[QGIS Commit] r15523 - trunk/qgis/src/gui
svn_qgis at osgeo.org
Wed Mar 16 16:24:38 EDT 2011
Author: jef
Date: 2011-03-16 13:24:38 -0700 (Wed, 16 Mar 2011)
New Revision: 15523
trunk/qgis/src/gui/qgsprojectionselector.cpp
trunk/qgis/src/gui/qgsprojectionselector.h
fix #3624
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp 2011-03-16 20:03:42 UTC (rev 15522)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp 2011-03-16 20:24:38 UTC (rev 15523)
@@ -163,18 +163,10 @@
// check if a paricular projection is waiting
// to be pre-selected, and if so, to select it now.
- if ( mCRSNameSelectionPending )
+ if ( mCRSNameSelectionPending || mCRSIDSelectionPending || mAuthIDSelectionPending )
- applyCRSNameSelection();
+ applySelection();
- if ( mCRSIDSelectionPending )
- applyCRSIDSelection();
- if ( mAuthIDSelectionPending )
- applyAuthIDSelection();
for ( int i = mRecentProjections.size() - 1; i >= 0; i-- )
insertRecent( mRecentProjections.at( i ).toLong() );
@@ -253,7 +245,7 @@
if ( isVisible() )
+ applySelection();
// else we will wait for the projection selector to
// become visible (with the showEvent()) and set the
@@ -270,7 +262,7 @@
if ( isVisible() )
+ applySelection();
@@ -290,30 +282,49 @@
mCRSNameSelectionPending = false; // only one type can be pending at a time
-void QgsProjectionSelector::applyCRSNameSelection()
+void QgsProjectionSelector::applySelection()
- if (
- mCRSNameSelectionPending &&
- mProjListDone &&
- mUserProjListDone
+ if ( !mProjListDone || !mUserProjListDone )
+ return;
+ QList<QTreeWidgetItem*> nodes;
+ if ( mCRSNameSelectionPending )
//get the srid given the wkt so we can pick the correct list item
QgsDebugMsg( "called with " + mCRSNameSelection );
- QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems( mCRSNameSelection, Qt::MatchExactly | Qt::MatchRecursive, 0 );
+ nodes = lstCoordinateSystems->findItems( mCRSNameSelection, Qt::MatchExactly | Qt::MatchRecursive, 0 );
- if ( nodes.count() > 0 )
- lstCoordinateSystems->setCurrentItem( nodes.first() );
- else // unselect the selected item to avoid confusing the user
- lstCoordinateSystems->clearSelection();
- teProjection->setText( "" );
+ if ( mAuthIDSelectionPending )
+ //get the srid given the wkt so we can pick the correct list item
+ QgsDebugMsg( "called with " + mAuthIDSelection );
+ nodes = lstCoordinateSystems->findItems( mAuthIDSelection, Qt::MatchExactly | Qt::MatchRecursive, AUTHID_COLUMN );
+ mAuthIDSelectionPending = false;
+ if ( mCRSIDSelectionPending )
+ QString myCRSIDString = QString::number( mCRSIDSelection );
+ nodes = lstCoordinateSystems->findItems( myCRSIDString, Qt::MatchExactly | Qt::MatchRecursive, QGIS_CRS_ID_COLUMN );
+ mCRSIDSelectionPending = false;
+ if ( nodes.count() > 0 )
+ lstCoordinateSystems->setCurrentItem( nodes.first() );
+ lstCoordinateSystems->scrollToItem( lstCoordinateSystems->currentItem(), QAbstractItemView::PositionAtCenter );
+ else // unselect the selected item to avoid confusing the user
+ lstCoordinateSystems->clearSelection();
+ teProjection->setText( "" );
void QgsProjectionSelector::insertRecent( long theCrsId )
@@ -332,51 +343,6 @@
<< nodes.first()->text( QGIS_CRS_ID_COLUMN ) ) );
-void QgsProjectionSelector::applyAuthIDSelection()
- if ( mAuthIDSelectionPending && mProjListDone && mUserProjListDone )
- //get the srid given the wkt so we can pick the correct list item
- QgsDebugMsg( "called with " + mAuthIDSelection );
- QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems( mAuthIDSelection, Qt::MatchExactly | Qt::MatchRecursive, AUTHID_COLUMN );
- mAuthIDSelectionPending = false;
-void QgsProjectionSelector::applyCRSIDSelection()
- if ( mCRSIDSelectionPending && mProjListDone && mUserProjListDone )
- QString myCRSIDString = QString::number( mCRSIDSelection );
- QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems( myCRSIDString, Qt::MatchExactly | Qt::MatchRecursive, QGIS_CRS_ID_COLUMN );
- mCRSIDSelectionPending = false;
//note this line just returns the projection name!
QString QgsProjectionSelector::selectedName()
@@ -848,7 +814,7 @@
QString myDescription;
emit sridSelected( QString::number( selectedCrsId() ) );
QString myProjString = selectedProj4String();
- lstCoordinateSystems->scrollToItem( theItem, QAbstractItemView::PositionAtCenter );
+ lstCoordinateSystems->scrollToItem( theItem );
teProjection->setText( myProjString );
lstRecent->clearSelection();
@@ -868,8 +834,8 @@
item->setHidden( cbxHideDeprecated->isChecked() );
if ( item->isSelected() && item->isHidden() )
item->setSelected( false );
Modified: trunk/qgis/src/gui/qgsprojectionselector.h
--- trunk/qgis/src/gui/qgsprojectionselector.h 2011-03-16 20:03:42 UTC (rev 15522)
+++ trunk/qgis/src/gui/qgsprojectionselector.h 2011-03-16 20:24:38 UTC (rev 15523)
@@ -140,7 +140,7 @@
QString ogcWmsCrsFilterAsSqlExpression( QSet<QString> * crsFilter );
- * \brief does the legwork of applying the CRS Name Selection
+ * \brief does the legwork of applying CRS Selection
* \warning This function does nothing unless getUserList() and getUserProjList()
* Have already been called
@@ -149,33 +149,9 @@
* does not scroll the list to the selection if the widget is not visible.
* Therefore you will typically want to use this in a showEvent().
- void applyCRSNameSelection();
+ void applySelection();
- * \brief does the legwork of applying the CRS ID Selection
- * \warning This function does nothing unless getUserList() and getUserProjList()
- * Have already been called
- * \warning This function only expands the parents of the selection and
- * does not scroll the list to the selection if the widget is not visible.
- * Therefore you will typically want to use this in a showEvent().
- void applyCRSIDSelection();
- * \brief does the legwork of applying the Authority ID Selection
- void applyAuthIDSelection();
* \brief gets an arbitrary sqlite3 expression from the selection
* \param e The sqlite3 expression (typically "srid" or "sridid")
