[QGIS Commit] r15352 - in trunk/qgis: images/themes/default src/app
src/app/legend
svn_qgis at osgeo.org
Sat Mar 5 21:18:18 EST 2011
Author: jef
Date: 2011-03-05 18:18:18 -0800 (Sat, 05 Mar 2011)
New Revision: 15352
Added:
trunk/qgis/images/themes/default/mActionHelpAPI.png
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/legend/qgslegend.h
trunk/qgis/src/app/legend/qgslegendlayer.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
[FEATURE] allow setting CRS for multiple layers at once
Added: trunk/qgis/images/themes/default/mActionHelpAPI.png
(Binary files differ)
Property changes on: trunk/qgis/images/themes/default/mActionHelpAPI.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2011-03-06 02:16:44 UTC (rev 15351)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2011-03-06 02:18:18 UTC (rev 15352)
@@ -33,7 +33,7 @@
#include "qgsproject.h"
#include "qgsrasterlayer.h"
#include "qgsvectorlayer.h"
-#include "qgsprojectbadlayerguihandler.h"
+#include "qgsgenericprojectionselector.h"
#include <QFont>
#include <QDomDocument>
@@ -525,16 +525,16 @@
QSettings settings;
- switch( settings.value( "/qgis/legendDoubleClickAction", 0 ).toInt() )
+ switch ( settings.value( "/qgis/legendDoubleClickAction", 0 ).toInt() )
- case 0:
- QgisApp::instance()->layerProperties();
- break;
- case 1:
- QgisApp::instance()->attributeTable();
- break;
- default:
- break;
+ case 0:
+ QgisApp::instance()->layerProperties();
+ break;
+ case 1:
+ QgisApp::instance()->attributeTable();
+ break;
+ default:
+ break;
@@ -558,7 +558,6 @@
theMenu.addAction( tr( "&Make to toplevel item" ), this, SLOT( makeToTopLevelItem() ) );
else if ( li->type() == QgsLegendItem::LEGEND_GROUP )
@@ -567,6 +566,9 @@
theMenu.addAction( QgisApp::getThemeIcon( "/mActionRemoveLayer.png" ),
tr( "&Remove" ), this, SLOT( legendGroupRemove() ) );
+ theMenu.addAction( QgisApp::getThemeIcon( "/mActionSetCRS.png" ),
+ tr( "&Set group CRS" ), this, SLOT( legendGroupSetCRS() ) );
if ( li->type() == QgsLegendItem::LEGEND_LAYER || li->type() == QgsLegendItem::LEGEND_GROUP )
@@ -739,6 +741,30 @@
+void QgsLegend::legendGroupSetCRS()
+ if ( !mMapCanvas || mMapCanvas->isDrawing() )
+ return;
+ QgsGenericProjectionSelector * mySelector = new QgsGenericProjectionSelector( this );
+ mySelector->setMessage();
+ if ( mySelector->exec() )
+ QgsCoordinateReferenceSystem crs( mySelector->selectedCrsId(), QgsCoordinateReferenceSystem::InternalCrsId );
+ QgsLegendGroup* lg = dynamic_cast<QgsLegendGroup *>( currentItem() );
+ setGroupCRS( lg, crs );
+ else
+ QApplication::restoreOverrideCursor();
+ delete mySelector;
void QgsLegend::removeGroup( QgsLegendGroup *lg )
@@ -766,6 +792,36 @@
adjustIconSize();
+void QgsLegend::setGroupCRS( QgsLegendGroup *lg, const QgsCoordinateReferenceSystem &crs )
+ return;
+ //delete the legend layers first
+ QTreeWidgetItem * child = lg->child( 0 );
+ while ( child )
+ QgsLegendLayer *cl = dynamic_cast<QgsLegendLayer *>( child );
+ QgsLegendGroup *cg = dynamic_cast<QgsLegendGroup *>( child );
+ if ( cl )
+ cl->layer()->setCrs( crs );
+ else if ( cg )
+ setGroupCRS( cg, crs );
+ child = lg->child( 0 );
+ delete lg;
void QgsLegend::moveLayer( QgsMapLayer *ml, int groupIndex )
if ( !ml )
@@ -999,20 +1055,11 @@
bool isOpen;
QgsLegendLayer* currentLayer = readLayerFromXML( childelem, isOpen );
- bool ignorePressed = QgsProjectBadLayerGuiHandler::mIgnore;
if ( !currentLayer )
- if( ignorePressed == true )
- continue;
- else
- return false;
+ continue;
// add to tree - either as a top-level node or a child of a group
if ( parent )
@@ -1920,3 +1967,32 @@
if ( renderFlagState )
mMapCanvas->setRenderFlag( true );
+void QgsLegend::setCRSForSelectedLayers( const QgsCoordinateReferenceSystem &crs )
+ // Turn off rendering to improve speed.
