[Qgis-community-team] QGIS alaska dataset reprojected to EPSG 2964
Otto Dassau otto.dassau at gmx.de
Wed Oct 8 08:56:42 EDT 2008
the reprojection of the alaska dataset should not make a difference for already
written manual chapters but fix the projection problems for OGC, OTF and
coordinate capture plugin.
@Jürgen: You can now use the existing NASA WMS server to show WMS-Capabilities
as long as we don't have any better.
@Tara: Instead of the aiports gpx file, I added a national mo__ument gpx file. It
includes 4 national mo__uments with an web URL for more information.
Maybe we can use this for an QGIS Action example...
regards,
 Otto
On Wed, 8 Oct 2008 14:46:38 +0200
Otto Dassau <otto.dassau at gmx.de> wrote:
> Hi,
> maybe you already made the experience that there is no EPSG definition for
> the alaska dataset using unit=meters anymore. This caused problems e.g. for
> OTF and the coordinate capture plugin.
> Instead QGIS allows to define an EPSG 2964 for Albers Equal Area CRS using
> unit feet: +proj=aea +lat_1=55 +lat_2=65 +lat_0=50 +lon_0=-154 +x_0=0 +y_0=0
> +ellps=clrk66 +datum=NAD27 +to_meter=0.3048006096012192 +no_defs
> As Gary suspects, the projection engine in QGIS isn't recognizing the to_meter
> parameter correctly. So I reprojected and updated the QGIS sample data set
> using this EPSG 2964 CRS. You find the data here.
> http://download.osgeo.org/qgis/data/qgis_sample_data.zip
> http://download.osgeo.org/qgis/data/qgis_sample_data.tar.gz
> Sorry for the inconvinience, but please update your sample datasets to be able
> to use and test all QGIS features with the alaska data. If there are any
> problems with the data, feel free to write to the list, so we can fix it.
> regards,
>  Otto
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
