[Qgis-community-team] images for manual
    Otto Dassau
    otto.dassau at gmx.de
    Thu Jul 24 05:32:00 EDT 2008
On Thu, 24 Jul 2008 11:05:01 +0200
Otto Dassau <otto.dassau at gmx.de> wrote:
> Hi Tara,
> On Wed, 23 Jul 2008 13:54:27 -0700
> Tara Athan <tara_athan at alt2is.com> wrote:
> > Dear Documentation Writers:
> > I have cleaned out and rearranged the image folders in the user_guide
> > trunk,  so the user_guide content revision can proceed.
> > This is what has been done
> > 1. all old images were deleted
> > 2. the folder structure was redefined and populated as follows:
> >  > GUI icons for the core of QGIS appear in the folder "images"
> >  > every plugin has its own folder for GUI icons- however, I was unable
> > to find these icons in the SVN where they are supposed(?) to be (under
> > qgis\src\plugins). So at present there are NO icons for plugins in
> > user_guide, until I find out what is going. (*** help, Tim? ***)
> >  > every tex file has its own folder for screenshots, with a name like
> > "working_with_raster_screenies" except for the plugin tex files, that
> > have a single folder plugins_screenies for the plugin chapter. All
> > screenshots should go in one of these folders and not be mixed with the
> > icons (please?), otherwise it will be difficult to update the GUI icons
> > for future releases.
> > 3. Makefiles were edited so they now run through the "make pics" section
> > without errors. Errors do occur when non-existent images are requested
> > in the latex files.
> > 4. I added all the grass module images to SVN, but only included in the
> > Makefile the one that is used in the user guide. Others can be easily
> > added to the list if needed.
> > I don't think I did the SVN directory restructuring by the best method
> > and you might have to checkout to a new location rather than update your
> > existing copy - that is what I had to do.
> Updating my svn copy i had to delete the folder /images and update again, but
> then it worked without problems.
sorry - some more changes are needed in your local copy to clean up old files
and directories:
rm -rf \
working_with_projections_images
creating_applications_images
working_with_ogc_images
grass_integration_images
mapserver_export_images
map_composer_images
rm -f
plugins_graticule_creator_images/graticule.eps
plugins_gps_images/importdialog.eps
plugins_gps_images/loadgpx.eps
plugins_gps_images/importmenu.eps
plugins_gps_images/download.eps
plugins_gps_images/icon.eps
plugins_georeferencer_images/result_map.eps
plugins_georeferencer_images/georeferencer.eps
plugins_georeferencer_images/choose_points.eps
plugins_georeferencer_images/select_image.eps
plugins_delimited_text_images/file_selected2.eps
plugins_delimited_text_images/file_selected3.eps
plugins_delimited_text_images/toolbar_icon.eps
plugins_delimited_text_images/dialog.eps
plugins_delimited_text_images/ellipsis.eps
plugins_delimited_text_images/file_selected.eps
plugins_delimited_text_images/file_selected1.eps
plugins_delimited_text_images/plugin_manager.eps
plugins_decorations_images/scale_bar.eps
plugins_decorations_images/north_arrow.eps
plugins_decorations_images/copyright.eps
plugins_python_images/plugin_results.eps
plugins_python_images/getfieldname.eps
plugins_python_images/getdsn.eps
plugins_python_images/gettablename.eps
> thanks a lot
>   Otto
> > Happy editing!!
> > Tara
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
