[QGIS Commit] r15496 - trunk/qgis/i18n
svn_qgis at osgeo.org
Tue Mar 15 09:35:26 EDT 2011
Author: macho
Date: 2011-03-15 06:35:26 -0700 (Tue, 15 Mar 2011)
New Revision: 15496
trunk/qgis/i18n/qgis_ja.ts
translation update: .ja by Yoichi (best wishes for Japan
Modified: trunk/qgis/i18n/qgis_ja.ts
--- trunk/qgis/i18n/qgis_ja.ts 2011-03-15 11:40:45 UTC (rev 15495)
+++ trunk/qgis/i18n/qgis_ja.ts 2011-03-15 13:35:26 UTC (rev 15496)
@@ -1957,7 +1957,7 @@
</message>
<message>
<source>Select the cutline file</source>
- <translation type="unfinished"></translation>
+ <translation>カットラインファイルを選択して下さい</translation>
</message>
<message>
<source>Select the input file for Grid</source>
@@ -1993,11 +1993,11 @@
</message>
<message>
<source>Output size required</source>
+ <translation>出力サイズの指定が必要です</translation>
</message>
<message>
<source>The output file doesn't exist. You must set up the output size to create it.</source>
+ <translation>出力ファイルは存在しません.それを作成するためには出力サイズを指定する必要があります.</translation>
</message>
<message>
<source>Select the input file for Proximity</source>
@@ -2523,14 +2523,14 @@
<location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="136"/>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="283"/>
<source>Width</source>
- <translation type="unfinished">幅</translation>
+ <translation>幅</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="823"/>
<location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="156"/>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="303"/>
<source>Height</source>
- <translation type="unfinished">高さ</translation>
+ <translation>高さ</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="247"/>
@@ -2926,12 +2926,12 @@
<message>
<location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="85"/>
<source>&Output file for rasterized vectors (raster)</source>
+ <translation>ラスタ化されたベクタ出力ファイル(ラスタ)(&O)</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="118"/>
<source>New size (required if output file doens't exist)</source>
+ <translation>新しいサイズ(出力ファイルが存在しない場合必要)</translation>
</message>
<message>
<source>&Output file for rasterized vectors (raster, must exists)</source>
@@ -3152,7 +3152,7 @@
<message>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="229"/>
<source>Cutline</source>
+ <translation>カットライン</translation>
</message>
<message>
<source>&Memory used for caching:</source>
@@ -4060,7 +4060,7 @@
<message>
<location filename="../src/ui/qgisapp.ui" line="958"/>
<source>Zoom to Native Pixel Resolution</source>
+ <translation>ネイティブピクセル解像度にズームする</translation>
</message>
<message>
<location filename="../src/ui/qgisapp.ui" line="970"/>
@@ -4255,7 +4255,7 @@
<message>
<location filename="../src/ui/qgisapp.ui" line="1214"/>
<source>Set project CRS from layer</source>
+ <translation>レイヤのCRSをプロジェクトに設定する</translation>
</message>
<message>
<location filename="../src/ui/qgisapp.ui" line="1219"/>
@@ -4440,12 +4440,12 @@
<message>
<location filename="../src/ui/qgisapp.ui" line="1476"/>
<source>Full histogram stretch</source>
+ <translation>全ヒストグラムを拡大</translation>
</message>
<message>
<location filename="../src/ui/qgisapp.ui" line="1479"/>
<source>Stretch histogram to full dataset</source>
+ <translation>ヒストグラムを全データセットに拡大する</translation>
</message>
</context>
<context>
@@ -6477,31 +6477,31 @@
<location filename="../src/core/qgsvectorfilewriter.cpp" line="856"/>
<location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1386"/>
<source>Geography Markup Language [GML]</source>
+ <translation>Geography Markup Language [GML]</translation>
</message>
<message>
<location filename="../src/core/qgsvectorfilewriter.cpp" line="863"/>
<location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1390"/>
<source>Generic Mapping Tools [GMT]</source>
+ <translation>Generic Mapping Tools [GMT]</translation>
</message>
<message>
<location filename="../src/core/qgsvectorfilewriter.cpp" line="870"/>
<location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1394"/>
<source>GPS eXchange Format [GPX]</source>
+ <translation>GPS eXchange Format [GPX]</translation>
</message>
<message>
<location filename="../src/core/qgsvectorfilewriter.cpp" line="891"/>
<location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1418"/>
<source>Keyhole Markup Language [KML]</source>
+ <translation>Keyhole Markup Language [KML]</translation>
</message>
<message>
<location filename="../src/core/qgsvectorfilewriter.cpp" line="919"/>
<location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1455"/>
<source>Spatial Data Transfer Standard [SDTS]</source>
+ <translation>Spatial Data Transfer Standard [SDTS]</translation>
</message>
<message>
<source>Geography Markup Language (GML)</source>
