[Qgis-community-team] update plugin structure in manual
Otto Dassau
dassau at gbd-consult.de
Sat Apr 30 10:54:03 EDT 2011
I finished the update of the plugin structure. I removed some plugins, that
are no longer available and added the new ones. What about the plan to
create a plugin folder and move all plugin related files and _images folders
there. Or is it good as it is?
David, you should now be able to just start and write/update the current
plugin sections. This is quite a lot of work. We can try to help, if you
want.
Regards,
Otto
Am Sat, 30 Apr 2011 15:11:39 +0200
schrieb Otto Dassau <dassau at gbd-consult.de>:
> Hi,
> I did more changes to the manual structure. I removed the 2 sections
> (files):
> a) external_plugins.tex
> b) other_core_plugins.tex.
> and added a) to plugins.tex and b) to core_plugins.tex. In the core_plugins
> table I added a reference column for all plugins.
> Bogus, the small section external_plugins.tex was your part in the wiki. I
> put your name now to the raster section. Maybe you can help Micha, who also
> takes care off the grass_integration.tex?
> Regards,
> Otto
More information about the Qgis-community-team
