[Qgis-community-team] Some problems with the albanian localization
Werner Macho werner.macho at gmail.com
Fri Oct 10 06:48:34 EDT 2008
Updated with the update script to represent the latest phrases to
translate..
I've done that already and commited all the .ts files
so just update your SVN and you should find the new phrases to translate.
Thanks for your hint
regards
Werner
Paolo L. Scala schrieb:
> Hi all!
> While testing the albanian localization, I found some strings that
> couldn't be translate, e.g.:
> Menu>Options>General>"Warn me when a project..."
> Is it a problem related to the QGIS source code, or something's wrong
> with the .ts file?
> Thanks,
> Paolo
I
More information about the Qgis-community-team mailing list
