[QGIS Commit] r15331 - in trunk/qgis/src/plugins: . ogr_converter
svn_qgis at osgeo.org
Fri Mar 4 12:13:55 EST 2011
Author: timlinux
Date: 2011-03-04 09:13:55 -0800 (Fri, 04 Mar 2011)
New Revision: 15331
Removed:
trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt
trunk/qgis/src/plugins/ogr_converter/README
trunk/qgis/src/plugins/ogr_converter/dialog.cpp
trunk/qgis/src/plugins/ogr_converter/dialog.h
trunk/qgis/src/plugins/ogr_converter/format.cpp
trunk/qgis/src/plugins/ogr_converter/format.h
trunk/qgis/src/plugins/ogr_converter/ogr_converter.png
trunk/qgis/src/plugins/ogr_converter/ogrconverter.qrc
trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui
trunk/qgis/src/plugins/ogr_converter/plugin.cpp
trunk/qgis/src/plugins/ogr_converter/plugin.h
trunk/qgis/src/plugins/ogr_converter/translator.cpp
trunk/qgis/src/plugins/ogr_converter/translator.h
trunk/qgis/src/plugins/CMakeLists.txt
Removed ogr converter: 1. its not maintained 2. its mostly duplicated by the layer save as... option.
Modified: trunk/qgis/src/plugins/CMakeLists.txt
--- trunk/qgis/src/plugins/CMakeLists.txt 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/CMakeLists.txt 2011-03-04 17:13:55 UTC (rev 15331)
@@ -7,7 +7,6 @@
raster_terrain_analysis
coordinate_capture
dxf2shp_converter
- ogr_converter
diagram_overlay
evis
point_displacement_renderer
Deleted: trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt
--- trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,65 +0,0 @@
-# $Id$
-# CMake configuration file for OGR Converter plugin
-# Author: Mateusz Loskot <mateusz at loskot.net>
-# Files
-SET (OGR_CONVERTER_SRCS
- plugin.cpp
- dialog.cpp
- format.cpp
- translator.cpp
-SET (OGR_CONVERTER_UIS ogrconverterguibase.ui)
-SET (OGR_CONVERTER_MOC_HDRS
- plugin.h
- dialog.h
-SET (OGR_CONVERTER_RCCS ogrconverter.qrc)
-SET (OGR_CONVERTER_PLUGIN ogrconverterplugin)
-# Build
-QT4_WRAP_UI (OGR_CONVERTER_UIS_H ${OGR_CONVERTER_UIS})
-QT4_WRAP_CPP (OGR_CONVERTER_MOC_SRCS ${OGR_CONVERTER_MOC_HDRS})
-QT4_ADD_RESOURCES(OGR_CONVERTER_RCC_SRCS ${OGR_CONVERTER_RCCS})
-ADD_LIBRARY (${OGR_CONVERTER_PLUGIN} MODULE
- ${OGR_CONVERTER_SRCS}
- ${OGR_CONVERTER_MOC_SRCS}
- ${OGR_CONVERTER_RCC_SRCS}
- ${OGR_CONVERTER_UIS_H}
-INCLUDE_DIRECTORIES (
- ${CMAKE_CURRENT_SOURCE_DIR}
- ${CMAKE_CURRENT_BINARY_DIR}
- ../../core
- ../../core/raster
- ../../core/renderer
- ../../core/symbology
- ../../gui
- ${GDAL_INCLUDE_DIR}
-TARGET_LINK_LIBRARIES(${OGR_CONVERTER_PLUGIN}
- qgis_core
- qgis_gui
-# Install
-INSTALL(TARGETS ${OGR_CONVERTER_PLUGIN}
- RUNTIME DESTINATION ${QGIS_PLUGIN_DIR}
- LIBRARY DESTINATION ${QGIS_PLUGIN_DIR}
Deleted: trunk/qgis/src/plugins/ogr_converter/README
--- trunk/qgis/src/plugins/ogr_converter/README 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/README 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,35 +0,0 @@
-OGR Layer Converter Pluginm, Version 0.1 (Alpha)
-Author: Mateusz Loskot <mateusz at loskot.net>
-OGR Layer Converter aims to be a GUI-based implementation of well-known
-ogr2ogr utility from GDAL/OGR package. The plugin translates layers
-between OGR supported formats built-in GDAL/OGR library available for
-particular QGIS installation.
-Built-in formats are listed in drop-down boxes.
-Currently, it is possible to translate one selected source
-layer to another OGR format.
-Testing appreciated.
- TODO
-translator.h: // TODO: Implement, currently always overwrite
-translator.h: // TODO: Append option not supported
-dialog.cpp:// TODO: Add support of QGIS projection selector
-dialog.cpp: // TODO: Transformation support
-dialog.cpp: // TODO: SRS transformation support
-dialog.cpp: // TODO: Use try-catch to display more meaningful error messages from Translator
-plugin.cpp: // TODO: Who is responsible for OGR cleanup?
-translator.cpp: // TODO: RAII for OGR handlers!!!
-translator.cpp: // TODO: Support translation of all layers from input data source
-translator.cpp: // TODO: -nlt option support
-translator.cpp: // TODO: Implement SRS transformation
-translator.cpp: // TODO: Append and createion options not implemented
-translator.cpp: // TODO: RAII for feature handlers!!!
-translator.cpp: // TODO: Transform feature geometry
-translator.cpp: // TODO: Skip failures support
-translator.cpp: // TODO: Add support for creation options
Deleted: trunk/qgis/src/plugins/ogr_converter/dialog.cpp
--- trunk/qgis/src/plugins/ogr_converter/dialog.cpp 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/dialog.cpp 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,450 +0,0 @@
-// $Id$
-// Copyright (C) 2008 by Mateusz Loskot <mateusz at loskot.net>
-// This program is free software; you can redistribute it and/or modify
-// it under the terms of the GNU General Public License as published by
-// the Free Software Foundation; either version 2 of the License,
-// or (at your option) any later version.
