[Qgis-community-team] Release date for manual 1.1
Otto Dassau
otto.dassau at gmx.de
Thu Apr 30 07:46:34 EDT 2009
On Thu, 30 Apr 2009 00:05:16 -0700
Claudia A Engel <cengel at stanford.edu> wrote:
> Otto and Carson,
> I edited the changes for Postgis SLL mode, improved handling of
> postgis layers and the map units/pixels addition and committed those
> to svn.
> These edits are reflected on the Manual Task page. I tested to make
> sure, and it all seems to compile fine here. I hope this is all ok,
> but me know if I should do something differently, as I have never done
> this before.
> I also added the headers for the following subsections as discussed,
> but they need to be written:
> -Spatialite Layers
> -Diagram overlay tab
> -Working with the attribute table
I can do the Diagram overlay tab.
Otto
> Lastly, the new Vector Load dialogue needs still to be added in. I can
> probably do this, plus another of the chapters above, this weekend.
> So if anyone can help out with the other chapters, that would be great.
> Thanks, Claudia
> On Apr 29, 2009, at 2:50 AM, Carson Farmer wrote:
> > Hi team,
> >> I saw that Carson already did something here.
> >> Carson what was your idea when you created the
> >> "plugins_diagram_overlay_images"
> >> folder? Do you plan to add an extra subsection for this plugin in
> >> the plugin
> >> chapter?
> > Well for starters I needed an icon for the core plugins chapter ;-)
> > But yes, I will be adding a section to the plugin as well. It would
> > be nice to see what Claudia has done as well, so that we don't end
> > up duplicating each others work... Claudia, have you committed your
> > edits yet?
> >> Or should it work as for the SPIT Plugin. It is listed in section
> >> 12 "Using Core
> >> Plugins" but there doesn't exist a SPIT plugin subsection. The
> >> description can
> >> be found in section 5.2.4 together with the PostGIS stuff.
> > hmm, now that I think of it, this might be the best route to take...
> > this adds more work to Claudia's list, so Claudia if you need help
> > just let us know... I imagine that in the future the vector overlay
> > stuff will become completely part of core, so putting it in the
> > working with vector layers section now might save some hassle later
> > on as well...
> > In this case, I think I'll add two new subsections for SPIT and the
> > Overlay stuff in the Using core plugins chapter, pointing the user
> > to the sections in the working with vector layers Chapter...
> >> For the diagram_overlay plugin this would mean, we add it to the
> >> list of core
> >> plugins but the description would go into working_with_vector.tex
> >> and we use the
> >> folder diagram_overlay plugin_images/ for the plugin icons and
> >> screenies. Is
> >> that correct?
> > see above
> >>> - Changes in attribute table
> >>> I could not find any description of the attribute table in the
> >>> manual, but maybe I looked in the wrong place. If there is none,
> >>> is it necessary to have one? Add another subsection?
> >> yes, I haven't found anything, too. In the other email I suggested
> >> to add a new
> >> subsubsection to 5.4 Editing \subsection{Working with the attribute
> >> table} just
> >> above the Query Builder?
> > This would be good. We should at least mention that there is an
> > attribute table somewhere... also, the attribute table is relatively
> > fast compared with other GIS, so this should probably be mentioned...
> >>> - Improved handling of postGIS layers.
> >>> I did not look around very thoroughly, but at first glance I could
> >>> not figure out what this exactly refers to.
> >> I don't know either? Carson, do you know? Otherwise we can ask
> >> Jürgen, I guess
> >> we did those improvements.
> > Yeh, Jürgen would be the one to ask... the SSL mode change is
> > probably one of the bigger changes, and increases PostGIS access
> > speed by up to 5 times in some cases!
> > Carson J. Q. Farmer
> > ISSP Doctoral Fellow
> > National Centre for Geocomputation (NCG),
> > Email: Carson.Farmer at gmail.com
> > Web: http://www.carsonfarmer.com/
> > http://www.ftools.ca/
More information about the Qgis-community-team
