[QGIS Commit] r15353 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sat Mar 5 21:19:47 EST 2011
Author: jef
Date: 2011-03-05 18:19:47 -0800 (Sat, 05 Mar 2011)
New Revision: 15353
Added:
trunk/qgis/src/app/qgshandlebadlayers.cpp
trunk/qgis/src/app/qgshandlebadlayers.h
trunk/qgis/src/ui/qgshandlebadlayersbase.ui
trunk/qgis/src/app/CMakeLists.txt
[FEATURE] allow managing missing layers in a list
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2011-03-06 02:18:18 UTC (rev 15352)
+++ trunk/qgis/src/app/CMakeLists.txt 2011-03-06 02:19:47 UTC (rev 15353)
@@ -92,6 +92,7 @@
qgsvectorlayerproperties.cpp
qgsquerybuilder.cpp
qgshighlight.cpp
+ qgshandlebadlayers.cpp
qgsmanageconnectionsdialog.cpp
@@ -218,6 +219,7 @@
qgsuniquevaluedialog.h
qgsvectorlayerproperties.h
qgswmssourceselect.h
+ qgshandlebadlayers.h
composer/qgsattributeselectiondialog.h
composer/qgscomposer.h
Added: trunk/qgis/src/app/qgshandlebadlayers.cpp
--- trunk/qgis/src/app/qgshandlebadlayers.cpp (rev 0)
+++ trunk/qgis/src/app/qgshandlebadlayers.cpp 2011-03-06 02:19:47 UTC (rev 15353)
@@ -0,0 +1,358 @@
+ qgshandlebadlayers.cpp - description
+ begin : Sat 5 Mar 2011
+ copyright : (C) 2011 by Juergen E. Fischer, norBIT GmbH
+ email : jef at norbit dot de
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+/* $Id$ */
+#include "qgshandlebadlayers.h"
+#include "qgisapp.h"
+#include "qgisgui.h"
+#include "qgsdatasourceuri.h"
+#include "qgslogger.h"
+#include "qgsrasterlayer.h"
+#include "qgsproviderregistry.h"
+#include <QDomDocument>
+#include <QDomElement>
+#include <QPushButton>
+#include <QMessageBox>
+QgsHandleBadLayersHandler::QgsHandleBadLayersHandler()
+void QgsHandleBadLayersHandler::handleBadLayers( QList<QDomNode> layers, QDomDocument projectDom )
+ QApplication::setOverrideCursor( Qt::ArrowCursor );
+ QgsHandleBadLayers *dialog = new QgsHandleBadLayers( layers, projectDom );
+ dialog->exec();
+ delete dialog;
+ QApplication::restoreOverrideCursor();
+QgsHandleBadLayers::QgsHandleBadLayers( const QList<QDomNode> &layers, const QDomDocument &projectDom )
+ : QDialog( QgisApp::instance() )
+ , mLayers( layers )
+ setupUi( this );
+ mVectorFileFilter = QgsProviderRegistry::instance()->fileVectorFilters();
+ QgsRasterLayer::buildSupportedRasterFileFilter( mRasterFileFilter );
+ mBrowseButton = new QPushButton( tr( "Browse" ) );
+ buttonBox->addButton( mBrowseButton, QDialogButtonBox::ActionRole );
+ mBrowseButton->setDisabled( true );
+ connect( mLayerList, SIGNAL( itemSelectionChanged() ), this, SLOT( selectionChanged() ) );
+ connect( mLayerList, SIGNAL( itemChanged( QTableWidgetItem * ) ), this, SLOT( itemChanged( QTableWidgetItem * ) ) );
+ connect( mLayerList, SIGNAL( cellDoubleClicked( int, int ) ), this, SLOT( cellDoubleClicked( int, int ) ) );
+ connect( mBrowseButton, SIGNAL( clicked() ), this, SLOT( browseClicked() ) );
+ mLayerList->clear();
+ mLayerList->setSortingEnabled( true );
+ mLayerList->setSelectionBehavior( QAbstractItemView::SelectRows );
+ mLayerList->setColumnCount( 5 );
+ mLayerList->setHorizontalHeaderLabels( QStringList()
+ << tr( "Layer name" )
+ << tr( "Type" )
+ << tr( "Provider" )
+ << tr( "New file" )
+ << tr( "New datasource" )
+ int j = 0;
+ for ( int i = 0; i < mLayers.size(); i++ )
+ const QDomNode &node = mLayers[i];
+ QString name = node.namedItem( "layername" ).toElement().text();
+ QString type = node.toElement().attribute( "type" );
+ QString datasource = node.namedItem( "datasource" ).toElement().text();
+ QString provider;
+ QString filename = datasource;
+ if ( type == "vector" )
+ provider = node.namedItem( "provider" ).toElement().text();
+ if ( provider == "spatialite" )
+ QgsDataSourceURI uri( datasource );
