[QGIS Commit] r15426 - in trunk/qgis: ms-windows/osgeo4w
src/providers/gdal src/providers/grass
svn_qgis at osgeo.org
Fri Mar 11 01:16:25 EST 2011
Author: jef
Date: 2011-03-10 22:16:25 -0800 (Thu, 10 Mar 2011)
New Revision: 15426
trunk/qgis/ms-windows/osgeo4w/qgis.bat.tmpl
trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp
fix windows build
Modified: trunk/qgis/ms-windows/osgeo4w/qgis.bat.tmpl
--- trunk/qgis/ms-windows/osgeo4w/qgis.bat.tmpl 2011-03-10 22:57:28 UTC (rev 15425)
+++ trunk/qgis/ms-windows/osgeo4w/qgis.bat.tmpl 2011-03-11 06:16:25 UTC (rev 15426)
@@ -4,5 +4,6 @@
call "%OSGEO4W_ROOT%"\bin\o4w_env.bat
call "%OSGEO4W_ROOT%"\bin\grass-env.bat
@echo off
+SET GDAL_DRIVER_PATH=%OSGEO4W_ROOT%\bin\gdalplugins\1.8
path %PATH%;%GISBASE%\bin
start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\@package@\bin\qgis.exe %*
Modified: trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
--- trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-10 22:57:28 UTC (rev 15425)
+++ trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-11 06:16:25 UTC (rev 15426)
@@ -22,8 +22,6 @@
#include "qgsgdalprovider.h"
#include "qgsconfig.h"
-#include <math.h>
#include "qgsapplication.h"
#include "qgscoordinatetransform.h"
#include "qgsrectangle.h"
@@ -302,7 +300,7 @@
// This block of code was in old version in QgsRasterLayer::bandStatistics
//ifdefs below to remove compiler warning about unused vars
#ifdef QGISDEBUG
+#if 0
int success;
double GDALminimum = GDALGetRasterMinimum( myGdalBand, &success );
@@ -341,8 +339,8 @@
QgsLogger::debug( "exactly computed GDALmaximum:", GDALrange[1] );
QgsDebugMsg( "starting manual stat computation" );
#endif
+#endif
mValid = true;
QgsDebugMsg( "end" );
@@ -510,7 +508,7 @@
void QgsGdalProvider::readBlock( int theBandNo, int xBlock, int yBlock, void *block )
- // TODO!!!: Check data alignment!!! May it happen that nearest value which
+ // TODO!!!: Check data alignment!!! May it happen that nearest value which
// is not nearest is assigned to an output cell???
QgsDebugMsg( "Entered" );
@@ -539,7 +537,7 @@
// TODO: fill block with no data values
- QgsRectangle myRasterExtent = theExtent.intersect( &mExtent );
+ QgsRectangle myRasterExtent = theExtent.intersect( &mExtent );
if ( myRasterExtent.isEmpty() )
QgsDebugMsg( "draw request outside view extent." );
@@ -547,46 +545,46 @@
QgsDebugMsg( "myRasterExtent: " + myRasterExtent.toString() );
- double xRes = theExtent.width()/thePixelWidth;
- double yRes = theExtent.height()/thePixelHeight;
+ double xRes = theExtent.width() / thePixelWidth;
+ double yRes = theExtent.height() / thePixelHeight;
// Find top, bottom rows and left, right column the raster extent covers
// These are limits in target grid space
int top = 0;
- int bottom = thePixelHeight-1;
+ int bottom = thePixelHeight - 1;
int left = 0;
- int right = thePixelWidth-1;
- if ( myRasterExtent.yMaximum() < theExtent.yMaximum() )
+ int right = thePixelWidth - 1;
+ if ( myRasterExtent.yMaximum() < theExtent.yMaximum() )
- top = static_cast<int> ( round( ( theExtent.yMaximum() - myRasterExtent.yMaximum() ) / yRes ) );
+ top = qRound(( theExtent.yMaximum() - myRasterExtent.yMaximum() ) / yRes );
- if ( myRasterExtent.yMinimum() > theExtent.yMinimum() )
+ if ( myRasterExtent.yMinimum() > theExtent.yMinimum() )
- bottom = static_cast<int> ( round( ( theExtent.yMaximum() - myRasterExtent.yMinimum() ) / yRes ) - 1 );
+ bottom = qRound(( theExtent.yMaximum() - myRasterExtent.yMinimum() ) / yRes ) - 1;
- if ( myRasterExtent.xMinimum() > theExtent.xMinimum() )
+ if ( myRasterExtent.xMinimum() > theExtent.xMinimum() )
- left = static_cast<int> ( round( ( myRasterExtent.xMinimum() - theExtent.xMinimum() ) / xRes ) );
+ left = qRound(( myRasterExtent.xMinimum() - theExtent.xMinimum() ) / xRes );
- if ( myRasterExtent.xMaximum() < theExtent.xMaximum() )
+ if ( myRasterExtent.xMaximum() < theExtent.xMaximum() )
- right = static_cast<int> ( round( ( myRasterExtent.xMaximum() - theExtent.xMinimum() ) / xRes ) - 1 );
+ right = qRound(( myRasterExtent.xMaximum() - theExtent.xMinimum() ) / xRes ) - 1;
- QgsDebugMsg( QString("top = %1 bottom = %2 left = %3 right = %4").arg(top).arg(bottom).arg(left).arg(right) );
+ QgsDebugMsg( QString( "top = %1 bottom = %2 left = %3 right = %4" ).arg( top ).arg( bottom ).arg( left ).arg( right ) );
- // We want to avoid another resampling, so we read data approximately with
+ // We want to avoid another resampling, so we read data approximately with
// the same resolution as requested and exactly the width/height we need.
