[Qgis-community-team] added bibliography
Otto Dassau
otto.dassau at gmx.de
Thu Sep 23 04:55:19 EDT 2010
Hi Alexander,
that's exactly where i stuck at the moment, too and why the Makefile
doesn't run properly (but you can click through the errors and get a pdf
with bibliography in the end).
I don't have an answer yet - sorry. Maybe someone else is more experienced
with pdflatex in combination with bibtex?
Regards,
Otto
Am Thu, 23 Sep 2010 11:43:38 +0300
schrieb Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Otto,
> thanks for this.
> But I have problems when compiling User Guide with bibliography.
> First run of pdflatex user_guide.tex is ok, running bibtex and makeindex
> also goes without problems. And the when I run pdflatex user_guide.tex
> again I get
> \bibdata{references}
> (./user_guide.bbl (/usr/share/texmf/tex/latex/cyrillic/t2acmss.fd)
> ! Undefined control sequence.
> \set at color ...\@pdfcolorstack push{\current at color
> }\aftergroup \reset at color
> l.1 \begin{thebibliography}{1}
> Any hints on this issue?
> Thanks
> 2010/9/22 Otto Dassau <otto.dassau at gmx.de>:
> > Hi,
> > I added the bibliography to the manual again. It needs some more
> > adaptions to compile with the Makefile, but can already be used if
> > desired, see Makefile for instruction:
> > # To add bibliography and index you need manually run at the moment
> > # pdflatex user_guide.tex
> > # bibtex user_guide
> > # makeindex -cl -o user_guide.ind user_guide.idx
> > If anybody has time to fix the problem easily, pls do so. Otherwise this
> > will be on my list for the hackfest in Wrozlaw.
> > Regards,
> > Otto
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