+ filename = uri.database();
+ else if ( provider == "ogr" )
+ QStringList theURIParts = datasource.split( "|" );
+ filename = theURIParts[0];
+ else if ( provider == "delimitedtext" )
+ QStringList theURIParts = datasource.split( "?" );
+ else if ( provider == "postgres" || provider == "sqlanywhere" )
+ continue;
+ else
+ provider = tr( "none" );
+ QgsDebugMsg( QString( "name=%1 type=%2 provider=%3 filename=%4 datasource='%5'" )
+ .arg( name )
+ .arg( type )
+ .arg( provider )
+ .arg( filename )
+ .arg( datasource ) );
+ mLayerList->setRowCount( j + 1 );
+ QTableWidgetItem *item;
+ item = new QTableWidgetItem( name );
+ item->setData( Qt::UserRole + 0, i );
+ item->setFlags( item->flags() & ~Qt::ItemIsEditable );
+ mLayerList->setItem( j, 0, item );
+ item = new QTableWidgetItem( type );
+ mLayerList->setItem( j, 1, item );
+ item = new QTableWidgetItem( provider );
+ mLayerList->setItem( j, 2, item );
+ item = new QTableWidgetItem( filename );
+ mLayerList->setItem( j, 3, item );
+ item = new QTableWidgetItem( datasource );
+ mLayerList->setItem( j, 4, item );
+ j++;
+ mLayerList->resizeColumnsToContents();
+QgsHandleBadLayers::~QgsHandleBadLayers()
+void QgsHandleBadLayers::itemChanged( QTableWidgetItem *item )
+ if ( item->column() != 3 )
+ return;
+ QFileInfo fi( item->text() );
+ item->setForeground( fi.exists() ? QBrush( Qt::green ) : QBrush( Qt::red ) );
+void QgsHandleBadLayers::cellDoubleClicked( int row, int column )
+ if ( column != 3 || !mBrowseButton->isEnabled() )
+ return;
+ mBrowseButton->click();
+void QgsHandleBadLayers::selectionChanged()
+ QgsDebugMsg( "entered." );
+ mRows.clear();
+ foreach( QTableWidgetItem *item, mLayerList->selectedItems() )
+ if ( item->column() != 0 )
+ continue;
+ mRows << item->row();
+ mBrowseButton->setEnabled( mRows.size() > 0 );
+void QgsHandleBadLayers::browseClicked()
+ if ( mRows.size() == 1 )
+ QString memoryQualifier;
+ QString fileFilter;
+ int idx = mLayerList->item( mRows[0], 0 )->data( Qt::UserRole ).toInt();
+ QTableWidgetItem *fileItem = mLayerList->item( mRows[0], 3 );
+ if ( mLayers[ idx ].toElement().attribute( "type" ) == "vector" )
+ memoryQualifier = "lastVectorFileFilter";
+ fileFilter = mVectorFileFilter;
+ else
+ memoryQualifier = "lastRasterFileFilter";
+ fileFilter = mRasterFileFilter;
+ QStringList selectedFiles;
+ QString enc;
+ QString title = tr( "Select file to replace '%1'" ).arg( fileItem->text() );
+ QgisGui::openFilesRememberingFilter( memoryQualifier, fileFilter, selectedFiles, enc, title );
+ if ( selectedFiles.size() != 1 )
+ QMessageBox::information( this, title, tr( "Please select exactly one file." ) );
+ return;
+ fileItem->setText( selectedFiles[0] );
+ else if ( mRows.size() > 1 )
+ QString enc;
+ QString title = tr( "Select new directory of selected files" );
+ QgisGui::openFilesRememberingFilter( "missingDirectory", tr( "All files (*)" ), selectedFiles, enc, title );
+ if ( selectedFiles.isEmpty() )
+ return;
+ QFileInfo path( selectedFiles[0] );
+ if ( !path.exists() )
+ return;
+ foreach( int i, mRows )
+ QTableWidgetItem *fileItem = mLayerList->item( i, 3 );
+ QFileInfo fi( fileItem->text() );
+ fi.setFile( path.dir(), fi.fileName() );
+ if ( !fi.exists() )
+ continue;
+ fileItem->setText( fi.absoluteFilePath() );
+void QgsHandleBadLayers::apply()
+ for ( int i = 0; i < mLayerList->rowCount(); i++ )
+ int idx = mLayerList->item( i, 0 )->data( Qt::UserRole ).toInt();
+ QDomNode &node = const_cast<QDomNode &>( mLayers[ idx ] );
+ QString type = mLayerList->item( i, 1 )->text();
+ QString provider = mLayerList->item( i, 2 )->text();
+ QString datasource = mLayerList->item( i, 4 )->text();
+ QString filename = fileItem->text();
