[QGIS Commit] r15566 - in trunk/qgis: python/gui src/gui
svn_qgis at osgeo.org
Tue Mar 22 19:18:06 EDT 2011
Author: jef
Date: 2011-03-22 16:18:06 -0700 (Tue, 22 Mar 2011)
New Revision: 15566
Added:
trunk/qgis/python/gui/qgsattributeeditor.sip
trunk/qgis/python/gui/qgsfieldvalidator.sip
trunk/qgis/src/gui/qgsfieldvalidator.cpp
trunk/qgis/src/gui/qgsfieldvalidator.h
trunk/qgis/python/gui/gui.sip
trunk/qgis/src/gui/CMakeLists.txt
trunk/qgis/src/gui/qgsattributeeditor.cpp
fix #2554:
- apply heavy modified patch from sunil.
- introduces QgsFieldValidator including sip bindings
- add missing sip bindings to QgsAttributeEditor
Modified: trunk/qgis/python/gui/gui.sip
--- trunk/qgis/python/gui/gui.sip 2011-03-22 20:35:44 UTC (rev 15565)
+++ trunk/qgis/python/gui/gui.sip 2011-03-22 23:18:06 UTC (rev 15566)
@@ -33,5 +33,7 @@
%Include qgstextannotationitem.sip
%Include qgsvertexmarker.sip
%Include qgssearchquerybuilder.sip
+%Include qgsattributeeditor.sip
+%Include qgsfieldvalidator.sip
%Include symbology-ng-gui.sip
Added: trunk/qgis/python/gui/qgsattributeeditor.sip
--- trunk/qgis/python/gui/qgsattributeeditor.sip (rev 0)
+++ trunk/qgis/python/gui/qgsattributeeditor.sip 2011-03-22 23:18:06 UTC (rev 15566)
@@ -0,0 +1,16 @@
+/* \brief create attribute widget for editing */
+class QgsAttributeEditor : public QObject
+%TypeHeaderCode
+#incude <qgsattributeeditor.h>
+%End
+ public:
+ QgsAttributeEditor( QObject *parent );
+ static QWidget *createAttributeEditor( QWidget *parent, QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value );
+ static bool retrieveValue( QWidget *widget, QgsVectorLayer *vl, int idx, QVariant &value );
+ static bool setValue( QWidget *widget, QgsVectorLayer *vl, int idx, const QVariant &value );
+ public slots:
+ void selectFileName( void );
+ void selectDate( void );
Added: trunk/qgis/python/gui/qgsfieldvalidator.sip
--- trunk/qgis/python/gui/qgsfieldvalidator.sip (rev 0)
+++ trunk/qgis/python/gui/qgsfieldvalidator.sip 2011-03-22 23:18:06 UTC (rev 15566)
@@ -0,0 +1,11 @@
+class QgsFieldValidator : public QValidator
+%TypeHeaderCode
+#include <qgsfieldvalidator.h>
+%End
+ QgsFieldValidator( QObject *parent, const QgsField &field );
+ ~QgsFieldValidator();
+ virtual State validate( QString &, int & ) const;
+ virtual void fixup( QString & ) const;
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt 2011-03-22 20:35:44 UTC (rev 15565)
+++ trunk/qgis/src/gui/CMakeLists.txt 2011-03-22 23:18:06 UTC (rev 15566)
@@ -35,6 +35,7 @@
qgsdetaileditemdata.cpp
qgsencodingfiledialog.cpp
qgsfiledropedit.cpp
+qgsfieldvalidator.cpp
qgsformannotationitem.cpp
qgsgenericprojectionselector.cpp
qgsmapcanvas.cpp
@@ -89,6 +90,7 @@
qgslegendinterface.h
qgisinterface.h
qgsencodingfiledialog.h
+qgsfieldvalidator.h
qgsformannotationitem.h
qgsgenericprojectionselector.h
qgsmapcanvas.h
@@ -206,6 +208,8 @@
qgsvertexmarker.h
qgsmaptip.h
qgssearchquerybuilder.h
+qgsattributeeditor.h
${CMAKE_CURRENT_BINARY_DIR}/../ui/ui_qgsdetaileditemwidgetbase.h
${CMAKE_CURRENT_BINARY_DIR}/../ui/ui_qgsgenericprojectionselectorbase.h
Modified: trunk/qgis/src/gui/qgsattributeeditor.cpp
--- trunk/qgis/src/gui/qgsattributeeditor.cpp 2011-03-22 20:35:44 UTC (rev 15565)
+++ trunk/qgis/src/gui/qgsattributeeditor.cpp 2011-03-22 23:18:06 UTC (rev 15566)
@@ -23,6 +23,7 @@
#include <qgscategorizedsymbolrendererv2.h>
#include <qgssymbol.h>
#include <qgslonglongvalidator.h>
#include <QPushButton>
#include <QLineEdit>
@@ -357,19 +358,7 @@
le->setCompleter( c );
- if ( myFieldType == QVariant::Int )
- le->setValidator( new QIntValidator( le ) );
- else if ( myFieldType == QVariant::LongLong )
- le->setValidator( new QgsLongLongValidator( le ) );
- else if ( myFieldType == QVariant::Double )
- le->setValidator( new QDoubleValidator( le ) );
