[Qgis-community-team] latex and svn conventions for manual
Ramon Andinach
custard at westnet.com.au
Wed Apr 20 11:15:53 EDT 2011
On 20/04/2011, at 22:52 , David Quinn wrote:
> Hello All,
> I'm started to work on the manual and I had a few questions.
> 1 - Is there a minimum amount of changes that should be done before a 'commit'?
> 2 - Is there a reason for the hard wrapping of the latex code?
> 3 - Would it be possible to have a less flat hierarchy of files? For example all the .tex files are currently in the one folder 'user_guide.tex'
> Would it make sense to structure it so that each folder has a section?
> Apologies if these are all things that have been discussed previously (if so, where can I read about it?). I'm also new to svn, so just figuring how best to use it.
Good questions. I'd been wondering a couple of those myself this evening. Can I add one?
4 - In the style file, is it possible to adjust the spacing between lines so that the line space is consistent through the document?
At the moment it gets bigger for for lines where there are inline images (e.g.\button{wombat} ) and smaller for lines where there isn't.
-ramon.
More information about the Qgis-community-team