@@ -6678,7 +6678,7 @@
<message>
<location filename="../src/plugins/spatialquery/qgsspatialquery.cpp" line="102"/>
<source>Is disjoint</source>
+ <translation>接続していないかどうか</translation>
</message>
<message>
<location filename="../src/plugins/spatialquery/qgsspatialquery.cpp" line="110"/>
@@ -6976,27 +6976,27 @@
<message>
<location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="187"/>
<source>Cannot get GDAL raster band: %1</source>
+ <translation>GDALラスタバンド %1 を取得できません</translation>
</message>
<message>
<location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="782"/>
<source>Cannot open GDAL MEM dataset %1: %2</source>
+ <translation>GDAL MEMデータセット%1をオープンできません</translation>
</message>
<message>
<location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="849"/>
<source>Cannot GDALCreateGenImgProjTransformer: </source>
+ <translation>GDALCreateGenImgProjTransformerを実行できません:</translation>
</message>
<message>
<location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="880"/>
<source>Cannot inittialize GDALWarpOperation : </source>
+ <translation>GDALWarpOperationを初期化できません:</translation>
</message>
<message>
<location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="891"/>
<source>Cannot ChunkAndWarpImage: %1</source>
+ <translation> ChunkAndWarpImage: %1を実行できません</translation>
</message>
<message>
<location filename="../src/providers/gdal/qgsgdalprovider.cpp" line="1657"/>
@@ -8123,13 +8123,13 @@
<location filename="../src/app/qgisapp.cpp" line="4851"/>
<location filename="../src/app/qgisapp.cpp" line="4860"/>
<source>To perform a full histogram stretch, you need to have a raster layer selected.</source>
+ <translation>ヒストグラムを拡張するためにラスタレイヤを選択する必要があります.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="4883"/>
<location filename="../src/app/qgisapp.cpp" line="4926"/>
<source>To perform a local histogram stretch, you need to have a grayscale or multiband (multiband single layer, singleband grayscale or multiband color) raster layer selected.</source>
+ <translation>ローカルヒストグラムを拡大するためにはグレイスケールまたはマルチバンド(マルチバンドシングルレイヤ,シングルバンドグレイスケールまたはマルチバンドカラー)ラスタレイヤを選択する必要があります.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="5039"/>
@@ -8157,12 +8157,12 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="5378"/>
<source>Current CRS: %1</source>
+ <translation>カレントCRS %1</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="5385"/>
<source>Inactive project CRS: %1</source>
+ <translation>無効なプロジェクトCRS %1</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="6352"/>
@@ -14174,17 +14174,17 @@
<location filename="../src/ui/qgsdbsourceselectbase.ui" line="83"/>
<source>Load</source>
<comment>Load connections from file</comment>
- <translation type="unfinished">読み込み</translation>
+ <translation>読み込み</translation>
</message>
<message>
<location filename="../src/ui/qgsdbsourceselectbase.ui" line="90"/>
<source>Save connections to file</source>
+ <translation>接続情報をファイルに保存する</translation>
</message>
<message>
<location filename="../src/ui/qgsdbsourceselectbase.ui" line="93"/>
<source>Save</source>
- <translation type="unfinished">保存</translation>
+ <translation>保存</translation>
</message>
<message>
<location filename="../src/ui/qgsdbsourceselectbase.ui" line="112"/>
@@ -21037,7 +21037,7 @@
<message>
<location filename="../src/app/legend/qgslegendlayer.cpp" line="438"/>
<source>Set &project CRS from layer</source>
+ <translation>レイヤのCRSをプロジェクトに設定する(&p)</translation>
</message>
<message>
<location filename="../src/app/legend/qgslegendlayer.cpp" line="447"/>
@@ -21256,7 +21256,7 @@
<location filename="../src/app/qgsmanageconnectionsdialog.cpp" line="247"/>
<location filename="../src/app/qgsmanageconnectionsdialog.cpp" line="445"/>
<source>The file is not an WFS connections exchange file.</source>
+ <translation>指定ファイルはWMSコネクションエクスチェンジファイルではありません.</translation>
</message>
<message>
<location filename="../src/app/qgsmanageconnectionsdialog.cpp" line="256"/>
@@ -22059,7 +22059,7 @@
<message>
<location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="87"/>
<source>Cut edges detected. Make sure the line splits features into multiple parts.</source>
+ <translation>切断境界がありました ラインが地物を切断して複数のパートになっていないか確認して下さい.</translation>
</message>
</context>
<context>
@@ -22294,27 +22294,27 @@
</message>
<message>
<source>meters</source>
+ <translation>メーター</translation>
</message>
<message>
<source>dd</source>
+ <translation>dd</translation>
</message>
<message>
<source>feet</source>
+ <translation>フィート</translation>
</message>
<message>
<source>miles</source>
+ <translation>マイル</translation>
</message>
<message>
<source>inches</source>
+ <translation>インチ</translation>
</message>
<message>
