[QGIS Commit] r15495 - in trunk/qgis/python/plugins/GdalTools: .
icons tools
svn_qgis at osgeo.org
Tue Mar 15 07:40:46 EDT 2011
Author: brushtyler
Date: 2011-03-15 04:40:45 -0700 (Tue, 15 Mar 2011)
New Revision: 15495
Added:
trunk/qgis/python/plugins/GdalTools/icons/dem.png
trunk/qgis/python/plugins/GdalTools/tools/doDEM.py
trunk/qgis/python/plugins/GdalTools/tools/widgetDEM.ui
trunk/qgis/python/plugins/GdalTools/GdalTools.py
trunk/qgis/python/plugins/GdalTools/__init__.py
trunk/qgis/python/plugins/GdalTools/resources.qrc
trunk/qgis/python/plugins/GdalTools/tools/doGrid.py
[FEATURE] added GUI for gdaldem, to fix #3064
Modified: trunk/qgis/python/plugins/GdalTools/GdalTools.py
--- trunk/qgis/python/plugins/GdalTools/GdalTools.py 2011-03-15 07:22:35 UTC (rev 15494)
+++ trunk/qgis/python/plugins/GdalTools/GdalTools.py 2011-03-15 11:40:45 UTC (rev 15495)
@@ -198,10 +198,16 @@
self.menu.addAction(self.rgb)
self.tileindex = QAction( QIcon( ":icons/tileindex.png" ), QCoreApplication.translate( "GdalTools", "Tile index" ), self.iface.mainWindow() )
- self.rgb.setStatusTip( QCoreApplication.translate( "GdalTools", "Build a shapefile as a raster tileindex" ) )
+ self.tileindex.setStatusTip( QCoreApplication.translate( "GdalTools", "Build a shapefile as a raster tileindex" ) )
QObject.connect( self.tileindex, SIGNAL( "triggered()" ), self.doTileIndex )
self.menu.addAction(self.tileindex)
+ if self.GdalVersion >= "1.7":
+ self.dem = QAction( QIcon( ":icons/dem.png" ), QCoreApplication.translate( "GdalTools", "DEM" ), self.iface.mainWindow() )
+ self.dem.setStatusTip( QCoreApplication.translate( "GdalTools", "Tool to analyze and visualize DEMs" ) )
+ QObject.connect( self.dem, SIGNAL( "triggered()" ), self.doDEM )
+ self.menu.addAction(self.dem)
self.settings = QAction( QCoreApplication.translate( "GdalTools", "GdalTools settings" ), self.iface.mainWindow() )
self.settings.setStatusTip( QCoreApplication.translate( "GdalTools", "Various settings for Gdal Tools" ) )
QObject.connect( self.settings, SIGNAL( "triggered()" ), self.doSettings )
@@ -311,6 +317,11 @@
d = TileIndex( self.iface )
d.show_()
+ def doDEM( self ):
+ from tools.doDEM import GdalToolsDialog as DEM
+ d = DEM( self.iface )
+ d.show_()
def doSettings( self ):
from tools.doSettings import GdalToolsSettingsDialog as Settings
d = Settings( self.iface )
Modified: trunk/qgis/python/plugins/GdalTools/__init__.py
--- trunk/qgis/python/plugins/GdalTools/__init__.py 2011-03-15 07:22:35 UTC (rev 15494)
+++ trunk/qgis/python/plugins/GdalTools/__init__.py 2011-03-15 11:40:45 UTC (rev 15495)
@@ -22,7 +22,7 @@
def description():
return "Integrate gdal tools into qgis"
def version():
- return "Version 1.2.23"
+ return "Version 1.2.24"
def qgisMinimumVersion():
return "1.0"
def icon():
Added: trunk/qgis/python/plugins/GdalTools/icons/dem.png
(Binary files differ)
Property changes on: trunk/qgis/python/plugins/GdalTools/icons/dem.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/qgis/python/plugins/GdalTools/resources.qrc
--- trunk/qgis/python/plugins/GdalTools/resources.qrc 2011-03-15 07:22:35 UTC (rev 15494)
+++ trunk/qgis/python/plugins/GdalTools/resources.qrc 2011-03-15 11:40:45 UTC (rev 15495)
@@ -1,23 +1,24 @@
<RCC>
- <qresource>
- <file>icons/contour.png</file>
- <file>icons/merge.png</file>
- <file>icons/polygonize.png</file>
- <file>icons/rasterize.png</file>
- <file>icons/sieve.png</file>
- <file>icons/vrt.png</file>
- <file>icons/warp.png</file>
- <file>icons/proximity.png</file>
- <file>icons/nearblack.png</file>
- <file>icons/grid.png</file>
- <file>icons/translate.png</file>
- <file>icons/raster-info.png</file>
- <file>icons/projection-add.png</file>
- <file>icons/raster-overview.png</file>
- <file>icons/raster-clip.png</file>
- <file>icons/raster-paletted.png</file>
- <file>icons/raster-rgb.png</file>
- <file>icons/tileindex.png</file>
- <file>icons/about.png</file>
- </qresource>
+ <qresource prefix="/" >
