 UTC (rev 15330)
@@ -16,6 +16,7 @@
 #define ROADGRAPH_GRAPHDIRECTOR
 //QT4 includes
+#include <QObject>
 //QGIS includes
 #include <qgsrectangle.h>
@@ -27,8 +28,14 @@
  * \class RgGraphDirector
  * \brief Determine making the graph
-class RgGraphDirector
+class RgGraphDirector : public QObject
+    Q_OBJECT
+  signals:
+    void buildProgress( int, int ) const;
+    void buildMessage( QString ) const;
   public:
     //! Destructor
     virtual ~RgGraphDirector() { };
Modified: trunk/qgis/src/plugins/roadgraph/linevectorlayerdirector.cpp
--- trunk/qgis/src/plugins/roadgraph/linevectorlayerdirector.cpp	2011-03-04 07:14:17 UTC (rev 15329)
+++ trunk/qgis/src/plugins/roadgraph/linevectorlayerdirector.cpp	2011-03-04 13:09:51 UTC (rev 15330)
@@ -69,6 +69,9 @@
   if ( vl == NULL )
     return;
+  int featureCount = ( int ) vl->featureCount() * 2;
+  int step = 0;
   QgsCoordinateTransform ct( vl->crs(), builder->destinationCrs() );
   QgsDistanceArea da;
@@ -117,6 +120,7 @@
       pt1 = pt2;
       isFirstPoint = false;
+    emit buildProgress( ++step, featureCount );
   // end: tie points to graph
@@ -212,12 +216,12 @@
             if ( directionType == 1 ||
                  directionType == 3 )
-              builder->addArc( pt1, pt2, cost, speed*su.multipler() );
+              builder->addArc( pt1, pt2, cost, speed*su.multipler(), feature.id() );
             if ( directionType == 2 ||
-              builder->addArc( pt2, pt1, cost, speed*su.multipler() );
+              builder->addArc( pt2, pt1, cost, speed*su.multipler(), feature.id() );
           pt1 = pt2;
@@ -227,7 +231,7 @@
       pt1 = pt2;
     } // for (it = pl.begin(); it != pl.end(); ++it)
   } // while( vl->nextFeature(feature) )
 } // makeGraph( RgGraphBuilder *builder, const QgsRectangle& rt )
Modified: trunk/qgis/src/plugins/roadgraph/shortestpathwidget.cpp
--- trunk/qgis/src/plugins/roadgraph/shortestpathwidget.cpp	2011-03-04 07:14:17 UTC (rev 15329)
+++ trunk/qgis/src/plugins/roadgraph/shortestpathwidget.cpp	2011-03-04 13:09:51 UTC (rev 15330)
@@ -222,7 +222,11 @@
 bool RgShortestPathWidget::getPath( AdjacencyMatrix& matrix, QgsPoint& p1, QgsPoint& p2 )
   if ( mFrontPointLineEdit->text().isNull() || mBackPointLineEdit->text().isNull() )
+    QMessageBox::critical( this, tr( "Point not selected" ), tr( "Frist, select start and stop points." ) );
     return false;
   RgSimpleGraphBuilder builder( mPlugin->iface()->mapCanvas()->mapRenderer()->destinationSrs(),
                                 mPlugin->topologyToleranceFactor() );
@@ -232,6 +236,9 @@
       QMessageBox::critical( this, tr( "Plugin isn't configured" ), tr( "Plugin isn't configured!" ) );
       return false;
+    connect( director, SIGNAL( buildProgress( int, int ) ), mPlugin->iface()->mainWindow(), SLOT( showProgress( int, int ) ) );
+    connect( director, SIGNAL( buildMessage( QString ) ), mPlugin->iface()->mainWindow(), SLOT( showStatusMessage( QString ) ) );
     QVector< QgsPoint > points;
     QVector< QgsPoint > tiedPoint;
Modified: trunk/qgis/src/plugins/roadgraph/simplegraphbuilder.cpp
--- trunk/qgis/src/plugins/roadgraph/simplegraphbuilder.cpp	2011-03-04 07:14:17 UTC (rev 15329)
+++ trunk/qgis/src/plugins/roadgraph/simplegraphbuilder.cpp	2011-03-04 13:09:51 UTC (rev 15330)
@@ -53,9 +53,9 @@
   return pt;
-void RgSimpleGraphBuilder::addArc( const QgsPoint& pt1, const QgsPoint& pt2, double cost, double speed )
+void RgSimpleGraphBuilder::addArc( const QgsPoint& pt1, const QgsPoint& pt2, double cost, double speed, int featureId )
-  mMatrix[ pt1 ][ pt2 ] = ArcAttributes( cost, cost / speed, 0 );
+  mMatrix[ pt1 ][ pt2 ] = ArcAttributes( cost, cost / speed, featureId );
 AdjacencyMatrix RgSimpleGraphBuilder::adjacencyMatrix()
Modified: trunk/qgis/src/plugins/roadgraph/simplegraphbuilder.h
--- trunk/qgis/src/plugins/roadgraph/simplegraphbuilder.h	2011-03-04 07:14:17 UTC (rev 15329)
+++ trunk/qgis/src/plugins/roadgraph/simplegraphbuilder.h	2011-03-04 13:09:51 UTC (rev 15330)
@@ -44,7 +44,7 @@
      * MANDATORY BUILDER PROPERTY DECLARATION
     QgsPoint addVertex( const QgsPoint& pt );
-    void addArc( const QgsPoint& pt1, const QgsPoint& pt2, double cost, double speed );
+    void addArc( const QgsPoint& pt1, const QgsPoint& pt2, double cost, double speed, int featureId );
      * return Adjacecncy matrix;
More information about the QGIS-commit mailing list
