[QGIS Commit] r15427 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Fri Mar 11 02:01:39 EST 2011
Author: macho
Date: 2011-03-10 23:01:39 -0800 (Thu, 10 Mar 2011)
New Revision: 15427
docs/trunk/english_us/user_guide/plugins_gdaltools.tex
docs/trunk/english_us/user_guide/print_composer.tex
docs/trunk/english_us/user_guide/working_with_vector.tex
applying patch from Alister to User guide
Modified: docs/trunk/english_us/user_guide/plugins_gdaltools.tex
--- docs/trunk/english_us/user_guide/plugins_gdaltools.tex 2011-03-11 06:16:25 UTC (rev 15426)
+++ docs/trunk/english_us/user_guide/plugins_gdaltools.tex 2011-03-11 07:01:39 UTC (rev 15427)
@@ -23,7 +23,7 @@
\hline Merge & This utility will automatically mosaic a set of images. All the images must be in the same coordinate system and have a matching number of bands, but they may be overlapping, and at different resolutions. In areas of overlap, the last image will be copied over earlier ones. \\
\hline Sieve & The gdal\_sieve.py script removes raster polygons smaller than a provided threshold size (in pixels) and replaces replaces them with the pixel value of the largest neighbour polygon. The result can be written back to the existing raster band, or copied into a new file.\\
\hline Proximity & The gdal\_proximity.py script generates a raster proximity map indicating the distance from the center of each pixel to the center of the nearest pixel identified as a target pixel. Target pixels are those in the source raster for which the raster pixel value is in the set of target pixel values.\\
-\hline Near Black & This utility will scan an image and try to set all pixels that are nearly black (or nearly white) around the collar to exactly black (or white). This is often used to "fix up" lossy compressed airphotos so that color pixels can be treated as transparent when mosaicing.\\
+\hline Near Black & This utility will scan an image and try to set all pixels that are nearly black (or nearly white) around the edge to exactly black (or white). This is often used to "fix up" lossy compressed aerial photos so that color pixels can be treated as transparent when mosaicing.\\
\hline Warp & The gdalwarp utility is an image mosaicing, reprojection and warping utility. The program can reproject to any supported projection, and can also apply GCPs stored with the image if the image is "raw" with control information. \\
\hline Grid & This program creates regular grid (raster) from the scattered data read from the OGR datasource. Input data will be interpolated to fill grid nodes with values, you can choose from various interpolation methods.\\
\hline Translate & The gdal\_translate utility can be used to convert raster data between different formats, potentially performing some operations like subsettings, resampling, and rescaling pixels in the process.\\
@@ -33,7 +33,7 @@
source spatial reference set. The coordinate systems that can be passed are anything supported by the OGRSpatialReference.SetFromUserInput() call, which includes EPSG PCS and GCSes (ie. EPSG:4296), PROJ.4 declarations (as above), or the name of a .prf file containing well known text.
-t\_srs srs\_def:
target spatial reference set. The coordinate systems that can be passed are anything supported by the OGRSpatialReference.SetFromUserInput() call, which includes EPSG PCS and GCSes (ie. EPSG:4296), PROJ.4 declarations (as above), or the name of a .prf file containing well known text. \\
-\hline Build Overviews & The gdaladdo utility can be used to build or rebuild overview images for most supported file formats with one over several downsampling algorithms.\\
+\hline Build Overviews & The gdaladdo utility can be used to build or rebuild overview images for most supported file formats with one of several downsampling algorithms.\\
\hline Clipper & This utility will automatically mosaic a set of images. All the images must be in the same coordinate system and have a matching number of bands, but they may be overlapping, and at different resolutions. In areas of overlap, the last image will be copied over earlier ones.
-ul\_lr ulx uly lrx lry:
The extents of the output file. If not specified the aggregate extents of all input files will be used. \\
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex 2011-03-11 06:16:25 UTC (rev 15426)
+++ docs/trunk/english_us/user_guide/print_composer.tex 2011-03-11 07:01:39 UTC (rev 15427)
@@ -104,7 +104,7 @@
Opening the print composer provides you with a blank canvas to which you can
add the current QGIS map canvas, legend, scalebar, images, basic shapes,
arrows and text. Figure \ref{fig:print_composer_blank} shows the initial view
-of the print composer with an activated \checkbox{Snap to grid} modus but
+of the print composer with an activated \checkbox{Snap to grid} mode but
before any elements are added. The print composer provides two tabs:
\begin{itemize}[label=--]
@@ -236,8 +236,8 @@
width used for cross or line grid type.