// Calculate rows/cols limits in raster grid space
// IMHO, we cannot align target grid to raster grid using target grid edges
// and finding the nearest raster grid because it could lead to cell center
// getting outside the right cell when doing resampling, example
// Raster width is 30m and it has 3 columns and we want to read xrange 5.1-30
// to 3 columns, the nearest edge for beginning in raster grid is 10.0
- // reading cols 1-2, we get raster[1] value in target[0], but the center of
+ // reading cols 1-2, we get raster[1] value in target[0], but the center of
// target[0] is 5.1 + ((30-5.1)/3)/2 = 9.25 so it falls to raster[0]. Is it right?
// => We are looking for such alignment with which the center of first/last cell
// alls to the right raster cell
@@ -598,7 +596,7 @@
double topSpace, bottomSpace, leftSpace, rightSpace;
// top
- center = myRasterExtent.yMaximum() - yRes/2;
+ center = myRasterExtent.yMaximum() - yRes / 2;
// center in raster space
// GDAL states that mGeoTransform[3] is top, but probably it can be also bottom
// if mGeoTransform[5] is negative ??? No, mGeoTransform[5] is negative normaly
@@ -607,69 +605,65 @@
if ( mGeoTransform[5] < 0 )
centerRaster = -1. * ( mGeoTransform[3] - center ) / mGeoTransform[5];
- else
+ else
centerRaster = ( center - mGeoTransform[3] ) / mGeoTransform[5];
- rasterTop = static_cast<int> ( floor ( centerRaster ) );
- topSpace = (mGeoTransform[3] + rasterTop*mGeoTransform[5])- myRasterExtent.yMaximum();
+ rasterTop = static_cast<int>( floor( centerRaster ) );
+ topSpace = ( mGeoTransform[3] + rasterTop * mGeoTransform[5] ) - myRasterExtent.yMaximum();
// bottom
- center = myRasterExtent.yMinimum() + yRes/2;
+ center = myRasterExtent.yMinimum() + yRes / 2;
//if ( mGeoTransform[5] > 0 )
- else
+ else
- rasterBottom = static_cast<int> ( floor ( centerRaster ) );
- bottomSpace = myRasterExtent.yMinimum() - ( mGeoTransform[3] + (rasterBottom+1)*mGeoTransform[5] );
+ rasterBottom = static_cast<int>( floor( centerRaster ) );
+ bottomSpace = myRasterExtent.yMinimum() - ( mGeoTransform[3] + ( rasterBottom + 1 ) * mGeoTransform[5] );
// left
- center = myRasterExtent.xMinimum() + xRes/2;
+ center = myRasterExtent.xMinimum() + xRes / 2;
centerRaster = ( center - mGeoTransform[0] ) / mGeoTransform[1];
- rasterLeft = static_cast<int> ( floor ( centerRaster ) );
- leftSpace = myRasterExtent.xMinimum() - (mGeoTransform[0] + rasterLeft * mGeoTransform[1] );
+ rasterLeft = static_cast<int>( floor( centerRaster ) );
+ leftSpace = myRasterExtent.xMinimum() - ( mGeoTransform[0] + rasterLeft * mGeoTransform[1] );
// right
- center = myRasterExtent.xMaximum() - xRes/2;
+ center = myRasterExtent.xMaximum() - xRes / 2;
- rasterRight = static_cast<int> ( floor ( centerRaster ) );
- rightSpace = (mGeoTransform[0] + (rasterRight+1)*mGeoTransform[1]) - myRasterExtent.xMaximum();
+ rasterRight = static_cast<int>( floor( centerRaster ) );
+ rightSpace = ( mGeoTransform[0] + ( rasterRight + 1 ) * mGeoTransform[1] ) - myRasterExtent.xMaximum();
- QgsDebugMsg( QString("rasterTop = %1 rasterBottom = %2 rasterLeft = %3 rasterRight = %4").arg(rasterTop).arg(rasterBottom).arg(rasterLeft).arg(rasterRight) );
+ QgsDebugMsg( QString( "rasterTop = %1 rasterBottom = %2 rasterLeft = %3 rasterRight = %4" ).arg( rasterTop ).arg( rasterBottom ).arg( rasterLeft ).arg( rasterRight ) );
- QgsDebugMsg( QString("topSpace = %1 bottomSpace = %2 leftSpace = %3 rightSpace = %4").arg(topSpace).arg(bottomSpace).arg(leftSpace).arg(rightSpace) );
