[QGIS Commit] r15476 - in trunk/qgis/python/plugins/GdalTools: .
tools
svn_qgis at osgeo.org
Mon Mar 14 13:17:37 EDT 2011
Author: brushtyler
Date: 2011-03-14 10:17:37 -0700 (Mon, 14 Mar 2011)
New Revision: 15476
trunk/qgis/python/plugins/GdalTools/__init__.py
trunk/qgis/python/plugins/GdalTools/tools/doWarp.py
trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui
added -cutline option to gdaltools warp tool, to fix #3066
Modified: trunk/qgis/python/plugins/GdalTools/__init__.py
--- trunk/qgis/python/plugins/GdalTools/__init__.py 2011-03-14 16:47:41 UTC (rev 15475)
+++ trunk/qgis/python/plugins/GdalTools/__init__.py 2011-03-14 17:17:37 UTC (rev 15476)
@@ -22,7 +22,7 @@
def description():
return "Integrate gdal tools into qgis"
def version():
- return "Version 1.2.22"
+ return "Version 1.2.23"
def qgisMinimumVersion():
return "1.0"
def icon():
Modified: trunk/qgis/python/plugins/GdalTools/tools/doWarp.py
--- trunk/qgis/python/plugins/GdalTools/tools/doWarp.py 2011-03-14 16:47:41 UTC (rev 15475)
+++ trunk/qgis/python/plugins/GdalTools/tools/doWarp.py 2011-03-14 17:17:37 UTC (rev 15476)
@@ -40,7 +40,9 @@
(self.cacheSpin, SIGNAL("valueChanged(int)"), self.cacheCheck),
( [self.widthSpin, self.heightSpin], SIGNAL( "valueChanged(int)" ), self.resizeGroupBox ),
(self.multithreadCheck, SIGNAL("stateChanged(int)")),
- (self.noDataEdit, SIGNAL( "textChanged( const QString & )" ), self.noDataCheck)
+ (self.noDataEdit, SIGNAL( "textChanged( const QString & )" ), self.noDataCheck),
+ (self.cutlineLayerCombo, [SIGNAL("currentIndexChanged(int)"), SIGNAL("editTextChanged(const QString &)")], self.cutlineCheck, "1.6.0"),
+ (self.selectCutlineFileButton, None, self.cutlineCheck, "1.6.0")
@@ -49,6 +51,7 @@
self.connect(self.selectOutputFileButton, SIGNAL("clicked()"), self.fillOutputFileEdit)
self.connect(self.selectSourceSRSButton, SIGNAL("clicked()"), self.fillSourceSRSEdit)
self.connect(self.selectTargetSRSButton, SIGNAL("clicked()"), self.fillTargetSRSEdit)
+ self.connect(self.selectCutlineFileButton, SIGNAL("clicked()"), self.fillCutlineFile)
self.connect( self.batchCheck, SIGNAL( "stateChanged( int )" ), self.switchToolMode )
@@ -90,12 +93,19 @@
def onLayersChanged(self):
self.fillInputLayerCombo()
+ self.fillCutlineLayerCombo()
def fillInputLayerCombo(self):
self.inputLayerCombo.clear()
- ( self.layers, names ) = Utils.LayerRegistry.instance().getRasterLayers()
+ ( self.inputLayers, names ) = Utils.LayerRegistry.instance().getRasterLayers()
self.inputLayerCombo.addItems( names )
+ def fillCutlineLayerCombo(self):
+ self.cutlineLayerCombo.clear()
+ ( self.cutlineLayers, names ) = Utils.LayerRegistry.instance().getVectorLayers()
+ self.cutlineLayerCombo.addItems( names )
def fillInputFile(self):
lastUsedFilter = Utils.FileFilter.lastUsedRasterFilter()
inputFile = Utils.FileDialog.getOpenFileName(self, self.tr( "Select the input file for Warp" ), Utils.FileFilter.allRastersFilter(), lastUsedFilter )
@@ -119,6 +129,17 @@
self.outputFormat = Utils.fillRasterOutputFormat( lastUsedFilter, outputFile )
self.outputFileEdit.setText(outputFile)
+ def fillCutlineFile(self):
+ lastUsedFilter = Utils.FileFilter.lastUsedVectorFilter()
+ cutlineFile = Utils.FileDialog.getOpenFileName(self, self.tr( "Select the cutline file" ), Utils.FileFilter.allVectorsFilter(), lastUsedFilter )
+ if cutlineFile.isEmpty():
+ return
+ Utils.FileFilter.setLastUsedVectorFilter(lastUsedFilter)
+ self.cutlineLayerCombo.setCurrentIndex(-1)
