[Qgis-community-team] latex and svn conventions for manual
    Elvis Wang
    wbprime at gmail.com
    Wed Apr 20 20:48:20 EDT 2011
As far as I know, you can change the files to adapt your manual writing
and translation work like qgis_style.sty.
By the way, I don't think the organization of the files is so complex. It
is just beautiful to look and work with.
Elvis Wang
On Wed, 20 Apr 2011 23:15:53 +0800, Ramon Andinach
<custard at westnet.com.au> wrote:
> On 20/04/2011, at 22:52 , David Quinn wrote:
>> Hello All,
>> I'm started to work on the manual and I had a few questions.
>> 1 - Is there a minimum amount of changes that should be done before a
>> 'commit'?
>> 2 - Is there a reason for the hard wrapping of the latex code?
>> 3 - Would it be possible to have a less flat hierarchy of files? For
>> example all the  .tex files are currently in the one folder
>> 'user_guide.tex'
>> Would it make sense to structure it so that each folder has a section?
>> Apologies if these are all things that have been discussed previously
>> (if so, where can I read about it?). I'm also new to svn, so just
>> figuring how best to use it.
> Good questions. I'd been wondering a couple of those myself this
> evening. Can I add one?
> 4 - In the style file, is it possible to adjust the spacing between
> lines so that the line space is consistent through the document?
>     At the moment it gets bigger for for lines where there are inline
> images (e.g.\button{wombat} ) and smaller for lines where there isn't.
> -ramon.
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
By Elvis Wang from Beijing, China. E-mail: wbprime at gmail.com
More information about the Qgis-community-team