+ QgsDebugMsg( QString( "topSpace = %1 bottomSpace = %2 leftSpace = %3 rightSpace = %4" ).arg( topSpace ).arg( bottomSpace ).arg( leftSpace ).arg( rightSpace ) );
int width = right - left + 1;
int height = bottom - top + 1;
int rasterWidth = rasterRight - rasterLeft + 1;
int rasterHeight = rasterBottom - rasterTop + 1;
- QgsDebugMsg( QString("width = %1 height = %2 rasterWidth = %3 rasterHeight = %4").arg(width).arg(height).arg(rasterWidth).arg(rasterHeight) );
+ QgsDebugMsg( QString( "width = %1 height = %2 rasterWidth = %3 rasterHeight = %4" ).arg( width ).arg( height ).arg( rasterWidth ).arg( rasterHeight ) );
- double rasterXRes = extent().width() / xSize();
- double rasterYRes = extent().height() / ySize();
// TODO: what is better floor/ceil, can be negative?
// should be similar
//double xAdd = rasterWidth*rasterXRes - width*xRes;
double xAdd = leftSpace + rightSpace;
- int xAddPixels = static_cast<int> ( round( xAdd / xRes ) );
- int leftAddPixels = static_cast<int> ( round( leftSpace / xRes ) );
+ int xAddPixels = qRound( xAdd / xRes );
+ int leftAddPixels = qRound( leftSpace / xRes );
//double leftAdd = rasterWidth*rasterXRes - width*xRes;
double yAdd = topSpace + bottomSpace;
- int yAddPixels = static_cast<int> ( round( yAdd / yRes ) );
- int topAddPixels = static_cast<int> ( round( topSpace / yRes ) );
+ int yAddPixels = qRound( yAdd / yRes );
+ int topAddPixels = qRound( topSpace / yRes );
- QgsDebugMsg( QString("xAddPixels = %1 yAddPixels = %2 leftAddPixels = %3 topAddPixels = %4").arg(xAddPixels).arg(yAddPixels).arg(leftAddPixels).arg(topAddPixels) );
+ QgsDebugMsg( QString( "xAddPixels = %1 yAddPixels = %2 leftAddPixels = %3 topAddPixels = %4" ).arg( xAddPixels ).arg( yAddPixels ).arg( leftAddPixels ).arg( topAddPixels ) );
// Currently only positive allowed, verify if negative has sense and check following use
xAddPixels = xAddPixels > 0 ? xAddPixels : 0;
yAddPixels = yAddPixels > 0 ? yAddPixels : 0;
@@ -679,17 +673,17 @@
int totalWidth = width + xAddPixels;
int totalHeight = height + yAddPixels;
- QgsDebugMsg( QString("totalWidth = %1 totalHeight = %2").arg(totalWidth).arg(totalHeight) );
+ QgsDebugMsg( QString( "totalWidth = %1 totalHeight = %2" ).arg( totalWidth ).arg( totalHeight ) );
- int size = dataTypeSize(theBandNo) / 8;
+ int size = dataTypeSize( theBandNo ) / 8;
- // fill with null values
- QByteArray ba = noValueBytes(theBandNo);
+ // fill with null values
+ QByteArray ba = noValueBytes( theBandNo );
char *nodata = ba.data();
- char *block = (char *) theBlock;
+ char *block = ( char * ) theBlock;
for ( int i = 0; i < thePixelWidth * thePixelHeight; i++ )
- memcpy ( block, nodata, size );
+ memcpy( block, nodata, size );
block += size;
@@ -700,50 +694,52 @@
// This can be probably used if xAddPixels and yAddPixels are 0 to avoid memcpy
#if 0
// Calc beginnig of data if raster does not start at top
- block = (char *) theBlock;
- if ( top != 0 )
+ block = ( char * ) theBlock;
+ if ( top != 0 )
block += size * thePixelWidth * top;
// Cal nLineSpace if raster does not cover whole extent
int nLineSpace = size * thePixelWidth;
- if ( left != 0 ) {
+ if ( left != 0 )
block += size * left;
- CPLErr err = GDALRasterIO( gdalBand, GF_Read,
- rasterLeft, rasterTop, rasterWidth, rasterHeight,
- (void *)block,
- width, height, type,
- 0, nLineSpace );
+ CPLErr err = GDALRasterIO( gdalBand, GF_Read,
+ rasterLeft, rasterTop, rasterWidth, rasterHeight,
+ ( void * )block,
+ width, height, type,
+ 0, nLineSpace );
#endif
// Allocate temporary block