-// qgis::plugin::ogrconv
-#include "dialog.h"
-#include "format.h"
-#include "translator.h"
-// QGIS includes
-#include <qgsapplication.h>
-#include <qgslogger.h>
-#include <qgscontexthelp.h>
-// TODO: Add support of QGIS projection selector
-//#include <qgsprojectionselector.h>
-// Qt4
-#include <QtAlgorithms>
-#include <QtDebug>
-#include <QFileDialog>
-#include <QMessageBox>
-#include <QSettings>
-#include <QString>
-#include <QStringList>
-#include <QVariant>
-#include <ogr_api.h>
-#if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1800
-#define TO8(x) (x).toUtf8().constData()
-#else
-#define TO8(x) (x).toLocal8Bit().constData()
-#endif
-Dialog::Dialog( QWidget* parent, Qt::WFlags fl )
- : QDialog( parent, fl )
- setupUi( this );
- populateFormats();
- resetSrcUi();
- resetDstUi();
-Dialog::~Dialog()
-void Dialog::resetSrcUi()
- // Clear all settings and states
- inputSrcDataset->clear();
- // TODO: Transformation support
- //inputSrcSrs->clear();
- comboSrcLayer->clear();
- radioSrcFile->setDisabled( true );
- radioSrcFile->setChecked( false );
- radioSrcDirectory->setDisabled( true );
- radioSrcDirectory->setChecked( false );
- radioSrcProtocol->setDisabled( true );
- radioSrcProtocol->setChecked( false );
- // Configure types of input sources
- unsigned char const& type = mSrcFormat.type();
- if ( isFormatType( type, Format::eFile ) )
- radioSrcFile->setDisabled( false );
- radioSrcFile->setChecked( true );
- if ( isFormatType( type, Format::eDirectory ) )
- radioSrcDirectory->setDisabled( false );
- if ( !radioSrcFile->isEnabled() )
- radioSrcDirectory->setChecked( true );
- if ( isFormatType( type, Format::eProtocol ) )
- radioSrcProtocol->setDisabled( false );
- if ( !radioSrcFile->isEnabled() && !radioSrcDirectory->isEnabled() )
- radioSrcProtocol->setChecked( true );
- inputSrcDataset->setText( mSrcFormat.protocol() );
- setButtonState( buttonSelectSrc, isFormatType( type, Format::eProtocol ) );
-void Dialog::resetDstUi()
- inputDstDataset->clear();
- //inputDstSrs->clear();
- unsigned char const& type = mDstFormat.type();
- bool isProtocol = isFormatType( type, Format::eProtocol );
- if ( isProtocol )
- inputDstDataset->setText( mDstFormat.protocol() );
- setButtonState( buttonSelectDst, isProtocol );
-void Dialog::setButtonState( QPushButton* btn, bool isProtocol )
- Q_CHECK_PTR( btn );
- if ( isProtocol )
- btn->setText( tr( "Connect" ) );
- else
- btn->setText( tr( "Browse" ) );
-void Dialog::populateFormats()
- comboSrcFormats->clear();
- comboDstFormats->clear();
- QStringList drvSrcList;
- QStringList drvDstList;
- QString drvName;
- QgsApplication::registerOgrDrivers();
- int const drvCount = OGRGetDriverCount();
- for ( int i = 0; i < drvCount; ++i )
- OGRSFDriverH drv = OGRGetDriver( i );
- Q_CHECK_PTR( drv );
- if ( 0 != drv )
- drvName = OGR_Dr_GetName( drv );
- drvSrcList.append( drvName );
- if ( 0 != OGR_Dr_TestCapability( drv, ODrCCreateDataSource ) )
- drvDstList.append( drvName );
- qSort( drvSrcList.begin(), drvSrcList.end() );
- qSort( drvDstList.begin(), drvDstList.end() );
- comboSrcFormats->addItems( drvSrcList );
- comboDstFormats->addItems( drvDstList );
-void Dialog::populateLayers( QString const& url )
- OGRDataSourceH ds = OGROpen( TO8( url ), 0, 0 );
- if ( 0 != ds )
- QString lyrName;
- QString lyrType;
- int const size = OGR_DS_GetLayerCount( ds );
- for ( int i = 0; i < size; ++i )
- OGRLayerH lyr = OGR_DS_GetLayer( ds, i );
- if ( 0 != lyr )
- OGRFeatureDefnH lyrDef = OGR_L_GetLayerDefn( lyr );
- Q_ASSERT( 0 != lyrDef );
- lyrName = OGR_FD_GetName( lyrDef );
- OGRwkbGeometryType const geomType = OGR_FD_GetGeomType( lyrDef );
- lyrType = OGRGeometryTypeToName( geomType );
- // FIXME: Appending type to layer name prevents from layer finding
- //comboSrcLayer->addItem(lyrName + " (" + lyrType.toUpper() + ")");
- comboSrcLayer->addItem( lyrName );
- OGR_DS_Destroy( ds );
- else
- QMessageBox::warning( this,
- tr( "OGR Converter" ),
- tr( "Could not establish connection to: '%1'" ).arg( url ),
- QMessageBox::Close );
-bool Dialog::testConnection( QString const& url )
- bool success = false;
- if ( 0 != ds )
- success = true;
- return success;
-QString Dialog::openFile()
- QSettings sets;
- QString path = QFileDialog::getOpenFileName( this,
- tr( "Open OGR file" ),
- sets.value( "/Plugin-OGR/ogr-file", "./" ).toString(),
- tr( "OGR File Data Source (*.*)" ) );
- return path;
-QString Dialog::openDirectory()
- QString path = QFileDialog::getExistingDirectory( this,
- tr( "Open Directory" ), "",
- QFileDialog::ShowDirsOnly | QFileDialog::DontResolveSymlinks );
- return path;
-void Dialog::on_buttonBox_accepted()
- // Validate input settings
- QString srcUrl( inputSrcDataset->text() );
- QString srcLayer( comboSrcLayer->currentText() );
- if ( srcUrl.isEmpty() )
- tr( "OGR Layer Converter" ),
- tr( "Input OGR dataset is missing!" ) );
- return;
- if ( srcLayer.isEmpty() )
- tr( "Input OGR layer name is missing!" ) );
- return;
- // Validate output settings
- QString dstFormat( comboDstFormats->currentText() );
- QString dstUrl( inputDstDataset->text() );
- QString dstLayer( inputDstLayer->text() );
- if ( dstLayer.isEmpty() )
- dstLayer = srcLayer;
- if ( dstFormat.isEmpty() )
- tr( "Target OGR format not selected!" ) );
- return;
- if ( dstUrl.isEmpty() )
- tr( "Output OGR dataset is missing!" ) );
- return;
- tr( "Output OGR layer name is missing!" ) );
- return;
- // TODO: SRS transformation support
- //QString srcSrs("EPSG:");
- //QString dstSrs("EPSG:");
- //srcSrs += inputSrcSrs->text();
- //dstSrs += inputDstSrs->text();
- // Execute layer translation
- // TODO: Use try-catch to display more meaningful error messages from Translator