+ if ( !QFileInfo( filename ).exists() )
+ continue;
+ uri.setDatabase( filename );
+ datasource = uri.uri();
+ theURIParts[0] = filename;
+ datasource = theURIParts.join( "|" );
+ datasource = theURIParts.join( "?" );
+ else
+ datasource = filename;
+ node.namedItem( "datasource" ).toElement().firstChild().toText().setData( datasource );
+ if ( QgsProject::instance()->read( node ) )
+ mLayerList->removeRow( i-- );
+ else
+ fileItem->setForeground( QBrush( Qt::red ) );
+void QgsHandleBadLayers::accept()
+ apply();
+ if ( mLayerList->rowCount() > 0 &&
+ QMessageBox::warning( this,
+ tr( "Unhandled layer will be lost." ),
+ tr( "There are still %n unhandled layer(s), that will be lost if you closed now.",
+ "unhandled layers",
+ mLayerList->rowCount() ),
+ QMessageBox::Ok | QMessageBox::Cancel,
+ QMessageBox::Cancel ) == QMessageBox::Cancel )
+ return;
+ QDialog::accept();
+void QgsHandleBadLayers::rejected()
+ return;
+ QDialog::reject();
Added: trunk/qgis/src/app/qgshandlebadlayers.h
--- trunk/qgis/src/app/qgshandlebadlayers.h (rev 0)
+++ trunk/qgis/src/app/qgshandlebadlayers.h 2011-03-06 02:19:47 UTC (rev 15353)
@@ -0,0 +1,67 @@
+ qgshandlebadlayers.h - description
+ begin : Sat 05 Mar 2011
+/* $Id:$ */
+#ifndef QGSHANDLEBADLAYERS_H
+#define QGSHANDLEBADLAYERS_H
+#include "ui_qgshandlebadlayersbase.h"
+#include "qgsproject.h"
+class QgsHandleBadLayersHandler
+ : public QObject
+ , public QgsProjectBadLayerHandler
+ Q_OBJECT
+ public:
+ QgsHandleBadLayersHandler();
+ /** implementation of the handler */
+ virtual void handleBadLayers( QList<QDomNode> layers, QDomDocument projectDom );
+class QPushButton;
+ : public QDialog
+ , private Ui::QgsHandleBadLayersBase
+ Q_OBJECT
+ public:
+ QgsHandleBadLayers( const QList<QDomNode> &layers, const QDomDocument &dom );
+ ~QgsHandleBadLayers();
+ private slots:
+ void selectionChanged();
+ void browseClicked();
+ void apply();
+ void accept();
+ void rejected();
+ void itemChanged( QTableWidgetItem * );
+ void cellDoubleClicked( int row, int column );
+ private:
+ QPushButton *mBrowseButton;
+ const QList<QDomNode> &mLayers;
+ QList<int> mRows;
+ QString mVectorFileFilter;
+ QString mRasterFileFilter;
+#endif
Added: trunk/qgis/src/ui/qgshandlebadlayersbase.ui
--- trunk/qgis/src/ui/qgshandlebadlayersbase.ui (rev 0)
+++ trunk/qgis/src/ui/qgshandlebadlayersbase.ui 2011-03-06 02:19:47 UTC (rev 15353)
@@ -0,0 +1,103 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>QgsHandleBadLayersBase</class>
+ <widget class="QDialog" name="QgsHandleBadLayersBase">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>834</width>
+ <height>505</height>
+ </rect>
+ </property>
+ <property name="windowTitle">
+ <string>Handle bad layers</string>
+ </property>
+ <layout class="QVBoxLayout" name="verticalLayout">
+ <item>
+ <widget class="QTableWidget" name="mLayerList">
+ <column>
+ <property name="text">
+ <string>Layer name</string>
+ </property>
+ </column>
+ <column>
+ <string>Type</string>
+ </property>
+ </column>
+ <column>
+ <string>Provider</string>
+ </property>
+ </column>
+ <column>
+ <string>Original filename</string>
+ </property>
+ </column>
+ <column>
+ <string>New filename</string>
+ </property>
+ </column>
+ <column>
+ <string>Original datasource</string>
+ </property>
+ </column>
+ <column>
+ <string>New datasource</string>
+ </property>
+ </column>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsHandleBadLayersBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>248</x>
+ <y>254</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>157</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>316</x>
+ <y>260</y>
+ </hint>
+ <x>286</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