<source>kilometers</source>
+ <translation>キロメーター</translation>
</message>
</context>
<context>
@@ -22713,7 +22713,7 @@
<message>
<location filename="../src/app/spatialite/qgsnewspatialitelayerdialog.cpp" line="298"/>
<source>@</source>
- <translation type="unfinished">@</translation>
+ <translation>@</translation>
</message>
<message>
<location filename="../src/app/spatialite/qgsnewspatialitelayerdialog.cpp" line="301"/>
@@ -24465,12 +24465,12 @@
<message>
<location filename="../src/plugins/oracle_raster/qgsoracle_plugin.cpp" line="57"/>
<source>Add Oracle GeoRaster Layer...</source>
+ <translation>Oracleジオラスタレイヤの追加...</translation>
</message>
<message>
<location filename="../src/plugins/oracle_raster/qgsoracle_plugin.cpp" line="59"/>
<source>Add a Oracle Spatial GeoRaster...</source>
+ <translation>Oracle Spatial ジオラスタの追加...</translation>
</message>
</context>
<context>
@@ -30281,7 +30281,7 @@
<message>
<location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="85"/>
<source>The spatial query requires at least two vector layers</source>
+ <translation>この空間クエリは少なくとも2つのレイヤが必要です</translation>
</message>
<message>
<location filename="../src/plugins/spatialquery/qgsspatialquerydialog.cpp" line="202"/>
@@ -30578,7 +30578,7 @@
<message>
<location filename="../src/plugins/spatialquery/qgsspatialquerydialogbase.ui" line="242"/>
<source>Result feature ID's</source>
+ <translation>結果の地物ID</translation>
</message>
<message>
<location filename="../src/plugins/spatialquery/qgsspatialquerydialogbase.ui" line="404"/>
@@ -30636,7 +30636,7 @@
<message>
<location filename="../src/plugins/spatialquery/qgsspatialqueryplugin.cpp" line="113"/>
<source>Query not executed</source>
+ <translation>クエリを実行できませんでした</translation>
</message>
<message>
<location filename="../src/plugins/spatialquery/qgsspatialqueryplugin.cpp" line="160"/>
@@ -33465,7 +33465,7 @@
<message>
<location filename="../src/plugins/wfs/qgswfsplugin.cpp" line="53"/>
<source>Add W&FS layer...</source>
+ <translation>WMSレイヤの追加(&F)...</translation>
</message>
</context>
<context>
@@ -33535,12 +33535,12 @@
<message>
<location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="470"/>
<source>Load connections</source>
+ <translation>接続情報のロード</translation>
</message>
<message>
<location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="471"/>
<source>XML files (*.xml *XML)</source>
- <translation type="unfinished">XMLファイル(*.xml *XML)</translation>
+ <translation>XMLファイル(*.xml *XML)</translation>
</message>
<message>
<location filename="../src/plugins/wfs/qgswfssourceselect.cpp" line="326"/>
@@ -33603,22 +33603,22 @@
<message>
<location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="84"/>
<source>Load connections from file</source>
+ <translation>接続情報をファイルからロードする</translation>
</message>
<message>
<location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="87"/>
</message>
<message>
<location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="94"/>
</message>
<message>
<location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="97"/>
</message>
<message>
<location filename="../src/plugins/wfs/qgswfssourceselectbase.ui" line="179"/>
@@ -33884,7 +33884,7 @@
<message>
<location filename="../src/ui/qgswmssourceselectbase.ui" line="21"/>
</message>
<message>
<location filename="../src/ui/qgswmssourceselectbase.ui" line="75"/>
@@ -33956,17 +33956,17 @@
<message>
<location filename="../src/ui/qgswmssourceselectbase.ui" line="256"/>
</message>
<message>
<location filename="../src/ui/qgswmssourceselectbase.ui" line="263"/>
</message>
<message>
<location filename="../src/ui/qgswmssourceselectbase.ui" line="266"/>
</message>
<message>
<location filename="../src/ui/qgswmssourceselectbase.ui" line="274"/>
@@ -37192,7 +37192,7 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="8"/>
<source>(Optional) column to read labels</source>
+ <translation>(任意)ラベルを読むためのカラム</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="9"/>
@@ -37262,7 +37262,7 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="22"/>
<source>Attribute field to (over)write</source>
+ <translation>(上)書き込み用属性フィールド</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="23"/>
@@ -38123,7 +38123,7 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="211"/>
<source>Feature type (for polygons, choose Boundary)</source>
+ <translation>地物タイプ(ポリゴンのための境界線を選ぶ)</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="226"/>
@@ -38690,7 +38690,7 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="301"/>
<source>Maximal tolerance value (higher value=more simplification)</source>
+ <translation>最大許容値(大きい値にするとさらみ簡素化が進みます)</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="302"/>