- Translator worker( srcUrl, dstUrl, dstFormat );
- worker.setSourceLayer( srcLayer );
- worker.setTargetLayer( dstLayer );
- success = worker.translate();
- if ( success )
- QMessageBox::information( this,
- tr( "Successfully translated layer '%1'" ).arg( srcLayer ) );
- else
- tr( "Failed to translate layer '%1'" ).arg( srcLayer ) );
- // Close dialog box
- accept();
-void Dialog::on_buttonBox_rejected()
- reject();
-void Dialog::on_radioSrcFile_toggled( bool checked )
- if ( checked )
- Q_ASSERT( isFormatType( type, Format::eFile ) );
-void Dialog::on_radioSrcDirectory_toggled( bool checked )
- if ( checked )
- Q_ASSERT( isFormatType( type, Format::eDirectory ) );
-void Dialog::on_radioSrcProtocol_toggled( bool checked )
- if ( checked )
- Q_ASSERT( isFormatType( type, Format::eProtocol ) );
-void Dialog::on_comboSrcFormats_currentIndexChanged( int index )
- // Select source data format
- QString frmtCode = comboSrcFormats->currentText();
- mSrcFormat = mFrmts.find( frmtCode );
- resetSrcUi();
-void Dialog::on_comboDstFormats_currentIndexChanged( int index )
- // Select destination data format
- QString frmtCode = comboDstFormats->currentText();
- mDstFormat = mFrmts.find( frmtCode );
- resetDstUi();
-void Dialog::on_buttonSelectSrc_clicked()
- QSettings settings;
- QString src;
- if ( radioSrcFile->isChecked() )
- src = openFile();
- else if ( radioSrcDirectory->isChecked() )
- src = openDirectory();
- else if ( radioSrcProtocol->isChecked() )
- src = inputSrcDataset->text();
- else
- Q_ASSERT( !"SHOULD NEVER GET HERE" );
- inputSrcDataset->setText( src );
- if ( !src.isEmpty() )
- populateLayers( src );
-void Dialog::on_buttonSelectDst_clicked()
- QString dst;
- QString msg;
- dst = inputDstDataset->text();
- if ( testConnection( dst ) )
- msg = tr( "Successfully connected to: '%1'" ).arg( dst );
- else
- msg = tr( "Could not establish connection to: '%1'" ).arg( dst );
- QMessageBox::information( this, tr( "OGR Converter" ), msg, QMessageBox::Close );
- else if ( isFormatType( type, Format::eDirectory ) )
- dst = openDirectory();
- else if ( isFormatType( type, Format::eFile ) )
- dst = QFileDialog::getSaveFileName( this,
- tr( "Choose a file name to save to" ),
- "output", tr( "OGR File Data Source (*.*)" ) );
- else
- inputDstDataset->setText( dst );
Deleted: trunk/qgis/src/plugins/ogr_converter/dialog.h
--- trunk/qgis/src/plugins/ogr_converter/dialog.h 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/dialog.h 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,63 +0,0 @@
-// $Id$
-#ifndef QGIS_PLUGIN_OGRCONV_DIALOG_H_INCLUDED
-#define QGIS_PLUGIN_OGRCONV_DIALOG_H_INCLUDED
-#include <ui_ogrconverterguibase.h>
-// Qt4
-#include <QDialog>
-#include "qgscontexthelp.h"
- at author Mateusz Loskot
-class Dialog : public QDialog, private Ui::OgrConverterGuiBase
- Q_OBJECT
- public:
- Dialog( QWidget* parent = 0, Qt::WFlags fl = 0 );
- ~Dialog();
- private:
- FormatsRegistry mFrmts;
- Format mSrcFormat;
- Format mDstFormat;
- void resetSrcUi();
- void resetDstUi();
- void setButtonState( QPushButton* btn, bool isProtocol );
- void populateFormats();
- void populateLayers( QString const& url );
- bool testConnection( QString const& url );
- QString openFile();
- QString openDirectory();
- private slots:
- void on_buttonBox_accepted();
- void on_buttonBox_rejected();
- void on_buttonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
- void on_radioSrcFile_toggled( bool checked );
- void on_radioSrcDirectory_toggled( bool checked );
- void on_radioSrcProtocol_toggled( bool checked );
- void on_buttonSelectSrc_clicked();
- void on_buttonSelectDst_clicked();
- void on_comboSrcFormats_currentIndexChanged( int index );
- void on_comboDstFormats_currentIndexChanged( int index );
-#endif // QGIS_PLUGIN_OGRCONV_DIALOG_H_INCLUDED
Deleted: trunk/qgis/src/plugins/ogr_converter/format.cpp
--- trunk/qgis/src/plugins/ogr_converter/format.cpp 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/format.cpp 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,112 +0,0 @@
-// $Id$
-// Qt4
-#include <QString>
-Format::Format()
-Format::Format( QString const& c, QString const& n )
- : mCode( c ), mName( n ), mTypeFlags( 0 )
-Format::Format( QString const& c, QString const& n, unsigned char const& t )
- : mCode( c ), mName( n ), mTypeFlags( t )
-Format::Format( QString const& c, QString const& n, QString const& p, unsigned char const& t )
- : mCode( c ), mName( n ), mProtocol( p ), mTypeFlags( t )
-QString const& Format::code() const
- return mCode;
-QString const& Format::name() const
- return mName;
-QString const& Format::protocol() const
- return mProtocol;
-unsigned char const& Format::type() const
- return mTypeFlags;
-FormatsRegistry::FormatsRegistry()
- init();
-void FormatsRegistry::add( Format const& frmt )
- QString code = frmt.code();
- mFrmts[code] = frmt;
-Format const& FormatsRegistry::find( QString const& code )
- mCache = mFrmts.value( code );
- return mCache;
-void FormatsRegistry::init()
- add( Format( "AVCBin", "Arc/Info Binary Coverage", Format::eFile ) );
- add( Format( "AVCE00", "Arc/Info .E00 (ASCII) Coverage", Format::eFile ) );
- add( Format( "BNA", "Atlas BNA", Format::eFile ) );
- add( Format( "CSV", "Comma Separated Value", Format::eFile | Format::eDirectory ) );
- add( Format( "DODS", "DODS/OPeNDAP", Format::eFile ) );
- add( Format( "DGN", "Microstation DGN", Format::eFile ) );
- add( Format( "ESRI Shapefile", "ESRI Shapefile", Format::eFile | Format::eDirectory ) );
- add( Format( "FMEObjects Gateway", "FMEObjects Gateway", Format::eFile ) );
- add( Format( "Geoconcept Text Export", "Geoconcept", Format::eFile ) );