+ bool renderFlagState = mMapCanvas->renderFlag();
+ if ( renderFlagState )
+ mMapCanvas->setRenderFlag( false );
+ foreach( QTreeWidgetItem * item, selectedItems() )
+ QgsLegendGroup* lg = dynamic_cast<QgsLegendGroup *>( item );
+ if ( lg )
+ continue;
+ QgsLegendLayer *ll = dynamic_cast<QgsLegendLayer *>( item );
+ if ( ll && ll->layer() )
+ ll->layer()->setCrs( crs );
+ continue;
+ // Turn on rendering (if it was on previously)
+ mMapCanvas->setRenderFlag( true );
Modified: trunk/qgis/src/app/legend/qgslegend.h
--- trunk/qgis/src/app/legend/qgslegend.h 2011-03-06 02:16:44 UTC (rev 15351)
+++ trunk/qgis/src/app/legend/qgslegend.h 2011-03-06 02:18:18 UTC (rev 15352)
@@ -34,6 +34,7 @@
class QDomNode;
class QMouseEvent;
class QTreeWidgetItem;
+class QgsCoordinateReferenceSystem;
//Information about relationship between groups and layers
//key: group name (or null strings for single layers without groups)
@@ -266,6 +267,9 @@
/** Remove selected layers */
void removeSelectedLayers();
+ /** Set CRS for selected layers */
+ void setCRSForSelectedLayers( const QgsCoordinateReferenceSystem &crs );
protected:
/*!Event handler for mouse movements.
@@ -362,8 +366,12 @@
void handleRightClickEvent( QTreeWidgetItem* item, const QPoint& position );
/**Removes the current legend group*/
void legendGroupRemove();
+ /**Set the CRS of the current legend group*/
+ void legendGroupSetCRS();
/**Removes a legend group and its layers*/
void removeGroup( QgsLegendGroup * lg );
+ /**Removes a legend group and its layers*/
+ void setGroupCRS( QgsLegendGroup * lg, const QgsCoordinateReferenceSystem &crs );
/**Sets all listview items to open*/
void expandAll();
/**Sets all listview items to closed*/
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp 2011-03-06 02:16:44 UTC (rev 15351)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp 2011-03-06 02:18:18 UTC (rev 15352)
@@ -432,6 +432,9 @@
// remove from canvas
theMenu.addAction( QgisApp::getThemeIcon( "/mActionRemoveLayer.png" ), tr( "&Remove" ), QgisApp::instance(), SLOT( removeLayer() ) );
+ // remove from canvas
+ theMenu.addAction( QgisApp::getThemeIcon( "/mActionSetCRS.png" ), tr( "&Set layer CRS" ), QgisApp::instance(), SLOT( setLayerCRS() ) );
theMenu.addSeparator();
if ( lyr->type() == QgsMapLayer::VectorLayer )
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2011-03-06 02:16:44 UTC (rev 15351)
+++ trunk/qgis/src/app/qgisapp.cpp 2011-03-06 02:18:18 UTC (rev 15352)
@@ -141,7 +141,7 @@
#include "qgspluginmetadata.h"
#include "qgspluginregistry.h"
#include "qgspoint.h"
+#include "qgshandlebadlayers.h"
#include "qgsprojectproperties.h"
#include "qgsproviderregistry.h"
@@ -506,7 +506,7 @@
QgsRasterLayer::buildSupportedRasterFileFilter( mRasterFileFilter );
// set handler for missing layers (will be owned by QgsProject)
- QgsProject::instance()->setBadLayerHandler( new QgsProjectBadLayerGuiHandler() );
+ QgsProject::instance()->setBadLayerHandler( new QgsHandleBadLayersHandler() );
#if 0
// Set the background color for toolbox and overview as they default to
@@ -1125,6 +1125,12 @@
connect( mActionRemoveLayer, SIGNAL( triggered() ), this, SLOT( removeLayer() ) );
mActionRemoveLayer->setEnabled( false );
+ mActionSetLayerCRS = new QAction( getThemeIcon( "mActionSetLayerCRS.png" ), tr( "Set CRS of Layer(s)" ), this );
+ shortcuts->registerAction( mActionSetLayerCRS, tr( "Ctrl+Shift+C", "Set CRS of Layer(s)" ) );
+ mActionSetLayerCRS->setStatusTip( tr( "Set CRS of Layer(s)" ) );
+ connect( mActionSetLayerCRS, SIGNAL( triggered() ), this, SLOT( setLayerCRS() ) );
+ mActionSetLayerCRS->setEnabled( false );
