[Qgis-community-team] images for manual
    Otto Dassau
    otto.dassau at gmx.de
    Thu Jul 24 05:05:01 EDT 2008
Hi Tara,
On Wed, 23 Jul 2008 13:54:27 -0700
Tara Athan <tara_athan at alt2is.com> wrote:
> Dear Documentation Writers:
> I have cleaned out and rearranged the image folders in the user_guide
> trunk,  so the user_guide content revision can proceed.
> This is what has been done
> 1. all old images were deleted
> 2. the folder structure was redefined and populated as follows:
>  > GUI icons for the core of QGIS appear in the folder "images"
>  > every plugin has its own folder for GUI icons- however, I was unable
> to find these icons in the SVN where they are supposed(?) to be (under
> qgis\src\plugins). So at present there are NO icons for plugins in
> user_guide, until I find out what is going. (*** help, Tim? ***)
>  > every tex file has its own folder for screenshots, with a name like
> "working_with_raster_screenies" except for the plugin tex files, that
> have a single folder plugins_screenies for the plugin chapter. All
> screenshots should go in one of these folders and not be mixed with the
> icons (please?), otherwise it will be difficult to update the GUI icons
> for future releases.
> 3. Makefiles were edited so they now run through the "make pics" section
> without errors. Errors do occur when non-existent images are requested
> in the latex files.
> 4. I added all the grass module images to SVN, but only included in the
> Makefile the one that is used in the user guide. Others can be easily
> added to the list if needed.
> I don't think I did the SVN directory restructuring by the best method
> and you might have to checkout to a new location rather than update your
> existing copy - that is what I had to do.
Updating my svn copy i had to delete the folder /images and update again, but
then it worked without problems.
thanks a lot
  Otto
> Happy editing!!
> Tara
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