- add( Format( "GML", "Geography Markup Language", Format::eFile ) );
- add( Format( "GMT", "GMT ASCII Vectors", Format::eFile ) );
- add( Format( "GPX", "GPS Exchange Format", Format::eFile ) );
- add( Format( "GeoJSON", "GeoJSON", Format::eFile ) ); // FIXME: Format::eProtocol));
- add( Format( "GRASS", "GRASS", Format::eDirectory ) );
- add( Format( "Informix DataBlade", "IDB", "IDB:", Format::eProtocol ) );
- add( Format( "Interlis 1", "INTERLIS", Format::eFile ) );
- add( Format( "Interlis 2", "INTERLIS", Format::eFile ) );
- add( Format( "Ingres Database", "INGRES", "@driver=ingres,", Format::eProtocol ) );
- add( Format( "KML", "KML", Format::eFile ) );
- add( Format( "MapInfo", "MapInfo File", Format::eFile ) );
- add( Format( "Memory", "Memory", Format::eFile ) );
- add( Format( "MySQL", "MySQL", "MySQL:", Format::eProtocol ) );
- add( Format( "ODBC", "Open DataBase Connectivity", "ODBC:", Format::eProtocol ) );
- add( Format( "OGDI", "Open Geographic Datastore Interface Vectors", "gltp:", Format::eProtocol ) );
- add( Format( "OCI", "Oracle Spatial", "OCI:", Format::eProtocol ) );
- add( Format( "PGeo", "ESRI Personal GeoDatabase", "PGeo:", Format::eFile | Format::eProtocol ) );
- add( Format( "PostgreSQL", "PostgreSQL", "PG:", Format::eProtocol ) );
- add( Format( "S57", "IHO S-57", Format::eFile ) );
- add( Format( "SDE", "ESRI ArcSDE", "SDE:", Format::eProtocol ) );
- add( Format( "SDTS", "SDTS Topological Vector Profile", Format::eFile ) );
- add( Format( "SQLite", "SQLite Database File", Format::eFile ) );
- add( Format( "UK.NTF", "UK National Transfer Format", Format::eFile ) );
- add( Format( "TIGER", "U.S. Census TIGER/Line", Format::eFile ) );
- add( Format( "VRT", "Virtual Datasource", Format::eFile ) );
- add( Format( "XPLANE", "X-Plane/Flightgear Aeronautical Data", Format::eFile ) );
Deleted: trunk/qgis/src/plugins/ogr_converter/format.h
--- trunk/qgis/src/plugins/ogr_converter/format.h 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/format.h 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,71 +0,0 @@
-// $Id$
-#ifndef QGIS_PLUGIN_OGRCONV_FORMATS_H_INCLUDED
-#define QGIS_PLUGIN_OGRCONV_FORMATS_H_INCLUDED
-// Qt4
-#include <QMap>
-#include <QString>
-class Format
- public:
- enum Type
- eUnknown = 0,
- eFile = 1,
- eDirectory = 2,
- eProtocol = 4
- Format();
- Format( QString const& c, QString const& n );
- Format( QString const& c, QString const& n, unsigned char const& t );
- Format( QString const& c, QString const& n, QString const& p, unsigned char const& t );
- QString const& code() const;
- QString const& name() const;
- QString const& protocol() const;
- unsigned char const& type() const;
- private:
- QString mCode;
- QString mName;
- QString mProtocol;
- unsigned char mTypeFlags;
-inline bool isFormatType( unsigned char const& frmt, Format::Type const& type )
- return (( frmt & type ) == type );
-class FormatsRegistry
- public:
- FormatsRegistry();
- void add( Format const& frmt );
- Format const& find( QString const& code );
- private:
- void init();
- QMap<QString, Format> mFrmts;
- Format mCache;
-#endif // QGIS_PLUGIN_OGRCONV_FORMATS_H_INCLUDED
Deleted: trunk/qgis/src/plugins/ogr_converter/ogr_converter.png
(Binary files differ)
Deleted: trunk/qgis/src/plugins/ogr_converter/ogrconverter.qrc
--- trunk/qgis/src/plugins/ogr_converter/ogrconverter.qrc 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/ogrconverter.qrc 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,5 +0,0 @@
-<RCC>
- <qresource prefix="/" >
- <file>ogr_converter.png</file>
- </qresource>
-</RCC>
Deleted: trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui
--- trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,328 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<ui version="4.0">
- <class>OgrConverterGuiBase</class>
- <widget class="QDialog" name="OgrConverterGuiBase">
- <property name="geometry">
- <rect>
- <x>0</x>
- <y>0</y>
- <width>491</width>
- <height>368</height>
- </rect>
- </property>
- <property name="sizePolicy">
- <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="minimumSize">
- <size>
- <width>0</width>
- <height>0</height>
- </size>
- </property>
- <property name="windowTitle">
- <string>OGR Layer Converter</string>
- </property>
- <property name="windowIcon">
- <iconset>
- <normaloff/>
- </iconset>
- </property>
- <layout class="QVBoxLayout" name="verticalLayout">
- <item>
- <widget class="QGroupBox" name="srcGroupBox">
- </sizepolicy>
- </property>
- <property name="title">
- <string>Source</string>
- </property>
- <layout class="QGridLayout" name="gridLayout_2">
- <item row="1" column="1" colspan="2">
- <layout class="QGridLayout" name="gridLayout">
- <property name="spacing">
- <number>0</number>
- </property>
- <item row="0" column="0">
- <widget class="QRadioButton" name="radioSrcFile">
- <property name="text">
- <string>File</string>
- </property>
- </widget>
- </item>
- <item row="0" column="2">
- <widget class="QRadioButton" name="radioSrcProtocol">
- <string>Remote source</string>
- </property>
- </widget>
- </item>
- <item row="0" column="1">
- <widget class="QRadioButton" name="radioSrcDirectory">
- <string>Directory</string>
- </property>
- </widget>
- </item>
- <item row="0" column="3">
- <spacer name="horizontalSpacer">
- <property name="orientation">
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>40</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
- </item>
- <item row="5" column="0">
- <widget class="QLabel" name="labelSrcLayer">
- <size>
- <width>52</width>
- <height>22</height>
- </size>
- </property>
- <string>Layer</string>
- </property>
