[QGIS Commit] r15477 - in trunk/qgis/src/app: . postgres spatialite
svn_qgis at osgeo.org
Mon Mar 14 15:35:23 EDT 2011
Author: jef
Date: 2011-03-14 12:35:23 -0700 (Mon, 14 Mar 2011)
New Revision: 15477
trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
trunk/qgis/src/app/qgsnewhttpconnection.cpp
trunk/qgis/src/app/qgswmssourceselect.cpp
trunk/qgis/src/app/spatialite/qgsnewspatialitelayerdialog.cpp
trunk/qgis/src/app/spatialite/qgsspatialitesourceselect.cpp
fix #3614
Modified: trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
--- trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2011-03-14 17:17:37 UTC (rev 15476)
+++ trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2011-03-14 19:35:23 UTC (rev 15477)
@@ -928,25 +928,10 @@
QSettings settings;
// If possible, set the item currently displayed database
QString toSelect = settings.value( "/PostgreSQL/connections/selected" ).toString();
- // Does toSelect exist in cmbConnections?
- bool set = false;
- for ( int i = 0; i < cmbConnections->count(); ++i )
- if ( cmbConnections->itemText( i ) == toSelect )
- cmbConnections->setCurrentIndex( i );
- set = true;
- break;
- // If we couldn't find the stored item, but there are some,
- // default to the last item (this makes some sense when deleting
- // items as it allows the user to repeatidly click on delete to
- // remove a whole lot of items).
- if ( !set && cmbConnections->count() > 0 )
+ cmbConnections->setCurrentIndex( cmbConnections->findText( toSelect ) );
+ if ( cmbConnections->currentIndex() < 0 )
- // If toSelect is null, then the selected connection wasn't found
- // by QSettings, which probably means that this is the first time
- // the user has used qgis with database connections, so default to
- // the first in the list of connetions. Otherwise default to the last.
if ( toSelect.isNull() )
cmbConnections->setCurrentIndex( 0 );
else
Modified: trunk/qgis/src/app/qgsnewhttpconnection.cpp
--- trunk/qgis/src/app/qgsnewhttpconnection.cpp 2011-03-14 17:17:37 UTC (rev 15476)
+++ trunk/qgis/src/app/qgsnewhttpconnection.cpp 2011-03-14 19:35:23 UTC (rev 15477)
@@ -92,5 +92,7 @@
settings.setValue( credentialsKey + "/username", txtUserName->text() );
settings.setValue( credentialsKey + "/password", txtPassword->text() );
+ settings.setValue( mBaseKey + "/selected", txtName->text() );
QDialog::accept();
Modified: trunk/qgis/src/app/qgswmssourceselect.cpp
--- trunk/qgis/src/app/qgswmssourceselect.cpp 2011-03-14 17:17:37 UTC (rev 15476)
+++ trunk/qgis/src/app/qgswmssourceselect.cpp 2011-03-14 19:35:23 UTC (rev 15477)
@@ -1008,31 +1008,18 @@
QSettings settings;
QString toSelect = settings.value( "/Qgis/connections-wms/selected" ).toString();
- bool set = false;
- set = true;
- break;
else
cmbConnections->setCurrentIndex( cmbConnections->count() - 1 );
void QgsWMSSourceSelect::showStatusMessage( QString const &theMessage )
labelStatus->setText( theMessage );
Modified: trunk/qgis/src/app/spatialite/qgsnewspatialitelayerdialog.cpp
--- trunk/qgis/src/app/spatialite/qgsnewspatialitelayerdialog.cpp 2011-03-14 17:17:37 UTC (rev 15476)
+++ trunk/qgis/src/app/spatialite/qgsnewspatialitelayerdialog.cpp 2011-03-14 19:35:23 UTC (rev 15477)
@@ -295,7 +295,7 @@
if ( !settings.contains( key ) )
- settings.setValue( "/SpatiaLite/connections/selected", fi.fileName() );
+ settings.setValue( "/SpatiaLite/connections/selected", fi.fileName() + tr( "@" ) + fi.canonicalFilePath() );
settings.setValue( key, fi.canonicalFilePath() );
QMessageBox::information( 0, tr( "SpatiaLite Database" ), tr( "Registered new database!" ) );
Modified: trunk/qgis/src/app/spatialite/qgsspatialitesourceselect.cpp
--- trunk/qgis/src/app/spatialite/qgsspatialitesourceselect.cpp 2011-03-14 17:17:37 UTC (rev 15476)
+++ trunk/qgis/src/app/spatialite/qgsspatialitesourceselect.cpp 2011-03-14 19:35:23 UTC (rev 15477)
@@ -887,25 +887,11 @@
QSettings settings;
QString toSelect = settings.value( "/SpatiaLite/connections/selected" ).toString();
- bool set = false;
- set = true;
- break;
else