\item The \checkbox{Draw annotation} checkbox allows to add coordinates to
the map frame. The annotation can be drawn inside or outside the map frame.
-As annotation direction can be defined horizontal, vertical, horizontal and
-vertical or boundary direction. And finally you can define the grid color,
+The annotation direction can be defined as horizontal, vertical, horizontal and
+vertical, or boundary direction. And finally you can define the grid color,
the annotation font, the annotation distance from the map frame and the
precision of the drawn coordinates.
\end{itemize}
@@ -573,8 +573,8 @@
The \toolbtntwo{mActionComposerManager}{Composer Manager} button in the
toolbar and in \mainmenuopt{File} \arrow
-\dropmenuopttwo{mActionComposerManager}{Composer Manager} allows to manage
-add new composer template or to manage already existing templates.
+\dropmenuopttwo{mActionComposerManager}{Composer Manager} allows to
+add a new composer template or to manage already existing templates.
\begin{figure}[h]
\centering
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2011-03-11 06:16:25 UTC (rev 15426)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2011-03-11 07:01:39 UTC (rev 15427)
@@ -506,8 +506,8 @@
use the file browser to point to your SpatiaLite database, which is a file with
a \filename{.sqlite } extension.
-If you want to save a vector layer to SpatiaLite format you can do this opening the right
-mouse menu of the layer. Then click on \dropmenuopt{Save as}, define the name of the output
+If you want to save a vector layer to SpatiaLite format you can do this by right clicking
+the layer in the legend. Then click on \dropmenuopt{Save as}, define the name of the output
file, sqlite as format and the CRS and then add 'SPATIALITE=YES' in the OGR data source
creation option field. This tells OGR to create a SpatiaLite database. See
also \url{http://www.gdal.org/ogr/drv_sqlite.html}.
@@ -902,11 +902,12 @@
\item Enter a default for lakes that have no name. The default label will be
used each time \qg encounters a lake with no value in the \guilabel{NAMES}
field.
-\item If have labels extending over several lines, check \checkbox{Multiline
+\item If you have labels extending over several lines, check \checkbox{Multiline
labels?}. \qg will check for a true line return in your label field and
insert the line breaks accordingly. A true line return is a \textbf{single}
character \textbackslash n, (not two separate characters, like a backlash
-\textbackslash ~followed by the character n).
+\textbackslash ~followed by the character n). To insert line returns in an
+attribute field configure the edit widget to be text edit (not line edit).
\item Click \button{Apply}.
\end{enumerate}
@@ -1095,10 +1096,10 @@
The \tab{General} tab is essentially like that of the raster dialog. It
allows you to change the display name, set scale dependent rendering options,
create a spatial index of the vector file (only for OGR supported formats and
-PostGIS) and view or change the projection of the specific vetor layer.
+PostGIS) and view or change the projection of the specific vector layer.
The \button{Query Builder} button allows you to create a subset of the
-features in the layer - but this button currently only is available when you
+features in the layer - but currently this button is only available when you
open the attribute table and select the \button{...} button next to Advanced
search.
@@ -1516,9 +1517,8 @@
tool buttons on the editing toolbar will become available.
\begin{Tip}\caption{\textsc{Save Regularly}}
-Remember to toggle \toolbtntwo{mActionToggleEditing}{Toggle editing}
-off regularly. This allows you to save your recent changes, and also confirms
-that your data source can accept all your changes.
+Remember to \toolbtntwo{mActionFileSave}{Save Edits} regularly. This will
+also check that your data source can accept all the changes.
\end{Tip}
\minisec{Adding Features}
@@ -1591,34 +1591,42 @@
\minisec{Basic operations}\index{vector layers!Node Tool}
Start by activating the \toolbtntwo{mActionNodeTool}{Node Tool} and selecting
-some features by clicking on it. Red boxes appear at each vertex of this feature.
-This is basic select of the feature. Functionalities are:
+a feature by clicking on it. Red boxes will appear at each vertex of this feature.