+ <file>icons/contour.png</file>
+ <file>icons/merge.png</file>
+ <file>icons/polygonize.png</file>
+ <file>icons/rasterize.png</file>
+ <file>icons/sieve.png</file>
+ <file>icons/vrt.png</file>
+ <file>icons/warp.png</file>
+ <file>icons/proximity.png</file>
+ <file>icons/nearblack.png</file>
+ <file>icons/grid.png</file>
+ <file>icons/translate.png</file>
+ <file>icons/raster-info.png</file>
+ <file>icons/projection-add.png</file>
+ <file>icons/raster-overview.png</file>
+ <file>icons/raster-clip.png</file>
+ <file>icons/raster-paletted.png</file>
+ <file>icons/raster-rgb.png</file>
+ <file>icons/tileindex.png</file>
+ <file>icons/about.png</file>
+ <file>icons/dem.png</file>
+ </qresource>
</RCC>
Added: trunk/qgis/python/plugins/GdalTools/tools/doDEM.py
--- trunk/qgis/python/plugins/GdalTools/tools/doDEM.py (rev 0)
+++ trunk/qgis/python/plugins/GdalTools/tools/doDEM.py 2011-03-15 11:40:45 UTC (rev 15495)
@@ -0,0 +1,144 @@
+# -*- coding: utf-8 -*-
+from PyQt4.QtCore import *
+from PyQt4.QtGui import *
+from qgis.core import *
+from qgis.gui import *
+from ui_widgetDEM import Ui_GdalToolsWidget as Ui_Widget
+from widgetPluginBase import GdalToolsBasePluginWidget as BasePluginWidget
+import GdalTools_utils as Utils
+class GdalToolsDialog(QWidget, Ui_Widget, BasePluginWidget):
+ def __init__(self, iface):
+ QWidget.__init__(self)
+ self.iface = iface
+ self.modes = ("hillshade", "slope", "aspect", "color-relief", "TRI", "TPI", "roughness")
+ self.setupUi(self)
+ BasePluginWidget.__init__(self, self.iface, "gdaldem")
+ # set the default QSpinBoxes and QProgressBar value
+ self.bandSpin.setValue(1)
+ self.hillshadeZFactorSpin.setValue(1)
+ self.hillshadeScaleSpin.setValue(1)
+ self.hillshadeAltitudeSpin.setValue(45.0)
+ self.hillshadeAzimuthSpin.setValue(315.0)
+ self.slopeScaleSpin.setValue(1)
+ self.outputFormat = Utils.fillRasterOutputFormat()
+ self.setParamsStatus(
+ (self.inputLayerCombo, [SIGNAL("currentIndexChanged(int)"), SIGNAL("editTextChanged(const QString &)")] ),
+ (self.outputFileEdit, SIGNAL("textChanged(const QString &)")),
+ (self.computeEdgesCheck, SIGNAL("stateChanged(int)"), None, "1.8.0"),
+ (self.bandSpin, SIGNAL("valueChanged(int)"), self.bandCheck),
+ (self.creationOptionsTable, [SIGNAL("cellValueChanged(int, int)"), SIGNAL("rowRemoved()")], self.creationGroupBox),
+ (self.modeCombo, SIGNAL("currentIndexChanged(int)")),
+ ([self.hillshadeZFactorSpin, self.hillshadeScaleSpin, self.hillshadeAltitudeSpin, self.hillshadeAzimuthSpin], SIGNAL("valueChanged(double)")),
+ (self.slopeScaleSpin, SIGNAL("valueChanged(double)")),
+ (self.slopePercentCheck, SIGNAL("stateChanged(int)")),
+ ([self.aspectTrigonometricCheck, self.aspectZeroForFlatCheck], SIGNAL("stateChanged(int)")),
+ (self.colorConfigFileEdit, SIGNAL("textChanged(const QString &)")),
+ ([self.colorExactRadio, self.colorNearestRadio], SIGNAL("toggled(bool)"), self.colorMatchGroupBox),
+ (self.colorAlphaCheck, SIGNAL("stateChanged(int)"))
+ self.connect(self.selectInputFileButton, SIGNAL("clicked()"), self.fillInputFileEdit)
+ self.connect(self.selectOutputFileButton, SIGNAL("clicked()"), self.fillOutputFileEdit)
+ self.connect(self.colorSelectConfigFileButton, SIGNAL("clicked()"), self.fillColorConfigFileEdit)
+ self.connect(self.modeCombo, SIGNAL("currentIndexChanged(int)"), self.showModeParams)
+ def showModeParams(self, index):
+ self.stackedWidget.setVisible( index < 4 )
+ def onLayersChanged(self):
+ self.fillInputLayerCombo()
+ def fillInputLayerCombo(self):
+ self.inputLayerCombo.clear()
+ ( self.layers, names ) = Utils.LayerRegistry.instance().getRasterLayers()
+ self.inputLayerCombo.addItems( names )
+ def fillInputFileEdit(self):
+ lastUsedFilter = Utils.FileFilter.lastUsedRasterFilter()
+ inputFile = Utils.FileDialog.getOpenFileName(self, self.tr( "Select the file for DEM" ), Utils.FileFilter.allRastersFilter(), lastUsedFilter)
+ if inputFile.isEmpty():