- <property name="buddy">
- <cstring>comboSrcLayer</cstring>
- </property>
- </widget>
- </item>
- <item row="2" column="0">
- <widget class="QLabel" name="labelSrcDataset">
- <string>Dataset</string>
- </property>
- <cstring>inputSrcDataset</cstring>
- </property>
- </widget>
- </item>
- <item row="2" column="1">
- <widget class="QLineEdit" name="inputSrcDataset">
- <size>
- <width>200</width>
- <height>25</height>
- </size>
- </property>
- </widget>
- </item>
- <item row="5" column="1" colspan="2">
- <widget class="QComboBox" name="comboSrcLayer">
- <size>
- <width>300</width>
- </size>
- </property>
- </widget>
- </item>
- <item row="2" column="2">
- <widget class="QPushButton" name="buttonSelectSrc">
- <string>Browse</string>
- </property>
- </widget>
- </item>
- <item row="0" column="1" colspan="2">
- <widget class="QComboBox" name="comboSrcFormats">
- <size>
- </size>
- </property>
- <property name="maxCount">
- <number>200</number>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="labelSrcFormat">
- <size>
- <width>52</width>
- </size>
- </property>
- <string>Format</string>
- </property>
- <cstring>comboSrcFormats</cstring>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item>
- <widget class="QGroupBox" name="dstGroupBox">
- </sizepolicy>
- </property>
- <string>Target</string>
- </property>
- <layout class="QGridLayout" name="gridLayout_3">
- <widget class="QLabel" name="labelDstFormat">
- <size>
- <width>52</width>
- </size>
- </property>
- </property>
- <cstring>comboDstFormats</cstring>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="comboDstFormats">
- <size>
- </size>
- </property>
- </property>
- </widget>
- </item>
- <item row="1" column="0">
- <widget class="QLabel" name="labelDstDataset">
- </property>
- <cstring>inputDstDataset</cstring>
- </property>
- </widget>
- </item>
- <item row="1" column="1">
- <widget class="QLineEdit" name="inputDstDataset">
- <size>
- </size>
- </property>
- </widget>
- </item>
- <item row="1" column="2">
- <widget class="QPushButton" name="buttonSelectDst">
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="labelDstLayer">
- <size>
- <width>52</width>
- </size>
- </property>
- </property>
- <cstring>inputDstLayer</cstring>
- </property>
- </widget>
- </item>
- <item row="2" column="1" colspan="2">
- <widget class="QLineEdit" name="inputDstLayer">
- <size>
- </size>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item>
- <widget class="QDialogButtonBox" name="buttonBox">
- <property name="standardButtons">
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- <layoutdefault spacing="6" margin="11"/>
- <tabstops>
- <tabstop>comboSrcFormats</tabstop>
- <tabstop>radioSrcFile</tabstop>
- <tabstop>radioSrcDirectory</tabstop>
- <tabstop>radioSrcProtocol</tabstop>
- <tabstop>inputSrcDataset</tabstop>
- <tabstop>buttonSelectSrc</tabstop>
- <tabstop>comboSrcLayer</tabstop>
- <tabstop>comboDstFormats</tabstop>
- <tabstop>inputDstDataset</tabstop>
- <tabstop>buttonSelectDst</tabstop>
- <tabstop>inputDstLayer</tabstop>
- <tabstop>buttonBox</tabstop>
- </tabstops>
- <resources/>
- <connections>
- <connection>
- <sender>buttonBox</sender>
- <signal>accepted()</signal>
- <receiver>OgrConverterGuiBase</receiver>
- <slot>accept()</slot>
- <hints>
- <hint type="sourcelabel">
- <x>424</x>
- <y>322</y>
- </hint>
- <hint type="destinationlabel">
- <x>481</x>
- <y>297</y>
- </hint>
- </hints>
- </connection>
- <connection>
- <signal>rejected()</signal>
- <slot>reject()</slot>
- <hints>
- <x>365</x>
- <y>323</y>
- </hint>
- <x>281</x>
- <y>339</y>
- </hint>
- </hints>
- </connection>
- </connections>
-</ui>
Deleted: trunk/qgis/src/plugins/ogr_converter/plugin.cpp
--- trunk/qgis/src/plugins/ogr_converter/plugin.cpp 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/plugin.cpp 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,179 +0,0 @@
-// $Id$
-// begin : Aug 24, 2008
-// copyright : (C) 2008 by Mateusz Loskot
-// email : mateusz at loskot.net
-#include "plugin.h"
-// QGIS
-#include <qgisinterface.h>
-#include <qgisgui.h>
-// Qt
-#include <QAction>
-#include <QFile>
-#include <QToolBar>
-static const char * const sIdent = "$Id$";
-static const QString sName = QObject::tr( "OGR Layer Converter" );
-static const QString sDescription = QObject::tr( "Translates vector layers between formats supported by OGR library" );
-static const QString sPluginVersion = QObject::tr( "Version 0.1" );
-static const QgisPlugin::PLUGINTYPE sPluginType = QgisPlugin::UI;
-static const QString sPluginIcon = ":/ogr_converter.png";
-// THE FOLLOWING METHODS ARE MANDATORY FOR ALL PLUGINS
-OgrPlugin::OgrPlugin( QgisInterface * theQgisInterface ) :
- QgisPlugin( sName, sDescription, sPluginVersion, sPluginType ),
- mQGisIface( theQgisInterface ),
- mQActionPointer( 0 )
- Q_ASSERT( mQGisIface );
-OgrPlugin::~OgrPlugin()
-void OgrPlugin::initGui()
- // Create the action for tool
- mQActionPointer = new QAction( QIcon(), tr( "Run OGR Layer Converter" ), this );
- // Set the icon
- setCurrentTheme( "" );
- // Set the what's this text
- mQActionPointer->setWhatsThis( tr( "Translates vector layers between formats supported by OGR library" ) );
- // Connect the action to the run
- connect( mQActionPointer, SIGNAL( triggered() ), this, SLOT( run() ) );
- // Add the icon to the toolbar
- mQGisIface->addToolBarIcon( mQActionPointer );
- mQGisIface->addPluginToMenu( tr( "OG&R Converter" ), mQActionPointer );
- // this is called when the icon theme is changed
- connect( mQGisIface, SIGNAL( currentThemeChanged( QString ) ), this, SLOT( setCurrentTheme( QString ) ) );
-//method defined in interface
-void OgrPlugin::help()
- //implement me!