+ self.cutlineLayerCombo.setEditText(cutlineFile)
def fillInputDir( self ):
inputDir = Utils.FileDialog.getExistingDirectory( self, self.tr( "Select the input directory with files to Warp" ))
if inputDir.isEmpty():
@@ -187,6 +208,13 @@
if not nodata.isEmpty():
arguments << "-dstnodata"
arguments << nodata
+ if self.cutlineCheck.isChecked():
+ cutline = self.getCutlineFileName()
+ if not cutline.isEmpty():
+ arguments << "-q"
+ arguments << "-cutline"
+ arguments << cutline
+ arguments << "-dstalpha"
if self.isBatchEnabled():
return arguments
@@ -199,12 +227,17 @@
def getInputFileName(self):
if self.inputLayerCombo.currentIndex() >= 0:
- return self.layers[self.inputLayerCombo.currentIndex()].source()
+ return self.inputLayers[self.inputLayerCombo.currentIndex()].source()
return self.inputLayerCombo.currentText()
def getOutputFileName(self):
return self.outputFileEdit.text()
+ def getCutlineFileName(self):
+ if self.cutlineLayerCombo.currentIndex() >= 0:
+ return self.cutlineLayers[self.cutlineLayerCombo.currentIndex()].source()
+ return self.cutlineLayerCombo.currentText()
def addLayerIntoCanvas(self, fileInfo):
self.iface.addRasterLayer(fileInfo.filePath())
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui 2011-03-14 16:47:41 UTC (rev 15475)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui 2011-03-14 17:17:37 UTC (rev 15476)
@@ -7,7 +7,7 @@
<x>0</x>
<y>0</y>
<width>415</width>
- <height>417</height>
+ <height>453</height>
</rect>
</property>
<property name="sizePolicy">
@@ -19,15 +19,15 @@
<property name="windowTitle">
<string>Warp</string>
</property>
- <layout class="QVBoxLayout" name="verticalLayout">
- <item>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
<widget class="QCheckBox" name="batchCheck">
<property name="text">
<string>Batch mode (for processing whole directory)</string>
</property>
</widget>
</item>
- <item>
+ <item row="1" column="0">
<layout class="QGridLayout" name="gridLayout_2">
<widget class="QLabel" name="label">
@@ -203,14 +203,14 @@
</property>
</widget>
</item>
- <item row="6" column="0">
+ <item row="7" column="0">
<widget class="QCheckBox" name="cacheCheck">
<string>&Memory used for caching</string>
</property>
</widget>
</item>
- <item row="6" column="1">
+ <item row="7" column="1">
<widget class="QSpinBox" name="cacheSpin">
<property name="suffix">
<string>MB</string>
@@ -223,9 +223,43 @@
</property>
</widget>
</item>
+ <item row="6" column="0">
+ <widget class="QCheckBox" name="cutlineCheck">
+ <property name="text">
+ <string>Cutline</string>
+ </property>
+ </widget>
+ </item>
+ <item row="6" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout_5">
+ <item>
+ <widget class="QComboBox" name="cutlineLayerCombo">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="editable">
+ <bool>true</bool>
+ </property>
+ <property name="insertPolicy">
+ <enum>QComboBox::NoInsert</enum>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="selectCutlineFileButton">
+ <string>Select...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
</layout>
</item>
- <item>
+ <item row="2" column="0">
<widget class="QGroupBox" name="resizeGroupBox">
<property name="title">
<string>Resize</string>
@@ -283,10 +317,10 @@
</layout>
</widget>
</item>
- <item>
+ <item row="3" column="0">
<widget class="QProgressBar" name="progressBar"/>
</item>
- <item>
+ <item row="4" column="0">
<widget class="QCheckBox" name="multithreadCheck">
<string>Use m&ultithreaded warping implementation</string>
