[Qgis-community-team] latex and svn conventions for manual
David Quinn
djq at MIT.EDU
Wed Apr 20 10:52:47 EDT 2011
Hello All,
I'm started to work on the manual and I had a few questions.
1 - Is there a minimum amount of changes that should be done before a
'commit'?
2 - Is there a reason for the hard wrapping of the latex code?
3 - Would it be possible to have a less flat hierarchy of files? For
example all the .tex files are currently in the one folder 'user_guide.tex'
Would it make sense to structure it so that each folder has a section?
Apologies if these are all things that have been discussed previously
(if so, where can I read about it?). I'm also new to svn, so just
figuring how best to use it.
Regards,
David
More information about the Qgis-community-team