+ return
+ Utils.FileFilter.setLastUsedRasterFilter(lastUsedFilter)
+ self.inputLayerCombo.setCurrentIndex(-1)
+ self.inputLayerCombo.setEditText(inputFile)
+ def fillOutputFileEdit(self):
+ outputFile = Utils.FileDialog.getSaveFileName(self, self.tr( "Select the raster file to save the results to" ), Utils.FileFilter.allRastersFilter(), lastUsedFilter )
+ if outputFile.isEmpty():
+ return
+ self.outputFormat = Utils.fillRasterOutputFormat( lastUsedFilter, outputFile )
+ self.outputFileEdit.setText(outputFile)
+ def fillColorConfigFileEdit(self):
+ configFile = Utils.FileDialog.getOpenFileName(self, self.tr( "Select the color configuration file" ), "*")
+ if configFile.isEmpty():
+ return
+ self.colorConfigFileEdit.setText(configFile)
+ def getArguments(self):
+ mode = self.modes[ self.modeCombo.currentIndex() ]
+ arguments = QStringList()
+ arguments << mode
+ arguments << self.getInputFileName()
+ if mode == "color-relief":
+ arguments << self.colorConfigFileEdit.text()
+ arguments << self.outputFileEdit.text()
+ if mode == "hillshade":
+ arguments << "-z" << str(self.hillshadeZFactorSpin.value())
+ arguments << "-s" << str(self.hillshadeScaleSpin.value())
+ arguments << "-az" << str(self.hillshadeAzimuthSpin.value())
+ arguments << "-alt" << str(self.hillshadeAltitudeSpin.value())
+ elif mode == "slope":
+ if self.slopePercentCheck.isChecked():
+ arguments << "-p"
+ arguments << "-s" << str(self.slopeScaleSpin.value())
+ elif mode == "aspect":
+ if self.aspectTrigonometricCheck.isChecked():
+ arguments << "-trigonometric"
+ if self.aspectZeroForFlatCheck.isChecked():
+ arguments << "-zero_for_flat"
+ elif mode == "color-relief":
+ if self.colorAlphaCheck.isChecked():
+ arguments << "-alpha"
+ if self.colorMatchGroupBox.isChecked():
+ if self.colorExactRadio.isChecked():
+ arguments << "-exact_color_entry"
+ elif self.colorNearestRadio.isChecked():
+ arguments << "-nearest_color_entry"
+ if self.computeEdgesCheck.isChecked():
+ arguments << "-compute_edges"
+ if self.bandCheck.isChecked():
+ arguments << "-b" << str(self.bandSpin.value())
+ if not self.outputFileEdit.text().isEmpty():
+ arguments << "-of" << self.outputFormat
+ if self.creationGroupBox.isChecked():
+ for opt in self.creationOptionsTable.options():
+ arguments << "-co" << opt
+ return arguments
+ def getInputFileName(self):
+ if self.inputLayerCombo.currentIndex() >= 0:
+ return self.layers[self.inputLayerCombo.currentIndex()].source()
+ return self.inputLayerCombo.currentText()
+ def getOutputFileName(self):
+ return self.outputFileEdit.text()
+ def addLayerIntoCanvas(self, fileInfo):
+ self.iface.addRasterLayer(fileInfo.filePath())
Modified: trunk/qgis/python/plugins/GdalTools/tools/doGrid.py
--- trunk/qgis/python/plugins/GdalTools/tools/doGrid.py 2011-03-15 07:22:35 UTC (rev 15494)
+++ trunk/qgis/python/plugins/GdalTools/tools/doGrid.py 2011-03-15 11:40:45 UTC (rev 15495)
@@ -39,7 +39,7 @@
(self.zfieldCombo, SIGNAL("currentIndexChanged(int)"), self.zfieldCheck),
(self.algorithmCombo, SIGNAL("currentIndexChanged(int)"), self.algorithmCheck),
- (self.stackedWidget, SIGNAL("currentChanged(int)"), self.algorithmCheck),
+ (self.stackedWidget, None, self.algorithmCheck),
([self.invdistPowerSpin, self.invdistSmothingSpin, self.invdistRadius1Spin, self.invdistRadius2Spin, self.invdistAngleSpin, self.invdistNoDataSpin], SIGNAL("valueChanged(double)")),
([self.invdistMaxPointsSpin, self.invdistMinPointsSpin], SIGNAL("valueChanged(int)")),
([self.averageRadius1Spin, self.averageRadius2Spin, self.averageAngleSpin, self.averageNoDataSpin], SIGNAL("valueChanged(double)")),
@@ -56,14 +56,14 @@
self.connect(self.inputLayerCombo, SIGNAL("currentIndexChanged(int)"), self.fillFieldsCombo)
- self.connect(self.extentGroup, SIGNAL("toggled(bool)"), self.onExtentCheckedChenged)
+ self.connect(self.extentGroup, SIGNAL("toggled(bool)"), self.onExtentCheckedChanged)
def onClosing(self):
self.extentSelector.stop()
