[Qgis-community-team] manual paper size definition
Otto Dassau otto.dassau at gmx.de
Wed Jul 28 03:21:51 EDT 2010
Am Tue, 27 Jul 2010 22:25:04 +0200
schrieb MORREALE Jean Roc <jr.morreale at enoreth.net>:
> Le 27/07/2010 10:55, Otto Dassau a écrit :
> > Hi Jean-Roc,
> > would it make sense to change the paper size for the manual again back to
> > something more common, such as A4? I saw you currently defined
> > \usepackage[paperwidth=18.89cm,paperheight=24.58cm,twoside,bindingoffset=9mm,outer=2.2cm,inner=1cm,top=2.6cm,bottom=4.5cm]{geometry}
> > maybe we can just add a second paper size definition and comment yours?
> > Is it that easy or would that mean more effort?
> > Regards,
> >   otto
> Hi,
> I've committed the change to A4 and fixed some float's overflow in the
> grass chapter, the actual svn is building fine.
thanks a lot Jean Roc, builds fine here as well.
Regards,
 Otto
> Good night,
> Jean Roc
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
