[Qgis-community-team] images for manual
Stephan Holl stephan.holl at intevation.de
Sun Jul 27 13:48:17 EDT 2008
Hello all,
Otto Dassau <otto.dassau at gmx.de>, [20080724-11:32:00]:
> On Thu, 24 Jul 2008 11:05:01 +0200
> Otto Dassau <otto.dassau at gmx.de> wrote:
> > Hi Tara,
> > On Wed, 23 Jul 2008 13:54:27 -0700
> > Tara Athan <tara_athan at alt2is.com> wrote:
> > > Dear Documentation Writers:
> > > I have cleaned out and rearranged the image folders in the
> > > user_guide trunk,  so the user_guide content revision can proceed.
> > > This is what has been done
> > > 1. all old images were deleted
> > > 2. the folder structure was redefined and populated as follows:
> > >  > GUI icons for the core of QGIS appear in the folder "images"
> > >  > every plugin has its own folder for GUI icons- however, I was
> > >  > unable
> > > to find these icons in the SVN where they are supposed(?) to be
> > > (under qgis\src\plugins). So at present there are NO icons for
> > > plugins in user_guide, until I find out what is going. (*** help,
> > > Tim? ***)
> > >  > every tex file has its own folder for screenshots, with a name
> > >  > like
> > > "working_with_raster_screenies" except for the plugin tex files,
> > > that have a single folder plugins_screenies for the plugin
> > > chapter. All screenshots should go in one of these folders and
> > > not be mixed with the icons (please?), otherwise it will be
> > > difficult to update the GUI icons for future releases.
> > > 3. Makefiles were edited so they now run through the "make pics"
> > > section without errors. Errors do occur when non-existent images
> > > are requested in the latex files.
> > > 4. I added all the grass module images to SVN, but only included
> > > in the Makefile the one that is used in the user guide. Others
> > > can be easily added to the list if needed.
> > > I don't think I did the SVN directory restructuring by the best
> > > method and you might have to checkout to a new location rather
> > > than update your existing copy - that is what I had to do.
> > Updating my svn copy i had to delete the folder /images and update
> > again, but then it worked without problems.
> sorry - some more changes are needed in your local copy to clean up
> old files and directories:
> rm -rf \
> working_with_projections_images
> creating_applications_images
> working_with_ogc_images
> grass_integration_images
> mapserver_export_images
> map_composer_images
> rm -f
> plugins_graticule_creator_images/graticule.eps
> plugins_gps_images/importdialog.eps
> plugins_gps_images/loadgpx.eps
> plugins_gps_images/importmenu.eps
> plugins_gps_images/download.eps
> plugins_gps_images/icon.eps
> plugins_georeferencer_images/result_map.eps
> plugins_georeferencer_images/georeferencer.eps
> plugins_georeferencer_images/choose_points.eps
> plugins_georeferencer_images/select_image.eps
> plugins_delimited_text_images/file_selected2.eps
> plugins_delimited_text_images/file_selected3.eps
> plugins_delimited_text_images/toolbar_icon.eps
> plugins_delimited_text_images/dialog.eps
> plugins_delimited_text_images/ellipsis.eps
> plugins_delimited_text_images/file_selected.eps
> plugins_delimited_text_images/file_selected1.eps
> plugins_delimited_text_images/plugin_manager.eps
> plugins_decorations_images/scale_bar.eps
> plugins_decorations_images/north_arrow.eps
> plugins_decorations_images/copyright.eps
> plugins_python_images/plugin_results.eps
> plugins_python_images/getfieldname.eps
> plugins_python_images/getdsn.eps
> plugins_python_images/gettablename.eps
As Otto stated above there were lots of 'restructurings' done. During
this operation the result does not seem to work, because some images
are gone now.
While being away from
the internet for some days I updated my manual-repository and got lots
of SVN-updates.
Too sad that the update did not gone smoothly. My version of the
current trunk does not compile.
Checking with  'svn log' there were lots of commits with no usefull
log-message, also the ChangeLog-file in SVN does not represent the
commits.
I would be happy if we could follow some more strict commit-rules
(which need to be formalized!).
Needless to say that the latex-files _always_ should work when checked
into SVN (which is currently not the case).
There is a brilliant documentation for SVN-usage[1] which sheds light
on all details of SVN...
Is someone responsible to change the filenames to the new images-names
in the whole document or is that left to the responsible person of
the chapter?
Again, I would love to have an always compiling SVN-repo.
Sorry for beeing so harsh, but cleaning up a local repository with
locally changed files plus some broken remote updates is really a pain
(and I will not spending another hour again to do so).
Best regards
	Stephan
[1] http://svnbook.red-bean.com/
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
More information about the Qgis-community-team mailing list