BasePluginWidget.onClosing(self)
- def onExtentCheckedChenged(self, enabled):
+ def onExtentCheckedChanged(self, enabled):
self.extentSelector.start() if enabled else self.extentSelector.stop()
Added: trunk/qgis/python/plugins/GdalTools/tools/widgetDEM.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetDEM.ui (rev 0)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetDEM.ui 2011-03-15 11:40:45 UTC (rev 15495)
@@ -0,0 +1,495 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>GdalToolsWidget</class>
+ <widget class="QWidget" name="GdalToolsWidget">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>418</width>
+ <height>408</height>
+ </rect>
+ </property>
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="windowTitle">
+ <string>DEM</string>
+ </property>
+ <layout class="QVBoxLayout" name="verticalLayout_2">
+ <item>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
+ <widget class="QLabel" name="label">
+ <property name="text">
+ <string>&Input file (DEM raster)</string>
+ </property>
+ <property name="buddy">
+ <cstring>selectInputFileButton</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout">
+ <item>
+ <widget class="QComboBox" name="inputLayerCombo">
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ <property name="editable">
+ <bool>true</bool>
+ </property>
+ <property name="insertPolicy">
+ <enum>QComboBox::NoInsert</enum>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="selectInputFileButton">
+ <string>Select...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="label_2">
+ <string>&Output file</string>
+ </property>
+ <cstring>selectOutputFileButton</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout_2">
+ <item>
+ <widget class="QLineEdit" name="outputFileEdit">
+ <property name="minimumSize">
+ <size>
+ <width>100</width>
+ <height>0</height>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="selectOutputFileButton">
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="2" column="0">
+ <widget class="QCheckBox" name="bandCheck">
+ <string>&Band</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1">
+ <widget class="QSpinBox" name="bandSpin">
+ <property name="minimum">
+ <number>1</number>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="0">
+ <widget class="QCheckBox" name="computeEdgesCheck">
+ <string>Compute &edges</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="0">
+ <widget class="QLabel" name="label_3">
+ <string>&Mode</string>
+ </property>
+ <cstring>modeCombo</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="1">
+ <widget class="QComboBox" name="modeCombo">
+ <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ <property name="currentIndex">
+ <number>0</number>
+ </property>
+ <item>
+ <string>Hillshade</string>
+ </property>
+ </item>
+ <item>
+ <string>Slop</string>
+ </property>
+ </item>
+ <item>
+ <string>Aspect</string>
+ </property>
+ </item>
+ <item>
+ <string>Color relief</string>
+ </property>
+ </item>
+ <item>
+ <string>TRI (Terrain Ruggedness Index)</string>
+ </property>
+ </item>
+ <item>
+ <string>TPI (Topographic Position Index)</string>
+ </property>
+ </item>
+ <item>
+ <string>Roughness</string>
+ </property>
+ </item>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
+ <widget class="QStackedWidget" name="stackedWidget">
+ </property>
+ <widget class="QWidget" name="page">
+ <layout class="QGridLayout" name="gridLayout_3">
+ <widget class="QLabel" name="label_4">
+ <string>Z factor (vertical exaggeration)</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="hillshadeZFactorSpin">
+ </sizepolicy>
+ </property>
+ <property name="decimals">
+ <number>2</number>
+ </property>
+ <property name="maximum">
+ <double>65000.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_5">
+ <string>Scale (ratio of vert. units to horiz.)</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="hillshadeScaleSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ <double>999999.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_6">