+%%Perhaps the error message mentioned below is in fact a bug, in which case the
+%%bug should be fixed rather than including this note
+Note that to select a polygon you must click one of its vertices or edges;
+clicking inside it will produce an error message. Once a feature
+is selected the following functionalities are available:
-\item \textbf{Selecting vertex}: Selecting is easy just click on vertex and
-color of this vertex will change to blue. When selecting more vertices
-\keystroke{Shift} key can be used to select more vertices. Or also the
-\keystroke{Ctrl} key can be used to invert selection of vertices (if selected then
-it will be unselected and when not selected vertex will be selected). Also more
-vertices can be selected at once when clicking somewhere outside feature and opening a rectangle where all vertices inside will be selected. Or just click on an edge and
-both adjacent vertices should be selected.
-\item \textbf{Adding vertex}: Adding vertex is simple, too. Just double click near
-some edge and a new vertex will appear on the edge near to the cursor. Note that
-vertex will appear on edge not on cursor position, there it has to be moved if
-necessary.
-\item \textbf{Deleting vertex}: After selecting vertices for deletion, click the
-\keystroke{Delete} key and vertices will be deleted. Note that according to
-standard Quantum GIS behavior, it will leave a necessary number of vertices for
-the feature type you are working on. To delete a complete feature, another tool
-has to be used.
-\item \textbf{Moving vertex}: Select all vertices you want to move. All selected
-vertices are moving in the same direction as the cursor. If snapping is enabled,
+\item \textbf{Selecting vertices}: You can select vertices by clicking on them
+one at a time, by clicking on an edge to select the vertices at both ends, or
+by clicking and dragging a rectangle around some vertices. When a vertex is
+selected its color changes to blue. To add more vertices to the current selection,
+hold down the \keystroke{Ctrl} key while clicking. Hold down
+\keystroke{Ctrl}\keystroke{Shift} when clicking to toggle the selection state of
+vertices (vertices that are currently unselected will be selected as usual, but
+also vertices that are already selected will become unselected).
+\item \textbf{Adding vertices}: To add a vertex simply double click near
+an edge and a new vertex will appear on the edge near to the cursor. Note that
+the vertex will appear on the edge, not at the cursor position, therefore it has
+to be moved if necessary.
+\item \textbf{Deleting vertices}: After selecting vertices for deletion, click the
+\keystroke{Delete} key. Note that you cannot use the
+\toolbtntwo{mActionNodeTool}{Node Tool} to delete a complete feature; \qg will
+ensure it retains the minimum number of vertices for the feature type you are
+working on. To delete a complete feature use the
+\toolbtntwo{mActionDeleteSelected}{Delete Selected} tool.
+\item \textbf{Moving vertices}: Select all the vertices you want to move. Click
+on a selected vertex or edge and drag in the direction you wish to move. All the
+selected vertices will move together. If snapping is enabled,
the whole selection can jump to the nearest vertex or line.
\end{itemize}
-The \button{Release} button stores all changes and a new entry appears in the undo
-dialog. Remember that all operations support topological editing when turned on. On
-the fly projection is also supported.
+Each change made with the node tool is stored as a separate entry in the undo dialog.
+Remember that all operations support topological editing when this is turned on.
+On the fly projection is also supported, and the node tool provides tooltips to
+identify a vertex by hovering the pointer over it.
\minisec{Cutting, Copying and Pasting Features}
\index{vector layers!cut!feature}
@@ -1763,22 +1771,21 @@
\index{vector layers!redo}
The \toolbtntwo{mActionUndo}{Undo} and \toolbtntwo{mActionRedo}{Redo} tools
-allow the user to undo or redo the last or a certain step within the vector editing
-operations. Basic view of Undo/Redo operations is a widget, where all operations
-are shown (see Figure~\ref{fig:vector_redoundo}). This widget is not displayed by
-default. Widget can be displayed by right clicking on toolbar and activating the
+allow the user to undo or redo vector editing operations. There is also a dockable
+widget, which shows all operations in the undo/redo history (see
+Figure \ref{fig:vector_redoundo}). This widget is not displayed by
+default; it can be displayed by right clicking on the toolbar and activating the
Undo/Redo check box. Undo/Redo is however active, even if the widget is not
displayed.
When Undo is hit, the state of all features and attributes are reverted to the
-state before the reverted operation happened. Changes which are done elsewhere
-(for example from some plugin), can show unspecific behavior for some operations
-which appears in this box. The operations can be reverted or they stay the same.
+state before the reverted operation happened. Changes other than normal vector
+editing operations (for example changes done by a plugin), may or may not be
+reverted, depending on how the changes were performed.