-void OgrPlugin::run()
- Dialog* ogrDialog = new Dialog( mQGisIface->mainWindow(), QgisGui::ModalDialogFlags );
- ogrDialog->setAttribute( Qt::WA_DeleteOnClose );
- ogrDialog->show();
-void OgrPlugin::unload()
- // TODO: Who is responsible for OGR cleanup?
- //OGRCleanupAll();
- // remove the GUI
- mQGisIface->removePluginMenu( tr( "OG&R Converter" ), mQActionPointer );
- mQGisIface->removeToolBarIcon( mQActionPointer );
- delete mQActionPointer;
-//! Set icons to the current theme
-void OgrPlugin::setCurrentTheme( QString theThemeName )
- QString myCurThemePath = QgsApplication::activeThemePath() + "/plugins/ogr_converter.png";
- QString myDefThemePath = QgsApplication::defaultThemePath() + "/plugins/ogr_converter.png";
- QString myQrcPath = ":/ogr_converter.png";
- if ( QFile::exists( myCurThemePath ) )
- mQActionPointer->setIcon( QIcon( myCurThemePath ) );
- else if ( QFile::exists( myDefThemePath ) )
- mQActionPointer->setIcon( QIcon( myDefThemePath ) );
- else if ( QFile::exists( myQrcPath ) )
- mQActionPointer->setIcon( QIcon( myQrcPath ) );
- else
- mQActionPointer->setIcon( QIcon() );
-// THE FOLLOWING CODE IS AUTOGENERATED BY THE PLUGIN BUILDER SCRIPT
-// YOU WOULD NORMALLY NOT NEED TO MODIFY THIS, AND YOUR PLUGIN
-// MAY NOT WORK PROPERLY IF YOU MODIFY THIS INCORRECTLY
-// Required extern functions needed for every plugin
-// These functions can be called prior to creating an instance
-// of the plugin class.
-// Class factory to return a new instance of the plugin class
-QGISEXTERN QgisPlugin * classFactory( QgisInterface * theQgisInterfacePointer )
- return new OgrPlugin( theQgisInterfacePointer );
-// Return the name of the plugin - note that we do not user class members as
-// the class may not yet be insantiated when this method is called.
-QGISEXTERN QString name()
- return sName;
-// Return the description
-QGISEXTERN QString description()
- return sDescription;
-// Return the type (either UI or MapLayer plugin)
-QGISEXTERN int type()
- return sPluginType;
-// Return the version number for the plugin
-QGISEXTERN QString version()
- return sPluginVersion;
-QGISEXTERN QString icon()
- return sPluginIcon;
-// Delete ourself
-QGISEXTERN void unload( QgisPlugin * thePluginPointer )
- delete thePluginPointer;
Deleted: trunk/qgis/src/plugins/ogr_converter/plugin.h
--- trunk/qgis/src/plugins/ogr_converter/plugin.h 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/plugin.h 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,102 +0,0 @@
-// $Id$
-#ifndef QGIS_PLUGIN_OGRCONV_PLUGIN_H_INCLUDED
-#define QGIS_PLUGIN_OGRCONV_PLUGIN_H_INCLUDED
-// QGIS
-#include "../qgisplugin.h"
-// Qt4
-#include <QObject>
-// Forward declarations
-class QAction;
-class QToolBar;
-class QgisInterface;
-* \class OgrPlugin
-* \brief Translates vector layers between formats supported by OGR library.
-class OgrPlugin : public QObject, public QgisPlugin
- Q_OBJECT
- public:
- // MANDATORY PLUGIN METHODS FOLLOW
- * Constructor for a plugin. The QgisInterface pointer is passed by
- * QGIS when it attempts to instantiate the plugin.
- * @param theInterface Pointer to the QgisInterface object.
- OgrPlugin( QgisInterface * theInterface );
- //! Destructor
- virtual ~OgrPlugin();
- public slots:
- * Initialize the GUI interface for the plugin.
- * This is only called once when the plugin is added to the plugin
- * registry in the QGIS application.
- virtual void initGui();
- * Slot called when the menu item is triggered.
- * If you created more menu items / toolbar buttons in initiGui,
- * you should create a separate handler for each action - this
- * single run() method will not be enough.
- void run();
- * Unload the plugin by cleaning up the GUI.
- void unload();
- //! show the help document
- void help();
- //! update the plugins theme when the app tells us its theme is changed
- void setCurrentTheme( QString theThemeName );
- private:
- // MANDATORY PLUGIN PROPERTY DECLARATIONS
- // FIXME: Is it used at all?
- int mPluginType;
- //! Pointer to the QGIS interface object
- QgisInterface *mQGisIface;
- //!pointer to the qaction for this plugin
- QAction * mQActionPointer;
- // ADD YOUR OWN PROPERTY DECLARATIONS AFTER THIS POINT.....
-}; // OgrPlugin
-#endif // QGIS_PLUGIN_OGRCONV_PLUGIN_H_INCLUDED
Deleted: trunk/qgis/src/plugins/ogr_converter/translator.cpp
--- trunk/qgis/src/plugins/ogr_converter/translator.cpp 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/translator.cpp 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,429 +0,0 @@
-// $Id$
-// QGIS
-// Qt4
-#include <QString>
-#include <QtDebug>
-#include <cpl_error.h>
-#define FROM8(x) QString::fromUtf8(x)
-#else
-#define FROM8(x) QString::fromLocal8Bit(x)
-#endif
-Translator::Translator()
- : mDstUpdate( false ), mDstLayerOverwrite( true )
-Translator::Translator( QString const& src, QString const& dst, QString const& format )
- : mSrcUrl( src ), mDstUrl( dst ), mDstFormat( format ),
- mDstUpdate( false ), mDstLayerOverwrite( true )
-QString const& Translator::targetFormat() const
- return mDstFormat;
-void Translator::setTargetFormat( QString const& format )
- mDstFormat = format;
-QString const& Translator::targetLayer() const
- return mDstLayer;
-void Translator::setTargetLayer( QString const& layer )
- mDstLayer = layer;
-QString const& Translator::sourceLayer() const
- return mSrcLayer;
-void Translator::setSourceLayer( QString const& layer )
- mSrcLayer = layer;
-QString const& Translator::targetReferenceSystem() const
- return mDstSrs;
-void Translator::setTargetReferenceSystem( QString const& srs )
- mDstSrs = srs;
-QString const& Translator::sourceReferenceSystem() const
- return mSrcSrs;
-void Translator::setSourceReferenceSystem( QString const& srs )
- mSrcSrs = srs;
-bool Translator::isTargetUpdate() const
- return mDstUpdate;
-void Translator::setUpdateTarget( bool update )
- mDstUpdate = update;
-bool Translator::isTargetLayerOverwrite() const
- return mDstLayerOverwrite;
-bool Translator::translate()
- // TODO: RAII for OGR handlers!!!
- // Open input data source
- OGRDataSourceH srcDs = openDataSource( mSrcUrl, true );
- if ( 0 == srcDs )
- QgsDebugMsg( "Open source failed: " + mSrcUrl );
- return false;
- // Open output data source
- OGRDataSourceH dstDs = openDataTarget( mDstUrl, mDstUpdate );
- if ( 0 == dstDs )
- QgsDebugMsg( "Open target failed: " + mDstUrl );
- OGR_DS_Destroy( srcDs );
- return false;
- // TODO: Support translation of all layers from input data source
- //for (int i = 0; i < OGR_DS_GetLayerCount(); ++i)
- OGRLayerH srcLayer = OGR_DS_GetLayerByName( srcDs, TO8( mSrcLayer ) );
- if ( 0 == srcLayer )
- QgsDebugMsg( "Can not find layer: " + mSrcLayer );
- OGR_DS_Destroy( dstDs );
- return false;
- if ( mDstLayer.isEmpty() )
- QgsDebugMsg( "Using source layer name: " + mDstLayer );
- mDstLayer = mSrcLayer;
- QgsDebugMsg( "START LAYER TRANSLATION ------" );
- success = translateLayer( srcDs, srcLayer, dstDs );
- QgsDebugMsg( "END LAYER TRANSLATION ------" );
- return success;
-bool Translator::translateLayer( OGRDataSourceH srcDs, OGRLayerH srcLayer, OGRDataSourceH dstDs )
- // Implementation based on TranslateLayer function from ogr2ogr.cpp, from GDAL/OGR.
- Q_ASSERT( 0 != srcDs );
- Q_ASSERT( 0 != srcLayer );
- Q_ASSERT( 0 != dstDs );
- // Get source layer schema
- OGRFeatureDefnH srcLayerDefn = OGR_L_GetLayerDefn( srcLayer );
- Q_ASSERT( 0 != srcLayerDefn );
- // Find if layer exists in target data source
- int dstLayerIndex = 0;
- OGRLayerH dstLayer = findLayer( dstDs, mDstLayer, dstLayerIndex );
- // If the user requested overwrite, and we have the layer in question
- // we need to delete it now so it will get recreated overwritten
- if ( 0 != dstLayer && mDstLayerOverwrite
- && 0 != OGR_DS_TestCapability( dstDs, ODsCDeleteLayer ) )
- if ( OGRERR_NONE != OGR_DS_DeleteLayer( dstDs, dstLayerIndex ) )
- QgsDebugMsg( "Delete layer failed when overwrite requested" );
- return false;
- if ( 0 == dstLayer )
- QgsDebugMsg( "Destination layer not found, will attempt to create" );
- // If the layer does not exist, then create it
- if ( 0 == OGR_DS_TestCapability( dstDs, ODsCCreateLayer ) )
- QgsDebugMsg( "Layer " + mDstLayer + " not found, and CreateLayer not supported by driver" );
- return false;
- // FIXME: Do we need it here?
- //CPLErrorReset();
- // TODO: -nlt option support
- OGRwkbGeometryType geomType = OGR_FD_GetGeomType( srcLayerDefn );
- // TODO: Implement SRS transformation
- OGRSpatialReferenceH dstLayerSrs = OGR_L_GetSpatialRef( srcLayer );
- dstLayer = OGR_DS_CreateLayer( dstDs, TO8( mDstLayer ), dstLayerSrs, geomType, 0 );
- qWarning() << QString( "Layer %1 not found and CreateLayer failed [OGR: %2]\n" ).arg( mDstLayer ).arg( CPLGetLastErrorMsg() );
- return false;
- // TODO: Append and createion options not implemented
- // else if (!mDstLayerAppend)
- Q_ASSERT( 0 != dstLayer );
- // Transfer attributes schema
- if ( !copyFields( srcLayerDefn, dstLayer ) )
- QgsDebugMsg( "Failed to copy fields from layer " + mSrcLayer );
- return false;
- // Transfer features
- success = copyFeatures( srcLayer, dstLayer );
- return success;
-bool Translator::copyFields( OGRFeatureDefnH layerDefn, OGRLayerH layer )
- Q_ASSERT( 0 != layerDefn );
- Q_ASSERT( 0 != layer );
- int const count = OGR_FD_GetFieldCount( layerDefn );
- for ( int i = 0; i < count; ++i )
- OGRFieldDefnH fieldDefn = OGR_FD_GetFieldDefn( layerDefn, i );
- Q_ASSERT( 0 != fieldDefn );
- if ( OGRERR_NONE != OGR_L_CreateField( layer, fieldDefn, true ) )
- return false;
- return true;
-bool Translator::copyFeatures( OGRLayerH srcLayer, OGRLayerH dstLayer )
- long srcFid = 0;
- long count = 0;
- // TODO: RAII for feature handlers!!!