void *tmpBlock = malloc( size * totalWidth * totalHeight );
CPLErrorReset();
- (void *)tmpBlock,
- totalWidth, totalHeight, type,
- 0, 0 );
+ ( void * )tmpBlock,
+ totalWidth, totalHeight, type,
+ 0, 0 );
if ( err != CPLE_None )
QgsLogger::warning( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
- QgsDebugMsg ( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
- free ( tmpBlock );
+ QgsDebugMsg( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+ free( tmpBlock );
return;
- for ( int i = 0; i < height; i++ ) {
+ for ( int i = 0; i < height; i++ )
int r = i + topAddPixels;
- char *src = (char *)tmpBlock + size*r*totalWidth + size*leftAddPixels;
- char *dst = (char *)theBlock + size*(top+i)*thePixelWidth + size*(left);
- memcpy ( dst, src, size*width );
+ char *src = ( char * )tmpBlock + size * r * totalWidth + size * leftAddPixels;
+ char *dst = ( char * )theBlock + size * ( top + i ) * thePixelWidth + size * ( left );
+ memcpy( dst, src, size*width );
+ free( tmpBlock );
return;
@@ -762,8 +758,8 @@
//myMemDsn.sprintf( "MEM:::DATAPOINTER=%lu,PIXELS=%d,LINES=%d,BANDS=1,DATATYPE=%s,PIXELOFFSET=0,LINEOFFSET=0,BANDOFFSET=0", ( long )theBlock, thePixelWidth, thePixelHeight, GDALGetDataTypeName(( GDALDataType )mGdalDataType[theBandNo-1] ) );
char szPointer[64];
- memset( szPointer, 0, sizeof(szPointer) );
- CPLPrintPointer( szPointer, theBlock, sizeof(szPointer) );
+ memset( szPointer, 0, sizeof( szPointer ) );
+ CPLPrintPointer( szPointer, theBlock, sizeof( szPointer ) );
myMemDsn.sprintf( "MEM:::DATAPOINTER=%s,PIXELS=%d,LINES=%d,BANDS=1,DATATYPE=%s,PIXELOFFSET=0,LINEOFFSET=0,BANDOFFSET=0", szPointer, thePixelWidth, thePixelHeight, GDALGetDataTypeName(( GDALDataType )mGdalDataType[theBandNo-1] ) );
@@ -839,15 +835,15 @@
NULL
- if ( !myWarpOptions->pTransformerArg )
+ if ( !myWarpOptions->pTransformerArg )
QMessageBox::warning( 0, QObject::tr( "Warning" ),
QObject::tr( "Cannot GDALCreateGenImgProjTransformer: " )
return;
//CPLAssert( myWarpOptions->pTransformerArg != NULL );
myWarpOptions->pfnTransformer = GDALGenImgProjTransform;
@@ -870,14 +866,14 @@
GDALWarpOperation myOperation;
- if ( myOperation.Initialize( myWarpOptions ) != CE_None )
+ if ( myOperation.Initialize( myWarpOptions ) != CE_None )
QObject::tr( "Cannot inittialize GDALWarpOperation : " )
return;
CPLErrorReset();
CPLErr myErr;
myErr = myOperation.ChunkAndWarpImage( 0, 0, thePixelWidth, thePixelHeight );
@@ -1212,30 +1208,30 @@
QString QgsGdalProvider::identifyAsText( const QgsPoint& point )
- return QString( "Not implemented" );
+ return QString( "Not implemented" );
QString QgsGdalProvider::identifyAsHtml( const QgsPoint& point )
QString QgsGdalProvider::lastErrorTitle()
QString QgsGdalProvider::lastError()
-QString QgsGdalProvider::name() const
+QString QgsGdalProvider::name() const
return PROVIDER_KEY;
-QString QgsGdalProvider::description() const
+QString QgsGdalProvider::description() const
return PROVIDER_DESCRIPTION;
@@ -1615,7 +1611,7 @@
// first get the GDAL driver manager
- //registerGdalDrivers();
+ QgsGdalProvider::registerGdalDrivers();
// then iterate through all of the supported drivers, adding the
// corresponding file filter
@@ -1785,7 +1781,7 @@
GDALDatasetH myDataset;
- GDALAllRegister();
CPLErrorReset();
Modified: trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp 2011-03-10 22:57:28 UTC (rev 15425)
+++ trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp 2011-03-11 06:16:25 UTC (rev 15426)
@@ -23,8 +23,6 @@
#include "qgsgrassrasterprovider.h"
-#include <cmath>