mActionTileScale = new QAction( getThemeIcon( "mActionTileScale.png" ), tr( "Tile scale slider" ), this );
shortcuts->registerAction( mActionTileScale, tr( "", "Tile scale slider" ) );
mActionTileScale->setStatusTip( tr( "Show tile scale slider" ) );
@@ -1249,7 +1255,15 @@
#endif
mActionHelpContents->setStatusTip( tr( "Help Documentation" ) );
connect( mActionHelpContents, SIGNAL( triggered() ), this, SLOT( helpContents() ) );
+ mActionHelpContents->setEnabled( QFileInfo( QgsApplication::pkgDataPath() + "/doc/index.html" ).exists() );
+#ifdef WITH_APIDOC
+ mActionHelpAPI = new QAction( getThemeIcon( "mActionHelpAPI.png" ), tr( "API documentation" ), this );
+ connect( mActionHelpAPI, SIGNAL( triggered() ), this, SLOT( apiDocumentation() ) );
+ mActionHelpAPI->setEnabled( QFileInfo( QgsApplication::pkgDataPath() + "/doc/api/index.html" ).exists() );
+#endif
mActionQgisHomePage = new QAction( getThemeIcon( "mActionQgisHomePage.png" ), tr( "QGIS Home Page" ), this );
#ifndef Q_WS_MAC
shortcuts->registerAction( mActionQgisHomePage, tr( "Ctrl+H", "QGIS Home Page" ) );
@@ -1609,6 +1623,7 @@
mLayerMenu->addAction( mActionLayerSaveAs );
mLayerMenu->addAction( mActionLayerSelectionSaveAs );
mLayerMenu->addAction( mActionRemoveLayer );
+ mLayerMenu->addAction( mActionSetLayerCRS );
mLayerMenu->addAction( mActionLayerProperties );
mLayerMenu->addAction( mActionLayerSubsetString );
mActionLayerSeparator2 = mLayerMenu->addSeparator();
@@ -1684,6 +1699,9 @@
mHelpMenu = menuBar()->addMenu( tr( "&Help" ) );
mHelpMenu->addAction( mActionHelpContents );
+#ifdef WITH_APIDOC
+ mHelpMenu->addAction( mActionHelpAPI );
+#endif
mActionHelpSeparator1 = mHelpMenu->addSeparator();
mHelpMenu->addAction( mActionQgisHomePage );
@@ -1730,6 +1748,7 @@
mLayerToolBar->addAction( mActionAddWmsLayer );
mLayerToolBar->addAction( mActionNewVectorLayer );
mLayerToolBar->addAction( mActionRemoveLayer );
+ mLayerToolBar->addAction( mActionSetLayerCRS );
//commented out for QGIS 1.4 by Tim
//mLayerToolBar->addAction( mActionAddToOverview );
//mLayerToolBar->addAction( mActionShowAllLayers );
@@ -1898,6 +1917,9 @@
mHelpToolBar = addToolBar( tr( "Help" ) );
mHelpToolBar->setObjectName( "Help" );
mHelpToolBar->addAction( mActionHelpContents );
+#ifdef WITH_APIDOC
+ mHelpToolBar->addAction( mActionHelpAPI );
+#endif
mHelpToolBar->addAction( QWhatsThis::createAction() );
mToolbarMenu->addAction( mHelpToolBar->toggleViewAction() );
@@ -2108,6 +2130,7 @@
mActionAddPgLayer->setIcon( getThemeIcon( "/mActionAddLayer.png" ) );
mActionAddSpatiaLiteLayer->setIcon( getThemeIcon( "/mActionAddSpatiaLiteLayer.png" ) );
mActionRemoveLayer->setIcon( getThemeIcon( "/mActionRemoveLayer.png" ) );
+ mActionSetLayerCRS->setIcon( getThemeIcon( "/mActionSetLayerCRS.png" ) );
mActionNewVectorLayer->setIcon( getThemeIcon( "/mActionNewVectorLayer.png" ) );
mActionAddAllToOverview->setIcon( getThemeIcon( "/mActionAddAllToOverview.png" ) );
mActionHideAllLayers->setIcon( getThemeIcon( "/mActionHideAllLayers.png" ) );
@@ -2120,6 +2143,9 @@
mActionOptions->setIcon( getThemeIcon( "/mActionOptions.png" ) );
mActionConfigureShortcuts->setIcon( getThemeIcon( "/mActionOptions.png" ) );
mActionHelpContents->setIcon( getThemeIcon( "/mActionHelpContents.png" ) );
+#ifdef WITH_APIDOC
+ mActionHelpAPI->setIcon( getThemeIcon( "/mActionHelpApi.png" ) );
+#endif
mActionLocalHistogramStretch->setIcon( getThemeIcon( "/mActionLocalHistogramStretch.png" ) );
mActionQgisHomePage->setIcon( getThemeIcon( "/mActionQgisHomePage.png" ) );
mActionAbout->setIcon( getThemeIcon( "/mActionHelpAbout.png" ) );