-An action can be triggered by clicking on Undo or Redo buttons or by clicking
-directly on the item to which you want to return to. Another possibility to
-trigger an undo operation is to click on the \button{undo/redo} buttons in
-the advanced digitizing tool bar.
+To use the undo/redo history widget simply click to select an operation in the
+history list; all features will be reverted to the state they were in after
+the selected operation.
\begin{figure}[ht]
\centering
@@ -1962,15 +1969,19 @@
\index{editing!working with the attribute table}
The attribute table displays features of a selected layer. Each row in the table
-represents one map feature with its attributes shown in several columns. The
-features in the table can be searched, selected, moved or even edited.
+represents one map feature and each column contains a particular piece of
+information about the feature. Features in the table can be searched, selected,
+moved or even edited.
To open the attribute table for a vector layer, make the layer active by clicking
on it in the map legend area. Then use \mainmenuopt{Layer} from the main menu
and and choose \dropmenuopttwo{mActionOpenTable}{Open Attribute Table}
from the menu. It is also possible to rightlick on the layer and
choose \dropmenuopttwo{mActionOpenTable}{Open Attribute Table} from the
-dropdown menu. This will open a new window which displays the attributes for
+dropdown menu.
+%%FIXME: The following statement is not necessarily correct as there is a setting
+%%which means it might only display the selected features or features in current canvas
+This will open a new window which displays the attributes for
every feature in the layer (figure \ref{fig:attributetable}). The number of features
are shown in the attribute table title.
@@ -1982,29 +1993,33 @@
\minisec{Selecting features in an attribute table}
-\textbf{A selected row} in the attribute table represents all attributes of a
-selected feature in the layer. The attribute table reflects any changes
-in the layer selection in the main window and vice versa. A changed selection
-in the attribute table also causes a change in the selected feature set in the
-main window and different layer feature selection means different rows are to be
-selected.
+\textbf{Each selected row} in the attribute table displays the attributes of a
+selected feature in the layer. If the set of features selected in the main window
+is changed, the selection is also updated in the attribute table.
+Likewise, if the set of rows selected in the attribute table is changed, the
+set of features selected in the main window will be updated.
Rows can be selected by clicking on the row number on the left side of the
-row. Selecting a row doesn't change the current cursor position. \textbf{Multiple
-rows} can be marked by holding the \keystroke{Ctrl} key. A \textbf{continuous
-selection} can be made by holding the \keystroke{Shift} key and clicking on several
-row headers on the left side of the rows. All rows between the current cursor
-position and the clicked row are selected.
+row. \textbf{Multiple rows} can be marked by holding the \keystroke{Ctrl} key. A
+\textbf{continuous selection} can be made by holding the \keystroke{Shift} key and
+clicking on several row headers on the left side of the rows. All rows between the
+current cursor position and the clicked row are selected. Moving the cursor
+position in the attribute table, by clicking a cell in the table, does not change
+the row selection. Changing the selection in the main canvas does not move the
+cursor position in the attribute table.
+%%This previously said that changing the row selection in the attribute table does not move the cursor position. But it does, if it is not meant to, there is a bug!
-Each column can be sorted by clicking on its column header. A small arrow
-indicates the sort order (downward pointing means descending values from the top
-row down, upward pointing means ascending values from the top rown down).
+The table can be sorted by any column, by clicking on the column header. A small
+arrow indicates the sort order (downward pointing means descending values from the
+top row down, upward pointing means ascending values from the top row down).
For a \textbf{simple search by attributes} on only one column the \button{Look for}
field can be used. Select the field (column) from which the search should be
-performed from the dropdown menu and hit the \button{Search} button. The number of
-matching rows will appear in the status bar. For more complex searches use
-the Advanced search \button{...}, which will lauch the Search Query Builder
+performed from the dropdown menu and hit the \button{Search} button. The matching
+rows will be selected and the total number of
+matching rows will appear in the title bar of the attribute table, and in the
+status bar of the main window. For more complex searches use
+the Advanced search \button{...}, which will launch the Search Query Builder
described in Section \ref{sec:select_by_query}.
To show selected records only, use the checkbox \checkbox{Show selected records only}. To search selected records only, use the checkbox \checkbox{Search selected records only}. The other buttons at the bottom left of the attribute table window provide following functionality:
