[QGIS Commit] r15493 - in trunk/qgis: i18n src/plugins/spatialquery
svn_qgis at osgeo.org
Tue Mar 15 03:06:04 EDT 2011
Author: jef
Date: 2011-03-15 00:06:04 -0700 (Tue, 15 Mar 2011)
New Revision: 15493
trunk/qgis/i18n/qgis_de.ts
trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp
translation string fix and german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2011-03-15 06:53:29 UTC (rev 15492)
+++ trunk/qgis/i18n/qgis_de.ts 2011-03-15 07:06:04 UTC (rev 15493)
@@ -5265,11 +5265,11 @@
<message>
<location filename="../src/plugins/evis/idtool/eviseventidtool.cpp" line="76"/>
<location filename="../src/plugins/evis/idtool/eviseventidtool.cpp" line="81"/>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="177"/>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="772"/>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="839"/>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="870"/>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="881"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="186"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="781"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="848"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="879"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="890"/>
<location filename="../src/providers/grass/qgsgrass.cpp" line="981"/>
<location filename="../src/providers/grass/qgsgrass.cpp" line="998"/>
<location filename="../src/providers/grass/qgsgrass.cpp" line="1034"/>
@@ -6014,8 +6014,8 @@
</message>
<message>
<location filename="../src/plugins/spatialquery/qgsspatialquery.cpp" line="102"/>
- <source>Disjoint</source>
- <translation>Außerhalb</translation>
+ <source>Is disjoint</source>
+ <translation>Ist außerhalb</translation>
</message>
<message>
<location filename="../src/plugins/spatialquery/qgsspatialquery.cpp" line="110"/>
@@ -6063,7 +6063,7 @@
<translation>Eine Erweiterung die räumliche Abfragen von Vektorlayern ermöglicht</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="331"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="333"/>
<source>SQLite DB (*.sqlite *.db);;All files (*)</source>
<translation>SQLite DB (*.sqlite *.db);;Alle Dateien (*)</translation>
</message>
@@ -6283,37 +6283,37 @@
<translation>Alle Dateien</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="178"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="187"/>
<source>Cannot get GDAL raster band: %1</source>
<translation>Konnte GDAL-Rasterkanal nicht bestimmen: %1</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="773"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="782"/>
<source>Cannot open GDAL MEM dataset %1: %2</source>
<translation>Konnte GDAL-MEM-Datensatz %1 nicht öffnen: %2</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="840"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="849"/>
<source>Cannot GDALCreateGenImgProjTransformer: </source>
<translation>GDALCreateGenImgProjTransformer-Fehler: </translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="871"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="880"/>
<source>Cannot inittialize GDALWarpOperation : </source>
<translation>GDALWarpOperation-Initialisierungsfehler: </translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="882"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="891"/>
<source>Cannot ChunkAndWarpImage: %1</source>
<translation>ChungAndWarpImage-Fehler: %1</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1648"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1657"/>
<source>[GDAL] All files (*)</source>
<translation>[GDAL] Alle Dateien (*)</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1806"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1815"/>
<source>This raster file has no bands and is invalid as a raster layer.</source>
<translation>Diese Rasterdatei hat keine Kanäle und ist als Rasterlayer ungültig.</translation>
</message>
@@ -12005,27 +12005,43 @@
<translation>Löschen</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="82"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="83"/>
+ <source>Load</source>
+ <comment>Load connections from file</comment>
+ <translation>Laden</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="90"/>
+ <source>Save connections to file</source>
+ <translation>Verbindungen in Datei speichern</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="93"/>
+ <source>Save</source>
+ <translation>Speichern</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="112"/>
<source>Also list tables with no geometry</source>
<translation>Auch geometrielose Tabelle anzeigen</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="89"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="119"/>
<source>Search options</source>
<translation>Suchoptionen</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="113"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="143"/>
<source>Search</source>
<translation>Suchen</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="126"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="156"/>
<source>Search mode</source>
<translation>Suchmodus</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="146"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="176"/>
<source>Search in columns</source>
<translation>In Spalten suchen</translation>
</message>
@@ -13643,52 +13659,52 @@
<context>
<name>QgsGdalProvider</name>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="385"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="394"/>
<source>Dataset Description</source>
<translation>Datensatzbeschreibung</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="406"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="415"/>
<source>Band %1</source>
<translation>Kanal %1</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="437"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="446"/>
<source>Dimensions:</source>
<translation>Dimensionen:</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="440"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="449"/>
<source>X: %1 Y: %2 Bands: %3</source>
<translation>X: %1 Y: %2 Kanäle: %3</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="472"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="481"/>
<source>Origin:</source>
<translation>Ursprung:</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="481"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="490"/>
<source>Pixel Size:</source>
<translation>Pixelgröße:</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1059"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1068"/>
<source>out of extent</source>
<translation>außerhalb der Ausdehnung</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1098"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1107"/>
<source>null (no data)</source>
<translation>Null (keine Daten)</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1427"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1436"/>
<source>Average Magphase</source>
<translation>Durchschnittliche Magphase</translation>
</message>
<message>
- <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1432"/>
+ <location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1441"/>
<source>Average</source>
<translation>Durchschnittlich</translation>
</message>
@@ -22288,112 +22304,96 @@
<translation>&Hinzufügen</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="65"/>
- <source>&Save</source>
- <translation>&Speichern</translation>
- </message>
- <message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="66"/>
- <source>Save connections</source>
- <translation>Verbindungen speichern</translation>
- </message>
- <message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="70"/>
- <source>&Load</source>
- <translation>&Laden</translation>
- </message>
- <message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="71"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="177"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="166"/>
<source>Load connections</source>
<translation>Verbindungen laden</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="78"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="243"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="67"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="232"/>
<source>Wildcard</source>
<translation>Platzhalter</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="79"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="247"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="68"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="236"/>
<source>RegExp</source>
<translation>RegAusdr</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="81"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="255"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="70"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="244"/>
<source>All</source>
<translation>Alle</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="82"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="259"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="71"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="248"/>
<source>Schema</source>
<translation>Schema</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="83"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="263"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="72"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="252"/>
<source>Table</source>
<translation>Tabelle</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="84"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="267"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="73"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="256"/>
<source>Type</source>
<translation>Typ</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="85"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="271"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="74"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="260"/>
<source>Geometry column</source>
<translation>Geometriespalte</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="86"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="275"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="75"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="264"/>
<source>Primary key column</source>
<translation>Primärschlüsselspalte</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="87"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="279"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="76"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="268"/>
<source>Sql</source>
<translation>SQL</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="145"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="134"/>
<source>Are you sure you want to remove the %1 connection and all associated settings?</source>
<translation>Sind Sie sicher, dass Sie die Verbindung %1 und alle zugehörigen Einstellungen löschen wollen?</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="147"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="136"/>
<source>Confirm Delete</source>
<translation>Löschen bestätigen</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="178"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="167"/>
<source>XML files (*.xml *XML)</source>
<translation>XML-Dateien (*.xml *.XML)</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="422"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="411"/>
<source>Select Table</source>
<translation>Tabelle wählen</translation>
</message>
<message>
<source>You must select a table in order to add a layer.</source>
<translation>Um einen Layer hinzuzufügen, muss eine Tabelle gewählt sein.</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="555"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="544"/>
<source>Connection failed</source>
<translation>Verbindungsfehler</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="556"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="545"/>
<source>Connection to %1 on %2 failed. Either the database is down or your settings are incorrect.
Check your username and password and try again.
@@ -22408,20 +22408,20 @@
%3</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="756"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="816"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="878"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="745"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="805"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="867"/>
<source>Accessible tables could not be determined</source>
<translation>Zugreifbare Tabellen konnten nicht festgestellt werden</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="757"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="746"/>
<source>Database connection was successful, but the accessible tables could not be determined.</source>
<translation>Die Datenbankverbindung war erfolgreich, jedoch konnten die zugänglichen Tabelle nicht bestimmt werden.</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="817"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="879"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="806"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="868"/>
The error message from the database was:
@@ -22434,22 +22434,22 @@
</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="843"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="832"/>
<source>Waiting</source>
<translation>Wartend</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="895"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="884"/>
<source>No geometry</source>
<translation>Keine Geometrie</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="907"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="896"/>
<source>No accessible tables found</source>
<translation>Keine zugänglichen Tabellen gefunden</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="908"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="897"/>
<source>Database connection was successful, but no accessible tables were found.
Please verify that you have SELECT privilege on a table carrying PostGIS
@@ -27125,68 +27125,68 @@
<translation>Datenbanken</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="55"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="57"/>
<source>&Build Query</source>
<translation>&Abfrage erstellen</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="50"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="52"/>
<source>&Add</source>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="62"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="126"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="64"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="128"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="63"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="130"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="65"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="132"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="65"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="138"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="67"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="140"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="66"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="142"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="68"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="144"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="67"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="146"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="69"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="148"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="68"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="150"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="70"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="152"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="69"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="154"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="71"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="156"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="204"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="272"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="286"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="206"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="274"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="288"/>
<source>SpatiaLite DB Open Error</source>
<translation>SpatiaLite-DB-Fehler beim Öffnen</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="205"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="273"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="287"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="207"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="275"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="289"/>
<source>Failure while connecting to: %1
%2</source>
@@ -27195,56 +27195,56 @@
%2</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="271"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="273"/>
<source>seems to be a valid SQLite DB, but not a SpatiaLite's one ...</source>
<translation>scheint eine gültige SQLite-DB zu sein, jedoch ohne SpatiaLite ...</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="280"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="656"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="860"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="282"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="658"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="862"/>
<source>unknown error cause</source>
<translation>unbekannte Fehlerursache</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="308"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="310"/>
<source>@</source>
<translation>@</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="330"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="332"/>
<source>Choose a SpatiaLite/SQLite DB to open</source>
<translation>Zu öffnende SpatiaLite/SQLite-DB wählen</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="410"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="412"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="412"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="414"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="459"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="461"/>
</message>
<message>
<source>You must select a table in order to add a Layer.</source>
<translation>Zum Hinzufügen eines Layers müssen Sie eine Tabelle wählen.</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="662"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="866"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="664"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="868"/>
<source>SpatiaLite getTableInfo Error</source>
<translation>SpatiaLite-getTableInfo-Fehler</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="663"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="867"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="665"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="869"/>
<source>Failure exploring tables from: %1
%2</source>
@@ -27308,19 +27308,8 @@
</context>
<context>
<name>QgsSpatialQueryDialog</name>
- <message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="47"/>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="64"/>
- <source>The spatial query requires at least two layers</source>
- <translation>Für die räumliche Abfrage werden mindestens zwei Layer benötigt</translation>
- </message>
- <message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="65"/>
- <source>Insufficient number of layers</source>
- <translation>Nicht ausreichende Layeranzahl</translation>
- </message>
<message numerus="yes">
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="138"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="164"/>
<source>%n selected geometries</source>
<comment>selected geometries</comment>
<translation>
@@ -27329,130 +27318,135 @@
</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="139"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="165"/>
<source>Selected geometries</source>
<translation>Gewählte Geometrien</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="183"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="209"/>
<source>< %1 ></source>
<translation>< %1 ></translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="293"/>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="322"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="319"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="348"/>
<source>%1 of %2</source>
<translation>%1 von %2</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="294"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="320"/>
<source>all = %1</source>
<translation>alle = %1</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="176"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="202"/>
<source>%1)Query</source>
<translation>%1)Abfrage</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="178"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="85"/>
+ <source>The spatial query requires at least two vector layers</source>
+ <translation>Für die räumliche Abfrage werden mindestens zwei Layer benötigt</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="204"/>
<source>Begin at %L1</source>
<translation>Bei %L1 beginnen</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="187"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="213"/>
<source>Total of features = %1</source>
<translation>Gesamtzahl der Objekte = %1</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="190"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="216"/>
<source>Total of invalid features:</source>
<translation>Gesamtzahl ungültiger Objekte:</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="195"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="221"/>
<source>Finish at %L1 (processing time %L2 minutes)</source>
<translation>Beendet bei %L1 (Verarbeitungszeit %L2 Minuten)</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="258"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="284"/>
<source>Using the field "%1" for subset</source>
<translation>Feld "%1" wird für Untermegen benutzt</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="261"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="287"/>
<source>Sorry! Only this providers are enable: OGR, POSTGRES and SPATIALITE.</source>
<translation>Entschuldigung! Nur diese Datenlieferung sind unterstützt: OGR, Postgres und SpatiaLite.</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="321"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="347"/>
<source>%1 of %2(selected features)</source>
<translation>%1 von %2 (gewählte Objekte)</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="486"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="512"/>
<source>Create new selection</source>
<translation>Neue Auswahl erzeugen</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="494"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="520"/>
<source>Add to current selection</source>
<translation>Zu aktuellen Auswahl hinzufügen</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="497"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="523"/>
<source>Remove from current selection</source>
<translation>Aus aktueller Auswahl entfernen</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="506"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="532"/>
<source>Result query</source>
<translation>Abfrageergebnis</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="508"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="534"/>
<source>Invalid source</source>
<translation>Ungültige Quelle</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="510"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="536"/>
<source>Invalid reference</source>
<translation>Ungültiges Bezugssystem</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="624"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="650"/>
<source>%1 of %2 selected by "%3"</source>
<translation>%1 von %2 durch "%3" gewählt</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="627"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="653"/>
<source>user</source>
<translation>Benutzer</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="679"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="705"/>
<source>Map "%1" "on the fly" transformation.</source>
<translation>Karte "%1" "On-The-Fly"-Transformation.</translation>
</message>
<message>
<source>enable</source>
<translation>einschalten</translation>
</message>
<message>
<source>disable</source>
<translation>abschalten</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="680"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="706"/>
<source>Coordinate reference system(CRS) of
"%1" is invalid(see CRS of provider).</source>
<translation>Koordinatenbezugssystem (KBS) von
"%1" is ungültig (siehe KBS des Datenlieferanten).</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="681"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="707"/>
<source>
CRS of map is %1.
@@ -27463,53 +27457,53 @@
%2.</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="684"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="710"/>
<source>Zoom to feature</source>
<translation>Zum Objekt zoomen</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="723"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="749"/>
<source>Missing reference layer</source>
<translation>Referenzlayer fehlt</translation>
</message>
<message>
<source>Select reference layer!</source>
<translation>Wählen Sie einen Referenzlayer!</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="728"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="754"/>
<source>Missing target layer</source>
<translation>Ziellayer fehlt</translation>
</message>
<message>
<source>Select target layer!</source>
<translation>Wählen Sie einen Ziellayer!</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="799"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="825"/>
<source>Create new layer from items</source>
<translation>Neuen Layer aus den Elementen erzeugen</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="817"/>
<location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="843"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="869"/>
<source>The query from "%1" using "%2" in field not possible.</source>
<translation>Die Abfrage von "%1" mit dem "%2" Feld ist nicht möglich.</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="825"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="851"/>
<source>Create new layer from selected</source>
<translation>Neuen Layer aus der Auswahl erzeugen</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="932"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="958"/>
<source>%1 of %2 identified</source>
<translation>%1 von %2 identifiziert</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="1075"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="1101"/>
<source>DEBUG</source>
<translation>DEBUG</translation>
</message>
@@ -27533,6 +27527,11 @@
<translation>Ziellayer wählen</translation>
</message>
<message>
+ <location filename="../src/plugins/spatialquery/qgsspatialquerydialogbase.ui" line="242"/>
+ <source>Result feature ID's</source>
+ <translation>Kennungen der Ergebnisobjekte</translation>
+ </message>
+ <message>
<location filename="../src/plugins/spatialquery/qgsspatialquerydialogbase.ui" line="350"/>
<source>Check to show log processing of query</source>
<translation>Abhaken um das Abfrageverarbeitungsprotokoll anzuzeigen</translation>
@@ -27620,11 +27619,6 @@
<translation>Layer mit gewählten erzeugen</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialquerydialogbase.ui" line="242"/>
- <source>FIDs identified</source>
- <translation>FIDs identifiziert</translation>
- </message>
- <message>
<location filename="../src/plugins/spatialquery/qgsspatialquerydialogbase.ui" line="273"/>
<source>Select one FID to identify geometry of feature</source>
<translation>Eine Objektkennung wählen, um die Geometrie des Objekts festzulegen</translation>
@@ -27660,7 +27654,12 @@
<translation>&Räumliche Abfrage</translation>
</message>
<message>
- <location filename="../src/plugins/spatialquery/qgsspatialqueryplugin.cpp" line="159"/>
+ <location filename="../src/plugins/spatialquery/qgsspatialqueryplugin.cpp" line="113"/>
+ <source>Query not executed</source>
+ <translation>Abfrage ist nicht ausführbar</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/spatialquery/qgsspatialqueryplugin.cpp" line="160"/>
</message>
@@ -30445,77 +30444,57 @@
<context>
<name>QgsWFSSourceSelect</name>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="288"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="278"/>
<source>Error</source>
<translation>Fehler</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="279"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="269"/>
<source>No Layers</source>
<translation>Keine Layer</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="49"/>
- </message>
- <message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="50"/>
- <source>Save WFS server connections to file</source>
- <translation>WFS-Serververbindungen in Datei speichern</translation>
- </message>
- <message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="54"/>
- </message>
- <message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="55"/>
- <source>Load WFS server connections from file</source>
- <translation>WFS-Serververbindungen aus Datei laden</translation>
- </message>
- <message>
<source>capabilities document contained no layers.</source>
<translation>Capabilities-Dokument enthielt keine Layer.</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="293"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="283"/>
<source>Capabilities document is not valid</source>
<translation>Capabilities-Dokument ist ungültig</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="298"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="288"/>
<source>GetCapabilities Error</source>
<translation>GetCapabilities-Fehler</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="313"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="303"/>
<source>Create a new WFS connection</source>
<translation>Neue WFS-Verbindung anlegen</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="324"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="314"/>
<source>Modify WFS connection</source>
<translation>WFS-Verbindung ändern</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="336"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="326"/>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="338"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="328"/>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="480"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="470"/>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="481"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="471"/>
</message>
@@ -30528,27 +30507,47 @@
<translation>WFS-Layer des Servers hinzufügen</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="95"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="84"/>
+ <source>Load connections from file</source>
+ <translation>Verbindungen aus Datei laden</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="87"/>
+ </message>
+ <message>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="94"/>
+ </message>
+ <message>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="97"/>
+ </message>
+ <message>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="113"/>
<source>Title</source>
<translation>Titel</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="100"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="118"/>
<source>Name</source>
<translation>Name</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="105"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="123"/>
<source>Abstract</source>
<translation>Zusammenfassung</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="113"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="131"/>
<source>Coordinate reference system</source>
<translation>Koordinatenbezugssystem</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="161"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="179"/>
<source>Only request features overlapping the current view extent</source>
<translation>Nur Objekte, die den aktuellen Ausschnitt schneiden laden</translation>
</message>
@@ -30558,27 +30557,27 @@
<translation>Serververbindungen</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="151"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="169"/>
<source>Change ...</source>
<translation>Ändern...</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="32"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="41"/>
<source>&New</source>
<translation>&Neu</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="42"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="61"/>
<source>Delete</source>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="52"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="51"/>
<source>Edit</source>
<translation>Bearbeiten</translation>
</message>
<message>
- <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="78"/>
+ <location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="34"/>
<source>C&onnect</source>
<translation>&Verbinden</translation>
</message>
@@ -30625,69 +30624,49 @@
<translation>Gewählte Layer zur Karte hinzufügen</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="65"/>
- </message>
- <message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="66"/>
- <source>Save WMS server connections to file</source>
- <translation>WMS-Serververbindungen in Datei speichern</translation>
- </message>
- <message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="70"/>
- </message>
- <message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="71"/>
- <source>Load WMS server connections from file</source>
- <translation>WMS-Serververbindungen aus Datei laden</translation>
- </message>
- <message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="235"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="225"/>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="237"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="227"/>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="404"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="394"/>
<source>encoding %1 not supported.</source>
<translation>Zeichenkodierung %1 nicht unterstützt.</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="410"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="400"/>
<source>CRS %1 not supported.</source>
<translation>KBS %1 nicht unterstützt.</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="503"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="493"/>
<source>WMS Password for %1</source>
<translation>WMS-Passwort für %1</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="429"/>
- <location filename="../src/app/qgswmssourceselect.cpp" line="457"/>
- <location filename="../src/app/qgswmssourceselect.cpp" line="542"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="419"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="447"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="532"/>
<source>WMS Provider</source>
<translation>WMS-Provider</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="255"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="245"/>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="256"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="246"/>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="430"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="420"/>
<source>Advertised GetMap URL
%2
@@ -30707,7 +30686,7 @@
Dies könnte ein Serverkonfigurationsfehler sein. Sollte die URL benutzt werden?</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="458"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="448"/>
<source>Advertised GetFeatureInfo URL
%2
@@ -30727,13 +30706,13 @@
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="543"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="533"/>
<source>Could not open the WMS Provider</source>
<translation>Konnte WMS-Provider nicht öffnen</translation>
</message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="836"/>
- <location filename="../src/app/qgswmssourceselect.cpp" line="936"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="826"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="926"/>
<source>Coordinate Reference System (%n available)</source>
<comment>crs count</comment>
<translation>
@@ -30742,37 +30721,37 @@
</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="924"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="914"/>
<source>Select layer(s)</source>
<translation>Layer wählen</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="926"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="916"/>
<source>Select layer(s) or a tileset</source>
<translation>Layer oder Tileset wählen</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="931"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="921"/>
<source>Select either layer(s) or a tileset</source>
<translation>Bitte Layer oder ein Tileset wählen</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="943"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="933"/>
<source>No common CRS for selected layers.</source>
<translation>Kein gemeinsames KBS für gewählte Layer.</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="948"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="938"/>
<source>No CRS selected</source>
<translation>Kein KBS gewählt</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="953"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="943"/>
<source>No image encoding selected</source>
<translation>Keine Bildkodierung gewählt</translation>
</message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="958"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="948"/>
<source>%n Layer(s) selected</source>
<comment>selected layer count</comment>
<translation>
@@ -30781,44 +30760,44 @@
</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="964"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="954"/>
<source>Tileset selected</source>
<translation>Tileset gewählt</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="1043"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="1033"/>
<source>Could not understand the response. The %1 provider said:
%2</source>
<translation>Antwort nicht verstanden. Der %1-Provider sagte:
%2</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="1096"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="1086"/>
<source>WMS proxies</source>
<translation>WMS-Proxys</translation>
</message>
<message>
<source>Several WMS servers have been added to the server list. Note that if you access the internet via a web proxy, you will need to set the proxy settings in the QGIS options dialog.</source>
<translation>Mehrere WMS-Server wurden der Serverliste hinzugefügt. Beachten Sie bitte, dass Sie ggf. noch die Proxyeinstellungen in den QGIS-Optionen einstellen müssen.</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="1172"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="1162"/>
<source>parse error at row %1, column %2: %3</source>
<translation>Fehler in Zeile %1, Spalte %2: %3</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="1177"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="1167"/>
<source>network error: %1</source>
<translation>Netzwerkfehler: %1</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="1200"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="1190"/>
<source>The %1 connection already exists. Do you want to overwrite it?</source>
<translation>Soll die bereits existierende Verbindung %1 überschrieben werden?</translation>
</message>
<message>
- <location filename="../src/app/qgswmssourceselect.cpp" line="1201"/>
+ <location filename="../src/app/qgswmssourceselect.cpp" line="1191"/>
<source>Confirm Overwrite</source>
<translation>Überschreiben bestätigen</translation>
</message>
@@ -30831,170 +30810,190 @@
<translation>Layer eines Servers hinzufügen</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="49"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="21"/>
+ </message>
+ <message>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="75"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="56"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="82"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="66"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="92"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="76"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="102"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="96"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="122"/>
<source>Adds a few example WMS servers</source>
<translation>Fügt einige Beispiel-WMS-Server hinzu</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="102"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="128"/>
<source>Add default servers</source>
<translation>Vorgegebene Server ergänzen</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="122"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="148"/>
<source>ID</source>
<translation>ID</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="127"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="153"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="132"/>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="371"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="158"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="408"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="137"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="163"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="205"/>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="215"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="231"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="241"/>
<source>Use base url instead of advertised GetFeatureInfo URL</source>
<translation>Basis-URL statt der gemeldeten GetFeatureInfo-URL benutzen</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="208"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="234"/>
<source>Ignore GetMap URL</source>
<translation>GetMap-URL ignorieren</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="218"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="244"/>
<source>Ignore GetFeatureInfo URL</source>
<translation>GetFeatureInfo-URL ignorieren</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="231"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="256"/>
+ </message>
+ <message>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="263"/>
+ </message>
+ <message>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="266"/>
+ </message>
+ <message>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="274"/>
<source>Layer Order</source>
<translation>Layerreihenfolge</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="268"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="311"/>
<source>Layer</source>
<translation>Layer</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="273"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="316"/>
<source>Style</source>
<translation>Stil</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="336"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="376"/>
<source>Server Search</source>
<translation>Serversuche</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="345"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="385"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="381"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="418"/>
<source>URL</source>
<translation>URL</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="376"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="413"/>
<source>Description</source>
<translation>Beschreibung</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="389"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="426"/>
<source>Add selected row to WMS list</source>
<translation>Gewählte Zeile der WMS-Liste hinzufügen</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="157"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="183"/>
<source>Image encoding</source>
<translation>Bildkodierung</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="37"/>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="307"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="63"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="347"/>
<source>Layers</source>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="164"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="190"/>
<source>Options</source>
<translation>Optionen</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="170"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="196"/>
<source>Layer name</source>
<translation>Layername</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="183"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="209"/>
<source>Coordinate Reference System</source>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="196"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="222"/>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="282"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="325"/>
<source>Tilesets</source>
<translation>Tilesets</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="312"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="352"/>
<source>Styles</source>
<translation>Stile</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="317"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="357"/>
<source>Size</source>
<translation>Größe</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="322"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="362"/>
<source>Format</source>
<translation>Format</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="327"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="367"/>
<source>CRS</source>
<translation>KBS</translation>
</message>
<message>
- <location filename="../src/ui/qgswmssourceselectbase.ui" line="413"/>
+ <location filename="../src/ui/qgswmssourceselectbase.ui" line="46"/>
<source>Ready</source>
<translation>Fertig</translation>
</message>
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp 2011-03-15 06:53:29 UTC (rev 15492)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp 2011-03-15 07:06:04 UTC (rev 15493)
@@ -16,7 +16,7 @@
* (at your option) any later version. *
-/* $Id: qgsspatialqueryplugin.cpp 15302 2011-03-01 08:00:54Z timlinux $ */
+/* $Id$ */
@@ -110,7 +110,7 @@
QString msg;
if ( ! QgsSpatialQueryDialog::hasPossibleQuery( msg ) )
- QMessageBox::warning( mIface->mainWindow(), tr( "Not possible execute the query" ), msg, QMessageBox::Ok );
+ QMessageBox::warning( mIface->mainWindow(), tr( "Query not executed" ), msg, QMessageBox::Ok );
return;
mDialog = new QgsSpatialQueryDialog( mIface->mainWindow(), mIface );