@@ -4107,7 +4133,7 @@
else
- destCRS = vlayer->srs();
+ destCRS = vlayer->crs();
else
@@ -4812,7 +4838,7 @@
QgsFeatureList features = selectionVectorLayer->selectedFeatures();
clipboard()->replaceWithCopyOf( selectionVectorLayer->pendingFields(), features );
- clipboard()->setCRS( selectionVectorLayer->srs() );
+ clipboard()->setCRS( selectionVectorLayer->crs() );
selectionVectorLayer->beginEditCommand( tr( "Features cut" ) );
selectionVectorLayer->deleteSelectedFeatures();
selectionVectorLayer->endEditCommand();
@@ -4839,7 +4865,7 @@
@@ -4865,7 +4891,7 @@
QgsFeatureList features;
if ( mMapCanvas->mapRenderer()->hasCrsTransformEnabled() )
- features = clipboard()->transformedCopyOf( pasteVectorLayer->srs() );
+ features = clipboard()->transformedCopyOf( pasteVectorLayer->crs() );
else
@@ -5233,6 +5259,34 @@
mMapCanvas->refresh();
+void QgisApp::setLayerCRS()
+ if ( mMapCanvas && mMapCanvas->isDrawing() )
+ return;
+ if ( !mMapLegend )
+ return;
+ mMapLegend->setCRSForSelectedLayers( crs );
+ mMapCanvas->refresh();
+ else
void QgisApp::showGpsTool()
if ( !mpGpsWidget )
@@ -5550,7 +5604,7 @@
myRenderer->setProjectionsEnabled( false );
delete optionsDialog;
@@ -5602,6 +5656,11 @@
openURL( "index.html" );
+void QgisApp::apiDocumentation()
+ openURL( "api/index.html" );
void QgisApp::helpQgisHomePage()
openURL( "http://qgis.org", false );
@@ -6283,6 +6342,7 @@
void QgisApp::legendLayerSelectionChanged( void )
mActionRemoveLayer->setEnabled( mMapLegend && mMapLegend->selectedLayers().size() > 0 );
+ mActionSetLayerCRS->setEnabled( mMapLegend && mMapLegend->selectedLayers().size() > 0 );
void QgisApp::activateDeactivateLayerRelatedActions( QgsMapLayer* layer )
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2011-03-06 02:16:44 UTC (rev 15351)
+++ trunk/qgis/src/app/qgisapp.h 2011-03-06 02:18:18 UTC (rev 15352)
@@ -287,6 +287,7 @@
QAction *actionLayerSaveAs() { return mActionLayerSaveAs; }
QAction *actionLayerSelectionSaveAs() { return mActionLayerSelectionSaveAs; }
QAction *actionRemoveLayer() { return mActionRemoveLayer; }
+ QAction *actionSetLayerCRS() { return mActionSetLayerCRS; }
QAction *actionTileScale() { return mActionTileScale; }
QAction *actionGpsTool() { return mActionGpsTool; }
QAction *actionLayerProperties() { return mActionLayerProperties; }
@@ -321,6 +322,7 @@
#endif
QAction *actionHelpContents() { return mActionHelpContents; }
+ QAction *actionHelpAPI() { return mActionHelpAPI; }
QAction *actionHelpSeparator1() { return mActionHelpSeparator1; }
QAction *actionQgisHomePage() { return mActionQgisHomePage; }
QAction *actionCheckQgisVersion() { return mActionCheckQgisVersion; }
@@ -496,6 +498,8 @@
void userCenter();
//! Remove a layer from the map and legend
void removeLayer();
+ //! Set CRS of a layer
+ void setLayerCRS();
//! Show GPS tool
void showGpsTool();
//! Show tile scale slider
@@ -577,6 +581,8 @@
bool setActiveLayer( QgsMapLayer * );
//! Open the help contents in a browser
void helpContents();
+ //! Open the API documentation in a browser
+ void apiDocumentation();
//! Open the QGIS homepage in users browser
void helpQgisHomePage();
//! Open a url in the users configured browser
@@ -980,6 +986,7 @@
QAction *mActionLayerSaveAs;
QAction *mActionLayerSelectionSaveAs;
QAction *mActionRemoveLayer;
+ QAction *mActionSetLayerCRS;
QAction *mActionTileScale;
QAction *mActionGpsTool;
QAction *mActionLayerProperties;
@@ -1013,6 +1020,7 @@
#endif
QAction *mActionHelpContents;
+ QAction *mActionHelpAPI;
QAction *mActionHelpSeparator1;
QAction *mActionQgisHomePage;
QAction *mActionCheckQgisVersion;
