[Qgis-community-team] manual paper size definition
MORREALE Jean Roc jr.morreale at enoreth.net
Tue Jul 27 16:25:04 EDT 2010
Le 27/07/2010 10:55, Otto Dassau a écrit :
> Hi Jean-Roc,
> would it make sense to change the paper size for the manual again back to
> something more common, such as A4? I saw you currently defined
> \usepackage[paperwidth=18.89cm,paperheight=24.58cm,twoside,bindingoffset=9mm,outer=2.2cm,inner=1cm,top=2.6cm,bottom=4.5cm]{geometry}
> maybe we can just add a second paper size definition and comment yours? Is
> it that easy or would that mean more effort?
> Regards,
>   otto
I've committed the change to A4 and fixed some float's overflow in the
grass chapter, the actual svn is building fine.
Good night,
Jean Roc
More information about the Qgis-community-team mailing list