+ <string>Azimuth of the light</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="hillshadeAzimuthSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ <double>359.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_7">
+ <string>Altitude of the light</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="1">
+ <widget class="QDoubleSpinBox" name="hillshadeAltitudeSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="page_2">
+ <layout class="QGridLayout" name="gridLayout_2">
+ <item row="0" column="0" colspan="2">
+ <widget class="QCheckBox" name="slopePercentCheck">
+ <string>Slope expressed as percent (instead of as degrees)</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_8">
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="slopeScaleSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <spacer name="verticalSpacer">
+ <property name="orientation">
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>40</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="page_3">
+ <layout class="QGridLayout" name="gridLayout_4">
+ <widget class="QCheckBox" name="aspectTrigonometricCheck">
+ <string>Return trigonometric angle (instead of azimuth)</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QCheckBox" name="aspectZeroForFlatCheck">
+ <string>Return 0 for flat (instead of -9999)</string>
+ </property>
+ </widget>
+ </item>
+ <spacer name="verticalSpacer_2">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="page_4">
+ <layout class="QGridLayout" name="gridLayout_5">
+ <widget class="QLabel" name="label_9">
+ <string>Color configuration file</string>
+ </property>
+ </widget>
+ </item>
+ <layout class="QHBoxLayout" name="horizontalLayout_3">
+ <item>
+ <widget class="QLineEdit" name="colorConfigFileEdit">
+ <size>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="colorSelectConfigFileButton">
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="1" column="0" colspan="2">
+ <widget class="QGroupBox" name="colorMatchGroupBox">
+ <property name="title">
+ <string>Matching mode</string>
+ </property>
+ <property name="checkable">
+ <bool>true</bool>
+ </property>
+ <property name="checked">
+ <bool>false</bool>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_6">
+ <widget class="QRadioButton" name="colorExactRadio">
+ <string>Exact color (otherwise "0,0,0,0" RGBA)</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <widget class="QRadioButton" name="colorNearestRadio">
+ <string>Nearest color</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <widget class="QCheckBox" name="colorAlphaCheck">
+ <string>Add alpha channel</string>
+ </property>
+ </widget>
+ </item>
+ <spacer name="verticalSpacer_3">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="page_5"/>
+ <widget class="QWidget" name="page_6"/>
+ <widget class="QWidget" name="page_7"/>
+ </widget>
+ </item>
+ <item>
+ <widget class="QGroupBox" name="creationGroupBox">
+ <string>&Creation Options</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </property>
+ <layout class="QVBoxLayout" name="verticalLayout">
+ <property name="bottomMargin">
+ </property>
+ <item>
+ <widget class="GdalToolsOptionsTable" name="creationOptionsTable" native="true"/>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <customwidgets>
+ <customwidget>
+ <class>GdalToolsOptionsTable</class>
+ <extends>QWidget</extends>
+ <header>optionsTable</header>
+ <container>1</container>
+ </customwidget>
+ </customwidgets>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>modeCombo</sender>
+ <signal>currentIndexChanged(int)</signal>
+ <receiver>stackedWidget</receiver>
+ <slot>setCurrentIndex(int)</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>282</x>
+ <y>201</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>208</x>
+ <y>310</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