- while ( true )
- OGRFeatureH srcFeat = OGR_L_GetNextFeature( srcLayer );
- if ( 0 == srcFeat )
- QgsDebugMsg( "Next source feature is null, finishing" );
- success = true;
- break;
- srcFid = OGR_F_GetFID( srcFeat );
- OGRFeatureH dstFeat = OGR_F_Create( srcLayerDefn );
- if ( OGRERR_NONE != OGR_F_SetFrom( dstFeat, srcFeat, true ) )
- QString msg = QString( "Unable to translate feature %1 from layer %2" ).arg( srcFid ).arg( mSrcLayer );
- QgsDebugMsg( msg );
- OGR_F_Destroy( srcFeat );
- OGR_F_Destroy( dstFeat );
- success = false;
- break;
- Q_ASSERT( 0 != dstFeat );
- // TODO: Transform feature geometry
- // TODO: Skip failures support
- if ( OGRERR_NONE != OGR_L_CreateFeature( dstLayer, dstFeat ) )
- QgsDebugMsg( "Feature creation failed" );
- success = false;
- break;
- count += 1;
- success = true;
- QgsDebugMsg( QString( "Number of copied features: %1" ).arg( count ) );
- return success;
-OGRSFDriverH Translator::findDriver( QString const& name )
- OGRSFDriverH drv = 0;
- QString drvName;
- OGRSFDriverH drvTmp = OGRGetDriver( i );
- Q_CHECK_PTR( drvTmp );
- if ( 0 != drvTmp )
- drvName = OGR_Dr_GetName( drvTmp );
- if ( name == drvName
- && 0 != OGR_Dr_TestCapability( drvTmp, ODrCCreateDataSource ) )
- QgsDebugMsg( "Driver found: " + name );
- drv = drvTmp;
- break;
- return drv;
-OGRLayerH Translator::findLayer( OGRDataSourceH ds, QString const& name, int& index )
- if ( 0 == ds )
- index = -1;
- return 0;
- OGRLayerH lyr = 0;
- int const count = OGR_DS_GetLayerCount( ds );
- OGRLayerH lyrTmp = OGR_DS_GetLayer( ds, i );
- if ( 0 != lyrTmp )
- OGRFeatureDefnH defn = OGR_L_GetLayerDefn( lyrTmp );
- Q_ASSERT( 0 != defn );
- QString nameTmp( OGR_FD_GetName( defn ) );
- if ( name == nameTmp )
- QgsDebugMsg( "Layer found: " + nameTmp );
- index = i;
- lyr = lyrTmp;
- break;
- return lyr;
-OGRDataSourceH Translator::openDataSource( QString const& url, bool readOnly )
- OGRDataSourceH ds = OGROpen( TO8( url ), !readOnly, 0 );
- if ( 0 == ds )
- QgsDebugMsg( "Failed to open: " + url );
- return ds;
-OGRDataSourceH Translator::openDataTarget( QString const& url, bool update )
- OGRDataSourceH ds = 0;
- if ( update )
- // Try opening the output datasource as an existing, writable
- ds = openDataSource( url, false );
- else
- // Find the output driver
- OGRSFDriverH drv = findDriver( mDstFormat );
- if ( 0 == drv )
- QgsDebugMsg( "Could not find driver: " + mDstFormat );
- return 0;
- // Create the output data source
- // TODO: Add support for creation options
- ds = OGR_Dr_CreateDataSource( drv, TO8( url ), 0 );
- if ( 0 == ds )
- return ds;
Deleted: trunk/qgis/src/plugins/ogr_converter/translator.h
--- trunk/qgis/src/plugins/ogr_converter/translator.h 2011-03-04 13:09:51 UTC (rev 15330)
+++ trunk/qgis/src/plugins/ogr_converter/translator.h 2011-03-04 17:13:55 UTC (rev 15331)
@@ -1,76 +0,0 @@
-// $Id$
-#ifndef QGIS_PLUGIN_OGRCONV_TRANSLATOR_H_INCLUDED
-#define QGIS_PLUGIN_OGRCONV_TRANSLATOR_H_INCLUDED
-// Qt4
-#include <QString>
-class Translator
- public:
- Translator();
- Translator( QString const& src, QString const& dst, QString const& format );
- QString const& targetFormat() const;
- void setTargetFormat( QString const& format );
- QString const& targetLayer() const;
- void setTargetLayer( QString const& layer );
- QString const& sourceLayer() const;
- void setSourceLayer( QString const& layer );
- QString const& targetReferenceSystem() const;
- void setTargetReferenceSystem( QString const& srs );
- QString const& sourceReferenceSystem() const;
- void setSourceReferenceSystem( QString const& srs );
- bool isTargetUpdate() const;
- void setUpdateTarget( bool update );
- bool isTargetLayerOverwrite() const;
- // TODO: Implement, currently always overwrite
- // void setTargetLayerOverwrite(bool overwrite);
- bool translate();
- private:
- QString mSrcUrl;
- QString mDstUrl;
- QString mDstFormat;
- QString mSrcLayer;
- QString mDstLayer;
- QString mSrcSrs;
- QString mDstSrs;
- bool mDstUpdate;
- bool mDstLayerOverwrite;
- // TODO: Append option not supported
- // bool mDstLayerAppend;
- bool translateLayer( OGRDataSourceH srcDs, OGRLayerH srcLayer, OGRDataSourceH dstDs );
- bool copyFields( OGRFeatureDefnH layerDefn, OGRLayerH layer );
- bool copyFeatures( OGRLayerH srcLayer, OGRLayerH dstLayer );
- OGRSFDriverH findDriver( QString const& name );
- OGRLayerH findLayer( OGRDataSourceH ds, QString const& name, int& index );
- OGRDataSourceH openDataSource( QString const& url, bool readOnly );
- OGRDataSourceH openDataTarget( QString const& url, bool update );
-#endif // QGIS_PLUGIN_OGRCONV_TRANSLATOR_H_INCLUDED