+ le->setValidator( new QgsFieldValidator( le, field ) );
myWidget = le;
Added: trunk/qgis/src/gui/qgsfieldvalidator.cpp
--- trunk/qgis/src/gui/qgsfieldvalidator.cpp (rev 0)
+++ trunk/qgis/src/gui/qgsfieldvalidator.cpp 2011-03-22 23:18:06 UTC (rev 15566)
@@ -0,0 +1,154 @@
+ qgsfieldvalidator.cpp - description
+ begin : March 2011
+ copyright : (C) 2011 by SunilRajKiran-kCube
+ email : sunilraj.kiran at kcubeconsulting.com
+ adapted version of QValidator for QgsField
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+/* $Id$ */
+#include "qgsfieldvalidator.h"
+#include <QValidator>
+#include <QRegExpValidator>
+#include <QDate>
+#include <QVariant>
+#include <QSettings>
+#include "qgslogger.h"
+#include "qgslonglongvalidator.h"
+#include "qgsfield.h"
+QgsFieldValidator::QgsFieldValidator( QObject *parent, const QgsField &field )
+ : QValidator( parent )
+ , mField( field )
+ switch ( mField.type() )
+ case QVariant::Int:
+ if ( mField.length() > 0 )
+ QString re = QString( "-?\\d{0,%1}" ).arg( mField.length() );
+ mValidator = new QRegExpValidator( QRegExp( re ), parent );
+ else
+ mValidator = new QIntValidator( parent );
+ break;
+ case QVariant::Double:
+ if ( mField.length() > 0 && mField.precision() > 0 )
+ QString re = QString( "-?\\d{0,%1}(\\.\\d{0,%2})?" ).arg( mField.length() - mField.precision() ).arg( mField.precision() );
+ else if ( mField.precision() > 0 )
+ QString re = QString( "-?\\d*(\\.\\d{0,%1))?" ).arg( mField.precision() );
+ else
+ mValidator = new QDoubleValidator( parent );
+ break;
+ case QVariant::LongLong :
+ mValidator = new QgsLongLongValidator( parent );
+ break;
+ default:
+ mValidator = 0;
+ QSettings settings;
+ mNullValue = settings.value( "qgis/nullValue", "NULL" ).toString();
+QgsFieldValidator::~QgsFieldValidator()
+ delete mValidator;
+QValidator::State QgsFieldValidator::validate( QString &s, int &i ) const
+ // empty values are considered NULL for numbers and dates and are acceptable
+ if ( s.isEmpty() &&
+ ( mField.type() == QVariant::Double
+ || mField.type() == QVariant::Int
+ || mField.type() == QVariant::LongLong
+ || mField.type() == QVariant::Date
+ return Acceptable;
+ // delegate to the child validator if any
+ if ( mValidator )
+ QValidator::State result = mValidator->validate( s, i );
+ return result;
+ else if ( mField.type() == QVariant::String )
+ // allow to enter the NULL representation, which might be
+ // longer than the actual field
+ if ( mNullValue.size() > 0 &&
+ s.size() > 0 &&
+ s.size() < mNullValue.size() &&
+ s == mNullValue.left( s.size() ) )
+ return Intermediate;
+ if ( s == mNullValue )
+ if ( mField.length() > 0 && s.size() > mField.length() )
+ return Invalid;
+ else if ( mField.type() == QVariant::Date )
+ return QDate::fromString( s ).isValid() ? Acceptable : Intermediate;
+ else
+ QgsDebugMsg( "unsupported type for validation" );
+ return Invalid;
+void QgsFieldValidator::fixup( QString &s ) const
+ if ( mValidator )
+ mValidator->fixup( s );
+ else if ( mField.type() == QVariant::String && mField.length() > 0 && s.size() > mField.length() )
+ // if the value is longer, this must be a partial NULL representation
+ s = mNullValue;
+ // invalid dates will also translate to NULL
+ s = "";
Added: trunk/qgis/src/gui/qgsfieldvalidator.h
--- trunk/qgis/src/gui/qgsfieldvalidator.h (rev 0)
+++ trunk/qgis/src/gui/qgsfieldvalidator.h 2011-03-22 23:18:06 UTC (rev 15566)
@@ -0,0 +1,50 @@
+ qgsfieldvalidator.h - description
+/* $Id$ */
+#ifndef QGSFIELDVALIDATOR_H
+#define QGSFIELDVALIDATOR_H
+class GUI_EXPORT QgsFieldValidator : public QValidator
+ Q_OBJECT
+ public:
+ private:
+ // Disables copy constructing
+ Q_DISABLE_COPY( QgsFieldValidator )
+ QValidator *mValidator;
+ QgsField mField;
+ QString mNullValue;
+#endif // QGSFIELDVALIDATOR_H
